Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 18th May 2011, 07:56   #1
arcticstoat
Hypermodder
arcticstoat's Avatar
arcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysis
Intel Solid-State Drive 510 120GB Review
Intel enters the SATA 6Gbps ring with its own SSD based on a Marvell controller.
http://www.bit-tech.net/hardware/201...120gb-review/1
__________________
Ben Hardwidge
Custom PC Editor
arcticstoat is offline   Reply With Quote
Old 18th May 2011, 08:39   #2
SMIFFYDUDE
Supermodders on my D
SMIFFYDUDE's Avatar
SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.
Always good to wake up to a SSD review
__________________
i7 6700K|Sabertooth Z170 S|16GB Crosair Dominator Platinum 3200MHz|KFA2 GTX 1080 HOF|Creative Sound Blaster ZxR|Super Flower Leadex Gold 850W|Corsair 780T|HP LP2475w|Speedlink Medusa 5.1|CM Storm Inferno|Windows 10
SMIFFYDUDE is offline   Reply With Quote
Old 18th May 2011, 09:04   #3
the_kille4
Chaos will rule da world.eventually
the_kille4 has yet to learn the way of the Dremel
the intel 510 ssd is actually cheaper... albeit very slightly here in singapore compared to the vertex 3....
__________________
Headphones: Grado SR325is | Oppo PM-3
Mic: Antlion ModMic 2.3 | Audio-Technica AT2020
Mixer: Alesis MultiMix 8 USB FX
Speakers: M-Audio Studiophile AV 40
the_kille4 is offline   Reply With Quote
Old 18th May 2011, 10:02   #4
Ph4ZeD
Banned
Ph4ZeD can run CrysisPh4ZeD can run CrysisPh4ZeD can run CrysisPh4ZeD can run CrysisPh4ZeD can run CrysisPh4ZeD can run CrysisPh4ZeD can run CrysisPh4ZeD can run CrysisPh4ZeD can run CrysisPh4ZeD can run CrysisPh4ZeD can run Crysis
Quite a meh SSD considering the price, which is why I went for the M4.
Ph4ZeD is offline   Reply With Quote
Old 18th May 2011, 10:07   #5
Chicken76
Hypermodder
Chicken76's Avatar
Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!
The performance analysis compares this 120GB Intel drive to the Crucial M4 reviewed earlier, which is a 256GB drive and 60% more expensive, and it fails to achieve the same performance. Isn't performance supposed to scale with size or am I missing something here? Wouldn't it be fair (and an interesting read) to test the 250GB version of the Intel 510 and compare it to the M4-256GB?
Chicken76 is offline   Reply With Quote
Old 18th May 2011, 10:46   #6
Technobod
Finally bought a desktop :D
Technobod's Avatar
Technobod is definitely a rep cheat.Technobod is definitely a rep cheat.Technobod is definitely a rep cheat.Technobod is definitely a rep cheat.Technobod is definitely a rep cheat.Technobod is definitely a rep cheat.Technobod is definitely a rep cheat.Technobod is definitely a rep cheat.Technobod is definitely a rep cheat.Technobod is definitely a rep cheat.Technobod is definitely a rep cheat.
Specifications;
Nominal capacity: 256GB
Formatted capacity: 238.47GB
The 120GB ... With a formatted capacity of 111GB,
Eh? I think someone's forgotten to update the table since the M4.
