Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 21st Apr 2011, 07:50   #1
mrbungle
Undercooked chicken giver
mrbungle's Avatar
mrbungle is almost as Godly as yodasarmpitmrbungle is almost as Godly as yodasarmpitmrbungle is almost as Godly as yodasarmpitmrbungle is almost as Godly as yodasarmpitmrbungle is almost as Godly as yodasarmpitmrbungle is almost as Godly as yodasarmpitmrbungle is almost as Godly as yodasarmpitmrbungle is almost as Godly as yodasarmpitmrbungle is almost as Godly as yodasarmpitmrbungle is almost as Godly as yodasarmpitmrbungle is almost as Godly as yodasarmpit
New monitor, slowly developing dull pixels.
I picked up a BenQ G2420HDBL LED back lit monitor a couple of months ago.
http://www.overclockers.co.uk/showpr...id=510&subcat=
Great screen for gaming, very vivid and a decent upgrade from the old 22" lcd I had come from.
I like everyone else am very iffy with any sort of defect, and initially it had nill dead pixels.
However last night while running through GTA 4 again I noticed a pixel which when black has fairly bad light bleed around it, very noticeable and its central left of the screen. A few weeks before this a pixel has gone dull in the top right corner. Im resigned to more going.
Im a bit stumped now, I collected it from ocuk and they surely wont help me out.
Am I resigned to ebaying it and taking a fairly big loss?
Help
__________________
One//i5 3570K 4.5Ghz//Z68X-UD4-B3//8gb DDR3//EVGA 670 F.T.W.//HX850W//CM690ii//2x128 V200 SSD//Xonar DG//
Two//i5 3570K 4.3Ghz//Z68P-DS3//8gb DDR3//MSI 7870//TX750W//Akasa Mirage//128 Vertex+ SSD//Xonar DG//
mrbungle is offline   Reply With Quote
Old 21st Apr 2011, 08:25   #2
glendronach
Supermodder
glendronach has yet to learn the way of the Dremelglendronach has yet to learn the way of the Dremel
It's not a case of the supplier "not helping you out" but accepting their responsibilities under consumer law.
Any fault which develops within the first six months after purchase is deemed to have been present at purchase and it is up to the seller ie ocuk to prove otherwise.
Take it back and see if ocuk will replace it with a bit of friendly negotiation.
If they won't play make it clear to them that the defect is unacceptable and REJECT it under the Sale of Goods Act.
glendronach is offline   Reply With Quote
Old 21st Apr 2011, 08:41   #3
favst89
Supermodder
favst89's Avatar
favst89 has yet to learn the way of the Dremelfavst89 has yet to learn the way of the Dremelfavst89 has yet to learn the way of the Dremelfavst89 has yet to learn the way of the Dremelfavst89 has yet to learn the way of the Dremelfavst89 has yet to learn the way of the Dremel
I think glendronach is right about 6 months, no real experience here. However, you may have to wait for it to get worse first as there is an "acceptable" for level (for manufacturers) of dead/stuck pixels in a monitor. I think its probably 4/5 is acceptable (from an iso standard I could find though it does not list many resolutions so some guess work) and over 6/7 it should be replaceable.
__________________
[center]i5 760 @ 4.2Ghz (200*21) | Gigabyte GA-P55A-UD3 | 2x4GB Sasmung Green C9 2000Mhz | M4 128GB | R0 Spinpoint F3 | GTX680 | XFX 850 Black | H80i | Asus xonar DX | 3 x U2212HM | Antec 300
RaspberryPi @ 1100Mhz | 8GB SD | 500GB 2.5 HDD
favst89 is offline   Reply With Quote
Old 21st Apr 2011, 08:44   #4
saspro
Infrastructure Specialist
saspro's Avatar
saspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpit
Give BenQ a call.
They'll send a courier over to swap it out under the 3 year warranty
__________________
If what I've said helps you please remember to hit the rep button on the left
Missing the old meeting place? Find us here
saspro is offline   Reply With Quote
Old 21st Apr 2011, 08:48   #5
mrbungle
mrbungle's Avatar
All this hassle.
