Reply
Thread Tools View Mode
Old 20th Jun 2011, 11:30   #41
p0Pe
gief cake?
p0Pe's Avatar
p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!
Small teaser before i make a small but important update, camera needs to recharge :P
__________________
p0Pe is offline   Reply With Quote
Old 20th Jun 2011, 14:26   #42
p0Pe
gief cake?
p0Pe's Avatar
OK, time for the update!
As you might have noticed by looking at my previous mod, PC-Beto, I like to have tidy cable routing in the case. This will be no different.
The plan is to get a fully modular PSU, and make every cable that have to go to the motherboard, go behind the mobo tray.
To do this, I will be using a 3D printer.
Now, all the haters that sometimes crawl up from their holes yelling "bwuuhuuh CNC machining is killing modding, and it have nothing to do with creativity" better slam their head against a wall and GTFO beacuse this machine is EPIC!
What you see in this picture is the part almost completet with support material at the bottom, and the actual plastic 3d print on top. It is obvious that you cant print into thin air, so it needs some sort of support structure in certain places. Other than that, it works almost just like a normal printer, exept that it prints in multiple layers to give the third dimension.
The finished part, this particular part took 5 hours to print. I could have cut the time down by having set the density of the printet material to 75 percent, but I wanted it to be sturdy.
And this is what I will actually be using it for! Routing the 24 pins cables.
On the backside the cables will run and join with cables from grafic cards and 8 pins, that I have yet to design. Note, this is mearly a prototype, and not likely to look anything like the final version, I just wanted to see if the concept would work, and it most certainly does!
Now, I will have to do some milling into the motherboard plate to make it fit perfectly, and a cover plate will go onto the whole section.
Also wanted to see how it looks when painted black. I need to fill the part down better beacuse you can still see the different layers from the printer. To make it entirely smooth, I have to hit it with some sanding love.
You can also tap it (pun intended)
How the white version would look,
And the black. I think I will stick with black. It seems to fit in the best with the white wirering.
And on another note, I sold my three 360 mm radiators! Replacements should be here within two weeks, and boy am I exited to get them!
Now, back to the drawing board. I have a few cosy hours infront of the computer in a 3d program to kill to finish up the cads to the cable system! And the a few days of printing lol
Stay tuned and thanks for reading!
__________________
Old 20th Jun 2011, 19:51   #43
bulldogjeff
The modding head is firmly back on.
bulldogjeff's Avatar
bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.
I like the white bracket, which by the way is a seriously cool mod. I'm always trying to think of different ways to do cable tidying if some one actually made stuff like that it would be ideal.
Or maybe if some one wanted to make one for me.............lol
Nice work dude.
bulldogjeff is offline   Reply With Quote
Old 20th Jun 2011, 20:22   #44
kelmannen
Supermodder
kelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremel
ok 3d printing, cool, not destroying modding, got it now!
kelmannen is offline   Reply With Quote
Old 20th Jun 2011, 21:11   #45
AnG3L
Ultimate Modder
AnG3L's Avatar
AnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run Crysis
You Dope, you gave me a dose I never had before. You my friend....
AnG3L is offline   Reply With Quote
Old 20th Jun 2011, 21:13   #46
AnG3L
Ultimate Modder
AnG3L's Avatar
Oh and if I might ask how much those pieces costs? I was planning a year ago to create a 3d printer but plans went down due to financial problems, then I looked for companies but they were expensive as hell !!!
Old 20th Jun 2011, 21:36   #47
AnG3L
Ultimate Modder
AnG3L's Avatar
Aaaaaaaaaaand one more thing!
HAPPY BDAY DOPEY!!!!!!!!!!!!!!!!!
Old 21st Jun 2011, 01:12   #48
wahoomcdaniel
Multimodder
wahoomcdaniel has yet to learn the way of the Dremel
3d printing.
That is on today's leading edge of technology & very cool..
wahoomcdaniel is offline   Reply With Quote
Old 21st Jun 2011, 03:00   #49
Shael
Multimodder
Shael's Avatar
Shael has yet to learn the way of the Dremel
Wow milling, alu / steel welding and 3d printing OMG defiantely subbed to this just to see what else you come up with
Shael is offline   Reply With Quote
Old 21st Jun 2011, 20:35   #50
p0Pe
gief cake?
p0Pe's Avatar
Nice work dude.
