Reply
Thread Tools View Mode
Old 23rd Apr 2011, 18:49   #41
IvanIvanovich
будет глотать вашу душу.
IvanIvanovich's Avatar
IvanIvanovich is a Super Spamming SaiyanIvanIvanovich is a Super Spamming SaiyanIvanIvanovich is a Super Spamming SaiyanIvanIvanovich is a Super Spamming SaiyanIvanIvanovich is a Super Spamming SaiyanIvanIvanovich is a Super Spamming SaiyanIvanIvanovich is a Super Spamming SaiyanIvanIvanovich is a Super Spamming SaiyanIvanIvanovich is a Super Spamming SaiyanIvanIvanovich is a Super Spamming SaiyanIvanIvanovich is a Super Spamming Saiyan
first plexi bending test today. i had some mis-cut pieces i got for very cheap to practice. i used the blowtorch method. very easy. i was worried the 5mm thick would be very difficult to bend. only thing that i am concerned is that i have already cut my pieces to the correct thickness and the bending made it shrank by about 3mm. is there a way to stop that?
__________________
intel xeon e5-2630l @2.7 | gigabyte g1.assassin.v2 | 16gb mushkin blackline 2133 | evga gtx970 ssc | kingston hyperx predator 240gb | seagate 600 240gb | seasonic ss460fl2 | nzxt s340 | gh60 keyboard | logitech g700 | achieva shimian qh270
IvanIvanovich is offline   Reply With Quote
Old 24th Apr 2011, 19:16   #42
AnG3L
Ultimate Modder
AnG3L's Avatar
AnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run Crysis
Really nice build bro though I the pictures aint clear but I hope the final shots will be better!
I also love the rad psu positioning I might steal your idea for my next mod!!! Mod on!!
AnG3L is offline   Reply With Quote
Old 24th Apr 2011, 20:11   #43
IvanIvanovich
thanks. feel free to use same layout, it's not a new one really. i'm still to see how effective the cooling will be with only 1.5cm clearance for fans intake... i might have to ventilate the motherboard tray to give it some more breathing room. i'll find out soon once i get my res and pump mounted for first test run.
i can't wait to be free from having to use my atom pc for everything...
__________________
Old 25th Apr 2011, 10:26   #44
Nexxo
Whatever's Geek.
Nexxo's Avatar
Nexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming Saiyan
I still think it would be easier just to get a cheap little digital camera. It is not meant to impinge on your artistic integrity --it is just a tool for recording your project log.
__________________
In memory of Kidmod-Southpaw (1997 - 2014), Teelzebub (1955 - 2016) and Waynio (1978 - 2016)
"We are the music makers; we are the dreamers of dreams"
Current project: Metaversa 02 Ada.
Nexxo is online now   Reply With Quote
Old 25th Apr 2011, 13:35   #45
amagriva
Supermodder
amagriva's Avatar
amagriva is definitely a rep cheat.amagriva is definitely a rep cheat.amagriva is definitely a rep cheat.amagriva is definitely a rep cheat.amagriva is definitely a rep cheat.amagriva is definitely a rep cheat.amagriva is definitely a rep cheat.amagriva is definitely a rep cheat.amagriva is definitely a rep cheat.amagriva is definitely a rep cheat.amagriva is definitely a rep cheat.
Maybe you think that those foggy pics add a little mistery to the "show" (sort of a guesswork??") but I think they're only annoying...
I mean that a cell phone camera is enough to let us see something more than a hypermetrope log.
amagriva is offline   Reply With Quote
Old 25th Apr 2011, 19:33   #46
IvanIvanovich
just received delivery on my new ddc and ek top... still too tall to put my res / pump mounting where i wanted it. still not enough clearance for pci-e cables. why aren't there any pci-e 90 degree connectors??? should have gone with a gpu with the plugs on the side instead of the rear. or gotten a smaller res to begin with. this problem wouldn't exist. was hoping to get this done enough to start using it today, now i'm not so sure...
__________________
Old 25th Apr 2011, 21:53   #47
IvanIvanovich
i found a solution for now. it looks like my old nasty looking koolance res will fit. its shorter, but fatter than the phobya. i'll probably have to attach the line from the rad to the top of the res on this one. it will be a real pain to fill it from the side.
i have a strong feeling this will be my last watercooling set up. it causes way too much hassle.
in any case i'm off to drill some mounting points for this components. hopefully i'll be victorious.
__________________
Old 26th Apr 2011, 13:36   #48
IvanIvanovich
i did in fact get my pump and res mounted successfully. i also finished out my plexi base and have that attached.
in the end i managed to use the phobya, though very very tight fit. i carefully bent the wiring very hard with pliers on the pci-e cables to create makeshift 90 degrees. will have pics up soon.
i've also hit another snag. my ideas for mounting my ssds aren't going to work either. i made an error in clearance when i placed my mounting post for the motherboard tray, so using the akasa adapter in there won't fit in the cavity anymore...
my other idea can't work now either because of compromise i had to make for res placement.
so i'm working on something more elegant than chucking the ssds loose in the cavity. even though ssds don't really need to be mounted due to no platters having to be level, i've taken a lot of care in making everything as nice as possible.
i'm trying right now to work out something involving a backplane board, but having troubles locating a pcb thats suitable. the zalman HS100 comes close, but i think its too tall. i've debated stripping one from a bay unit, but thats so wasteful.
so if anyone knows where i can find a 2 or 3 drive sata backplane pcb that can work in a 25mm deep space including cables plugged in with dimensions not exceeding 110mm w x 100mm h i would really love to know!
