#141 |
I use my dremel as a toothbrush
I suggest that we should hold up to the original intention, modify a CM HAF, not starting a scratch. Also by the word 'frame' i understand basic chasis - plain SECC frame completly stripped off w/o any plastic parts, fans, whatever, with the same dimensions. tho Confusis said we can cut it, im going the 'do not cut your HAF' way.
#142 |
↓ Don't trust that face!
Any sign that you were at least trying to use the haf model would help here...
-80 fl oz of diet Coke and things like this happen.
__________________
#143 |
Kiwi-modder
Will review the deadline on the 10th
#144 |
Ook ? Ook !
Today's work, still a lot to do. What's new ?
- Added a dual 200mm Rad on top - Made a custom "heat exchanger" on the back. It's made of a single block, which includes a 140mm rad in the center and 2 "channels" at the entry and at the exit. Those channels help to dissipate heat through the back fins. ![]() ![]() ![]() ![]() Hope you like the idea
#145 |
what was dat sandvich ?
looking really nice !! that motherboard is huge
__________________
My deviantart page : link Battlefield 3: Mindrusted My computer : Link |||||||||
#146 |
Ook ? Ook !
#147 |
Veni Vidi Vado
That's the Tyan Thunder n4250QE I think. C'mon, use the Tyan Thunder M4985-SI Expansion Board & HT-cards as well. You know you want to.
![]() Edit: Come to think of it - maybe you already did. Hard to tell from the pictures.
__________________
Feel free to correct this post per PN or otherwise to help me improve my English. |
#148 |
That heat exchanger/radiator combo is delicious.
__________________
#149 |
The deadline approaches, and everyone got quiet.
__________________
#150 | |
Ook ? Ook !
Update incoming tonight .... I did fit the expansion board .... 8x opterons + 2x Radeon 6990 .... with everything watercooled (well, massive use of custom cooling hardware
)Just need to add the hotswap HDD bay. Quote:
#151 |
theorycrafting
I've finished my thingy two days after launch of the contest... waiting for the last day to post pictures
__________________
...and allways remember, that the world is an orange!
Define Mini Black [Gigabyte Z77MX-D3H | intel i5-3450 | Kingston HyperX DDR3-1600 8GB | Gigabyte GTX660OC Windforce2 | intel 330 120GB | WD AV GP 1TB] |
#152 |
Ook ? Ook !
#153 |
i haven't had the time to do much more then this :/
__________________
#154 |
My finger is in the fan
Still working on mine. I'm not too experienced with sketchup so things are taking a bit more time to do than it would for others. I don't stand a chance against the epic monster hafenstein anyway. ;D
__________________
I always said, if there was a way to go, it'd have something to do with computer cases, spraypaint, and a dremel... |
#155 | |
#156 |
Ook ? Ook !
Today's update :
I'm near final design. Still have to refine the overall look, but I'm happy with the concept .Here are the pics (I know, it looks like a snail or a "@" )Outside : ![]() ![]() Inside : ![]() ![]() ![]() In blue, the radiators (passive and active) : ![]() Hardware and cooling bits : ![]() Air flow : ![]() I hope you like the idea. I still have to make the CPUs blocks. There won't be much tubing since I decided to use "channels" acting like passive heat-spreader. Edit : Close-up to the custom Radeon 6990 block (inspired by the enzotech GTX 295 block)
#158 |
me like. me want.
__________________
#159 |
What's a Dremel?
Wow nice designs just wanted to ask a question i came across this from a link on MNPC Tech. I was wondering if i would be able to make an entry being i just joined the site or do you guys have a rule about being here for so long or something before you can enter? I looked but didn't see anything about this in any of the rules.
#160 |
jack of all trades
Aye, that's looking sweet!
Had even less time than I was expecting to work on this, and really can't dedicate any more time to it, so this is what I've got to finish with. ![]()
| Tags |
| aurora, contest, cooler master design comp, design, haf 932 design, mnpctech, prizes, sketchup |
| Thread Tools | |
| View Mode | |
