#1 |
What's a Fret Saw?
Valkyrie
Hi everyone,
It's been a while since I posted at bit-tech (still an avid reader though) because I couldn't show my face around much after failing to complete my previous worklog. ![]() My previous work - ANGEL Ideas for a new case has been brewing in my mind for a while and the final push to build one came when I saw the news on Cooler Master case mod competition here. Anyway, I'm posting my worklog here as well. I really hope to see some feedback. Thanks for reading! **WORKLOG START** ![]() I'm starting my worklog for the Cooler Master 2011 case mod competition. I've been working on it for about a month or so since knowing about the competition. I did a lot of fabrication previously and it sure was very tedious~! Some of the central theme of this build include
As mentioned, I won't be doing a lot of the fabrication this time, instead I'll be focusing on the design. So how does it get made? 3D printing! I'm getting most of the parts made by what I called the Internet Factory. I send out designs that are separately made by various people from the Internet. If you think about it, it's almost like Ponoko except maybe a lot cheaper. The idea is also allow the use of radically different material from conventional cases. It will be made of out mostly plastics! Enough of words. Here are some pictures of my initial design idea. ![]() ![]() Example of transparent acrylic used. ![]() More exotic materials! ![]() ![]() ![]() Finally a layout sketch.
#2 |
What's a Fret Saw?
Update!
I'm finally about 95% done with the drawings. Here is the final design! ![]() ![]() ![]() There was a lot of effort being made to ensure that the drawings are accurate and matches up perfectly. ![]() I ran into some problems with small alignments issue. Even though they were off by less than a millimeter, I made sure I correct them. ![]() And to conclude this update, I've received my first printed parts!! This is one of the part. ![]() This is the printed part!! I'm using Shapeways for printing. ![]() ![]() Thanks for viewing.
#3 | |||
What's a Fret Saw?
![]() This whole thing needs to be done by 15th May so it's going to be happening pretty quickly. In fact, I'd have to start buying my parts next week. Sim lim square (if you know where I mean), here I come! |
#4 | ||
What's a Fret Saw?
![]() More updates soon, sending out the last batch of files to be printed. |
#5 | ||
What's a Fret Saw?
![]() Quote:
Anyway, some updates! I'm in the process of waiting for parts to be fabricated. Meanwhile, I'm doing some of my own fabrication. Because the case is rather unique, I couldn't find any suitable IO panel. So I'm making my own. I took a long time to source for the power button. It's a tactile button that has an LED. The LED will serve as a HDD activity LED. Some close up look of the assembly. ![]() ![]() This is the part of the case that will house the IO panel. ![]() Finally, a simple test/demo of the HDD LED using my current rig. It's really bright! ![]() Last edited by Pazu; 5th May 2011 at 02:09. |
#6 | ||
What's a Fret Saw?
From my experience it boils down to how thick you are designing the material and how much structural support you are using. Factors like how much load does a particular feature need to take has to be consider. Thanks! More updates soon. Next up are the laser cut parts!
#7 | ||||||
What's a Fret Saw?
#8 | ||
What's a Fret Saw?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sadly, my laser cut parts are only ready on Wed and some other 3D parts only next week too. So until then, please keep the feedback coming! Can't wait to play Brink on this! Last edited by Pazu; 7th May 2011 at 03:21. |
#9 | |
What's a Fret Saw?
Thanks!
![]() Quote:
#10 |
What's a Fret Saw?
More parts arrived!
![]() Test fitting some of the parts. ![]() ![]() ![]() It's going to be down to the wire for this... Wish I had started off fabrication earlier.
#11 | ||
What's a Fret Saw?
IMO, all these is only possible because of Shapeways' down-to-earth pricing. I'm not getting sponsored by them or anything but I've done 3D printing/prototyping elsewhere before and the cost is 20x higher and quality 10x worse.Quote:
Which back plate? I'm using WSF/BSF from Shapeways... |
#12 | |||
What's a Fret Saw?
One problem though, I dunno if I can export out to Sketchup. Would STL files be fine?Quote:
Co-incidence? LOL. Thanks! |
#13 |
What's a Fret Saw?
Even more parts! This is the last batch of parts to arrive.
Brass inserts for motherboard standoffs and 6mm standoffs. ![]() I'm using all stainless steel 3mm bolt socket head screws. ![]() ![]() And these... DA laser cut parts! ![]() ![]() ![]() Finally I'll be able to do final assembly. Frankly, I feel a little nervous.. What if things go horribly wrong... ![]() Wish me luck! |
#14 |
What's a Fret Saw?
Just a quick update. I began assembly this morning and am I psyched!!
Quick snap with my phone camera. ![]() Those twin 140mm fans sure looks huge in the case! |
#15 | |||||
What's a Fret Saw?
I'm using Inventor.
#16 | |
What's a Fret Saw?
Thanks!
1mm? Hm.. I would say it's strong but not rigid. The material has very good flexibility. Quote:
![]() Rightttt... Assembly pictures! This is a material called Transparent detail. I find the lines a bit disturbing. But for this case, it makes for a rather interesting texture. Also I think it'll diffuse the back light well. ![]() ![]() Using this glue. Brilliant stuff. ![]() LED module from Sparkfun. ![]() Attached! ![]() IO panel I posted earlier attached. ![]() ![]() ![]() Some of the other sub-assemblies. ![]() ![]() Installing the brass inserts was nerve-racking. The only way to get it in was to push hard and all the while I was thinking I'm gonna crack the plastic. ![]() ![]() ![]() That's all for now. ![]() p.s. some of you bit-tech guys have emailed me regarding sharing my CAD files for the rear IO and PCI port. As I said earlier, I've no problem sharing those. But I'm a little pressed for time now the event date is closing. I'd like to clean up the CAD before I share them. So a little patience please.
#17 |
What's a Fret Saw?
Bummer.
Sorry I've not posted any updates because I've been reeling from the blow of not being able to complete this build. I've made some fatal errors in my drawing and estimation. I thought of just leaving this post to die off but I think it deserves some closure. Here are some of the things I've learn from this build: 1. Always use actual parts for mock up and measurement. 2. Structural strength comes from structural support, not material toughness. 3. PC components are heavy, good ones are even heavier! 4. Never rush to finish off a proper design. 5. Measure many times, print/make/cut once. So far, I think the best thing about this build has been the constant feedback and encouragement from the bit-tech community (much like my last build). My grateful thanks. With that I'll end off with some final pictures. Thanks. And I will be back. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() p.s. i'm not sure if you guys still want the PCI-e port drawings... let me know... |
#18 | |||||||||
What's a Fret Saw?
Wow. Thanks for the encouragement, guys.
![]() Quote:
#19 | ||
What's a Fret Saw?
#20 | ||
What's a Fret Saw?
![]() Quote:
| Thread Tools | |
| View Mode | |
