Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 31st May 2011, 18:55   #1
Claave
You Rebel scum
Claave's Avatar
Claave has yet to learn the way of the DremelClaave has yet to learn the way of the DremelClaave has yet to learn the way of the Dremel
Asus shows LGA2011 concept board
One LGA1366 and one LGA2011 socket allows a perfect upgrade path, according to Asus
http://www.bit-tech.net/news/hardwar...oncept-board/1
Claave is offline   Reply With Quote
Old 31st May 2011, 18:59   #2
HourBeforeDawn
a.k.a KazeModz
HourBeforeDawn has yet to learn the way of the DremelHourBeforeDawn has yet to learn the way of the Dremel
ya its interesting how they are diving the ram between the CPU, in reason for that? I havent been following the 2011 as much as I have been following bulldozer.
__________________
Current Rig: Project STEALTH
DimasTech Test Bench Black ICE Triple 120 Rad Dual Bay Res/Pump DD Fill Port & Res D-Tek FuZion 2 CPU Block ASUS M3A79-T Deluxe Mobo AMD Phenom II 3ghz @ 4ghz 8gb DDR2-1100 Memory (2) AMD 6870 XFire (2) WD Black 640gb Raid 0 (2) 1.5TB SEAGATE Blu-Ray/HD DVD Drive ASUS XONAR DX2 30" DOUBLESIGHT LCD (2) 23" ASUS LCD ZALMAN 8 FAN CONTROLLER (4) NOCTUA P12 (2) NOCTUA P14 1000W ZALMAN PSU WINDOWS 7 PRO 64
HourBeforeDawn is offline   Reply With Quote
Old 31st May 2011, 19:00   #3
Valinor
Multimodder
Valinor has yet to learn the way of the Dremel
That sure looks.. interesting.
I am of course talking about the Republic of Gamers tattoo on that person's arm.
Valinor is offline   Reply With Quote
Old 31st May 2011, 19:18   #4
thetrashcanman
Angel headed hipsters
thetrashcanman's Avatar
thetrashcanman is almost as Godly as yodasarmpitthetrashcanman is almost as Godly as yodasarmpitthetrashcanman is almost as Godly as yodasarmpitthetrashcanman is almost as Godly as yodasarmpitthetrashcanman is almost as Godly as yodasarmpitthetrashcanman is almost as Godly as yodasarmpitthetrashcanman is almost as Godly as yodasarmpitthetrashcanman is almost as Godly as yodasarmpitthetrashcanman is almost as Godly as yodasarmpitthetrashcanman is almost as Godly as yodasarmpitthetrashcanman is almost as Godly as yodasarmpit
not the first time i've seen it, but look at the size of that socket!
__________________
is rebuilding his rig.... Asus Maximus IV Extreme/ i5 2500k @4.4Ghz/ EVGA 780 Classified/ 2 x Corsair 960Gb Neutron XT SSD / Mac Pro Tower
thetrashcanman is offline   Reply With Quote
Old 31st May 2011, 19:26   #5
TAG
Supermodder
TAG's Avatar
TAG has yet to learn the way of the DremelTAG has yet to learn the way of the Dremel
What's this X68 chipset you're on about? I thought Z68 was for 1155 and X79 was for 2011?
edit: hmm so x68 is indeed for 2011.
So many chipsets, crisscrossed references between ranges. Thank you intel, as if your confusing CPU name scheme wasn't enough already.
edit2: actually I've just read X68 might get skipped alltogether in favour of Z79?
__________________
[---- Project Huge NAS ----]
[---- My Big & Heavy Lian-Li Project (on hold) ----]
Asus P8P67 Pro # Intel i5 2500k # 2x ASUS 6950 2GB # 2x4GB Corsair Vengeance 1600 CAS9
Crucial C300 128GB # 5x Samsung F1 1TB
Corsair TX850 # Coolermaster CM690 II Advanced # 3x Dell U2410 monitors
TAG is offline   Reply With Quote
Old 31st May 2011, 19:32   #6
vdbswong
It's a Hedgehod
vdbswong's Avatar
vdbswong - may the hammer of Bindi be bestowed on youvdbswong - may the hammer of Bindi be bestowed on youvdbswong - may the hammer of Bindi be bestowed on youvdbswong - may the hammer of Bindi be bestowed on youvdbswong - may the hammer of Bindi be bestowed on youvdbswong - may the hammer of Bindi be bestowed on youvdbswong - may the hammer of Bindi be bestowed on youvdbswong - may the hammer of Bindi be bestowed on youvdbswong - may the hammer of Bindi be bestowed on youvdbswong - may the hammer of Bindi be bestowed on youvdbswong - may the hammer of Bindi be bestowed on you
Originally Posted by TAG View Post
What's this X68 chipset you're on about? I though Z68 was for 1155 and X79 was for 2011?
