Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 10th May 2011, 13:19   #1
arcticstoat
Hypermodder
arcticstoat's Avatar
arcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysis
PC Hardware Buyer's Guide May 2011
Our monthly guide to getting the best components for your PC build, whatever your budget.
http://www.bit-tech.net/hardware/buy...ide-may-2011/1
__________________
Ben Hardwidge
Custom PC Editor
arcticstoat is offline   Reply With Quote
Old 10th May 2011, 13:43   #2
jakobfrimmel
Supermodder
jakobfrimmel's Avatar
jakobfrimmel has yet to learn the way of the Dremel
GTX 590 most powerful card?
i thought that was the HD 6990....
__________________
Main rig:
CPU: Phenom II 955 @ 4ghz cooled with a H50
GPU: HD 5850 Powercolor (Bricked) awaiting new card to hold me out till August
Motherboard: Gigabyte 890xA-ud3
RAM: 4gb ddr3 1600 OCZ @1600
jakobfrimmel is offline   Reply With Quote
Old 10th May 2011, 13:45   #3
r3loaded
Ultramodder
r3loaded's Avatar
r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.
I wouldn't pick up a C300 nowadays, especially with the Crucial M4, the Intel 510 and the immense OCZ Vertex 3 available at similar price points.
__________________
Main: Silverstone FT03 | Asus P8P67-M Pro | i5 2500K @ 4.6Ghz | CM 212+ | 16GB Corsair Vengeance 1600Mhz | XFX Radeon 7970 DD | 500GB Samsung 840 Evo | Samsung XL2270HD | KBT Race | Logitech G402
Mac: 13 inch MacBook Pro 2014 | 16GB RAM | Filco Minila Air | Magic Trackpad
Server: Asus M3N78-AM | Athlon II X3 400e | 4GB Corsair XMS2 | 4x 2TB Samsung F4EG (RAID-5) | LSI MegaRAID 8708EM2 | Corsair CX400 | Arch Linux
r3loaded is offline   Reply With Quote
Old 10th May 2011, 13:56   #4
Action_Parsnip
Hypermodder
Action_Parsnip's Avatar
Action_Parsnip - it's over 9000!!!!!!!!1!1!1!!!Action_Parsnip - it's over 9000!!!!!!!!1!1!1!!!Action_Parsnip - it's over 9000!!!!!!!!1!1!1!!!Action_Parsnip - it's over 9000!!!!!!!!1!1!1!!!Action_Parsnip - it's over 9000!!!!!!!!1!1!1!!!Action_Parsnip - it's over 9000!!!!!!!!1!1!1!!!Action_Parsnip - it's over 9000!!!!!!!!1!1!1!!!Action_Parsnip - it's over 9000!!!!!!!!1!1!1!!!Action_Parsnip - it's over 9000!!!!!!!!1!1!1!!!Action_Parsnip - it's over 9000!!!!!!!!1!1!1!!!Action_Parsnip - it's over 9000!!!!!!!!1!1!1!!!
Erm........... gtx590? Id say its an even coin toss between that and the 6990, wouldnt you? Otherwise, nice lists of kit made.
__________________
"Ooh he card read good!"
Q6700@3.475ghz 9x386mhz, Asus P5-B Deluxe WIFI-AP, 2x2gb Kingston 1066 @965mhz 5-5-5-15, western Digital Caviar Black 1tb HDD, Titan Fenrir, PC Power&Cooling 750w, XFX 4890
Action_Parsnip is offline   Reply With Quote
Old 10th May 2011, 13:58   #5
Shayper09
Swimming in Deionized.
Shayper09's Avatar
Shayper09 has yet to learn the way of the Dremel
Hd6990>Gtx590
Why you ask?
I prefer my computer not to explode when given something challenging to do...
__________________
The Ghost
i5 2500k
GTX 580
Watercooled Phantom
Click For Build Log
Shayper09 is offline   Reply With Quote
Old 10th May 2011, 14:01   #6
Parge
the worst
Moderator
Parge's Avatar
Parge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming Saiyan
Surprised you didn't opt for a 5850 Xtreme @ 100 over a 460 GTX!
__________________
NCase M1 - 5820k @4.3Ghz - H105 - GTX 980ti - ASRock X99e ITX/ac - 16GB DDR4 - 3x SSD - 600w SFX - 29" Ultrawide - Xonar U7 - Bassshaker - RAT3 - Quickfire TK - Q90s - Orbweaver - Warthog
Parge is offline   Reply With Quote
Old 10th May 2011, 14:11   #7
logan'srun
following the footsteps of giants
logan'srun's Avatar
logan'srun has yet to learn the way of the Dremellogan'srun has yet to learn the way of the Dremellogan'srun has yet to learn the way of the Dremellogan'srun has yet to learn the way of the Dremellogan'srun has yet to learn the way of the Dremel
if I wanted a photo- editing machine(multi-tasker, some film editing - no gaming) with tons of storage should I look at the set up for the Gaming Workhorse or the All Rounder?
logan'srun is offline   Reply With Quote
Old 10th May 2011, 14:18   #8
Luay
Minimodder
Luay has yet to learn the way of the Dremel
Thanks Bit-Tech and respect to not recommending a new part until you get your hands on it, such as the Crucial M4 SSD 64GB which is $30 more expensive than the C300.
Not optimistic about the SIlverstone Raven 03 when the reviews come out.
GTX590 is hard to find. I'd change the motherboard to Pro (2 pci-e2.0 x 8), and go for HD6950 2GB CF.
I would recommend the Asus Proart 24" 1920x1200 ips display.
