Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 27th May 2011, 07:45   #1
arcticstoat
Hypermodder
arcticstoat's Avatar
arcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysis
Corsair SP2200 Review
At 70, the SP2200 is much cheaper than Corsair's other speaker set, but can it still deliver?
http://www.bit-tech.net/hardware/201...p2200-review/1
__________________
Ben Hardwidge
Custom PC Editor
arcticstoat is offline   Reply With Quote
Old 27th May 2011, 08:22   #2
spazmochad
Supermodder
spazmochad is the Cheesecake. Relix smiles down upon them.spazmochad is the Cheesecake. Relix smiles down upon them.spazmochad is the Cheesecake. Relix smiles down upon them.spazmochad is the Cheesecake. Relix smiles down upon them.spazmochad is the Cheesecake. Relix smiles down upon them.spazmochad is the Cheesecake. Relix smiles down upon them.spazmochad is the Cheesecake. Relix smiles down upon them.spazmochad is the Cheesecake. Relix smiles down upon them.spazmochad is the Cheesecake. Relix smiles down upon them.spazmochad is the Cheesecake. Relix smiles down upon them.spazmochad is the Cheesecake. Relix smiles down upon them.
They look horrid!
spazmochad is offline   Reply With Quote
Old 27th May 2011, 08:32   #3
mi1ez
Game Boy Modder
mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!
Why do PC speaker companies insist on sitting their subs on padded feet? Give users a choice. I'd want spikes any day of the week!
__________________
The Angel Delights?
mi1ez is offline   Reply With Quote
Old 27th May 2011, 09:51   #4
do_it_anyway
Supermodder
do_it_anyway's Avatar
do_it_anyway has yet to learn the way of the Dremeldo_it_anyway has yet to learn the way of the Dremel
@mi1ez.
My kef 5.1 set comes with spikes on the sub, but I never truly understood why.
Whats the advantage/disadvantage of spikes vs rubber feet?
do_it_anyway is offline   Reply With Quote
Old 27th May 2011, 10:51   #5
fingerbob69
Hypermodder
fingerbob69's Avatar
fingerbob69 has yet to learn the way of the Dremelfingerbob69 has yet to learn the way of the Dremel
Note to author: the SP2500 is now £180 inc vat at scan.
__________________
Antec 902, Asus P6T se, i7-920 D0 oc@3.6ghz, Asaka Nero S, 6gb Corsair, Thermaltake 750w Evo Blue, MSI R9-280 OC @1065/1315, Asus Xonar DS, 2x 500gb Seagate HDD, Win7 hp, NEC ea231wmi, MS X4, Roccat Kova+
Cordless Mouseman optical ...deceased
XFX 4890 + Artic Twin Turbo Pro ...retired 26.10.2014
fingerbob69 is offline   Reply With Quote
Old 27th May 2011, 13:11   #6
mi1ez
Game Boy Modder
Originally Posted by do_it_anyway View Post
@mi1ez.
With a speaker, you want the enclosure to move as little as possible as it's shape will produce unusual harmonics and fire off in stupid directions if it vibrates.
Essentially you want the carefully designed driver to be doing all of the movement and creating all of the sound.
Spikes can allow speakers to be sat on floorboards through a carpet at best, or they can at least be much better anchored.
Due to the size of the driver and the amount of air it's shifting (you need to shift 4 times the amount of air to maintain the same volume for every octave lower your go in pitch (a halving of frequency)), only woofers and subs suffer from this problem.
The difference is noticable on my Mission floorstanders (which also have a chamber designed for filling with sand, again to prevent the speaker body moving)
Blimey, that was longer than I expected!
__________________
The Angel Delights?
Old 27th May 2011, 16:39   #7
Jipa
Avoiding the "I guess.." since 2004
Jipa's Avatar
Jipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run Crysis
@mi1ez.
SNIP WALL OF TEXT
Yeah, the thing is, none of this is going to really make a difference in a 70 set with a 6" bass cone in a housing made from pretty thin chip board.
Also I don't imagine PC-users really wanting their 70 bass to punch holes to their carpet or scratch the desk (keeping in mind how many keep the sub on the desk).
And after all this, if you still really care, you can just buy the spikes separately.
__________________
Half a dozen operational setups and truckloads of spare parts.
AllTheMods - MetkuMods - LedCalc - Flickr - BF:BC2
Jipa is offline   Reply With Quote
Old 27th May 2011, 19:41   #8
OCJunkie
OC your Dremel too
OCJunkie's Avatar
OCJunkie has yet to learn the way of the DremelOCJunkie has yet to learn the way of the DremelOCJunkie has yet to learn the way of the DremelOCJunkie has yet to learn the way of the Dremel
My thought exactly, tiny sub in a crap enclosure so doesn't need spikes. And sub on the desk, are you kidding? That's just blasphemy, you don't even deserve to have bass if you're gonna do that... :P
__________________
Gaming: CM 690 II A / XFX Pro850 XXX / GB 990FXA-UD3 / X4 955BE @3.8GHz - Hyper 212+ / 8GB Corsair Vengeance 1600 / XFX HD 6950 2GB - Twin Turbo Pro / OCZ Agility 3 60GB / WD Black 640GB & Green 1TB / 3x Acer 23in @5760x1080 Eyefinity
Media: Ultra Aluminus / Corsair TX750 / GB MA790X-UD4 / X2 7750BE @3GHz - Freezer64 Pro / 4GB OCZ Reaper HPC 1066 / HD 4670 1GB / WD Blue 320GB + Green 1TB & 1.5TB / Samsung 40in HDTV / Samsung HW-C560S / Harmony 300
OCJunkie is offline   Reply With Quote
Old 27th May 2011, 22:27   #9
Jipa
Jipa's Avatar
Just keep an eye on the "post your computer desk" and you'll find plenty. You'll also find endless 5.1. sets where all the satellites are neatly lined just under the monitor.
The most common limiting factor for computer audio is the user...
__________________
Old 28th May 2011, 11:11   #10
fingerbob69
Hypermodder
"You'll also find endless 5.1. sets where all the satellites are neatly lined just under the monitor. "
huh-oh ...guilty as charged m'lud. No further questions.
__________________
Old 2nd Sep 2011, 10:05   #11
Shayper09
Swimming in Deionized.
Shayper09's Avatar
Shayper09 has yet to learn the way of the Dremel
At 38.99 on TWO over at OcUK, this review has swayed me. I can't afford the sp2500s, so these will do
__________________
The Ghost
i5 2500k
GTX 580
Watercooled Phantom
Click For Build Log
Shayper09 is offline   Reply With Quote
Old 2nd Sep 2011, 10:06   #12
Zinfandel
I Mod, Therefore I Own
Zinfandel's Avatar
Zinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpit
38.66 on Scan with free delivery (OCUK might be that too, never used them).
Zinfandel is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
