Case Mod - In Progress CM-HAF-XL
Discussion in 'Project Logs' started by kier, 12 May 2011.
  1. kier
    kier -----------------
    1 Mar 2011
    Hi there, It's kier again
    After some requests to post the build of the CM-HAF-XL, i've decided to place it
    I am a bit ashamed that I did not post it earlier on Bit-tech ;)
    Ok..... he,s finished but maybe there are some nice ideas in it for you guys that you can use in your builds.
    I'm gonna post it in stages, otherwise it's too much at ones, I think
    This build is also my CoolerMaster Case Mod Competition Entry, so i've you like it.........
    please vote ;)
    But before i start, i wanna thank some sponsors
    Mister Freddy from Highflow.nl
    And
    Mister Ruud from Coolermaster.nl
    Want to thank you for the trust and products
    Let's begin:
    I've started this build begin december 2010, and build it in about 3 months
    Coolermaster has send me a very nice case, and a beautiful psu
    The HAF X and a 1200W Silent pro gold
    The hardware that i'm gonna use:
    - HAF X
    - PSU Coolermaster Silent pro gold 1200W
    - EVGA Classified E759
    - I7 930
    - 6x 2GB Corsair DDR3
    - Tripple GTX470
    - Aqua-computer Aquaero
    - Sony Optairc AD-7670
    - 2 x SSD Intel 160GB
    - 2 x 1 TB HDD
    De components are gonna be cooled wih EK blocks and:
    - 2 x Swiftech MCP 355
    - 1 x EK Radiator XT360 (maybe 2 x instead. the 240)
    - 1 x EK Radiator 240
    - Tygon slang clear. 1/2
    - 3 x EK GTX470 waterblock acetal/ nickel
    - Bitspower Fittingen Black
    - EK-FB EVGA X58 Classified
    - EK Supreme CPU block Black
    - 3 x EK Link Geforce
    - EK Bridge serial tripple
    - 2 x Aqua-computer cover MCP355
    - 3 x EK Backplate GTX470 Black
    for the reservoirs i have more options,
    - 2 x EK-Multioption RES X2 - 150 Advanced (Round 60mm)
    - 1 x EK-Multioption RES X2 - 250 Advanced (Round 60mm)
    - 2 x EK-Multioption 250 (Round 50mm)
    - 2 x EK-Spin Reservoir- plexi
    some pics, before i take the case apart
    the package from Coolermaster
    The big one from Coolermaster
    Inside beautiful black
    Enough space for the components
    Sata dock, always easy
    A lot of space for the reservoirs or radiators
    What i really like for modding is the air duct for the gpu's
    For so far the case. Also there was a nice psu, the 1200W silent pro
    Enough cables for my tripple gtx setup
    Gonna be a lot of sleeving
    Next step is to take the case apart, and fit some components
    The Haf XL, sad to see him like this.
    Yesterday i had a little brainstorming session, I will reveal you some ideas
    A 360 rad in this case is almost impossible, except for the top, but for the top I've got other ideas,
    now it,s going to be 2 x 240 rads
    Both sides 2 x 120 mm fan
    For the top a have some nice ideas
    Here comes 2 x EK spinbays
    I'll have to do some grinding for the spin Bays
    Gonna make 2 x square / octagon 3 mm plex fan bays, which will be the lid of the spin Bays
    Like this,
    In the cover is coming a aquaero, and in the flat side i,am gonna make a slot for a slimline DVD-RW
    i Am not sure where and if i place the airduct voor the gpu,s
    The last idea for now., Gonna make a hood from the front to the back of the case over the psu, on top of this 2 x MCP 355 pump, all in sight
    Under the hood i gonna place my hdd, s
    Hello again, new update
    Cut 2 holes for the 240 rad
    removed some plastic
    Cut a piece of uv-green plex
    Drilled the holes for the screws from the spinbay
    And installed the spinbay, only need to order 2 black impellers
    Yes, it fits
    One to go
    The color for this mod is black/green
    some Umzug von der Familie MDPC
    Sata and small green sleeve
    Black for the sata and psu
    The total family package
    heatshrink
    Heatshrink for the sata en small
    Black rivets, ad to drill a lot when i took the case apart
    Mdpc M3 screws
    Some special parts from mdpc, countersunk Black-Oxide screws
    And snap-caps, nice for over some ugly screws
    The second spinbay
    Put it all togheter
    Did some small grinding, to make it fit
    Sawn some little pieces of uv-green acryl.
