#141 |
E22.BIZ
Drifted off to CNC heaven watching hat video
Absolutely love that little tool changer! We just placed an order for a 3D systems Projet MP3000 today at work so I may have to rack your brain soon Hans! Last edited by Editor22; 24th Oct 2011 at 21:25. |
#143 |
Professional Sleever & Modder
this is simply fantastic
#144 | ||
gief cake?
I expect some parts soon then![]() Quote:
And I will!Thank you mate! Just to show how good my measures is on this thing:P ![]() ![]() ![]()
__________________
#145 |
Keep calm & mod on. =)
Perfecto
#146 |
has finished Blue Horizon
Looking good p0Pe
#148 |
long live the pc
just read through all your posts on this build p0Pe and i must say it's
![]() ![]() .subescribed and +rep
__________________
i5 2500k, asrock z68 extreme 4, corsair 4x2gb 1600mhz,fractal define xl, ![]() |
#149 |
↓ Don't trust that face!
Sweeeeet fit!
First mod I've seen of the AC rads.That zeroing setup on the tool changer is awesome. Watching the machine clip the work every time it changed position made me cringe, though. That could chip like a mofo on something like plexiglas. The position of the rad/res has me thinking you might have them ported together with a custom plug too.
__________________
#150 |
Multimodder
this is amazing you make me wish i had access to half the gear you do. keep up the amazing work dude
#151 | |||
gief cake?
Thanks Waynio
With that mod of yours one have something to live up toThanks I was a bit nervous getting all the dust in my camera but i think it went fine:PYay! Vacation! (I wish:P) Quote:
And thanks!Quote:
And I guess I should slow down the plunge speed when I will work with acrylic:P ThanksAnd about porting them together - look below ![]() Quote:
Just wanted to show you all how this thing works, as it really is not a reservoir lol. ![]() This is how the water will flow, coming in in the bottom and exiting in the top. ![]() And for the connections - The main reason to make this thing was because I thought it would look cool (lol) and because setting the pump and radiator together by itself would look dumb. So how it works now is that the pump pumps the water into the, lets just call it the showoff reservoir for now, and then into the radiator. The acrylic tubes in the picture will of course be replaced with some longer ones:P The main reservoir will sit in the front and occupy the three 120 mm fanslots there (did anyone say 40 mm POM?) Stay tuned
__________________
#153 |
Never stuck with stock@Hotmods.net
Three 120 mm. fanslots? How huge is that thing going to be? If it's going to become a waterfall res, it sounds like something you could actually die from riding down inside a wooden barrel, so tall it's going to be?
__________________
Best regards, Nutman Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks |
#154 | ||
gief cake?
More to come hopefully!Quote:
The reservoir wont be a waterfall reservoir. That would make some un-wanted noice in the case, and my goal is absolute silence ![]() I might post some renders of the big reservoir tonight But I am not sure that it is totally done
__________________
#155 |
Supermodder
Lovely pOPe i see that the connecter line up perfect. But if u place the plexiglass window in the reservoir wont the hole thing move 4to 5mm depending how thick it is. Then i think the connector from rad to res wouldn't line up again?
#156 | |
gief cake?
Have a +rep for that!And yes, you are absolutely right the offset will be 4.5 mm duo to the plexi glass plate. With the fitting screwed in tight, that should be enough to cover for the offset you see in the pic below.![]() As you see on this picture, there is a offset on the fitting now So it should like up just right when the acrylic cover gets in place
__________________
#157 | |
__________________
#158 |
Supermodder
Perfect pOPe
#159 |
gief cake?
Dont get your hopes up
It will be clean and simple I think![]() Thanks Alain ![]() Tested the flow in the thing. Works quite well ![]() ![]() And yes, that is a wire acting as a o-ring inthere Worked.. erm.. somewhat OK xD![]() And the testsetup
__________________
| Thread Tools | |
| View Mode | |