I got confused as well...
Everywhere else i've seen mentions the X79 Chipset for LGA2011...
Can someone explain ?
vdbswong is offline   Reply With Quote
Old 31st May 2011, 20:04   #7
cdb
No comment
cdb has yet to learn the way of the Dremelcdb has yet to learn the way of the Dremelcdb has yet to learn the way of the Dremelcdb has yet to learn the way of the Dremelcdb has yet to learn the way of the Dremel
I can't see the point of the board apart from comparing lga1366 and lga2011.
Now if they were to build a dual lga2011 board, that could be interesting.
How does it compare sizewise to the SR-2 board?
cdb is offline   Reply With Quote
Old 31st May 2011, 20:11   #8
Aracos
Ultramodder
Aracos's Avatar
Aracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run Crysis
Have you seen the size of the CPU sockets? If that's what they'll look like does this mean we can expect MASSIVE cpu's?
__________________
Originally Posted by Ubisoft CEO
Our clear goal today is to come more regularly with our top brands
Ragnarok: i5 750 @ 3200MHz | Titan Fenrir | MSI P55-GD65 | 8GiB Vengence 1600MHz CAS 9 | 1GiB 6950 DirectCU II | 60GB Crucial M4 | Samsung F3 500GB | Samsung F3 1TB | Seasonic X-750 | X-Fi XtremeGamer | HAF932 | Win 7 Pro | openSUSE
Aracos is offline   Reply With Quote
Old 31st May 2011, 20:49   #9
Chicken76
Hypermodder
Chicken76's Avatar
Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!
Hmmm... so I'm guessing today's coolers won't be compatible with LGA2011, eh?
Chicken76 is offline   Reply With Quote
Old 31st May 2011, 21:28   #10
Pookie
Level 0
Pookie's Avatar
Pookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming Saiyan
Debit card at the ready
__________________
Unlimited Fibre Broadband 38Inc Per month including line Rental!
http://pulse8broadband.co.uk/fibreoptic-broadband
Pookie is online now   Reply With Quote
Old 31st May 2011, 21:54   #11
Altron
LIKE A BAUCE!!!!
Altron's Avatar
Altron has yet to learn the way of the DremelAltron has yet to learn the way of the DremelAltron has yet to learn the way of the DremelAltron has yet to learn the way of the DremelAltron has yet to learn the way of the DremelAltron has yet to learn the way of the DremelAltron has yet to learn the way of the DremelAltron has yet to learn the way of the Dremel
No idea why anyone would want this. It probably costs more than a 1366 board and a 2011 board, and will require you to have a EATX case.
This looks to be the latest in a long line of miserable failures that were designed to "make upgrading easy" - i.e. the DDR2 and DDR3 boards, the AGP and PCIe boards, and the 775 + 939 dual socket board. They 'kinda' worked, but couldn't do either thing as well as the correct mobo, plus they cost as much as both.
For someone who has a 1366 rig already, and plans to upgrade to 2011, this is a terrible idea. It would be cheaper for them to just wait for 2011 to come out and buy a 2011 motherboard, and continue using their 1366 motherboard.
__________________
If this post is not up to your standards, please lower your standards.
e^i(pi)+1=0
Altron is offline   Reply With Quote
Old 31st May 2011, 21:56   #12
Ayrto
Supermodder
Ayrto should be considered for presidentAyrto should be considered for presidentAyrto should be considered for presidentAyrto should be considered for presidentAyrto should be considered for presidentAyrto should be considered for presidentAyrto should be considered for presidentAyrto should be considered for presidentAyrto should be considered for presidentAyrto should be considered for presidentAyrto should be considered for president
Interesting concept, but it'd surely need v complex drivers ...bugs?
*waits for* But can it run Crysis?
Ayrto is offline   Reply With Quote
Old 31st May 2011, 23:11   #13
TWeaK
Supermodder
TWeaK's Avatar
TWeaK has yet to learn the way of the Dremel
Props to Harry (it was Harry, wasn't it?) for scooping the quad-channel memory!