    Gonna be sanded and polished
    The idea is to put smd led strips behind them
    pics in the dark
    nice effect
    Received some nice stuff from Highflow.nl and EK
    To begin with tje black EK impellers
    Always nice to receive a package
    Pump number 2
    The third nickel block
    with three times a nice black backplate
    put everything togheter with a tripple bridge
    and three Link force,s
    An extra 240 Radiator
    And 4 beautiful Nanoxia 120mm Fans, uv green, same color as the green acryl i used
    +1 140mm fan
    To control the fans and pumps i'm gonna use a Aquaero VF display.
    And some small stuff to try out some nice ideas
    2 nice fillports from Danger den
    And 2 shiny nickel tops for the Mcp-355 pumps
    Put them together
    Think it,s gonna be perfect in this case
    And the first Bitspower fittingen
    Impellers already placed, looks better like this. Fillports coming up
    I have made the midplate from a piece of mesh panel, gonna be painted black and some nice ideas in it
    Made the radiator bay
    The first thought was to put the in/outputs of the rads turned to the inside, like this
    But i want the pumps in one line
    That's why i,ve turned one radiator
    Putting al together
    I love the color of the fans, really nice
    Other side
    Painted the bay and fitting it together
    flip side
    Made the fillports into the spinbays
    And in received a package from Coolermaster, some beautiful flatcabels. The idea is to
    sleef the psu cables and to use flatcabels for the gpu.
    Coolermaster thnx!!!
    bought myself a new cpu block
    EK-Supreme HF - Acetal+Nickel
    Replaced the red plexi cover for the black acetal for the classified
    EK-FB EVGA X58 Classified - Acetal+Nickel
    Looking good i think
    A new set of rams, 6x 2 GB
    placed on the board
    Also looks nice. And i bought my third GTX 470, Nickel block placed on it
    And the backplate.
    Conected all together with the EK tripple bridge
    I'm in love, but it,s real heavy now
    Backplates really nice like this
    I think i need to make something for the weight, but that,s for later
    Have played with the Aquaero, and was real happy with the color of the display, with the green filter it was even better
    Perfect, just the right color for this build
    Started with the top, and placed the display in it
    Little test
    Had sawn a small plate of acryl, need to polish it, but looks good for now
    Again little test
    And again, the green filter placed back
    The place where the usb and other stuff was is now for the buttons for the aquaero and some other nice ideas i have. But this is for the weekend, so.... be continued
    Greetings to you all.
  2. llamafur
    llamafur WaterCooled fool
    27 Jul 2009
    DAMN great way to start a project log.
  3. Fedmas
    Fedmas Leader of the casemod watchers :D
    29 Jan 2010
    Nice..
  4. zeBriukas
    zeBriukas What's a Dremel?
    25 Apr 2011
    Awesome man! Those reservoirs are cool ! Subbed :)
  5. Xunsu
    Xunsu What's a Dremel?
    24 Apr 2011
    that case is nice, I like the ideas.
  6. Nitrixflare
    Nitrixflare Building and engineering enthusiast
    31 Dec 2010
    yeah i agree, i like the way you think, how you fitted those parts in.
  7. kier
    1 Mar 2011
    Hi y'all,
    Another day, another update.
    I'm sure you like this one ;)
    For the aquaero buttons the idea is to place them vertical and place two extra buttons for the power and reset
    In the past i had destroyd an aquaero, what is now very handy for spare parts, sawn the two buttons out of the old one. For the power and reset
    Different sizes from the old and new aquaero
    drilled and sawn a piece of acryl
    And placed the two extra buttons
    the pushbuttons at the same height
    And we have a " X "
    Removed the frontcover
    Sawn a piece out of the case
    Horizontal mounting is not an option, because the aquaero is to long and i want the " X " in the middle, thats why vertical
    Fits nicely between the 2 radiators
    Gonna light up the buttons with green uv acryl
    Covered this with black acryl. I need to make this black acryl over because the holes aren't that good, but just for the idea
    And light it up
    Tried some things today, and i removed the black acryl. Instead of this i have placed a sticker and cut out the stripes
    Better like this
    And some shots by night
    Have replaced al the rivets and screws, before the hardware is placed
    have made a solid tube between the reservoir and the Ek bridge
    From Reservoir to....
