#81 |
Technophile(and yes, thats 724Mb/s)
Never seen that before.
http://www.aquatuning.co.uk/product_...--3x120mm.html Just had a hunt through Aquatuning, Specialtech and WatercoolingUK and can't find the stant you linked too...
__________________
i5 3570k @ 4.6GHz (1.28v) on custom water loop/ Watercooling how-to, Asus Maximus 5 Gene, 16GB Corsair Vengence 1600MHz (2 black, 2 red), Sapphire Radeon HD 5870, 128GB Crucial M4, 3 x Samsung F1 1TB in RAID 5, Xigmatek Elysium, Enermax Revolution 85+ 850W, Corsair K60, Corsair SP2500 speakers, Dell U2311H & Asus VK222W. |
#82 | |
And that link is a mount not a stand.
__________________
NZXT Tempest EVO >> Phenom II X4 955 >> Thermaltake Frio >> Zotac GTX570
ASRock 890 GM Pro3 >> 4GB (2x2GB) Crucial Ballistix DDR3 1600MHz CL8 >> Corsair TX650W Samsung Spinpoint F3 1TB >> NZXT Sentry 2 >> WD Caviar Black 640GB |
#83 |
You can use it as a stand though...
__________________
#84 |
Only horizontally though?
I was hoping for vertical.
__________________
#85 |
Hmmmm You could use a 120mm one and screw it into a block of wood to give it a firmer base...
__________________
#86 | |
Minimodder
I wonder where the OP got it too. Not of any use for me personally at the moment, but I have a friend here who could also make use of it. I have an account on OcUK forum, I might be able to PM the OP and ask. |
#87 |
Fully armed and operational.
__________________
Intel Core i5 2500k | ASUS HD 7970 DirectCU II | 8GB Corsair XMS3 1600MHz | Crucial M4 128GB | F3 1TB x 2 | Asus Sabertooth P67 | Corsair HX1050 | HAF 932 | Dell U3011 EK Supreme HF | XSPC RX360 | Scythe AP-14's | MCP355 ARCAM rDAC | Matrix M-Stage Amp | KRK RP5 G2 | KRK 10s | Beyerdynamic DT990 600Ω |
#89 |
I've just noticed that stand is for 140mm radiators
__________________
#90 |
Minimodder
#91 |
I know I saw that stand somewhere else. And I think it was 120mm. And it was cheaper.
Sigh. EDIT: This (dont worry, it's not nyan cat)
__________________
ASRock 890 GM Pro3 >> 4GB (2x2GB) Crucial Ballistix DDR3 1600MHz CL8 >> Corsair TX650W Samsung Spinpoint F3 1TB >> NZXT Sentry 2 >> WD Caviar Black 640GB Last edited by xTatic; 26th Apr 2011 at 14:47. |
#92 |
Modder
Sorry to cut on in but wouldn't it be 4 more? 3 for the T fitting and 1 for the fill port?
#93 | |
__________________
Intel Core i5 2500k | ASUS HD 7970 DirectCU II | 8GB Corsair XMS3 1600MHz | Crucial M4 128GB | F3 1TB x 2 | Asus Sabertooth P67 | Corsair HX1050 | HAF 932 | Dell U3011 EK Supreme HF | XSPC RX360 | Scythe AP-14's | MCP355 ARCAM rDAC | Matrix M-Stage Amp | KRK RP5 G2 | KRK 10s | Beyerdynamic DT990 600Ω Last edited by Apocalypso; 26th Apr 2011 at 16:48. |
#94 |
(づ。◕‿‿◕。)づ ︵ ┻━┻
http://www.specialtech.co.uk/spshop/...pid-13037.html
120mm rad stand
__________________
Xigmatek Utgard || i7 930 @ 3.8Ghz || Titan Fenrir || Asus P6T || MSI 6870 || 6GB XMS3 || Coolermaster 600W Gold || Asus Xonar DX || 1TB F3 || Beyerdynamic DT 990 250Ω || Dell U2311H
#95 | |
__________________
#96 |
Why not make your own? Metal maybe hard, but you could probably do it with wood easily enough...
__________________
#97 |
I did ask if that was a possibility
__________________
#98 |
Ah, must have missed that :P All depends on your skills really
__________________
#99 | |
I think my dad has a few tools and stuff. And I mean really, how hard can it be
__________________
#100 |
Get a block of wood some sticky backed Velcro strips. Job done
__________________
| Thread Tools | |
