Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 25th Apr 2011, 19:53   #1
Nexxo
Whatever's Geek.
Nexxo's Avatar
Nexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming Saiyan
Metaversa 2.0: Even More Messing about with concepts...
Metaversa 01 has been a good workhorse, able to keep up with the best of current machines, but in some respects it is showing its age. It is time to start thinking of a new build... and a new modding project.
My inspiration has been anything from Confederate Motorcycles to antique microscopes, to Babbage's Difference Engine to anything that is Victorian scientific engineering. 'Cause I like the look of Steampunk, see?
Another inspiration has been my passively cooled HTPC. There is something really cool (pardon the pun) about switching on a PC and hearing... nothing. Just a power LED and some subtle chittering of the hard disk to indicate its heart beat. Silence is golden, so I have been wondering if it is possible to design a capable system around the Alphacool Cape Cora passive radiator system. Tricky, because a decent array is huge and would dominate the design of the case.
The problem has been to design something that works (obviously), looks fairly elegant and can be fairly easily manufactured from brass and aluminium. This is not as easy as it seems... some rules have to be obeyed. The reservoir needs to be at the highest point in the loop, the pump as low as possible. Weight distribution needs to be even --a beefy PSU weighs about 2kg at least, but so does a Cape Cora radiator filled with 2+ litres of fluid.
Another consideration was that I want to get away from the same old square box. Problem is: most PC components are designed to fit in square boxes. Not only that, but in specific locations and orientations in those square boxes. You see the problem...
The most important consideration is: aesthetics. Metaversa 01 was a long time ago, when 12V pumps for PC watercooling did not yet exist (I improvised with a car booster pump) and, well, my humble attempts with aluminium shrouds and GPU support brackets still impressed. The project logs I see on Bit-Tech nowadays blow my old mod clean out of the water. Modding has become a lot more sophisticated and the quality of the work has been raised sky-high... I would have to pull something mega-awesome out of the hat to compete...
With that in mind, this is what I came up with messing about in SketchUp so far...
Design 1:
Nice idea, but no good spot for the reservoir. Weight distribution would also be uneven.
Design 2:
I like this one, but it would be huge. The pump is in the bottom of the reservoir. The HDDs at the back of the mobo have a clever self-clamping mechanism. However it is getting a bit complicated to build...
Design 3:
Inspired by Carlo Bugatti's furniture (seriously, have a look at his stuff!). The mobo tray (not modelled here) would tilt forward on a big circular hinge (which at the back houses the pump, at the front would house the panel with power button, indicators etc.) to allow access to the connectors at the top. Still, not quite what I was looking for.
Design 4:
This is the current state of play... Metaversa 02 Cathedral "Camille". I quite like this design but although most parts consist of simple aluminium tubing (with some brass milled collars) and flat laser-cut aluminium parts, there are a few parts that would need CNC'ing, particularly the curved legs, the reservoir clamps at the top and the brass reservoir end caps. Not something I could do myself, and I can see the manufacturing costs mount... still, I may explore this idea a bit further.
What do y'all think? Would it work? Would it not work? Is it just plain ugly? Those of you who have l33t CNC and milling/lathing skills, do you spot anything that would be a nightmare (or very expensive) to produce? Your thoughts and considerations are eagerly solicited.
__________________
In memory of Kidmod-Southpaw (1997 - 2014), Teelzebub (1955 - 2016) and Waynio (1978 - 2016)
"We are the music makers; we are the dreamers of dreams"
Current project: Metaversa 02 Ada.
Nexxo is offline   Reply With Quote
Old 25th Apr 2011, 20:12   #2
Stuey
You will be defenestrated!
Stuey's Avatar
Stuey has yet to learn the way of the DremelStuey has yet to learn the way of the DremelStuey has yet to learn the way of the DremelStuey has yet to learn the way of the DremelStuey has yet to learn the way of the DremelStuey has yet to learn the way of the Dremel
I like the centralized look of the res as in the 2nd design, but overall the 4th design looks to be the most pleasing. I especially like the look of the legs!
What I find particularly appealing is the color contrast between the brass and white-painted aluminum in the render. I don't think you'll be able to achieve the same effect with brushed or even polished alum.
I'm not a machinist, but nothing in your proposed build looks impossible to fabricate.
