Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 27th May 2011, 11:59   #1
Baz
I work for Corsair
Baz's Avatar
Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.
Investigating 3D Screens
We interview screen makers to see why we've only seen TN gaming screens, and what's in the future.
http://www.bit-tech.net/hardware/mon...g-3d-screens/1
Baz is offline   Reply With Quote
Old 27th May 2011, 12:42   #2
mi1ez
Game Boy Modder
mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!
Could we not strike a balance with IPS and a refresh rate of 80/90/100Hz?
__________________
The Angel Delights?
mi1ez is offline   Reply With Quote
Old 27th May 2011, 13:00   #3
PureSilver
E-tailer Tailor
PureSilver's Avatar
PureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpit
Shutter glasses alternate frames, effectively halving the visible refresh rate. Try dropping the refresh rate of your current screen down to 40/45/50Hz and you'll see why anything less than 120Hz is going to be a problem.
__________________
Intel Core i7 920 @ 3Ghz, Noctua NH-U12P SE, Asus P6T Deluxe V1, Corsair 12GB (6x2GB) 1600Mhz C8 @ XMP,
EVGA GTX-680, Corsair AX760, 2x Samsung SpinPoint F3 1TB, Lian-Li V1020R with 3x Noctua NF-P12 & 3x NF-P14FLX
2.4Ghz 13" unibody MacBook, 4GB RAM & 128GB Samsung SSD
PureSilver is offline   Reply With Quote
Old 27th May 2011, 13:12   #4
Xir
I Mod, Therefore I Own
Xir's Avatar
Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.
tellies can’t get away with using TN technology as they need to have sufficiently wide viewing angles for many people to watch them. They must therefore be using IPS or VA panels. However, Guenther from Dell pointed out to us that ‘It’s unfortunately a slow process to have the technology trickle down from TVs to PC monitors and also from Asia/Japan to Europe.’ In other words, all those flashy tellies are nicking the good 3D screen technology and us PC users will have to wait.
Ehmmm, no.
This part implies that TV screens, using fast IPS or VA panels (they're 3D capable) are superior to monitors, and tests just don't show this.
A 24" TV is cheaper than a 24" IPS monitor, and they've got the same digital input and resolution now. We'd all have one, right?
__________________
SN25P
A64 3700+ (San Diego)
2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T
X1800XT 512mb Sapphire
200GB Samsung SP2004C 24" Asus VW246H 1920x1080
Xir is offline   Reply With Quote
Old 27th May 2011, 13:14   #5
leveller
Yeti Sports 2 - 2011 Champion!
leveller has yet to learn the way of the Dremelleveller has yet to learn the way of the Dremelleveller has yet to learn the way of the Dremelleveller has yet to learn the way of the Dremelleveller has yet to learn the way of the Dremelleveller has yet to learn the way of the Dremel
If what Acer say is true about their 27" 3D then I might be convinced to ditch my current monitor later this year ...
leveller is offline   Reply With Quote
Old 27th May 2011, 13:58   #6
Glix
Left Thumb Stick in the mud.
Glix has yet to learn the way of the Dremel
Ehmmm, no.
Isn't there a difference in dot pitch though?
Glix is offline   Reply With Quote
Old 27th May 2011, 16:48   #7
HandMadeAndroid
That's handy.
HandMadeAndroid has yet to learn the way of the DremelHandMadeAndroid has yet to learn the way of the DremelHandMadeAndroid has yet to learn the way of the Dremel
If a movie needs all these bells and whistles then it's probably not worth watching.I know I get engrossed in a film if I'm enjoying it.
__________________
i7 3770k, Asus P8Z77-I , 16gb Patriot 1866 ddr3,EVGA 670FTW, Bitfenix Prodigy,crucial M4 128ssd,western digital black 2tb storage, wacom intuos/ i7 sandy bridge kobalt 17" laptop,120ssd, 8gb crucial ram, 500gb7200 WD storage drive, nvidia 555m 3gb/64gb iPad 2
HandMadeAndroid is offline   Reply With Quote
Old 27th May 2011, 17:22   #8
SMIFFYDUDE
Supermodders on my D
SMIFFYDUDE's Avatar
SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.
I'd rather they all went back to making 1920x1200 resolution screens.
__________________
i7 6700K|Sabertooth Z170 S|16GB Crosair Dominator Platinum 3200MHz|KFA2 GTX 1080 HOF|Creative Sound Blaster ZxR|Super Flower Leadex Gold 850W|Raijintek Triton|Corsair 780T|HP LP2475w|Speedlink Medusa 5.1|CM Storm Inferno|Windows 10
Steam: SMIFFY
SMIFFYDUDE is offline   Reply With Quote
Old 27th May 2011, 17:31   #9
tigertop1
Modder
tigertop1 has yet to learn the way of the Dremel
One point in favour of these 3D screens is that they run at 120Hz. 2D viewing improves a lot when you use it versus a 60Hz monitor. I have had two 3D screens now, A Samsung which was OK but would not run Blu-Ray unless one reset it to 60Hz. The Acer GD245HQ is simply the best screen I have ever had and it is pretty well pefect for gaming and watching 3D DVDs
tigertop1 is offline   Reply With Quote
Old 27th May 2011, 19:43   #10
OCJunkie
OC your Dremel too
OCJunkie's Avatar
OCJunkie has yet to learn the way of the DremelOCJunkie has yet to learn the way of the DremelOCJunkie has yet to learn the way of the DremelOCJunkie has yet to learn the way of the Dremel
Ok, I'm officially getting tired of this 3D week thing... what's next, shark week?