__________________
[i5-4690K][RANGER][16GB][AX760][2xM4 128GB (RAID0)][450D][8.1-Pro][U2414H]
[EK Supremacy][EK X3 150][D5 Vario EK Top][EK 240+ST30 360]
[HP N40L][Neo@1.5GHz][6GB][4x3TB (RAIDZ2)][2TB+250GB][UbuntuServer]
[Weihrauch HW100KT .22 + .177 + HW97K .22 + .177][Hawke Panoramas 4x-12x x4]
Technobod is offline   Reply With Quote
Old 18th May 2011, 10:47   #7
misterd77
Multimodder
misterd77 has yet to learn the way of the Dremel
the drive capacities are way too low, even the 256gb versions dont have enough capacity for me, My installed programs + windows comes to well over 370gb, so using these ssd's as program drives really fails, I would be constantly unstalling and installing programs, on another note, nice to finally see the prices come down a bit, the m4 is still £350 though, I could build a whole pc for that, and bit tech's buyers guide pc is just another £100 or so more, if these ssd's are going to gain ground, they need to lower the prices for the 256gb versions by at least £100, I wouldnt buy a 120gb, the capacity is too low and the redunancy eats a large chunk of that, 14% writeoff is a good chunk of data on any drive, if they released a 256gb ssd for around £150, (3 times the price of a 2tb drive), it may convince me to part with the cash, until that happens, these drives are just way too expensive for the average gamer, if your using ur pc to encode video, then it makes sense though, the trade off in time saved V cost makes sense, other than that, its a huge waste of money just to play games a bit faster than a traditional drive.
misterd77 is offline   Reply With Quote
Old 18th May 2011, 11:04   #8
Xir
I Mod, Therefore I Own
Xir's Avatar
Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.
+1
They're getting faster instead of cheaper...wrong choice for the mass market
__________________
SN25P
A64 3700+ (San Diego)
2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T
X1800XT 512mb Sapphire
200GB Samsung SP2004C 24" Asus VW246H 1920x1080
Xir is offline   Reply With Quote
Old 18th May 2011, 11:05   #9
maverik-sg1
Supermodder
maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.
I love the SSD performance and overall pacakge.
However, the technology moves forward but prices remain far too high for my liking, I always gave myself a benchmark of buying a 128gb drive when the price for a decent performer was £128 for the unit (which was around the same price I paid for raptors back in the day) - we seem to be a long way off that and I still have question marks over the long term life expectancy.
When it all satarted all we heard was this is the end of the hard disk disk drive, all I see now is that for the foreseeable future they simply compliment the storage devices as a means to simply put your OS and main program on and forget about using them for anything else.
maverik-sg1 is offline   Reply With Quote
Old 18th May 2011, 11:29   #10
InfernoZeus
Minimodder
InfernoZeus has yet to learn the way of the Dremel
Page 1, Paragraph 4: "The Marvell 9174 is a proven SATA 6Gbps controller, having been used in last yearís Crucial C300 series of SSDs, as well as the Crucial M4 (review coming soon)"
You've already reviewed the M4? http://www.bit-tech.net/hardware/sto...256gb-review/1
Edit: You mention it again at the end, but you clarify it as the 128GB version of the M4, which makes more sense.
InfernoZeus is offline   Reply With Quote
Old 18th May 2011, 12:03   #11
Ph4ZeD
Banned
Theres a 120GB SSD on the marketplace for £125. I'm selling my own 64GB C300 for £70. Not so far off.
Old 18th May 2011, 12:30   #12
Baz
I work for Corsair
Baz's Avatar
Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.
Originally Posted by Technobod
Specifications;
Thanks for the spot!
Baz is offline   Reply With Quote
Old 18th May 2011, 16:14   #13
Fordy
Multimodder
Fordy has yet to learn the way of the DremelFordy has yet to learn the way of the DremelFordy has yet to learn the way of the Dremel
Awesome review, not such an awesome drive.
Thanks, one note though:
"Crucial M4 (Review coming soon!)"
It's come, before this one. Maybe drop the link in? (Unless it refers specifically to the 128GB M4, which it doesn't seem to in the context)
__________________
Fordy
HTPC Project Log
Fordy is offline   Reply With Quote
Old 18th May 2011, 16:25   #14
PingCrosby
Supermodder
PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.
It's always good just to wake up when you get to my age.
