News LGA2011 motherboard showcase
Discussion in 'Article Discussion' started by arcticstoat, 2 Jun 2011.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
  2. Tyrmot
    Tyrmot Minimodder
    12 Mar 2008
    Why yes, yes I did. I think my aging Core2 dual-core will probably just about see me to the release of Ivy Bridge in Q1... Though as ever the temptation to upgrade is hard to ignore...
  3. Hawkest
    Hawkest I got some 4GB new RAM
    22 Jun 2009
    i want one now!!!!
  4. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    It worries me slightly that there's two banks of memory on each side of the CPU. Bloody hell, is that the reference Intel design, or something?
  5. Claave
    Claave You Rebel scum
    29 Nov 2008
    We suspect it's for the quad-channel memory that LGA2011 CPUs are rumoured to support. I think Intel is still cagey on confirming that, however.
  6. thelaw
    thelaw What's a Dremel?
    10 Sep 2010
    Someone broke the link
  7. SpAceman
    SpAceman What's a Dremel?
    1 Nov 2010
    I was considering an LGA2011 Ivy Bridge upgrade along with a new GPU... But I am thinking of waiting a little longer. So far my C2Q Q9400 with GTX 260+ is still doing well enough. I know its borderline but with the CPU sitting at 3.2GHz (from 2.66) and the GPU only having a small boost too, I haven't found anything to be too much to run at max settings apart from Crysis at later points and Arma 2. I could always wait for Haswell...
  8. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    Intel still hasn't confirmed it, but my suspicion (from last year when I saw a leaked system diagram) is pretty much 100% now as several memory vendors are already working on quad-channel kits for release when LGA2011 hits.
  9. Bede
    Bede Minimodder
    30 Sep 2007
    I just can't see the point in waiting until the next hardware iteration for most gamers. The i5-2500k is not going to be a bottleneck for a gaming system for most of the next decade imho (especially with its OC'ing abilities).
  10. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    but we want moar POWER!
    true its pretty useless for gamers atm, but people will still buy it because its new and shiny and nice (cant blame them). if you're running 2x 6990 or something of that ilk it could be useful.
    on another not, how are these ram slots going to effect big CPU coolers? i can see tall heatspreaders being a thing of the past
  11. mclean007
    mclean007 Officious Bystander
    22 May 2003
    I suspect that's probably right. Putting the 4 banks 2 on each side of the socket is probably to minimise the length of the traces, as that may determine maximum speed. The traces to the nearer banks will doubtless be folded back on themselves a few times to make sure they are all of equal length. Motherboard design is a fearsomely complex process!
  12. mclean007
    22 May 2003
    For the mainstream, I absolutely agree that LGA1155 will be sufficient for the foreseeable future (but "most of the next decade" is hella long in technology terms so I'm sure we'll see a replacement to LGA1155 before then), but then LGA2011 is a replacement for LGA1366, which was never a mainstream chipset anyway. It's for workstations, power-users and elite enthusiasts who want / need the best of kit. The additional memory bandwidth of a quad channel design would likely be great for people doing heavy number crunching in photo / video editing, for example, or for certain server applications like highly loaded databases.
  13. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    that looks awesome, but it also looks like asus haven't finished there boards, yellow pcb? *VOMITS*
  14. McSteel
    McSteel Shape Memory Alloy
    5 May 2010
    These are all just basic templates, there's plenty of time for fine-tuning... I wouldn't worry about the PCB lacquer color just yet ;)
  15. Christopher N. Lew
    Christopher N. Lew Folding in memory of my father
    23 Apr 2009
    Molex sockets on the Asus boards? They can not be serious :nono:
  16. Hawkest
    22 Jun 2009
    I doubt this is a finished board the prototypes always have random things on them!
  17. Paul2011
    Paul2011 Minimodder
    20 Jul 2010
    i have personally put on hold my new build so i can go LGA2011, i just hope that we get chips like the k brand that o/c like mad (i havn't read up on it so if there are please let me know) my current rig is useless now for gaming (c2d e7400 & 9600GSO) but it will mean i'll have plenty of games to keep my entertained when i finally do upgrade.
  18. McSteel
    5 May 2010
    That Molex is probably there to provide additional power to the PCI-E slots in multi-GPU setups. Namely, those slots receive their power from the main ATX power connector (20+4-pin), which only has one 12V wire. Each slot is supposed to provide up to 75W of power, by PCI-E specification. Imagine running a 4-way SLI or CF and having 300W (25A) drawn from one 18AWG (or 16AWG, best-case scenario) wire. Not good. 18AWG can carry up to 14A continuous (while heating up to 80-or-so °C), and 16AWG can carry up to 18A continuous. Molex is also not a very good solution, seeing how it too has only one 12V wire. Sill, 2 wires at 25 amps means that even an 18AWG wire would suffice. There is also the question of motherboard traces and their carrying capacity... Perhaps putting a 6-pin PCI-E connector there would be best/safest (just as MSI does on some of it's boards), this way the power traces can be shorter and going from multiple sources, and there are more wires in play, meaning lower voltage drops and less chance of melting the insulation...
  19. Shayper09
    Shayper09 Swimming in Deionized.
    14 Jun 2010
    Release of these coincides with the next part of my student loan :)
    I hope to god XSPC release a 2011 faceplate for the RASA, my water-cooling is primed and ready ;)
  20. tonyd223
    tonyd223 king of nothing
    12 Nov 2009
    what, my single core athlon 64 939 3500+ is out of date? when did that happen?
Tags: Add Tags
