Reply
Thread Tools View Mode
Old 8th Aug 2011, 00:26   #41
Spotswood
Custom PC case builder
Spotswood's Avatar
Spotswood has yet to learn the way of the DremelSpotswood has yet to learn the way of the DremelSpotswood has yet to learn the way of the DremelSpotswood has yet to learn the way of the DremelSpotswood has yet to learn the way of the Dremel
Two cutouts were routed out of the back sheet for the bottom mounted PSU (left hand side of the pic) and intake fan, and two intake fans up top.
Eventually, some "adapter plates" will be mounted over the two cutouts.
To attach the MB tray to the back sheet, four PEM cinch nuts were pressed into the interior side of the .10-inch thick aluminum sheet. I love these nuts because they make quick work out of adding some threads to sheet metal.
Spotswood is offline   Reply With Quote
Old 16th Aug 2011, 05:37   #42
Spotswood
Spotswood's Avatar
Another awesome feature of this case is the "false" back, which is simply a sheet of aluminum between the removable back panel and the motherboard tray. The "false" back prevents the case from racking and is the primary cable management feature. In this case, the "false" back consists of three pieces of .10-inch thick aluminum.
The sheets that make-up the "false" back are threaded along the top via PEM nuts. Fastening them to the top support beam is simplified via the addition of slots routed out of the support beam. These allow the hex wrench to be raised into position as the socket cap screws are driven into the sheet.
Along the bottom, the sheets are fastened to some 1/2-inch angle.
__________________
Rich
Custom Case Builder
Old 16th Aug 2011, 08:13   #43
jeckulz
Supermodder
jeckulz's Avatar
jeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremel
That thing is a f***ing behemoth!
Hope it's gonna have wheels on? Or are you not taking it to lan parties??
jeckulz is offline   Reply With Quote
Old 3rd Sep 2011, 20:40   #44
Spotswood
Spotswood's Avatar
Top and bottom sheets cut. Still needs to be fastened though.
__________________
Rich
Custom Case Builder
Old 3rd Sep 2011, 21:23   #45
L1U
Multimodder
L1U's Avatar
L1U has yet to learn the way of the Dremel
plenty of space in there, i like it! do you plan to use all of your 5.25 drive rails?
L1U is offline   Reply With Quote
Old 3rd Sep 2011, 23:33   #46
Fuganater
Supermodder
Fuganater's Avatar
Fuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run Crysis
Wow!! I have to keep watching this. +sub
Fuganater is offline   Reply With Quote
Old 14th Nov 2011, 01:33   #47
Spotswood
Spotswood's Avatar
Slots for wire and tube routing were cut out of the top and bottom shelves. I attempted to use a pattern router bit, but the deep cut forced the bit's bearing into the 3/8-inch thick particle board, ruining it.
So I switched to using a pattern to guide the base of the router.
The slots along the edge of the bottom shelf were cut in such a way to allow tubing and wiring to pass without significantly weakening the 1/2 x 1-inch u-channel.
Bottom shelf slots:
Top shelf slots:
Finally, two slots were also cut out of a portion of the "false" back:
Old 18th Nov 2011, 21:17   #48
Spotswood
Spotswood's Avatar
The three pieces of "false" back were attached to the bottom shelf via three pieces of 1/2-inch angle and some socket cap screws.
Old 19th Nov 2011, 07:53   #49
peteski
long live the pc
peteski's Avatar
peteski has yet to learn the way of the Dremel
man you work is very inspirational love your routor skills. look foward to more updates
__________________
i5 2500k, asrock z68 extreme 4, corsair 4x2gb 1600mhz,fractal define xl,
peteski is offline   Reply With Quote
Old 19th Nov 2011, 18:58   #50
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
Yes. That sums up my thoughts exactly. There's plenty of room to grow...
...cats in there
Cheapskate is offline   Reply With Quote
Old 21st Nov 2011, 17:22   #51
ASPHIAX
Beyond Complexity Lies Simplicity
ASPHIAX's Avatar
ASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the Dremel
Loving this build man !
I wish I had your skills with alu!
Keep it up !
__________________
Current Build : BORG COSMOS II
Current build : 2001 - A Case Modyssey
Finished build : IMPERIAL AT-AT
Finished Build : USS EURISKO - Intrepid Mark II Class
www.asphiax.wordpress.com
ASPHIAX is offline   Reply With Quote
Old 23rd Nov 2011, 20:24   #52
Spotswood
Spotswood's Avatar
Up until now the front of the case has been held on with masking tape, but its now time to attach it securely. I had originally planned on drilling through holes and bolting the front to the case, but there wasn't much room for my hands to hold onto a nut, so I increased the size of the through hole a bit and pressed-in some PEM nuts.
The front frame consists of 1x1 1/2x1 u-channels.
Button head bolts were used to attach the front to the case.
Old 26th Nov 2011, 16:24   #53
KoSoVaR^
Professional Sleever & Modder
KoSoVaR^'s Avatar
KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.
this is a good start!
KoSoVaR^ is offline   Reply With Quote
Old 1st Dec 2011, 03:42   #54
Spotswood
Spotswood's Avatar
Thanks guys!
The side panels were cut via the help of a large makeshift square made from a small square clamped to a ruler.
The radiator ventilation cutouts were made with the help of a router template. Some bits of scrap aluminum were bolted to the underside to eliminate any errors with placing the template accurately on the sheets.
Determining where to make the cutouts was easily done via a dab of India ink on the head of a screw and some masking tape. The panel was repeatedly pushed up against the inked bolt.
Old 1st Dec 2011, 07:46   #55
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Cool idea for a giant square .
Waynio is offline   Reply With Quote
Old 2nd Dec 2011, 05:39   #56
Spotswood
Spotswood's Avatar
In order to accurately drill the bolt holes to attach the perforated aluminum to the side panels, I fabricated a drill template from some left over flat bar stock and a drill bushing I had lying around the shop.
A couple of spacers was used to quickly and accurately place the jig on the work piece (to avoid having to measure/layout the location of the holes).
Some .063 perforated aluminum cut to size:
To accurately cut the rounded corners on the side panels a router jig was fab'd from a piece of the corner round used on the body of the case, 1-inch u-channel and a couple of 1-2-3 block hot glued to some particle board. Two strips of Mylar from an old drum head was used to smooth out any irregularities.
Tah-dah!
Old 2nd Dec 2011, 17:50   #57
peteski
long live the pc
peteski's Avatar
coming along well mate keep up the good work
__________________
Old 2nd Dec 2011, 17:54   #58
KoSoVaR^
KoSoVaR^'s Avatar
it gets better and better !
I cant whait to see this finished
Old 4th Dec 2011, 02:21   #59
voigts
Hypermodder
voigts's Avatar
voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.
Looking good as always Rich.
__________________
Previous Project: Zenith Antique Radio Scratch Build
Current project: Project Quintessence
voigts is offline   Reply With Quote
Old 4th Dec 2011, 11:10   #60
z3bb0
Minimodder
z3bb0 has yet to learn the way of the Dremel
Awesome
z3bb0 is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