    Ek Bridge.
    Connected
    Placed the green nanoxia-140mm
    Back of the case is not finished yet
    The Msi bracket is gonna be replaced
    From the gpu to the pump is gonna be a solid tube also, and the same for the pump to the radiator
    The right shape
    The curve is for to get the right angel for the tube but also for the flatcables of the gpu,s
    Just like this, the tube between the pump and gpu needs to be longer, but just to give you an idea
    And the last thing i do this weekend, pimping the fans. Nanoxia sticker has to go
    Made my own stickers
    The famous snap-caps
    All fans are finished
    It's sleeving time. The Silent pro is an easy psu to sleeve i think. Lots of space
    The original flatcables had a bridge in it, really ugly so that has to change
    sleeving meets flatcable.
    2 x modulair pci-e
    And 2 x non-modulair
    Placed the flatcables but need to straigt it, just for the idea
    Nice green sleeve, same color as my Nanoxia fans
    Green is finished, now it's time for the black sleeve
    Ready to plug in
    Had to make the cpu cables longer
    These wil be black
    split the green and black as much as possible
    And finished
    Placed in de Haf.
    Green color of the sleeves are really the same as the fans
    Cpu cable black sleeved 4 x 4 pins
    Nice curve in it
    And a total shot with flatcables and sleeved cables. Need to straigten al the cables
    Also made a mesh cover for the front panel out of a ceiling plate. This ceiling plate has a filter glued on it, so perfect for this purposes
    The ceiling plate
    Filter on the inside
    Beautiful mesh i think
    After some sawing and bending
    And the filter on the inside
    Placed a light on the inside to show you the filter
    And this little project is finished
    Greetings and till the next update :thumb:
  8. Thecyp31
    Thecyp31 Mini moddeur
    11 May 2011
    Good job!!! But only 2 240 for all the components?
  9. kier
    1 Mar 2011
    Don,t have any problems with the temps, i'm not overclocking only modding ;)
  10. Thecyp31
    11 May 2011
    ok good luck for the work !
  11. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    ... wow.
  12. kier
    1 Mar 2011
    Update-------------------Recycling
    A friend of mine has given my a broken Logitech G15. The idea was to use it for the lcd screen, but when i dismantel it i saw the small plex for the illuminated board
    Idea !!!
    Used a bigger piece for the cover
    Sawn a piece out of it and drilled 3 holes for the bitspower fillport
    The three Bitspower fillport
    Swan the acryl from the G15
    testing with a green ledstrip
    Looks like the matrix
    Put a black vinyl sticker over the transparent acryl and cut small pieces out of it
    Place it in the haf
    Shot in the dark
    3 fittings installed
    Everything is gonna be replaced for black fittings and solid tubes
    And a little Sponsor Update
    Today a nice updat for the sponsors (and you offcourse)
    First i wanna thank the people from Letterop Ijmuiden, who had made the perfect sticker.
    Letterop Reclame uw specialist in de IJmond!
    And i wanna thank mr. D hard, he also made this update possible
    Logo number 1
    HighFlow Computer Cooling Shop - Uw shop voor PC waterkoeling, luchtkoeling, modding, behuizingen en gaming!
    Logo number 2
    Cooler Master
    The sticker
    Sawn a piece of uv-green acryl, and made a slot for the slimline dvd-rw
    Very carfully placed the sticker and cut the sides
    To have a nice illuminated cover, Mr.D. Hard has given my 2 nice glowpads
    Color is blue, thats why i had placed the uv-green
    You can cut the glowpads any shape you want
    placed on the back of the cover
    Illuminates Highflow
    Illuminates Coolermaster
    And illuminates the hole cover, nice effect i think
    Placed back in de Haf
    The front almost finished
    In the dark............