Should have kept the ex's cinema display that was epic
The thing is the pixels are fine except for bleed behind them when black, just so happens when its black its every bloody obvious. So they are not technically dead as such. Dont know how that would effect things return wise.
Id rather not deal with ocuk at all they just wind me up.
__________________
Old 21st Apr 2011, 13:17   #6
IvanIvanovich
будет глотать вашу душу.
IvanIvanovich's Avatar
IvanIvanovich is the Cheesecake. Relix smiles down upon them.IvanIvanovich is the Cheesecake. Relix smiles down upon them.IvanIvanovich is the Cheesecake. Relix smiles down upon them.IvanIvanovich is the Cheesecake. Relix smiles down upon them.IvanIvanovich is the Cheesecake. Relix smiles down upon them.IvanIvanovich is the Cheesecake. Relix smiles down upon them.IvanIvanovich is the Cheesecake. Relix smiles down upon them.IvanIvanovich is the Cheesecake. Relix smiles down upon them.IvanIvanovich is the Cheesecake. Relix smiles down upon them.IvanIvanovich is the Cheesecake. Relix smiles down upon them.IvanIvanovich is the Cheesecake. Relix smiles down upon them.
sounds like stuck pixels. try running it for a bit face down on some carpet playing one of those color strobe videos in a loop. i've been able to unstick pixels with a good level of success with that technique.
__________________
[end of line]
intel i5-750 | evga p55 sli | 8gb mushkin blackline | evga gtx670 | 240gb mushkin chronos dx
| creative titanium hd | mushkin 580w | gh60 custom | logitech mx revolution | achieva shimian qh270
IvanIvanovich is offline   Reply With Quote
Old 23rd Apr 2011, 20:13   #7
mrbungle
mrbungle's Avatar
After playing a dark game like metro this is very annoying.
Raised a rma with Benq.
As my first Benq screen it will be interesting to see what happens.
__________________
Old 26th Apr 2011, 09:30   #8
mrbungle
mrbungle's Avatar
Just recieved a very blunt email stating they need 5 or more dead pixels to rma the screen.
Will not go anywhere near a Benq monitor again
__________________
Old 26th Apr 2011, 09:52   #9
N17 dizzi
Packet of mints and a Phillips head
N17 dizzi's Avatar
N17 dizzi is the Cheesecake. Relix smiles down upon them.N17 dizzi is the Cheesecake. Relix smiles down upon them.N17 dizzi is the Cheesecake. Relix smiles down upon them.N17 dizzi is the Cheesecake. Relix smiles down upon them.N17 dizzi is the Cheesecake. Relix smiles down upon them.N17 dizzi is the Cheesecake. Relix smiles down upon them.N17 dizzi is the Cheesecake. Relix smiles down upon them.N17 dizzi is the Cheesecake. Relix smiles down upon them.N17 dizzi is the Cheesecake. Relix smiles down upon them.N17 dizzi is the Cheesecake. Relix smiles down upon them.N17 dizzi is the Cheesecake. Relix smiles down upon them.
That is the industry standard for class 2 screens I believe
I had the same problem with a Dell 2209wa
It had a warranty that covered for any pixel defect but they only sent out refurbs. I got 5 different screens sent to me and they all had pixel faults.
Basically I don't know who to buy from. Viewsonic do a 0 pixel defect warranty on their premium panels but whether they honour it or not is another matter.
__________________
Silverstone PS07B | Core i5 2500k @ 4.5 | Arctic Freezer i30 | Maximus V Gene | Corsair 8GB 1600Mhz | MSI GTX 670
| Crucial M4 256GB | Antec Truepower 650w | Dell U2412M | Qpad 3202 | Corsair M60 |
N17 dizzi is offline   Reply With Quote
Old 26th Apr 2011, 10:03   #10
mrbungle
mrbungle's Avatar
I am in the same situation.
I know what I want and it is a decent screen with no pixels.
But I see many threads on here that state even companies such as dell who have a warranty in place to cover dead pixels the replacement screens are rarely clear of defects as they are just refurbs.
Frustrating to say the least.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