TWeaK is offline   Reply With Quote
Old 1st Jun 2011, 00:35   #14
Autti
Multimodder
Autti has yet to learn the way of the Dremel
Its X79 for LGA 2011 CPU's also there is heaps of photos of the new 2011 boards already.
__________________
Zen and the Art of Modding: an Amateur Foray
2 days since last hospital visit
Autti is offline   Reply With Quote
Old 1st Jun 2011, 00:35   #15
bagman
I Mod, Therefore I Own
bagman's Avatar
bagman is the Cheesecake. Relix smiles down upon them.bagman is the Cheesecake. Relix smiles down upon them.bagman is the Cheesecake. Relix smiles down upon them.bagman is the Cheesecake. Relix smiles down upon them.bagman is the Cheesecake. Relix smiles down upon them.bagman is the Cheesecake. Relix smiles down upon them.bagman is the Cheesecake. Relix smiles down upon them.bagman is the Cheesecake. Relix smiles down upon them.bagman is the Cheesecake. Relix smiles down upon them.bagman is the Cheesecake. Relix smiles down upon them.bagman is the Cheesecake. Relix smiles down upon them.
i don't think we will ever see this on the market because of the layout of the board, because look at where the ram slots for the 2011 cpu, 4 of them are in line with where the PCI slots are, so when ivy bridge does come out you won't be able to play on it, and if you have a motherboard like this you probably have more than 1 or 2 graphics cards
bagman is offline   Reply With Quote
Old 1st Jun 2011, 02:15   #16
Shayper09
Swimming in Deionized.
Shayper09's Avatar
Shayper09 has yet to learn the way of the Dremel
Can I haz plox? Along with 2 ASUS Mars 2's?
Kthxbai
__________________
The Ghost
i5 2500k
GTX 580
Watercooled Phantom
Click For Build Log
Shayper09 is offline   Reply With Quote
Old 1st Jun 2011, 04:39   #17
slothy89
MicroModder
slothy89's Avatar
slothy89 has yet to learn the way of the Dremel
Can they make a board that allows both 1366 and 2011 CPUs in the same socket? Now that would be a good selling point! (even if it is an AMD invention)
__________________
CPU : Intel i7 2600K @4.5GHz ~ Cooler : Zalman CNPS 9900MAX Blue
GPU : 2xSLI Gainward GTX460 1GB GLH ~ PSU : Superflower 800W Modular
Mobo : ASUS P8P67 Pro B3 ~ RAM : 4x4GB (16GB) Corsair Vengeance 1600 @ 9-9-9-24
Case : Zalman Z9+ (filled with Xigmatek XLF fans 120mm&140mm)
Storage : 120GB OCZ Vertex 3 Max IOPS - 1TB WD Caviar Black SATA III
slothy89 is offline   Reply With Quote
Old 1st Jun 2011, 05:19   #18
Bindibadgi
Am I out of touch?
Bindibadgi's Avatar
Bindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming Saiyan
1) It's X79
@ Slothy - Same socket? No.
@ Chicken - No. New coolers.
@ cbd - Dual 2011 will come in time, although exclusively workstation.
The two CPUs talk to each other via QPI, and the 2011 CPU then provides the PCI-E or talks to the X79 to provide the SATA etc
__________________
The bitterness of poor quality remains long after the sweetness of low price is forgotten.
Bindibadgi is offline   Reply With Quote
Old 1st Jun 2011, 09:31   #19
l3v1ck
really joined on Dec 24th 2004.
l3v1ck's Avatar
l3v1ck has yet to learn the way of the Dremell3v1ck has yet to learn the way of the Dremell3v1ck has yet to learn the way of the Dremell3v1ck has yet to learn the way of the Dremell3v1ck has yet to learn the way of the Dremell3v1ck has yet to learn the way of the Dremel
Would youi be able to use both at the same time or is this designed to let you use 1366 now, then swap to 2011 later on?
If it's the later then it's a bit pointless, as I'm sure this board will comand a huge price premium at the moment.
__________________
Originally Posted by Sifter3000
We swung the banhammer in his little stupid spamming face
The old Dennis Forums (CPC, PC Pro, Mac User etc) - Meeting Place lives on. You're welcome to visit it HERE
l3v1ck is offline   Reply With Quote
Old 1st Jun 2011, 09:46   #20
Bindibadgi
Am I out of touch?
Bindibadgi's Avatar
No you have to use the LGA2011 chip as the 1366 connects to it. It basically means you can throw out your X58 board and still use the 1366 Core i7
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