    Did some nice things these days. Finally received my Acryl and aluminum panels
    1mm black aluminum
    and the panels i was waiting for Uv green 3mm
    And 5 mm
    A little idea i had, drawing a mold
    Then cut out some cardboard
    Shapping the cpu
    And the Corsair memory
    The gpu's
    and the mold is finished
    And now the nice part, when i screw this up, i have a big problem, this came out of a hole panel, so really cant screw this up. But with same patience it came out very well, i think
    Cut out some openings for the cpu cables and motherboard cables
    And the cover is finished
    there,s gonna be black stickers on it, and cutting these for a green outline
    Some places have bubbles, so need to rub them out
    And the I/O blocks (or how do you call them?) also black
    Smd strips where ordered today, and iam very curious how this looks
    Ordered green smd strips, smd Uv strips and some other led strips to test
    The whole thing...
    By the way, there's gonna be an airflow behind the acryl and the motherboard, so dont wurry ;)
    Last days did some thinking about the hdd/ssd bays. used for this the original Haf bay, cut it in 2 pieces
    One for the ssd's and one for the hdd's
    Bay 1 for the ssd
    Bay 2 for the hdd
    Hmmm my new friend, Mr. Gorillatorch, helped me a lot lately with my build
    Again bay 2
    Gonna place them like this
    Bay 2 installed
    And bay 1 beneed the slimeline dvd drive.
    Have made a bay for the slimline dvd-rw
    fits perfectly
    just about this, need to do some little things to it, to make it look better, but for now.....
    Cut out a piece for the dvd
    Fits also
    The opening for the power cable to my gpu's
    For the noise reduction i used some isolation tape
    And grind a piece of my ceiling plate
    Vry nice piece i think
    This is all beeing covered with a midplate 5mm black acryl
    like this
    Replaced the original rivets for countersunk rivets.
    The original rivet
    countersunk rivets with tape for protection
    Whole back is finished for another idea
    For this update i wanna thank Mr. Sammie from cK-leds
    He has given my some very nice led strips
    Green silicone strips
    Green Smd strips
    Uv purple Smd strips
    also did some nice things with my pumps. Sawn 4 pieces of acryl.
    2 x uv green acryl 5mm
    And 2 x Black acryl 5mm
    Need to polish them
    Sawn the green acryl one more time with 4 feet instead of 2
    black acryl under the pump
    my 2 pumps ready to go
    Looks nice i think on my black midplate. and placed a single led in it
    Placed in the Haf with the led
    And some pics in the dark
    I've frosted the uotside from the acryl, and put some led strips around the motherboard
    Placed the cover, still need to get the strips right
    But it's a nice effect already
    Have some disappointment about the solid tubes
    "Old" Tube
    "new" Tube
    doesnt fit anymore in the Bitspower fittings, so need to change plans. So i put the new solid tube in the Tygon tube
    Have tested it first, and looked really nice
    So did some sawning and fitting, and here,s the result
    Everything almost straight
    Have to exchange some silver for black fittings
    Lights out please.......nice, but need to buy some extenders for a straight line
    But the most lines are straight
    Total shot
    Pump 1 plugged in, only pump 2 now
    Reservoirs also nice with the green light
    Next step, buying BP black fittings and the acid green fluid
    So did some shopping by Highflow.nl
    Black and silver again for a new idea
    And i bought 6 BP zilveren L-Rotery,s second hand for a really good price
    For the link between the cpu and the motherboard i used silver fittings andextenders, this looks really good woth the nickel blocks from the gpu
    still need to put a small link between the cpu and the NB
    Did some cable managment, looks messy, but first things first
    The inside is better looking
    Mdpc sleeving always nice
    And the cpu power, 4 x 4 blocks
    a good friend have helped me with my slotloader dvd-rw
    He was really fast with putting this together again......... respect
    2 wires soldered on it, and tested it
    looks really nice, i think
    My reset button is now the eject button for the slotloader on the aquaero
    Mr. wwwicked thanks a lot, i owe you one
    Some stuff from my favorite shop HighFlow Computer Cooling Shop - Uw shop voor PC waterkoeling, luchtkoeling, modding, behuizingen en gaming!