__________________
Gaming: CM 690 II A / XFX Pro850 XXX / GB 990FXA-UD3 / X4 955BE @3.8GHz - Hyper 212+ / 8GB Corsair Vengeance 1600 / XFX HD 6950 2GB - Twin Turbo Pro / OCZ Agility 3 60GB / WD Black 640GB & Green 1TB / 3x Acer 23in @5760x1080 Eyefinity
Media: Ultra Aluminus / Corsair TX750 / GB MA790X-UD4 / X2 7750BE @3GHz - Freezer64 Pro / 4GB OCZ Reaper HPC 1066 / HD 4670 1GB / WD Blue 320GB + Green 1TB & 1.5TB / Samsung 40in HDTV / Samsung HW-C560S / Harmony 300
OCJunkie is offline   Reply With Quote
Old 27th May 2011, 20:07   #11
tad2008
Supermodder
tad2008 has yet to learn the way of the Dremel
As far as 3D goes for monitors it is well behind the Real 3D TV technology that companies like LG, Samsung and Philips (to name a few) are already producing. Since I can plug a PC in via a VGA or ideally HDMI port and have happily done so on a 42" screen with good results, then I would have to say monitor manufacturers have some serious catching up to do.
tad2008 is offline   Reply With Quote
Old 27th May 2011, 21:23   #12
DbD
Supermodder
DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.
Personally I don't agree that colour is a major problem with these 3D TN panels - the LG W2363D is fine colour wise, deviation is low enough and colour gamut is high enough. Viewing angles mean you might loose a bit if it wasn't your primary screen but it is my primary screen so not a problem. Sure we always want better but the colours aren't bad, particularly if you use it for games which aren't true to life - it's not like you are trying to photo edit with the monitor.
DbD is offline   Reply With Quote
Old 28th May 2011, 05:40   #13
Grape Flavor
Multimodder
Grape Flavor's Avatar
Grape Flavor has yet to learn the way of the Dremel
Excellent article. People can blast 3D all they want but the problem in the end is the displays - you have to wear shutter glasses and the screen itself is poor quality. These are not inherently unfixable concerns.
Wait a few years until we have auto-stereoscopic displays with excellent color and all this "3D is a worthless gimmick" stuff is going to be looked back on as stuck-in-the-past nonsense. Only those with 3D-blindness will continue to defend such a position.
Grape Flavor is offline   Reply With Quote
Old 28th May 2011, 11:35   #14
Kris
Lord Lolwut
Kris has yet to learn the way of the DremelKris has yet to learn the way of the DremelKris has yet to learn the way of the Dremel
and who cares about 3d anyway? it's just a gimmick :P
__________________
Phenom X4 B50 @3.5GHz| 2x2GB DDR3 1333Mhz | Asus M4A79XTD Evo
Radeon 6950 2GB | 1TB + 500GB Samsung F3 | Akasa Omega | Akasa Nero
Kris is offline   Reply With Quote
Old 28th May 2011, 15:14   #15
FelixTech
Robot
FelixTech's Avatar
FelixTech has yet to learn the way of the DremelFelixTech has yet to learn the way of the Dremel
This is what ViewSonic specialise in, making the sum of the parts greater than the whole
Isn't the saying 'making the whole greater than the sum of its parts'? I hope Viewsonic aren't publicly stating that their products provide less performance than you'd expect from their parts >_<
FelixTech is offline   Reply With Quote
Old 28th May 2011, 18:18   #16
AstralWanderer
Banned
AstralWanderer has yet to learn the way of the DremelAstralWanderer has yet to learn the way of the DremelAstralWanderer has yet to learn the way of the DremelAstralWanderer has yet to learn the way of the Dremel
...it had already released 3D technology in the form of the RadiForce GS521-ST for mammography viewing...
Ah yes - here's a true 3D killer application for the gamer demographic - viewing mammograms.
AstralWanderer is offline   Reply With Quote
Old 28th May 2011, 20:34   #17
lp rob1
I *am* a Dremel
lp rob1's Avatar
lp rob1 is a Super Spamming Saiyanlp rob1 is a Super Spamming Saiyanlp rob1 is a Super Spamming Saiyanlp rob1 is a Super Spamming Saiyanlp rob1 is a Super Spamming Saiyanlp rob1 is a Super Spamming Saiyanlp rob1 is a Super Spamming Saiyanlp rob1 is a Super Spamming Saiyanlp rob1 is a Super Spamming Saiyanlp rob1 is a Super Spamming Saiyanlp rob1 is a Super Spamming Saiyan
I thought that the frame rate at which a game is considered 'playable' is 25 fps, and that most movies run at 30fps? So 60Hz refresh rate is pretty useless? As the image is actually changed every 2 refreshes / the screen has to wait for the image to change. I never really understood that.
__________________
The Linux Schools Project
lp rob1 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
