#1 |
Modding and coffee
Project: XBOX Supreme
Sponsored by:
![]() Presenting: ![]() Hi fellow modders, it's kier again. I was looking a long time for this Lian Li case, the PC-XB01 I knew he was EOL, but there is always someone who has this one. So the search continued. Did this case is really a beauty and offers quite a few opportunities because Xbox is not really big and little more content, while the Lian Li is quite large. It therefore offers opportunities for an expanded water cooling setup to installon the CPU and the GPU Proccesor. After some research, I accidentally found a lovely Lili with a good friend: Gnoom172. Gnoom I owe you one Also He had a nice Watercooling set for the Xbox. Which is very sweet, but too little for me. I was then also noted by wwwicked a nice set from the famous Highflow shop ![]() It was the XBOX PRO Dual 40 Watercooling Kit Also very nice. But for a large case like i have now it’s actually too small So after some fitting and measuring, I found out that it is quite possible for the following parts: EK-Multioption RES X2 - 250 Advanced Laing DDC-1 MCP350 12V Black Ice GT Stealth 120 Black Nanoxia DX Series 120MM DX12 Hmm, I think the color combo is gonna be again black / green uv......I like it ![]() And 2 x a EK-Supreme HF Nickel CPU Block The Supreme's will fit nicely. I just need to mod the brackets, but this will definitely be nice With this beautiful List I went to Freddy, and Highflow is again prepared sponsor this build Freddy / Highflow thnx again very much To start with I have some photo’s taken from the beautiful Lili ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() These are the victims that I had left from a distant past. ![]() ![]() And I could not resist to test the little sweet set ![]() ![]() ![]() ![]() ![]() With the set is nothing wrong, but would like some more extreme than this, what will succeed. I know it for sure. So this is the start of a my new build. Grtzzz. And to be continued Last edited by kier; 28th May 2011 at 07:10. |
#2 |
Making You Feel Old Since 2010
Kier is back! This looks promising.
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2) "The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181 |
#3 |
Please... Just call me Stu.
Looking forward to this!
#4 |
The modding head is firmly back on.
Is back? I don't remember him leaving. That make 3 projects on the go now...lol
#5 |
Modding and coffee
![]() Update!!! Today and yesterday got some very nice stuff in of my belgium neighbors and High Flow Yes, I had some luck ............ Ac Ryan acryl still in there shop ![]() ![]() Uv green rules ![]() ![]() The size of the side panel taken ![]() And put some nice UV strips in the back ![]() Both sides and just the right size ![]() Placed the acryl and lights out ![]() Also placed the sidepanel ![]() And the effect is quiet nice ![]() ![]() The other side is coming the same with some adjustments, transparent window and hole in the side panel. And today got some nice stuff from Highflow The Black Ice GT Stealth 120 Black radiator ![]() A nice EK acryl top for the Laing DDC-1 MCP350 ![]() And the MCP350 pump ![]() And my favorite fan, the Nanoxia DX 120MM DX12 ![]() Also not to forget, the 2 EK-Supreme HF Nickel CPU Blocks ![]() Placed the EK acryl top ![]() And this is what's coming in xbox ![]() After all this picture taking, it's time to Dremel the bracket marked the pieces ![]() After some filing and grinding ![]() And put it together again ![]() ![]() Number 1 ![]() Both Supreme's side by side ![]() That's it for now. Weekend is coming more ![]() Grtzzz. Last edited by kier; 28th May 2011 at 07:10. |
#6 |
Addicted to modding.
looking good!!
#7 |
Hypermodder
I'm not sure why you'd want to watercool an xbox since the cooling would cost more than the xbox bt it will look eic! looking forward to this one
#8 |
Supermodder
Holy watercooled xbox!
