Reply
Thread Tools View Mode
Old 27th May 2011, 21:24   #1
LuZmA
Minimodder
LuZmA has yet to learn the way of the Dremel
FINISHED : Silverstone TJ 07 WaterCooling MOD
Hello!
First, i advise you my english is not the best, so excuse me if you see any mistake. i'm doing my best
This year i am going to do an aesthetic mod, i have chosen this case because it is perfect for what i want to do
1º Sponsor
2º Sponsor
3º Sponsor
4º Sponsor
5º Sponsor
6º Sponsor
7º Sponsor
8º Sponsor
UPDATES
WaterCooling
http://forums.bit-tech.net/showpost....66&postcount=4
Unboxing of the case
Inversion of mobo tray
Unboxing of the Gigabyte P67A-UD4 and an i5 2500K
http://forums.bit-tech.net/showpost....00&postcount=2
Topgrill made by a CNC machine
Some parts made by CNC
http://forums.bit-tech.net/showpost....8&postcount=10
OCZ VERTEX 3 120GB
http://forums.bit-tech.net/showpost....5&postcount=17
The side panel cut by a water jet cutting machine
http://forums.bit-tech.net/showpost....7&postcount=22
Mounting the parts
http://forums.bit-tech.net/showpost....4&postcount=24
The electronic
http://forums.bit-tech.net/showpost....7&postcount=27
Euskal Encounter 19
http://forums.bit-tech.net/showpost....3&postcount=33
3M DI-NOC Carbon Fiber Vinyl
http://forums.bit-tech.net/showpost....7&postcount=34
Material given by ColdZero
http://forums.bit-tech.net/showpost....5&postcount=36
Material given by Atlas Informática & Corsair
http://forums.bit-tech.net/showthrea...=210240&page=2
Last Pics
http://forums.bit-tech.net/showpost....7&postcount=43
Design
I have worked hard to do this design
As you can see, the silverstone temjin black 07 is (at least for me) a special case for work and modify
this is the topgrill, it is made of acrylic.
The faceplate, topgrill etc. will be done by a CNC machine.
LuZmA is offline   Reply With Quote
Old 27th May 2011, 21:29   #2
LuZmA
Minimodder
WaterCooling
here i have some watercooling components.
1/2" Primoxil PrimoFlex Pro 19/13
EK Waterblocks EK-Multioption RES X2 - 250 Advanced
CPU Block Supreme HF Plexi/Nickel
Radiator Swiftech MCR420
Laing DDC-1PlusT/12V and an ek x-top v2
It didn´t fit in my car !!
Thank god, i have a good trunk
Look at that effect
Well, it´s dremel time, as you can see, im going to invert the mobo tray
This is a good screwdriver xD
Well, i´m removing little by little the parts of the case
that screw was a pita, so i cut it with the dremel
I´m sorry about some pics, because i took it at night
I put some filler at these holes
Holy tape...
As you can see, i put some brass motherboard standoffs to elevate the mobo tray
Close and it´s done
Old 28th May 2011, 17:40   #3
ColdzeroTeam
Multimodder
ColdzeroTeam's Avatar
ColdzeroTeam has yet to learn the way of the Dremel
nice stuff
ColdzeroTeam is offline   Reply With Quote
Old 4th Jun 2011, 19:16   #4
LuZmA
Minimodder
Here is my brand new mobo,
Gigabyte P67A-UD4
And my new cpu too, an intel 2500K processor
The worst CPU fan, powered by nidec ...
Greetings
Old 4th Jun 2011, 19:56   #5
LuZmA
Minimodder
This is the topgrill, is made by a CNC machine
Greetings and comment please
Old 5th Jun 2011, 13:56   #6
Blooddrunken
In Flames we Trust
Blooddrunken's Avatar
Blooddrunken has yet to learn the way of the Dremel
The concept looks nice - I'm looking forward for this build.
