Reply
Thread Tools View Mode
Old 17th Apr 2011, 22:30   #1
Spotswood
Custom PC case builder
Spotswood's Avatar
Spotswood has yet to learn the way of the DremelSpotswood has yet to learn the way of the DremelSpotswood has yet to learn the way of the DremelSpotswood has yet to learn the way of the DremelSpotswood has yet to learn the way of the Dremel
Project: Aluminum Water Cooling Case
This is a project/build log for an aluminum case designed specifically for a large water cooled rig, specifically:
  • 3 x 140x4 radiators
  • 1 140x3 radiator
  • 10-slot motherboard tray
So far, the aluminum constituting the frame of the case has been cut:
Stay tuned!
__________________
Rich
Custom Case Builder
Spotswood is offline   Reply With Quote
Old 18th Apr 2011, 07:10   #2
Nexxo
There is no rep for awesomeness.
Moderator
Nexxo's Avatar
Nexxo is definitely a rep cheat.Nexxo is definitely a rep cheat.Nexxo is definitely a rep cheat.Nexxo is definitely a rep cheat.Nexxo is definitely a rep cheat.Nexxo is definitely a rep cheat.Nexxo is definitely a rep cheat.Nexxo is definitely a rep cheat.Nexxo is definitely a rep cheat.Nexxo is definitely a rep cheat.Nexxo is definitely a rep cheat.
Project log should contain pics of work in progress, please. Moved to Modding...
__________________
"You actually hope to achieve your ideals, I just use mine as an excuse to hate everything" --specofdust
"Right wing Republicans, all the murderousness of nut-job Iranian ayatollahs, none of the bearded coolness" --specofdust
Nexxo is offline   Reply With Quote
Old 18th Apr 2011, 07:38   #3
Wicked_Sludge
My eyes! The goggles do nothing!
Wicked_Sludge's Avatar
Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.
thats a lot of cooling. do you know what hardware is going in it yet?
__________________
My Rig:
Gigabyte GA-P55A-UD3|Intel Core i5 750 @ 4.0Ghz|12GB G.Skill Ripjaws DDR3 1600|XFX HD5870|2x Barracuda 1TB RAID 1
Fiancées Rig:
Gigabyte GA-P67A-UD3|Intel Core i5 2500k @ 4.0Ghz|12GB Corsair XMS3 DDR3 1600|XFX HD5770 Xtreme|Samsung F3 1TB
Wicked_Sludge is offline   Reply With Quote
Old 22nd Apr 2011, 04:12   #4
Spotswood
Spotswood's Avatar
Unfortunately, no.
The basic frame of the case is done, which consists of .5x1-inch u-channel with its ends plugged with blocks (pictured in the first post), press-fitted and pinned with a #4 screw along with some 1-inch angle:
The assembled case frame is too tall to fit in the camera frame. hehe
The frame looks kind'a "meh" until I bolt on the gorgeous anodized quarter rounds.
__________________
Rich
Custom Case Builder
Old 22nd Apr 2011, 17:12   #5
Nexxo
Moderator
Nexxo's Avatar
...and there's the project log. Moving right back...
__________________
Old 22nd Apr 2011, 17:13   #6
KidMod-Southpaw
Making You Feel Old Since 2010
KidMod-Southpaw's Avatar
KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.
That's going to be an absolute monster of a case! Great start.
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2)
"The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181
KidMod-Southpaw is offline   Reply With Quote
Old 22nd Apr 2011, 17:58   #7
Gravitea
What's a Dremel?
Gravitea has yet to learn the way of the Dremel
I have a quick question, you are using U channel aluminum for your frame, how much stronger is it compared to angle aluminum? Also, can 3mm angled aluminum be strong enough to make a watercooling case?
Thanks
Gravitea is offline   Reply With Quote
Old 22nd Apr 2011, 23:14   #8
Spotswood
Spotswood's Avatar
Thanks
I'm not an engineer, but the u-channel feels to be at least as twice as strong as an angle (as to be expected).
