#121 |
aka Dave
Sweet build man! Going to keep an eye on this one.
__________________
My Room and PC build
i5 2500k with H-50 @ ΔT 5ºc - 29ºc | XFX HD 6870 Black | P8P67M-Pro | 8GB Corsair Vengeance 8-8-8-24 64GB Crucial RealSSD C300 | Spinpoint F3s: 500GB + 1TB | LEPA B-750 | Silverstone FT03b Dell Ultrasharp 2209WA | Dell Ultrasharp 2209WA | Dell Ultrasharp 2209WA ![]() |
#122 |
bit-tech sponsor
Awesome! Your builds are always amazing Pope
__________________
Shop Our Case Mod Store We Ship International Orders! Client Builds / FIREFLY PC / DISTRICT-9 PC / Official STAR TREK PC / WOLFENSTEIN PC / LANBOY APOCALYPSE PC / CodeMasters DiRT Showdown PC |
#123 |
Professional Sleever & Modder
nice! love the rads !
#124 |
May contain traces of sanity.
Sweeet rads indeed
![]() May have to get one of them if I eventually watercool my next PC build
#125 |
has finished Blue Horizon
Will you even need both ?
#126 | |
gief cake?
Thanks man!
![]() Thanks Bill Yours are rocking too![]() That makes two of us ![]() Quote:
Both? There is 3 dude:P And it is massive overkill
__________________
#127 |
Supermodder
Those rads are gorgeous!
Where from? |
#129 |
E22.BIZ
That's some awesome radiators dude! nice to see the build progressing along smoothly
![]() We are looking into getting a 3D printer at work, every time I read more of your log I keep getting inspired and praying they decide it's a good idea
#130 |
gief cake?
Time to get on with this, so it will be somewhat ready to S7 Lan at my school:P
First of all, I have been busy with some other stuff that I will post tonight, or tomorrow But i will give you a teaser:![]() Anyways, on to the big and expensive thing that I am about to cut holes in ![]() ![]() So, as mentioned earlier i had to cut off a piece of the mobo tray to make it fit with the radiators. ![]() Also had to cut off the two thingies that I think is supposed to hold some feets for the mobo tray, if you want to use it as a bench table ![]() ![]() Like a glove! Fits lovely in there! ![]() ![]() So, got my hands on some raw material! From this, ![]() I made this. But what is it? I will show in a min. ![]() First, I cut a hole in the case This hole lines up with the radiator in the other side. You see, instead of connecting the two radiators with tubes, I will just connect them with the piece shown in the previous pic.![]() So just put it in, make it go into the radiator on the other side aaand... ![]() Mount radiator number two Saves me a couple of fittings, and it looks darn clean!![]() Here you can see it connected to the two radiators ![]() That was all for now fokes. I have some dye coming in, so that I can hopefully colour the 3d printed stuff in a real black, and not some brownish like the last dye I got
__________________
#131 |
Never stuck with stock@Hotmods.net
Sweet solution, but how will you make the threads to make it possible to screw this piece into both rads at the same time?
__________________
Best regards, Nutman Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks |
#132 |
Keep calm & mod on. =)
I guess it must just plug in nicely & not screw in
knowing p0Pe I'd say so, big on the tiny details ![]() sweet little piece Nice fit for the rad too .
#133 | |||
gief cake?
And for your question. Look below![]() Quote:
This pieces: Quote:
Took quite a while to make it on the lathe, since the measurements had to be exactly if i did not want it to leak![]() I am at the moment building a "leaktester" that will work with air and a pressure gauge, so i dont have to fill water in the loop to leaktest lol:P
__________________
#134 |
I like wood ಠ_ಠ
3d printer = amazing
I am jealous
__________________
- i7 3770k - MSI Z77A-GD65 - EVGA GTX 570 - 8Gb G.Skill Sniper (1.25v) - Fractal R3 Black - Corsair H50 - Corsair 750HX - Samsung 830 128Gb SSD - 6 Samsung F4EG 2TB - 2 WD Black 1TB - 2 WD Black 750GB - Dell UltraSharp U2410 - WASD V1 Custom - IBM Model M SSK - KBC Poker (Ergo-Clears) - Logitech Mx518 & G500 - Audio Technica AD700 - Logitech Z4 - Windows 7 Pro -
#135 |
Are those radiators Aluminium on the inside or just the fins? They are just too nice looking.
#136 | |
gief cake?
Thanks mate
![]() Quote:
The fins are alu![]() This aint dead guys Just been very busy with other stuff ![]() Came around to mill a prototype for the small "reservoir" ![]()
__________________
#137 |
Ultimate Modder
LIKE A BOSS! nuff said....
#138 |
Ugh I want some deus ex type implants so I can match the accuracy & speed of CNC with a dremel
![]() .Looking good p0Pe .
#139 |
Supermodder
Looking good pOPe ^^
#140 | |
gief cake?
Haha thanks Alex!
Thanks ![]() I will do another testrun tomorrow with the final settings for the POM I will mill this from. I should have the acrylic i need next week so hopefully the final reservoirs will be done sometime next week
__________________
| Thread Tools | |
| View Mode | |