PingCrosby is offline   Reply With Quote
Old 18th May 2011, 16:37   #15
mucgoo
I *am* a Dremel
mucgoo should be considered for presidentmucgoo should be considered for presidentmucgoo should be considered for presidentmucgoo should be considered for presidentmucgoo should be considered for presidentmucgoo should be considered for presidentmucgoo should be considered for presidentmucgoo should be considered for presidentmucgoo should be considered for presidentmucgoo should be considered for presidentmucgoo should be considered for president
If someone can release a 60GB SSD with 200mb or so sequential read and 20mb random for £50 I'll buy one but till then. Is there really any point to 500mb+ sequential read speed?
mucgoo is offline   Reply With Quote
Old 18th May 2011, 17:22   #16
gcwebbyuk
Dib Dabbler
gcwebbyuk's Avatar
gcwebbyuk is a hoopy frood who really knows where their towel is.gcwebbyuk is a hoopy frood who really knows where their towel is.gcwebbyuk is a hoopy frood who really knows where their towel is.gcwebbyuk is a hoopy frood who really knows where their towel is.gcwebbyuk is a hoopy frood who really knows where their towel is.gcwebbyuk is a hoopy frood who really knows where their towel is.gcwebbyuk is a hoopy frood who really knows where their towel is.gcwebbyuk is a hoopy frood who really knows where their towel is.gcwebbyuk is a hoopy frood who really knows where their towel is.gcwebbyuk is a hoopy frood who really knows where their towel is.gcwebbyuk is a hoopy frood who really knows where their towel is.
I don't see why manufacturers should lower prices if people are still buying them at the current price.
An SSD is a premium drive. If you want cheap, go mechanical.
I use a C300 as my boot disk for my main PC (with an 800GB data / Steam drive) and an 80GB X25 in my laptop. They cost me quite a bit, but I appreciate the speed.
You wouldn't expect Ferrari to lower their prices just to make them more available to the public?
Slightly lower price would be nice but £100 off is a bit harsh! A 256GB for £150 - what about a GTX590 for £100 off...
gcwebbyuk is offline   Reply With Quote
Old 18th May 2011, 18:40   #17
mucgoo
I *am* a Dremel
RAM was a super premium item. SSD need to start coming down in price so that a boot SSD + storage HD becomes the norm rather than enthusiast exception.
Old 18th May 2011, 18:59   #18
gcwebbyuk
Dib Dabbler
gcwebbyuk's Avatar
Is that "Need" so that you can buy one or just a general "Need".
There is no reason why it should become the norm - take my GPU suggestion - should it be the norm that high end GPUs become cheaper so that everyone can buy them?
What is wrong with "non-enthusiasts" using fast mechanical drives? They are still plenty fast, just not as lightning quick as an SSD.
Old 19th May 2011, 10:06   #19
maverik-sg1
Supermodder
You can't seriously expect people to look at this and not burst out laughing? One simply cannot compare an Ferrari to an SSD, even the GTX590 is an aweful analogy, the GTX590 is 2x GPU's, 2x RAM, 2x Cooling, 2x RAM and when you look at that you can see/feel believe that there are more components being used and thus you feel as though you got what you paid for - SSD's are not getting larger capacities, they are becoming cheaper to manufacture but the general operation remains the same.
The only real performance gain for a normal PC user with SSD's are load times, the nature of the chips means that they degrade if you re-write too much to it (although this is a constant state of upgrade) - Raptors were premium drives back in the day, twice the price of a regular HDD (the HDD being double the capacity too).
Today 2TB drives are £60 so a 128gb SSD @ >£200 is an unreasonable amount of money, especially as the technology is now a tech node set smaller and cheaper to make, so my point is valid - I am all for paying a premium for a performance boost, but seriously the price ratio is far too high - of course I appreciate that development costs need to be absorbed for early adoptors, but we're past that now, I sincerely hope that one of these SSD providers realises this and start a trend
Old 19th May 2011, 10:15   #20
gcwebbyuk
Dib Dabbler
gcwebbyuk's Avatar
Laugh your way to the bank then thinking of the money you are saving not buying one...
You could have broken down my analogy about the ferrari further and explained about how many more parts they have etc etc. I merely used it to define a premium item.
Maybe one day ssd manufacturers will lower prices, but they don't "need" to until they feel they are losing money by people not buying them. Maybe Apple "need" to lower their prices so I will buy one, but I am sure they won't.
Stick with your hdd if you can't afford an ssd, you don't "need" one...
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