Blooddrunken is offline   Reply With Quote
Old 5th Jun 2011, 16:13   #7
lilgoth89
Captin Calliope
lilgoth89's Avatar
lilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyan
hey, you mention your using a 420mm rad ? this would be 140x3 but the rad in your pic is a quad... wondering if you ment a 480mm
anyways. awesome looking project i love the tj07
its amazing people are still finding new things to do to it
lilgoth89 is offline   Reply With Quote
Old 5th Jun 2011, 18:47   #8
LuZmA
Minimodder
Originally Posted by ColdzeroTeam View Post
nice stuff
Thanks
No, i mention the name of the radiator, its length is about 55 cm approximately
http://www.sidewindercomputers.com/swmcqupo4xbl.html
xD
Well, i´m going to update this worklog soon
Greetings
Old 6th Jun 2011, 09:54   #9
lilgoth89
Captin Calliope
lilgoth89's Avatar
thats an oddly named radiator lol
i would have thought being a 120x4 it would be called a 480 ( like the naming of most rads )
Old 11th Jun 2011, 20:28   #10
LuZmA
Minimodder
New UpDaTe!
This is the part of fans
I have to sand it
Here is the topgrill, don´t worry, the plastic protector is below it
This is the frontal, it is made of 3mm aluminium
Old 12th Jun 2011, 00:36   #11
bagman
I Mod, Therefore I Own
bagman's Avatar
bagman is the Cheesecake. Relix smiles down upon them.bagman is the Cheesecake. Relix smiles down upon them.bagman is the Cheesecake. Relix smiles down upon them.bagman is the Cheesecake. Relix smiles down upon them.bagman is the Cheesecake. Relix smiles down upon them.bagman is the Cheesecake. Relix smiles down upon them.bagman is the Cheesecake. Relix smiles down upon them.bagman is the Cheesecake. Relix smiles down upon them.bagman is the Cheesecake. Relix smiles down upon them.bagman is the Cheesecake. Relix smiles down upon them.bagman is the Cheesecake. Relix smiles down upon them.
this is starting to shape up very nicely indeed
bagman is offline   Reply With Quote
Old 12th Jun 2011, 01:09   #12
Tna
Moda'a'foca modding power!
Tna's Avatar
Tna has yet to learn the way of the Dremel
very nice project, im folowing
Tna is offline   Reply With Quote
Old 12th Jun 2011, 12:24   #13
LuZmA
Minimodder
Thanks
Old 12th Jun 2011, 15:26   #14
LuZmA
Minimodder
Let´s make a little comparison between:
Sketchup
Reality
Greetings!
Old 12th Jun 2011, 15:46   #15
ColdzeroTeam
Multimodder
that front panel looks pretty good
__________________
Finished Projects -> Casemod: Little Big 840 ATCS || Casemod: Corsair 700D R.O.G. 'R US MOTM Nominee || Casemod: Snow White || Casemod: TJ07 Classified ||
Work in Progress -> Casemod: TJ07 Black & White ||
Old 12th Jun 2011, 16:59   #16
socal-mods
What's a Dremel?
socal-mods has yet to learn the way of the Dremel
wow! nice renders
socal-mods is offline   Reply With Quote
Old 17th Jun 2011, 14:22   #17
LuZmA
Minimodder
Well, it's time to update this thread
This is the 4º sponsor
ProSilent PC
And as you can see, i have a new SSD
OCZ VERTEX 3 120GB
Greetings
Old 17th Jun 2011, 20:01   #18
Toxicgrx
What's a Dremel?
Toxicgrx has yet to learn the way of the Dremel
Luzma you know I really like this mod.
I hope to see completed in the Euskal Encounter 19 in July.
ReGards!
Toxicgrx is offline   Reply With Quote
Old 20th Jun 2011, 11:45   #19
Hawkest
I got some 4GB new RAM
Hawkest's Avatar
Hawkest has yet to learn the way of the DremelHawkest has yet to learn the way of the Dremel
I'll be keeping a close on this, its looking very good!!!
__________________
Win 7 64-bit - Silverstone RV02 - Q6600 @ 2.4 - 4GB Kingston Hyperx 8500 - Asus Striker II Formula - BenQ G2220HD - BFG GTX260 @ Core-700, Shader-1500, Mem-12000 with an Artic Cooler GTX Pro
Hawkest is offline   Reply With Quote
Old 20th Jun 2011, 16:00   #20
bruce_rob
Supermodder
bruce_rob's Avatar
bruce_rob has yet to learn the way of the Dremel
looks amazing
cant wait to see the progress
loving the vertex 3 (dribble)
bruce_rob is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