Like it
#9 |
Modding and coffee
![]() Update!!! I found out that the radiator does not quite fit nicely. When i put him on the inside and place the fan on top it came too much into the case. So I moved him to the outside. First marked the holes for the fittings. ![]() After drilling the holes placed the radiator ![]() ![]() Placed BP Fittings ![]() And placed the fan ![]() ![]() Power on ![]() I love the looks of the Nanoxia uv green ![]() The total is still quite nice, the radiator is pretty slim. But not finished, something beautiful is coming my way from Mnpc , but that’s classified ![]() I also have painted the mounting hardware for the dvd and hdd black ![]() And I’ve started to work an the other side. In this I want the uv green edge back again. So again sawn another piece of green ![]() And then mod the original panel ![]() The intention is that there is a window in the same shape as the original Tape on both sides ..... ![]() Draw some lines ![]() And after some cutting and filing: ![]() Tape off and he's done. ![]() Now it is obviously not good to have a green window. Windows should be transparent, no color allowed. Therefore I used the green plate and did some more cutting First, mark and drill holes in the corners for the jigsaw ![]() ![]() And again some sawing ![]() ![]() First I placed and fixed with bolts to put everything in place ![]() ![]() After that I had a mold for the transparent acryl. ![]() And the result ![]() ![]() And put everything in place. All that work for a green edge, lol ![]() But I like it ![]() ![]() And the window just transparent ![]() Total shot...........you like? ![]() Next update, I’m gonna let you see the loop of the water cooling See you then, I hope Grtzzz. |
#10 |
Multimodder
It's simple but it looks great ! Great job on the window too, I would've solved it the same way
#11 |
Side bewb.
This looks awesome man!!
Subbed!!
__________________
Bewbs. |
#12 |
Bokehlicious!
Awesomez!
__________________
Check out my build: the Shuttle.
Q8300. 8gb XMS2. ATI 4650. Thermalright AXP-140. Samsung SpinPoint 1TB. 1U 300w PSU. Shuttle Case. MDPC-X Sleeving. |
#13 |
bit-tech sponsor
Nanoxia uv green fan was perfect choice
__________________
Shop Our Case Mod Store We Ship International Orders! Client Builds / FIREFLY PC / DISTRICT-9 PC / Official STAR TREK PC / WOLFENSTEIN PC / LANBOY APOCALYPSE PC / CodeMasters DiRT Showdown PC |
#14 |
I was planning on making my own 360 case, but this look so much better. I love the green UV accents. I thought I grew out of UV, but it's so nicely done here. Well done!
#15 |
Modding and coffee
![]() Update 30-05 Here we go again....update time Had the tray of the Xbox board disassembled and painted it black ![]() This is better than the aluminum look. ![]() Exchanged the original rivets for black ones ![]() scotch tape on it from damage the paint ![]() ![]() Nice flat and black ![]() Also did some brainstorming for the window and got some nice ideas presented. I am going to try engraving this time. So after some practice and see some movies For the lines I use a diamond point bit ![]() And for coloring / Shadow effect I used a diamond tip ![]() First some practice on a scrap piece and then ............. the real work with a steady hand you'll do quite well. The first angle ![]() In the dark, and an LED strip behind ![]() And yesterday, the second part done. Pretty funny this engraving ![]() ![]() And that was the update for now......you like it? I know I did Grtzzz. |
#16 |
Moderate Modder
its an xbox .. but dam its a very predddy xbox now: Congrats
__________________
Watering down PC's since 2009.... |
#17 |
Hypermodder
man this work log is evil
evil i say now i want to stuff a 360 in my stalled project wonderful |
#18 |
bit-tech sponsor
The etching is perfect, nice work kier
__________________
#19 |
Modding and coffee
![]() Update 02-06 Today did the final touches to the engraving. Like this engraving thing we gonna do this often ![]() ![]() ![]() ![]() The black painted parts are also placed back ![]() And I was brainstorming for the watercooled components. Pump and the 250mm Reservoir ![]() ![]() The EK Supreme's with BP fittings ![]() Reservoir next to it ![]() We fill under the xbox drive. This gonna make a plate with a hole for reinforcement ![]() He goes from the pump in to the first block ![]() ![]() And from the second block he goes into the radiator, and from the radiator back to the reservoir. And two last pictures of the hardware with window ![]() ![]() This is it!!! Grtzzz. |
#20 |
Multimodder
The etching on the window looks amazing!!!
+1 rep |
| Tags |
| water cooled xbox, xbox 360 mod |
| Thread Tools | |
| View Mode | |