Luay is offline   Reply With Quote
Old 10th May 2011, 14:22   #9
bogie170
Supermodder
bogie170 has yet to learn the way of the Dremel
You guys seriously need to review the OCZ Vertex 3 Max IOPS SSD. I think that you should choose it for premium player rig.
bogie170 is offline   Reply With Quote
Old 10th May 2011, 14:25   #10
Cei
pew pew pew
Cei's Avatar
Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.
Phew, my system is still current despite being bought in January. Was expecting it to be obsolete by now...
Glad to see the R3 is available in the US now too!
__________________
Join the BitSec organisation in Star Citizen! | Fleet Roster
i7 3770K | Asus RoG Maximus V Gene | 16GB 1866Mhz Vengeance | Crucial M4 256 & Samsung EVO 500 | Corsair H105 | Corsair AX860 | GTX 1080 FE | Air 240
i5 4670K | Asus RoG Maximus VI Impact | 8GB 1866Mhz Vengeance LP | Samsung 840 EVO 128GB | Noctua NH-U9B SE2 | GTX 770 SC 2GB | EVGA Hadron Air
Cei is offline   Reply With Quote
Old 10th May 2011, 14:26   #11
Luay
Minimodder
One more thing about the cooler. You haven't mentioned Thermalright's SIlver Arrow, nor Noctua's NHD14 & NHC14, so I'm not sure what you guys make of them compared to the Dark Rock, unless you haven't reviewed them yet. Thanks as always!
Old 10th May 2011, 15:04   #12
Snips
I can do dat, giz a job
Snips's Avatar
Snips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming Saiyan
LOL the 6990 fanbois start it off again. It has no place on this elite list.
Snips is offline   Reply With Quote
Old 10th May 2011, 15:07   #13
sotu1
Ex-Modder
sotu1's Avatar
sotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on you
probably has been stated before, but can we add speakers, headsets and monitors to those lists? I'm sure you've already got a stack of decent recommendations and they wouldn't change month to month....plzthanks
__________________
Still alive
sotu1 is offline   Reply With Quote
Old 10th May 2011, 15:12   #14
KiNETiK
Multimodder
KiNETiK has yet to learn the way of the DremelKiNETiK has yet to learn the way of the DremelKiNETiK has yet to learn the way of the Dremel
560Ti over a 480GTX? You can get a standard 480GTX for same price as this 560Ti or pay a little more and get a Gigabyte SOC addition which will give you near on 580GTX performance...
KiNETiK is offline   Reply With Quote
Old 10th May 2011, 15:12   #15
wuyanxu
still wants Homeworld 3
wuyanxu's Avatar
wuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyan
monitor: Dell U2711
Bit-tech concluded with 590 being faster than 6990, they are obviously not going to do a U-turn in a hardware recommendation article.
__________________
i7 2700k \ 16GB \ GTX 970 \ D2x \ Z68x-UD5 \ m4 128GB +2TB \ S12G-550 \ FT02-RW \ G15+G5+G51 \ U2711
X100 \ X-E2 \ 10-24 \ 55-200 \ 18/2 \ 60/2.4 \ Yn560 \ X1.1a \ Hadley Pro -- Photostreamr
wuyanxu is offline   Reply With Quote
Old 10th May 2011, 16:19   #16
DbD
Supermodder
DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.
With the Z68 motherboards coming out tomorrow if I understand correctly I would have thought the best thing to do right now is wait a few days (I am about to do a partial build and that's what I am planning to do).
DbD is offline   Reply With Quote
Old 10th May 2011, 16:40   #17
Valinor
Multimodder
Valinor has yet to learn the way of the Dremel
The Crucial M4 is generally ~£40-£60 cheaper than the other two drives, which are roughly the same price.
Valinor is offline   Reply With Quote
Old 10th May 2011, 16:56   #18
Pete J
RIP Teelzebub
Pete J's Avatar
Pete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming Saiyan
I was wondering how quickly this would be brought up. First post, no less! You have to remember that in the BT tests, the 590 fared well against the 6990 and was comparatively quiet.
Not true. Most other sites have the 6990 beating the 590.
Damn good point! Though they haven't reviewed it yet...
The 480 would require a more powerful PSU (extra money right there) and a stock version would be louder than a 560.
__________________
Latest system review here / I also have a laptop: Gigabyte P35X v6
HTC Vive review coming soon!
Pete J is offline   Reply With Quote
Old 10th May 2011, 16:57   #19
technogiant
Supermodder
technogiant is definitely a rep cheat.technogiant is definitely a rep cheat.technogiant is definitely a rep cheat.technogiant is definitely a rep cheat.technogiant is definitely a rep cheat.technogiant is definitely a rep cheat.technogiant is definitely a rep cheat.technogiant is definitely a rep cheat.technogiant is definitely a rep cheat.technogiant is definitely a rep cheat.technogiant is definitely a rep cheat.
Trouble with the motherboard you've chosen is the lack of any possibility of crossfire/sli because the second slot is only X4 electrically. That really limits the possibility of making a gaming powerhouse by using two more buget minded overclockable cards.
For instance my current system a Foxconn X38a chipset mobo socket 775 has two pciex16 2.0 both of which are x16 electrically even when both populated......I'm using an sli patch as the mobo chipset doesn't normally support sli and have two palit 2gb gtx460's sli'ed together and OCed to 820MHz from the stock of 675MHz.....matched with a Q6600 @3.5GH and 8Gb DDR2 this would shame all but your most expensive build in gpu limited gaming scenarios.
It really does play Crysis.......at max settings and 1920X1200.
technogiant is offline   Reply With Quote
Old 10th May 2011, 17:57   #20
bogie170
Supermodder
+1 on the crossfire issue. I just bought the Asus P8P67 Deluxe as it has its own optimised PLX crossfire engine embedded into the mobo for more performance.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
