Old 31st May 2011, 14:32   #1
Claave
You Rebel scum
Claave's Avatar
Claave has yet to learn the way of the DremelClaave has yet to learn the way of the DremelClaave has yet to learn the way of the Dremel
Computex 2011 News
This is a hub article to let you easily find all our Computex news, previews, gossip and first-looks. We'll be updating it throughout the week, so check back, either through this thread or the widget in the right-hand column of the home page.
http://www.bit-tech.net/hardware/201...ex-2011-news/1
Claave is offline   Reply With Quote
Old 31st May 2011, 17:45   #2
the_kille4
Chaos will rule da world.eventually
the_kille4 has yet to learn the way of the Dremel
If you look over at vr-zone.com you can get alot of stuff there as well...
http://vr-zone.com/articles/noctua-s...l/12474-2.html
this is regarding the cpu socket of the LGA 2011... the above link shows that it is different to the LGA 1366 and therefore does it mean that the current range of LGA 1366 based coolers are not compatible with the new one?
__________________
Headphones: Grado SR325is | Oppo PM-3
Mic: Antlion ModMic 2.3 | Audio-Technica AT2020
Mixer: Alesis MultiMix 8 USB FX
Speakers: M-Audio Studiophile AV 40
the_kille4 is offline   Reply With Quote
Old 31st May 2011, 17:52   #3
the_kille4
have you looked at this?
http://vr-zone.com/articles/asus-dan...led/12449.html
its CRAZY... i don't see how it would work without a Xeon processor... however if you look at the LGA 2011 slot there are effectively 8 channels... totaling 64GB? of high performance ram....
__________________
Old 31st May 2011, 17:58   #4
the_kille4
And I also want some insight to whether the Z68, M-ITX flavoured motherboard from Zotec would be available soon...
__________________
Old 1st Jun 2011, 01:21   #5
Lizard
@ Scan R&D
Lizard's Avatar
Lizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run Crysis
There are loads of mini-ITX Z68 boards here at the show from loads of companies, not just Zotac. The schedule for each company is different, but they should start going on sale in the next few weeks/months.
Lizard is offline   Reply With Quote
Old 1st Jun 2011, 17:46   #6
okenobi
Ultramodder
okenobi's Avatar
okenobi is definitely a rep cheat.okenobi is definitely a rep cheat.okenobi is definitely a rep cheat.okenobi is definitely a rep cheat.okenobi is definitely a rep cheat.okenobi is definitely a rep cheat.okenobi is definitely a rep cheat.okenobi is definitely a rep cheat.okenobi is definitely a rep cheat.okenobi is definitely a rep cheat.okenobi is definitely a rep cheat.
Why is this article/thread not my source for info on Llano? In fact, why is there virtually zero mention of Llano throughout BT?
I'm thinking about a new portable device of some kind and I NEED info!
okenobi is offline   Reply With Quote
Old 3rd Jun 2011, 11:31   #7
tonyd223
king of nothing
tonyd223 has yet to learn the way of the Dremel
You're guys don't seem to be doing much posting from Computex... wonder what they're doing instead?
tonyd223 is offline   Reply With Quote
Old 29th Jul 2011, 13:37   #8
SolidShot
Supermodder
SolidShot has yet to learn the way of the DremelSolidShot has yet to learn the way of the Dremel
they have found the 3d pron section and arent mentioning it to try and keep it a secret?
SolidShot is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