__________________
ToolGuyd - Stuey's Tool Blog
Stuey is offline   Reply With Quote
Old 25th Apr 2011, 20:16   #3
Tangster
Butt-kicking for goodness!
Tangster's Avatar
Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.
Why not take the side arm in 2 and extend it to make part of the legs?
EDIT:
or extend the scroll in 3 to form a foot?
__________________
The Box:i7 2700K@5.3GHz|EK Supreme LT+Coolstream XT 360|16GB HyperX DDR3@1866MHz|EVGA GTX780 ti+EK FC780ti|MSI P67A-GD55||M5 512|BeQuiet Dark Power Pro 750W|U3011|Raven RV-02E|KBT Pure+Perixx MX2000 + Intuos 4M
Audio: PC->TosLink->TEAC UD-501->Fostex TH600|InEar LivePro 3|Truth B2030A Monitors
BT Feedback
Tangster is offline   Reply With Quote
Old 25th Apr 2011, 20:22   #4
KayinBlack
Toxophile
KayinBlack's Avatar
KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.
I liked 2. It looks quite interesting...
KayinBlack is offline   Reply With Quote
Old 25th Apr 2011, 20:22   #5
Archtronics
Mod Master
Archtronics's Avatar
Archtronics is the Cheesecake. Relix smiles down upon them.Archtronics is the Cheesecake. Relix smiles down upon them.Archtronics is the Cheesecake. Relix smiles down upon them.Archtronics is the Cheesecake. Relix smiles down upon them.Archtronics is the Cheesecake. Relix smiles down upon them.Archtronics is the Cheesecake. Relix smiles down upon them.Archtronics is the Cheesecake. Relix smiles down upon them.Archtronics is the Cheesecake. Relix smiles down upon them.Archtronics is the Cheesecake. Relix smiles down upon them.Archtronics is the Cheesecake. Relix smiles down upon them.Archtronics is the Cheesecake. Relix smiles down upon them.
I like the elegant scroll shape in design 3 but I don't think it relates to the rest base of the design particulary well. Myself I would maybe continue designing 3 some more however how they are now I agree with above 4 looks the best.
Archtronics is offline   Reply With Quote
Old 25th Apr 2011, 20:49   #6
cchr
Multimodder
cchr's Avatar
cchr has yet to learn the way of the Dremel
you call that messing about?! your design is a masterpiece! i cant wait to see it underway!
btw personally i like the 3rd design, but as Archtronics said, the base would have to be redesigned a bit.
respect man, nothing more to say.
__________________
Sony Vaio VGN-FW11M:
Intel Core 2 Duo P8400 2.26GHz, 4GB RAM, 250GB HDD, ATI Mobility Radeon HD3470.
Dell Mini 1012:
Intel Atom N450 1.66GHz, 1GB RAM, 32GB SSD.
No Desktop for now
cchr is offline   Reply With Quote
Old 25th Apr 2011, 21:17   #7
KayinBlack
Toxophile
KayinBlack's Avatar
Brass, wood and leather would work very well, you know. As well as not be as expensive to produce.
Besides, you should anodize those radiators to look brass. It'll look badass.
Old 25th Apr 2011, 21:35   #8
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
GODLY!!
You may have just re-booted my design thinking too. I've been working along the 'simplify and cheapen' route so much lately that it's killing my mojo. Feel free to build ALL of them.
As far as seeing problems... I'd need to see more details first. Routing and assembly are usually where the trouble comes up.
4 looks the hardest to mill. It has a lot of parts that would need to be flipped and custom mounting made just to cut it.
3 is the simplest at a glance, but boring holes on the inside of the curved frame will make most machinists 'splode.
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 25th Apr 2011, 23:31   #9
Dark~3nergy
what was dat sandvich ?
Dark~3nergy's Avatar
Dark~3nergy has yet to learn the way of the DremelDark~3nergy has yet to learn the way of the DremelDark~3nergy has yet to learn the way of the DremelDark~3nergy has yet to learn the way of the Dremel
very interesting, i really like the 2nd and 4th !
__________________
My deviantart page : link Battlefield 3: Mindrusted My computer : Link
Dark~3nergy is offline   Reply With Quote
Old 25th Apr 2011, 23:46   #10
jhanlon303
The Keeper of History
jhanlon303's Avatar
jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.
