#21 |
Multimodder
Sweet! That's some serious rad you got there! 4x140mm push'n'pull configuration?
__________________
Mobo: ASUS P8P67 CPU: Intel Core I-7-2600K @ 4,636 GHz GPU: 2x MSI N560GTX-Ti Twin Frozr II @ 1022 Mhz RAM: 4x4GB Corsair Vengeance DDR3 1600 MHZ CL8 Storage: Seagate Barracuda XT 2TB and waiting for OCZ Vertex 3 to be released in Norway Case: Fractal Design Define R3 Black Pearl PSU: Corsair AX 850W OS: Windows 7 ultimate x64 Keyboard: Logitec Illuminated Wireless Keyboard K800 Mouse: Cyborg R.A.T 9 |
#22 | |
Custom PC case builder
__________________
Rich Custom Case Builder |
#23 |
Keep calm & mod on. =)
Looking very much perfect
#24 |
Hypermodder
Nice Rich. Very nice.
__________________
Previous Project: Zenith Antique Radio Scratch Build Current project: Project Quintessence |
#25 |
Multimodder
Awesome shroud you got there! You need to do a metal working guide once you're done
__________________
#26 | |
Thanks. Here's my aluminum working guide:
__________________
#27 |
Next up is to cut the front sheet.
![]() In order to cut-out all of the openings for the 5.25-inch drives accurately, a custom router template is required. I used .5x1-inch u-channel and .25x1.25-inch flat bar to frame the openings on .5-inch particle board. ![]() The aluminum bits guided my flush trimming router bit. ![]() The aluminum bits were removed and the particle board template was used to cut the .10-inch thick aluminum sheet. ![]() ![]() Now I just need to square all of the corners and cut to width. Ugh.
__________________
#28 | |
Multimodder
Nice work with the router too! Never seen Attila use a router btw :P
__________________
#29 |
"Life" had gotten in the way of this project for a few weeks, but I've managed to fabricate the inner and outer sheets of the front panel. It took me 5 hours to square-off all of the inside corners.
__________________
#30 |
Back sheet cut to width, height and the hole for the 10-slot motherboard tray routed out.
__________________
#31 |
In Flames we Trust
nice work so far - I like the rounded corners.
__________________
Scratch Build - Jestercon - MOTM Nominee Aug 2010 - building paused |
#32 |
Multimodder
Looking good, got the exact same motherboard tray for my build
__________________
#33 |
The inner and outer front sheets, cut to final length.
#34 |
Looking really nice Rich
#35 |
Shelves!
#36 |
Ero-sennin-tebayo
I remember the render threads for this in the EVGA forum. Glad to see it's finally coming to life
__________________
Intel e6550, eVGA 680 A1 D00 revision (P32 BIOS, latest drivers) eVGA 7900gs, 2x1GB Corsair XMS2 800Mhz @ 1.85v, Corsair 620HX, Seagate Barracuda 500GB x2, Pioneer DVR-212D (SATA), CoolerMaster Cosmos S |
#37 |
Expert Modder
nice case you got there.
it must be sturdy as hell with all that thick alu
__________________
Finished Projects -> Casemod: Little Big 840 ATCS || Casemod: Corsair 700D R.O.G. 'R US MOTM Nominee || Casemod: Snow White || Casemod: TJ07 Classified || Work in Progress -> Casemod: TJ07 Black & White || |
#38 |
The 5.25-inch drive bay rails:
__________________
#39 |
I bolted the 5.25-inch drive rail assemblies to the front inner sheet.
![]() ![]() Note how the extra deep rails will completely hide the drives and cables. ![]() ![]() Another design benefit of the front air duct is hiding all of the mounting hardware. ![]()
#40 |
Building Proxima
Monstrous. Looking good
__________________
Proxima - The log of Dreams
CAGE - MOTM September 2010 Winner ------------------------------------------------------ LOSIAS.net Losias.net Facebook :: Losias.net Twitter |
| Thread Tools | |
| View Mode | |