__________________
Old 26th Apr 2011, 19:47   #49
shah
Hypermodder
shah is a hoopy frood who really knows where their towel is.shah is a hoopy frood who really knows where their towel is.shah is a hoopy frood who really knows where their towel is.shah is a hoopy frood who really knows where their towel is.shah is a hoopy frood who really knows where their towel is.shah is a hoopy frood who really knows where their towel is.shah is a hoopy frood who really knows where their towel is.shah is a hoopy frood who really knows where their towel is.shah is a hoopy frood who really knows where their towel is.shah is a hoopy frood who really knows where their towel is.shah is a hoopy frood who really knows where their towel is.
Very nice work mate
__________________
Sugo SG08| Zotac H67 ITX| Ivy Bridge i5 3450 | Corsair H50 | 4GB Corsair Dominator - 1600MHz | HD5770 | Samsung SSD 128GB | WD RED 3TB
shah is offline   Reply With Quote
Old 29th Apr 2011, 21:04   #50
IvanIvanovich
thanks shah.
finally up and running. so good to be back on a real computer, i was about to loose my mind trying to get any real work done on my atom pc.
so my idea on having the radiator like this didn't pan out as well as i had hoped, though i think the fans may just be too weak. i can't feel any air being pushed through the radiators fins at all. at least the temps aren't any worse than when i was running it passive from before on my old case. the fans are nice and bright white though so at least it looks good with a lot of light coming through. might toss a couple more on at the pull side.
another thing since i have both disks as ssds there is a marked improvement there as well. as i had my /users directory on a 5400 rpm before. nice and silent, well almost, the ddc is a little noisier than the cpx i had before, but i can tell its a lot more powerful as well. the res looks like a hot tub on high with the water coming back into it.
i also got delivery on my gallo a'diva speakers today as well. very very nice, but lacks bass a bit. nothing a sub can't fix.
as for progress i think i've figured out what i'm going to do about the drive mounting. i think the easiest approach will be to make a small plexi piece to mount the drives to and sandwich them in between it and the metal in front of the psu area. i've got a few designs on that i'm mulling over.
asides from that i just need to make a couple of 'molds' for plexi bending and i can start preparations for phase 3.
small complaints - the black ek fittings finish rubs off easily. i have a bunch of black / grey stains on my tubing from them now after i tightened down the compression ring. so beware if you're using light colored tubing.
also i'm disappointed by how dim my el wire is. it's a little too subtle, nearly unnoticeable.
i know i'm being slow, but pictures are on the way soon.
__________________
Old 19th May 2011, 19:16   #51
IvanIvanovich
pump installed.
light.
replaced stock green led fan with white.
baby water - the pro's choice.
now in working order, but still far from finished.
blank keyboard - proof of 1337... lol.
sorry for the excessive delay on getting these posted.
__________________
Old 20th May 2011, 00:15   #52
sixfootsideburns
modeteer
sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.
Looks awesome man! And I have to say I'm not with the crowd here, the scanned pictures are a welcome change from the norm in my opinion. While clean crisp pictures are sweet, they can get really redundant. In my opinion analog is still superior in a lot of things in the global society these days, and if you've got the gear to make it work I think photography can definitely be one of them.
Your radiator placement is excellent also, such a simple and smart solution to keeping things looking clean!
sixfootsideburns is offline   Reply With Quote
Old 20th May 2011, 00:18   #53
domthecondom
Noob Modder
domthecondom's Avatar
domthecondom has yet to learn the way of the Dremel
I don't like the quality of the photos i bet many people just clicked off your mod due to photos and this deserves not clicking off
domthecondom is offline   Reply With Quote
Old 20th May 2011, 06:41   #54
Attila
still thinking....
Attila's Avatar
Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.
I think this may be interesting, but I cant get a good look at it through the sandstorm.
I do hope we can have some clear photo's soon. At least to check out the quality of the work.
__________________
stillthinking
Attila is offline   Reply With Quote
Old 20th May 2011, 15:53   #55
voigts
Hypermodder
voigts's Avatar
voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.
Sorry to say, but I have to +1 this.
__________________
Project Log: Zenith Antique Radio Scratch Build
Project Log: Project Quintessence
voigts is offline   Reply With Quote
Old 20th May 2011, 22:45   #56
IvanIvanovich
thanks for the positive comments. and yes i am aware that some of the pics are poor. these latest though i feel are an improvement, the next should be better.
__________________
Old 22nd May 2011, 03:26   #57
SuicideNeil
Banned
SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.
Originally Posted by lysol View Post
thanks for the positive comments. and yes i am aware that most of the pics are poor. these latest though i feel are a slight improvement, the next should be better.
Fixed.
I can see a bit of improvement ( less grain, clearer colours ), but these pictures still look like they've been de-ressed in photoshop with some hipster-matic filter to make them look antique.
The build looks great, but it's just impossible to see all the little details, or many of the larger features either through the blur. Even a cheap digi camera without a zoom would do for the final pics, just needs to be well lit with a short exposure time to get some clarity...
Did I say it does look great though?
SuicideNeil is offline   Reply With Quote
Old 23rd May 2011, 05:26   #58
Mosquito
Hypermodder
Mosquito's Avatar
Mosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for president
This is starting to look very good!
Mosquito is offline   Reply With Quote
Old 10th Jan 2012, 22:12   #59
jezmck
I Mod, Therefore I Own
jezmck's Avatar
jezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyan
Status?
__________________
Have you seen The SketchUp Components Collection's latest items?
jezmck is offline   Reply With Quote
Old 11th Jan 2012, 11:16   #60
amagriva
Supermodder
amagriva's Avatar
Lost in the fog...
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
