Reply
Thread Tools View Mode
Old 5th Nov 2012, 07:29   #101
jeckulz
Supermodder
jeckulz's Avatar
jeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremel
Happy to see the build hasnt gone dead
__________________
Intel i5 2500k @ 4.5Ghz / Dark Rock Adv. MSI Z68A-GD55
Asus Radeon HD6850 Direct CU @902Mhz 8gb (4x2) Corsair Vengance LP 1600Mhz
OCZ Vertex 4 128gb Seagate 320gb & Samsung 1tb
Coolermaster 600w Silent Pro Modded Lian Li PC-0700
jeckulz is offline   Reply With Quote
Old 5th Nov 2012, 10:42   #102
Razarach
Multimodder
Razarach's Avatar
Razarach has yet to learn the way of the DremelRazarach has yet to learn the way of the DremelRazarach has yet to learn the way of the Dremel
Nice work. This would be one awesome case.
Razarach is offline   Reply With Quote
Old 21st Nov 2012, 03:08   #103
Spotswood
Custom PC case builder
Spotswood's Avatar
Spotswood has yet to learn the way of the DremelSpotswood has yet to learn the way of the DremelSpotswood has yet to learn the way of the DremelSpotswood has yet to learn the way of the DremelSpotswood has yet to learn the way of the Dremel
Finished the lower portion of the back sheet, which involved installing the PEM nuts, trimming the PSU mounting plates to the final size and creating an extra solid cover plate (which I almost forgot to do).
Spotswood is offline   Reply With Quote
Old 14th Dec 2012, 04:47   #104
Spotswood
Spotswood's Avatar
In order to ensure that the flat head bolts in the top sheet would sit perfectly straight and flush, I drilled slightly over-size through holes in the top u-channel so a hex nut could go onto the ends of the bolts. But those nuts were now in the way of the sliding bar used to latch the side panels. A fix for that was to mill-out those areas from underneath the sliding bar (via my handheld router).
The mill marks were quickly removed with some hand filing.
To prevent the sliding bar from falling out of the u-channel, some small pieces of aluminum angle were cut and attached to the channel.
But now the angles interfered with the latching hooks on the side panel, so those areas also had to be milled away (via a center-cutting mill on the drill press).
Finally, one leg of the angle that was used to make the latching hooks was visible through the side panel perforated aluminum, so that too required having to remove around 1/4-inch of material (via my trusty router).
__________________
Rich
Custom Case Builder
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
