Reply
Thread Tools View Mode
Old 31st May 2012, 17:00   #81
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Every time I look at the side panel mounting method I want to do that reminds me of how nice & easy they mount on/off, could do it 1 handed on my old Lian-Li, my favorite panel mount method when done right like this.
And cheaps fix is so true, original version & fixed version.
Waynio is offline   Reply With Quote
Old 4th Jun 2012, 03:07   #82
Spotswood
Custom PC case builder
Spotswood's Avatar
Spotswood has yet to learn the way of the DremelSpotswood has yet to learn the way of the DremelSpotswood has yet to learn the way of the DremelSpotswood has yet to learn the way of the DremelSpotswood has yet to learn the way of the Dremel
Another router template was made to cutout the areas for the PSUs out of the back sheet. A guide was clamped to the bottom of the template to keep the cutouts perfectly aligned along the bottom.
Spotswood is offline   Reply With Quote
Old 4th Jun 2012, 12:39   #83
Waynio
Waynio's Avatar
Nicely done & all these jigs you make, do you keep them aside labelled for future use to make things quicker?.
Old 4th Jun 2012, 18:14   #84
Furball Zen
Shut up and Mod
Furball Zen's Avatar
Furball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run Crysis
Its amazing the n00bs who cant figure out that this is not his case lol.
__________________
Life. Liberty. The pursuit of those who oppose it.
Guides: Modular PSU ~ FC foam removal Mods: Blue on Black ~ DVD-ROM Worklog: Acronymus ~ Carbide
@furballzen
Furball Zen is online now   Reply With Quote
Old 6th Jun 2012, 15:44   #85
Spotswood
Spotswood's Avatar
Yes, usually I will save and re-use templates. But in this situation I could make the opening larger (because of the extra room) to avoid having to square-off the corners.
Old 6th Jun 2012, 17:02   #86
Mosquito
Hypermodder
Mosquito's Avatar
Mosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run Crysis
I'm quite glad to see this going again :-)
Can I ask what speed you use with the router? I have two routers, one variable speed, and one non, and I was thinking about using the non-variable speed one for this.
And if I could also ask what bits you use? (You said 3/16" and 1/4" down cut spiral, but I was wondering about brand)
__________________
Mosquito
Scratch Builds: Just A-PC | Mini HTPC | Music Box | Ham Theater PC
Case Mod: Definition: Server | IBM PC AT Reborn
Mosquito is offline   Reply With Quote
Old 7th Jun 2012, 12:17   #87
bluc
Supermodder
bluc has yet to learn the way of the Dremel
Awesome stuff amazing craftsmanship and great work with the router. I have not been brave enough yet to run a router through aluminium.
__________________
Got the mod bug bad project dmx lighting overkill http://forums.bit-tech.net/showthread.php?t=231790
bluc is online now   Reply With Quote
Old 8th Jun 2012, 15:22   #88
kinghong1970
Just a Clumsy Ape
kinghong1970's Avatar
kinghong1970 has yet to learn the way of the Dremel
and do you use any lubrication?
kinghong1970 is offline   Reply With Quote
Old 8th Jun 2012, 15:52   #89
Waynio
Waynio's Avatar
Rich pointed this beauty out to me when asking him some other time, not sure if he got around to getting it yet though, looks excellent for routers.
http://www.vhipe.com/product-private/SuperPID.htm
Old 11th Jun 2012, 09:15   #90
jeckulz
Supermodder
jeckulz's Avatar
jeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremel
Aaaaaawww yeaahhh.
Superb work to now man, keep it up, you got a sub!
__________________
Intel i5 2500k @ 4.5Ghz / Dark Rock Adv. MSI Z68A-GD55
Asus Radeon HD6850 Direct CU @902Mhz 8gb (4x2) Corsair Vengance LP 1600Mhz
OCZ Vertex 4 128gb Seagate 320gb & Samsung 1tb
Coolermaster 600w Silent Pro Modded Lian Li PC-0700
jeckulz is offline   Reply With Quote
Old 19th Aug 2012, 00:36   #91
Spotswood
Spotswood's Avatar
Turned out that I needed to cut one more slot out of the bottom shelf. But the last time I used my wooden "small slot" router template, I somehow managed to crush one edge, so I quickly cobbled together a new out of some left over t-slot extrusion. I'm really loving using these t-slot extrusions to make router templates - fast and accurate!
Here's a teeth-shattering video of me cutting out the slot:
Old 20th Aug 2012, 08:47   #92
matt...
Slacker
matt...'s Avatar
matt... has yet to learn the way of the Dremelmatt... has yet to learn the way of the Dremelmatt... has yet to learn the way of the Dremelmatt... has yet to learn the way of the Dremelmatt... has yet to learn the way of the Dremelmatt... has yet to learn the way of the Dremel
This looks like it will be awesome!
But seriously, 3 x 140x4 radiators and 1 140x3 radiator - are you trying to cool Africa??!?
__________________
"I have not failed. I've just found 10,000 ways that won't work," Thomas Edison
matt... is offline   Reply With Quote
Old 21st Aug 2012, 01:17   #93
SpleenBeGone
What's a Dremel?
SpleenBeGone has yet to learn the way of the Dremel
I love how elegantly simple your construction methods are.
SpleenBeGone is offline   Reply With Quote
Old 21st Aug 2012, 02:04   #94
Spotswood
Spotswood's Avatar
Wow! That's one of the nicest compliments I've ever received. Thanks!
One of my motivations for publishing a build log is to convey how relatively easy it is to craft a case out of aluminum. Seriously, all you need to invest in are a drill press, a router, and some hand tools. (Unless your Attila, in which case, all you need is a hand file).
Old 21st Aug 2012, 20:07   #95
SpleenBeGone
What's a Dremel?
I've actually been considering making a case for a while, but for some reason it never occurred to me that I could cut the aluminum with my router. The way to get nice clean cuts like that was always the biggest drawback for me, as I never had access to a CNC, and dremel and nibbler cuts look bad IMO. When I build a new rig, I'll be making a custom case as well using your method, and will be following your threads for more tips.
Edit - Also, where did you get that self centering vice? I could get so much use out of one of those for all my projects.
Old 21st Aug 2012, 20:45   #96
Spotswood
Spotswood's Avatar
I got the vice from Grizzly. And is of better quality than most other tools from that site.
Yeah, you'd have to kill me in order to take away my vice.
__________________
Rich
Custom Case Builder
Old 21st Aug 2012, 20:51   #97
SpleenBeGone
What's a Dremel?
Thanks for the link, I'll be ordering one of those.
Old 10th Sep 2012, 01:14   #98
Spotswood
Spotswood's Avatar
Performed the mind-numbing task of fastening the bottom and top sheets to the case frame via flat head socket cap screws. Through and countersink holes were drilled into the sheet and transferred to the case frame via a self-centering counterbore drill bit.
Bottom sheet all fastened:
And top sheet all drilled out:
Old 10th Sep 2012, 18:52   #99
FatPandas
Minimodder
FatPandas has yet to learn the way of the Dremel
Originally Posted by Spotswood View Post
...four PEM cinch nuts were pressed into the interior side of the .10-inch thick aluminum sheet. I love these nuts because they make quick work out of adding some threads to sheet metal.
Ah - that's what they're called. Cheers man, you saved me a lotta headache
FatPandas is offline   Reply With Quote
Old 5th Nov 2012, 03:56   #100
Spotswood
Spotswood's Avatar
Drilled out the holes for the vandal resistant switches and fastened the front sheeting to the case.
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
