Reply
Thread Tools View Mode
Old 26th Apr 2011, 06:00   #1
Javerh
Topiary Golem
Javerh's Avatar
Javerh has yet to learn the way of the DremelJaverh has yet to learn the way of the DremelJaverh has yet to learn the way of the DremelJaverh has yet to learn the way of the Dremel
Project: 1, April 26th
The fight against plain black and beige boxes continues.
This time around I'll do better.
(1)
List of parts and materials:
2x 800x300x18mm glued laminated birch 38.00€
4x 1000x70x15mm kiln-dried, planed beech 62.00€
1x 125x40x20mm brass billet 28.60€
24x Stainless Countersunk bolt M5x25 4.63€
4x 30mm spring clamp 4.80€
1kg Clear Shellac-flakes 39.35€
1l Etasol denaturated alcohol 5.60€
0.5l Emulsified carnauba wax 7.20€
Total: 190.18€
Certainly, I made plenty of mistakes with Seawolf. It was (and is) horribly difficult to break apart and put it back in one piece. Moreover, trying to use it as my main rig while building it was an even worse mistake. I'll use this new build as my main rig so I can finish Seawolf at a later date.
I've been thinking about a wooden project log for a while now. The concept is to make a system that is pure, clear and shows the materials as they are. No paint and no covering sleeving. The shape is symmetric on many levels. As Seawolf is so hard to maintain, I want to make every panel and rail detachable. The first two pictures are early renderings of different concepts for the case.
The actual case won't look like either of them. As you know me, I'll only show teasers at this stage. The PC will be an aircooled mATX. The planned size is about 40x30x30cm. I don't know about the exact hardware.
So far I've bought the wood and the brass for the case. The wood came from Kodin Terra. I found the rails from a pile of about 50 pieces of beech. The 4 pieces that I picked most resemble quarter sawn. In quarter sawn boards the grain is perpendicular to the surface. This limits twisting and warping due to changes in moisture. Also, quarter sawn beech has a lovely wavy surface texture. The panels will be made from glued laminated birch. I chose boards that had the least knots and other defects. I also ordered 5kg of brass from metallstore.de.
The postage to Finland was about half of the total price. I'm only going to use a small portion of the brass on this build. The brass and the wood will be finished with a coat of bleached shellac and some carnauba wax.
The most tedious work in this build will go into shaping the brass brackets. I started by cutting them to size and started filing away.
This filing is taking forever. Don't hold your breath.
__________________
Project: Seawolf
Project: 1
Project: Flux (est 2012)
Modders make project logs. Project logs make mods. Mods make modders.
Javerh is offline   Reply With Quote
Old 26th Apr 2011, 18:19   #2
(FIH) The Don
Multimodder
(FIH) The Don's Avatar
(FIH) The Don has yet to learn the way of the Dremel
just the fact that you have huge chunks of brass makes me follow this for the epicness!!
(FIH) The Don is offline   Reply With Quote
Old 26th Apr 2011, 18:31   #3
bulldogjeff
The modding head is firmly back on.
bulldogjeff's Avatar
bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.
This looks interesting. Nice design. I'll be keeping an eye on this to see how it develops.
bulldogjeff is offline   Reply With Quote
Old 26th Apr 2011, 18:57   #4
llamafur
WaterCooled fool
llamafur's Avatar
llamafur has yet to learn the way of the Dremelllamafur has yet to learn the way of the Dremelllamafur has yet to learn the way of the Dremelllamafur has yet to learn the way of the Dremelllamafur has yet to learn the way of the Dremel
That is a lot of brass! Can't wait to see this take off.
llamafur is offline   Reply With Quote
Old 26th Apr 2011, 19:40   #5
Journeyer
Mod Master
Journeyer's Avatar
Journeyer is a hoopy frood who really knows where their towel is.Journeyer is a hoopy frood who really knows where their towel is.Journeyer is a hoopy frood who really knows where their towel is.Journeyer is a hoopy frood who really knows where their towel is.Journeyer is a hoopy frood who really knows where their towel is.Journeyer is a hoopy frood who really knows where their towel is.Journeyer is a hoopy frood who really knows where their towel is.Journeyer is a hoopy frood who really knows where their towel is.Journeyer is a hoopy frood who really knows where their towel is.Journeyer is a hoopy frood who really knows where their towel is.Journeyer is a hoopy frood who really knows where their towel is.
I am loving that first concept sketch!
__________________
When you have eliminated the impossible, whatever remains, however improbable, must be the truth.
ASUS Sabertooth 990FX || FX-8150BE || 16Gb Corsair DDR3 1866Mhz || 2xGTX285 SLI|| 2xOCZ Agility 3 120Gb RAID0 for OS
Journeyer is offline   Reply With Quote
Old 26th Apr 2011, 19:43   #6
ringo
Supermodder
ringo has yet to learn the way of the Dremel
I like the design of your case. It looks amazing.
ringo is offline   Reply With Quote
Old 26th Apr 2011, 20:32   #7
Nexxo
There is no rep for awesomeness.
Moderator
Nexxo's Avatar
Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.
It's wood, it's brass, it's an original shape. Ticks all my boxes!
__________________
"You actually hope to achieve your ideals, I just use mine as an excuse to hate everything" --specofdust
"Right wing Republicans, all the murderousness of nut-job Iranian ayatollahs, none of the bearded coolness" --specofdust
Nexxo is offline   Reply With Quote
Old 27th Apr 2011, 03:46   #8
Javerh
Topiary Golem
Javerh's Avatar
Thanks guys!
__________________
Project: Seawolf
Project: 1
Old 27th Apr 2011, 04:43   #9
craig - toyoracer
Supermodder
craig - toyoracer's Avatar
craig - toyoracer has yet to learn the way of the Dremelcraig - toyoracer has yet to learn the way of the Dremelcraig - toyoracer has yet to learn the way of the Dremelcraig - toyoracer has yet to learn the way of the Dremelcraig - toyoracer has yet to learn the way of the Dremelcraig - toyoracer has yet to learn the way of the Dremel
Really wood brass, I like. Maybe the front and top of #1 with flat sides. Oh this looks like a good start.
craig - toyoracer is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
