#61 |
Custom PC case builder
Another requirement for this case is a hidden door latching mechanism.
Look Ma! No latches! ![]() A length of .125x.75-inch flat bar was bolted to the bottom of the door to act as a lip that will hook into the u-channel along the bottom of the case, for example: ![]() Along the top of the door, there is a piece of angle with three "hooks", which were routed out using a cobbled together router template. ![]() ![]() A thick piece of flat bar was filed down to where it'll slide easily inside the u-channel along the top of the case. To that three "posts" were bolted to it. When slid forward, the posts will engage the hooks. ![]()
#62 |
long live the pc
nice work mate
__________________
i5 2500k, asrock z68 extreme 4, corsair 4x2gb 1600mhz,fractal define xl, ![]() |
#63 |
Keep calm & mod on. =)
Beautifully done panel mounting methods.
![]() rep![]() Very Lian-Li style but done in a dudes shed instead of a nice factory, awesome work Rich. ![]()
#64 |
Multimodder
Awesome build! Great craftsmanship!
__________________
[BUILD LOG] Project Ametros: Scratch Built Carbon Fiber Case + WC
Updated: Feb 29, 2012 |
#65 |
Just a Clumsy Ape
wow spots... great work!
your build thread has been quite informative as well! btw, how did you install the self clinching nuts? (PEM nuts) Last edited by kinghong1970; 9th Feb 2012 at 16:14. |
#66 | |
I simply drilled the appropriate size hole and squeezed it home using my bench vise. A large area of the right side panel was cutout for a 16x15-inch acrylic window.
#67 |
I made a mistake, placing the false back too far into the case, which required having to re-fabricate the back sheet. But I figured I could take advantage of the situation by improving the mounting of the motherboard tray, by fastening the tray to the false back with a 7/8-inch long spacer.
![]() I don't remember if I already offered this tip before, but I try to reduce the wear and tear on my 1/2-inch flush cutting router bit by first rough cutting with a 3/16-inch spiral downward cutting bit.
#68 |
A PSU mounting plate was routed out of a piece .10-inch thick aluminum sheet with the help of a custom template.
In order to accurately transfer the locations of the PSU mounting holes, threaded hole transfer punches (mcmaster.com part # 3385A31) were threaded into a PSU. ![]() ![]() And then the PSU was carefully centered and pressed into the sheeting, with the end result being a perfect squarely mounted PSU.
#69 |
Professional Sleever & Modder
great, nice punches !
#70 |
MegaRUSH
Awesome work man, good details on that case.
__________________
Intel i5 3570K @ 5Ghz | Asrock Z77 Extreme 6| Kingston HyperX Beast 2133 16Gb | Asus GTX580 DirectCU II | Kingston HyperX 3K 120Gb | Corsair AX860i | XSPC H2 @ Full WC| Projects: Purple Li | Dragon Beast | Fractal uP Gaming | Pande Benchtable |
#71 |
Nice to see this still rolling on Rich, looking excellent.
#72 |
Ultimate Modder
Holy molly man thats SICK!!!! Excellent job !!!
#73 |
< Your add here >
Great work. Love the rounded corners
#74 |
Minimodder
jejej nice actual build of the mick64 design (thats how i calll this 3 thermal area design)
i got some questions 1. how much does it weights 2. how much it cost to make and how much u are willing to sell ? |
#75 | |
#2: Unless you think the SilverStone TJ11 is inexpensive, you can't afford this case.
#76 | |
Minimodder
the TJ11 inexpensive , your case cant be afforded ? what? dont get it lol #2: Unless you think the Silverstone TJ11 is expensive, you cant afford this case. there , i think i've fixed it |
#77 |
My eyes! The goggles do nothing!
spotswood has it worded correctly.
the tj11 is a $500-600 case. unless you think $600 is cheap (inexpensive), you cannot afford his case. BTW nice work spot!
__________________
My Rig: Gigabyte GA-P55A-UD3|Intel Core i5 750 @ 4.0Ghz|8GB G.Skill Ripjaws DDR3 1600|XFX HD5870|2x Barracuda 1TB RAID 1 Fiancées Rig:
Gigabyte GA-P67A-UD3|Intel Core i5 2500k @ 4.0Ghz|12GB Corsair XMS3 DDR3 1600|XFX HD5770 Xtreme|Samsung F3 1TB |
#78 |
Minimodder
#79 |
Supermodder
There's this saying in the jewelry world: If you have to ask how much that ring is; you can't afford it.
Same applies for stuff like this case. One of + entirely custom fabricated +made to the client's own specifications = expensive. |
#80 | |
↓ Don't trust that face!
![]() Loving the heavy-duty-fied OEM features. Those punches are a sweet find too.
__________________
| Thread Tools | |
| View Mode | |