Build em ALL ! I need to spend some more cycles on this thread. Awesome thinking going on here.
john
__________________
Coming to a forum near you. January 2014.
jhanlon303 is offline   Reply With Quote
Old 26th Apr 2011, 10:27   #11
Genghis
Minimodder
Genghis's Avatar
Genghis has yet to learn the way of the Dremel
ouaouh great design on 2 !!
for me, the design N°2 let me thinking about a motor.
i love it
Genghis is offline   Reply With Quote
Old 26th Apr 2011, 11:13   #12
GuilleAcoustic
Ook ? Ook !
GuilleAcoustic's Avatar
GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.
I like the second one. anyway, this is deadly steam punk and I'm lovin' it . Great job
GuilleAcoustic is offline   Reply With Quote
Old 26th Apr 2011, 11:45   #13
stonedsurd
Is a cackling Yuletide Belgian
stonedsurd's Avatar
stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.
I made a mess of my pants, so you'll have no suggestions from me.
Off to change...
__________________
stonedsurd is offline   Reply With Quote
Old 26th Apr 2011, 13:16   #14
Attila
still thinking....
Attila's Avatar
Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.
Not a fan of steampunk but these do look tasty! Kudos for great SU technique. I can see a thousand pounds or more, worth of milling for any of those designs. Unless of coarse you've used some standard tubing etc. Can I book a front row seat for the show?
__________________
stillthinking
Attila is offline   Reply With Quote
Old 26th Apr 2011, 15:55   #15
Nexxo
Whatever's Geek.
Nexxo's Avatar
Thank you all for your comments. Design 3 indeed needed some work on the base. The problem was that I could not see how to continue the curve without it interfering with the PSU. Design 2 was abandoned because it was quickly becoming complicated to build --lots of complex parts that would drive the price up...
4 has only 12 parts that would need CNC'ing as such, and all of them are repeats. Really there are only five different shapes, four of which need to be made twice and one four times.
The rest is standard 3/4" diameter aluminium rod that needs a bit of lathing at the ends and twelve 2D shapes that can be cut from 5mm aluminium sheet (and six from 10mm thick aluminium). There are also 12 identical brass collars and some brass rings which are not very complicated. I'll do a sketchup of all the parts laid out soon.
Yeah, I think it is going to be in that price range too...
And of course you, Atilla, can have the royal box! I'm not worthy, I'm not worthy...
__________________
Old 26th Apr 2011, 17:54   #16
Nexxo
Whatever's Geek.
Nexxo's Avatar
I've been playing in my head with some wooden box designs. Nothing that looks as good as project Quitessence though.
Agreed on the radiator. They come in silver or black. I wonder if silver anodised aluminium could be re-anodised in brass/gold.
__________________
Old 26th Apr 2011, 18:28   #17
Mankz
5318008
Mankz's Avatar
Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.
Less talky more maky.
Mankz is offline   Reply With Quote
Old 26th Apr 2011, 19:07   #18
Javerh
Topiary Golem
Javerh's Avatar
Javerh has yet to learn the way of the DremelJaverh has yet to learn the way of the DremelJaverh has yet to learn the way of the DremelJaverh has yet to learn the way of the Dremel
A good bath of lye to remove the anodize, then a new coat of anodize, then a proper dye and finally sealing. If the alu is thick enough the anodize can be taken off. The dye should not penetrate beneath the alu-oxide.
__________________
Project: Seawolf
Project: 1
Project: Flux (est 2012)
Modders make project logs. Project logs make mods. Mods make modders.
Javerh is offline   Reply With Quote
Old 26th Apr 2011, 19:28   #19
GuilleAcoustic
Ook ? Ook !
Wood (Ebony or hazelnut) and brass would be lovely. There's also good paint with corroded metal aspect (brass, copper, bronze...)
Old 26th Apr 2011, 19:29   #20
KidMod-Southpaw
KidMod-Southpaw's Avatar
KidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming Saiyan
CHRIST MAN! Any of those would look great, design 4 catches my eye more though.
__________________
Project Logs: Refraction - Steampunk Flash Drive - Steel; Sleek; Slate
BitFenix Prodigy - Gigabyte Z87N - Intel 4670K - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - M4 128GB - WD Red 1TB X2 - H60 - Antec 650W - Dell U2312HM - Poker MX Red - Sennheiser HD 598
"The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181
KidMod-Southpaw is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
