Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 8th Apr 2011, 11:37   #1
stuartwood89
Please... Just call me Stu.
stuartwood89's Avatar
stuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpit
Sketchup Integration with Kerkythea in Linux?
Hey guys.
I'm running Sketchup through WINE, which seems to be going ok for now. I'm also using Kerkythea, which has its own native Linux release. The problem I'm having is that when I install the SU2KT script, which allows me to export models from Sketchup into Kerkythea for rendering, the script asks me to locate the Kerkythea program file. In Windows this is fine, as I would just locate the .exe in Program Files. However because WINE sets up its own C: drive, it won't let me locate Kerkythea which is outside of it.
Kerkythea is here -> /home/stuart/.kerkythea2008/Kerkythea
...but the dialogue won't go there. It appears that I have to use a symlink, but I have no idea how to do it. The places I've looked are too vague to be of any use, so I'm wondering if anyone here could tell me how to make one.
Hope someone can help, I'll really appreciate it.
__________________
My new blog Stu-Topia.com: because stutopia.com was already taken
Project - Storm Scout Restoration
Originally Posted by Joey Propane View Post
I thought Dragonforce were like a joke/troll rock band? Ya'know, like Nickelback?
stuartwood89 is offline   Reply With Quote
Old 10th Apr 2011, 01:23   #2
RadEd
Minimodder
RadEd has yet to learn the way of the Dremel
Try using winecfg to map /home/stuart/.kerkythea2008/Kerkythea to a drive letter.
RadEd is offline   Reply With Quote
Old 10th Apr 2011, 12:07   #3
stuartwood89
Ah I'll give that a go when I'm back home. Thanks for the reply
__________________
Old 10th Apr 2011, 16:17   #4
stuartwood89
I didn't bother doing that, although it probably would have worked had I kept trying. Instead I realised that because the exporter saves the model as an .xml file before trying to open Kerkythea, I don't actually need to locate the program. Instead I just export as normal and when it asks for the program file, I close it down. Then I open KT and locate the .xml file through there, seems to work fine
Doing a simple test render right now.
__________________
Old 24th May 2011, 09:24   #5
stuartwood89
Sorry I have to revive this thread, seemed like a better idea than opening a new one.
I've recently moved from Ubuntu to Linux Mint (after seeing what they did when I updated Ubuntu to 11.04). I installed Sketchup through WineTricks, exactly the same way as I did with my other installation, and it works fine. Now I'm trying to install the SU2KT script so that I can export to Kerkythea, and I can't find the Sketchup folder in Program Files, meaning that I can't install the script. The program is running from somewhere, but I have no idea where. As per usual, Google is returning absolutely nothing of any use, it seems to be a new or rare problem :/
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