I personally wouldn't build a case out of 3mm angle, but ymmv.
Good luck!
Old 23rd Apr 2011, 06:27   #9
StonieX
Multimodder
StonieX's Avatar
StonieX has yet to learn the way of the Dremel
Nice work on the main frame . It looks pretty solid and decent. I also think the U-channel were a good choice because of the stability against twisting
StonieX is offline   Reply With Quote
Old 23rd Apr 2011, 18:28   #10
nlancaster
Multimodder
nlancaster has yet to learn the way of the Dremel
1/16th aluminum is plenty strong enough to build an entire case from. Just have to have some triangluation built in. Either angled braces or some form of solid plate. and example would be the mid play in a Lian-li style case, and the motherboard tray. Attach those plates along at least three sides and the case will stand up great. And be lightweight.
Spotswood, I love your idea for scre blocks in the aluminum channel. I will have to still it for future builds.
Where did you get the quarter round extruded aluminum parts?
nlancaster is offline   Reply With Quote
Old 23rd Apr 2011, 21:38   #11
voigts
Hypermodder
voigts's Avatar
voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.
You are really keeping busy these days. very nice as always Rich.
__________________
Previous Project: Zenith Antique Radio Scratch Build
Current project: Project Quintessence
voigts is offline   Reply With Quote
Old 23rd Apr 2011, 22:11   #12
jhanlon303
The Keeper of History
jhanlon303's Avatar
jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.
The young have no patience.
john
__________________
My deepest gratitude to this community.
jhanlon303 is offline   Reply With Quote
Old 23rd Apr 2011, 22:55   #13
Nexxo
Moderator
Nexxo's Avatar
The young should respect the rules.
Nexxo
__________________
Old 15th May 2011, 22:13   #14
Spotswood
Spotswood's Avatar
The two shelves were cut from a .10-inch thick 5052 via my trusty router, a straight edge and a downcut spiral bit.
At the back corners of the shelves, two .5x1-inch cutouts were routed out via a temporary router jig.
The rounded inside corner left by the .5-inch flush router bit were filed square.
FWIW, here's the difference in the thickness of the aluminum sheeting I use compared to everyone else.
Finally, a mockup of the shelf inside the frame of the case:
Old 15th May 2011, 22:19   #15
Spotswood
Spotswood's Avatar
mk Technology Group.
__________________
Rich
Custom Case Builder
Old 15th May 2011, 23:56   #16
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Spotswood, you give me faith that I don't need an expensive mill & instead just need to buy a router & get good at using it & making custom jigs.
What is the thickest aluminium you have routed? also do you have to do it in gradually deeper depths like a couple of mm at a time?.
Your cases rock sturdy & great looking . +rep
Waynio is offline   Reply With Quote
Old 16th May 2011, 00:03   #17
Spotswood
Spotswood's Avatar
1/4-inch is probably the thickest I've cut so far, and yes I did that in two passes. Everything else I do at full depth. However, when cutting raw material I'll cut them oversize with a 3/16-inch mill/bit, then sneak-up to the desired dimension with a 1/4-inch spiral down cut bit i.e. the final pass is only removing ~.5mm of material for a nice smooth finish.
__________________
Rich
Custom Case Builder
Old 16th May 2011, 00:24   #18
Waynio
Waynio's Avatar
Thanks for the useful info Rich .
Wow it must be fun making mad extreme cases .
Old 19th May 2011, 22:05   #19
Radcarton Mods
I do graphics
Radcarton Mods's Avatar
Radcarton Mods has yet to learn the way of the Dremel
Huge great looking case on the horizon..its amazing how those two pieces of quarter rounds transform the basic frame..great work so far
Radcarton Mods is offline   Reply With Quote
Old 3rd Jun 2011, 04:47   #20
Spotswood
Spotswood's Avatar
The 5.25-inch drive bay rails finally came back from a local fabricator.
And a 140x4 rad arrived in the shop.
__________________
Rich
Custom Case Builder
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
