Reply
Thread Tools View Mode
Old 17th May 2011, 20:16   #1
jj_sky5000
Multimodder
jj_sky5000's Avatar
jj_sky5000 has yet to learn the way of the Dremel
Blood Ice HAF 922 ICE Version !!!!!
After weeks of designing, and planning i am ready to unveil Blood Ice HAF 922. I had a couple of projects that i was working and wasnt sure i had the time for another. The system with feature a Red & White Theme incased in a Icy Shell.
2011 Cooler Master Case Mod Entry
I would like to thank my sponsors for contributing to the Build
Intel
Sapphire
BioStar
Part List
Cooler Master HAF 922
Intel i5-2500 k
Sapphire 6970 GPU
Biostar MB
Phoybia 4 120mm Silent Fans red/clear
First off was to clean I dust off HAF 922 it has been sitting in a box for about 8 months then onto
disassmebly and strip the old paint from the system, which i was long and very time consuming.
Now that i have it clean enough to piant, I started riviting it back together a added the new wheels to It
primed and painted!! 4 days!!! lol
A few red pieces
jj_sky5000 is offline   Reply With Quote
Old 17th May 2011, 20:17   #2
jj_sky5000
Multimodder
jj_sky5000's Avatar
Ok back to the unique & by far hardest part of the mod, Moldings very risky!!!!
front panel
dremeled to lay very flat
I have a idea for the front grill
after a day of drying
Molds are ready
Up next a custom side panel i ran out of polyurethane mold supplies, so i had to think of something else i had on hand, Resin perfect.
The HAF 922 side panel sumerged in resin
a sign of curing
Came out better than exspected
Old 17th May 2011, 20:18   #3
jj_sky5000
Multimodder
jj_sky5000's Avatar
I love these fans
quick hardware test
Top Panel was rough
Cleaning Up the side panel
Thanks for looking
Old 17th May 2011, 20:18   #4
jj_sky5000
Multimodder
jj_sky5000's Avatar
Thanks for looking good luck everybody
Thanks for looking !!!!!
Old 24th May 2011, 19:35   #5
jj_sky5000
Multimodder
jj_sky5000's Avatar
It was sunny and i wanted to see if the ice would melt!!!
Old 25th May 2011, 19:24   #6
jj_sky5000
Multimodder
jj_sky5000's Avatar
I am still going to be to adding watercooling, paint the bay covers white , ect , sleeve the new power supply and add a see through side panel.
Old 27th May 2011, 06:39   #7
jeckulz
Supermodder
jeckulz's Avatar
jeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremel
Dont know about anyone else mate, but I ****ing love it!
Good job on thinking outside the square-ish cube looking thing made of cardboard
jeckulz is offline   Reply With Quote
Old 27th May 2011, 15:27   #8
jj_sky5000
Multimodder
jj_sky5000's Avatar
Thank you , This is the 3rd of the4 builds i have done with resin, i like the icy effect that it brings to the builds
more to come making a few changes
Old 27th May 2011, 16:25   #9
Kovoet
Do I or Don't I
Kovoet's Avatar
Kovoet is the Cheesecake. Relix smiles down upon them.Kovoet is the Cheesecake. Relix smiles down upon them.Kovoet is the Cheesecake. Relix smiles down upon them.Kovoet is the Cheesecake. Relix smiles down upon them.Kovoet is the Cheesecake. Relix smiles down upon them.Kovoet is the Cheesecake. Relix smiles down upon them.Kovoet is the Cheesecake. Relix smiles down upon them.Kovoet is the Cheesecake. Relix smiles down upon them.Kovoet is the Cheesecake. Relix smiles down upon them.Kovoet is the Cheesecake. Relix smiles down upon them.Kovoet is the Cheesecake. Relix smiles down upon them.
very different but liking it
Kovoet is offline   Reply With Quote
Old 29th May 2011, 15:04   #10
jj_sky5000
Multimodder
jj_sky5000's Avatar
Let some more fun begin
Old 14th Jun 2011, 02:53   #11
jj_sky5000
Multimodder
jj_sky5000's Avatar
Ok I began updating the pc to more teh finished product that i had envisioned. First up took off the rollers and add some cool case feet.
Oh getting excited to see it match up with the red inside the case.
Next up adding a window to teh side of the case
added a little ecting With a chilling look
Up next adding water cooling blocks to the components ( converted my 1366 Danger den water block to fit 1156 sockets)
Asus Maximus Gene III and a HD5970
Thats all for now
Old 15th Jun 2011, 04:41   #12
jj_sky5000
Multimodder
jj_sky5000's Avatar
Ok a good nite of progress added the ROG logo to the front panel fan intake. Came out better than expected
Finished up the ROG logo illumination on the side panel
a few areas to fix but came out pretty good
Installed MB VGA and began tubing fore the water cooling
Thanks again cant wait to put it all back together.
Old 15th Jun 2011, 21:46   #13
Karrek
Multimodder
Karrek's Avatar
Karrek has yet to learn the way of the Dremel
I really like the two-tone window etching. How did you do that? By using two pieces of plexi that are lit up individually?
I'm really impressed with this build - good job!
Karrek is offline   Reply With Quote
Old 15th Jun 2011, 23:04   #14
jj_sky5000
Multimodder
jj_sky5000's Avatar
yes that is correct !!!!
Old 16th Jun 2011, 07:32   #15
jj_sky5000
Multimodder
jj_sky5000's Avatar
Finished the loop
Did some sleeving !!!! yeh
leak test yea of course it leaked (lol)
running very smooth now
teaser pic
Old 22nd Jun 2011, 01:13   #16
jj_sky5000
Multimodder
jj_sky5000's Avatar
Another Small update!!!! I had some left over cured resin that game me a great idea
Started on the Asus ROG logo On the side panel!!!!
over to the saw!!
plain old Side panel
3D logo
Some more sleeving to the top panel
Teaser pic
Thank you for Looking
Old 22nd Jun 2011, 01:43   #17
jeckulz
Supermodder
jeckulz's Avatar
LUSH!
Where can I get one? LOL
Old 22nd Jun 2011, 02:24   #18
j0rd
FLOSS folder
j0rd's Avatar
j0rd has yet to learn the way of the Dremel
The lenovo was my fave ice mod but this one is shaping up to be a whole nuva level above that. Look forward to seeing progress as it happens
__________________
Word Press blog
Losias stats tracker (under development) is here
‾pɹ0ɾ
j0rd is offline   Reply With Quote
Old 1st Jul 2011, 03:53   #19
jj_sky5000
Multimodder
jj_sky5000's Avatar
Some finished pics
ASUS ROG Formula X event
Thanks you for looking !!!!
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