Thanks dude If you can draw it yourself, then feel free to pm me, and maybe we can work something out
I actually think you are right regarding the colors, and i might stick to the white version. Will try and mount it when i print the final version and see if it looks good!
Haha thank you Alex! Plenty more coming as soon as i can get the rest of the parts drawed and printet Working trough some different designs, and changes now, to better keep the cables in place
That particulary part would cost me ( i get a 25% discount on material) around 20bucks. But that dont count in machine hours and maintanence. I only have to pay for the material
And thanks for the B-day regards Got myself plenty of cake and presents
Originally Posted by wahoomcdaniel View Post
3d printing.
That is on the on today's leading edge of technology & very cool..
Its all about trying something new
Got a few things in the sleeve you might like
Mini update, since i just got a full time job in the summer vacation, i will have some time to mod on this Mostly i will have to make drawings the next couple of weeks, but i have an inbound delivery that calls for its own update when it gets here
__________________
Old 22nd Jun 2011, 01:11   #51
Attila
still thinking....
Attila's Avatar
Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.
Looking at that wire routing block, you could skip the wire altogether and make a cool connector that runs around the back of the board. Unless, of coarse, you want to see the wires. But that 3d printing has all sorts of possibilities.
__________________
stillthinking
Attila is offline   Reply With Quote
Old 25th Jun 2011, 00:05   #52
p0Pe
gief cake?
p0Pe's Avatar
I am actually tinkering with that at the moment. One problem is that i dont know what motherboard i am going to use in the case, another on is that it would have to be split into two, to actually get on the mobo But this might be the route i am going. Right now, its the grafic card cable system that is giving me the most headache
__________________
Old 28th Jun 2011, 05:33   #53
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Think it's about time I subbed , looking great p0pe .
Waynio is offline   Reply With Quote
Old 28th Jun 2011, 21:44   #54
p0Pe
gief cake?
p0Pe's Avatar
Thanks man! Hopefully I should have some updates for you soon, but am still messing around trying to figure out what mobo to use
Also have to buy a PSU -.-
__________________
Old 29th Jun 2011, 00:00   #55
Dragonphreak
Multimodder
Dragonphreak has yet to learn the way of the Dremel
p0Pe, What program did you use to create the model? I'm almost ready to start my build log, and have one piece on its way from a 3D printer, but my MoBo tray was too expensive to do originally, and then they cancelled my second attempt because they claim its too weak. You mind if I shoot you some Sketch-up models of what I'm trying to do?
Dragonphreak is offline   Reply With Quote
Old 29th Jun 2011, 00:36   #56
KoSoVaR^
Professional Sleever & Modder
KoSoVaR^'s Avatar
KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.
Nice work man ! Subbed!
KoSoVaR^ is offline   Reply With Quote
Old 29th Jun 2011, 06:50   #57
p0Pe
gief cake?
p0Pe's Avatar
Fire away man Iīve pmīd you an email you can send the files too.
I am using autodesk inventor for the most. I will upload a video of the 3d part, and some functions in inventor i think.
Thank you KoSoVaR!
__________________
Old 29th Jun 2011, 08:07   #58
KoSoVaR^
KoSoVaR^'s Avatar
Thank you KoSoVaR!
det er ikke noget problem
Old 29th Jun 2011, 23:17   #59
Dragonphreak
Multimodder
I am using autodesk inventor for the most. I will upload a video of the 3d part, and some functions in inventor i think.!
You've got PM
Old 1st Jul 2011, 11:06   #60
riekmaharg2
has finished Blue Horizon
riekmaharg2's Avatar
riekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremel
Nice start to a new mod p0Pe , on that 3D printer could you have the wires in place and print over them, thereby creating some very neat cable management?
__________________
Scratch Builds
Silent Fiberglass PC
Completed * Blue Horizon * - 2012
riekmaharg2 is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