    I,ve seen this fluid by the L3p desk, what looks really good ;)
    Feser One Cooling Fluid - UV ACID GREEN
    Black extenders, have bought a lot of these
    Bitspower G1/4 Matt Black IG1/4 Extender BP-MBWTP-C40
    A rally nice rotery
    Bitspower G1/4 Matt Black Dual Rotary 90 Degree IG1/4 Adapter BP-MB90R2
    And more rotery's
    Bitspower Matt Black fittings
    And some shiny silverware
    Bitspower Silver Shiny Fittings
    I had to extend my Aquaero from the dispaly.
    Power on, and works fine
    And placed all the new fittings
    straight behind the powercables
    New black rotery's on the EK bridge
    And the pumps connected
    1 tube underneed the radiator bay
    The only thing now is to connect everything togheter and do some more wiring
    But have space enough for this.
    I hope to put the acid green fluid this weekend in, and show you some pics of this
    Grtzzz.
  13. l3p
    l3p www.^.nl
    1 Nov 2010
    I love Acid Green ! :rock:
  14. kier
    1 Mar 2011
    I remember you did't something with acid green,............something with a desk
    Am I right? :D :jawdrop: :D
  15. TaRkA DaHl
    TaRkA DaHl Modder
    15 Mar 2011
    Very tidy, like the placement of the rads. Not 100% on the mobo cover at the moment, but that could change once complete :)
    Keep it up, much enjoyment so far.
  16. Rodhizzle
    Rodhizzle What's a Dremel?
    9 Apr 2011
    Kier, you are an artist.
  17. kier
    1 Mar 2011
    Update: filled it up and cables
    Did al the wirring voor the aquaero
    And some updates for the firmware and software for the aquaero
    The 140mm fan works fine.
    The other fans also
    filling loop 1. No problems
    Tubes on top
    straight to the pump
    The fan is really coming out nice with the uv light
    Because there is a solid tube inside the Tygon tube, there's a lot of air inside
    Uv strips are really nice , and a good effect
    Uv acryl is very nice also
    and filled loop 2
    Beautiful pomps i think
    Looks good with the green acryl under need the ppumps
    And a total shot
    pics by daylight
    Was a lot of pushing and pulling
    For the airflow behind the acryl and the motherboard i have placed some nice small fans
    witch blow air up
    They blow air against a small metal stripe, and bend the flow down, behind the acryl
    Works perfectly
    And i have placed some green strips for the frontbay
    everything placed in order
    Have sawn small pieces of green 3mm acryl
    think it looks nice with the black top
    But need to frost it some more
    Cover the behind also
    Gonna think it over some more
    And last but not least, the side panel
    Sawning time
    Used a 5mm green acryl again
    Need to be shappen some more
    And placed it back
    Looks fine with uv led strips
    But needs to be placed it in the right direction
    After this i did some thinking, and think it's a shame that the gpu's are not fully in sight
    So did some sawning again.
    Better like this, i think. The idea is to use the green acryl piece i've made, to place it in the other side panel
    the other side of the case,(other sidepanel) did some sawning and grinding
    It took some time, but almost finished
    Have used the green acryl from the other side, never throw something away ;)
    Recycling again
    Need to shappen the slots some more
    And did some more small things. Maked the cover for the display again, but now with aluminium
    Better then the 3mm black acryl
    some more grinding and sawning
    put the grey display in
    only paint the cover again and it's finished
    Have used the same black aluminium for the sli cover
    Mdpc bolts in it
    nothing more for this cover, think it's finished like this
    Also did the final placing for the led strips
    Placed with the uv strips a green stripe, just to remove the purple color
    Looks nice on the mesh panel
    Lines on the motherboard cover are very good visible now
    Need to shappen the cables some more, but almost there
    Before i will show you the final pics, some more modding
    To turn the lights on and off i'am gonna use a multiswitch
    Made a cover for this
    Multiswitch Behind
    And the location where it's gonna be
    CM-HAF-XL is now up and running. So here some final pics for you guys
    Only need to put a piece acryl in the side panel, but it's delayed, and not really important for the pics ;)
    Pics by night coming up, dont want to bore you with to much pics
    Grtzzz.
    CoffeeTwoSugars likes this.
  18. Dragonite
    Dragonite Minimodder
    15 Feb 2011
    Really nice :D
  19. Waynio
    Waynio Relaxing
    20 Aug 2009
    Very very nice mod kier :thumb:.
  20. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    night pics please :D
