Reply
Thread Tools View Mode
Old 2nd Jun 2011, 16:18   #1
mnpctech
bit-tech sponsor
mnpctech's Avatar
mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.
Official Star Trek Case Mod: "TRICORDER CHIC" Listed on Ebay by Winner for $8,000...
A Star Trek case mod theme that will be stylish.. Er, I mean Chic! and we've only got 12 days to get it finished!
edit: Deadline extended to July 1st, for both cases!
Maximum PC has a presence at Comic-Con every year as an outreach opportunity—to let the hardcore comics and sci-fi fans know that PC enthusiasm goes hand-in-hand with that kind of fandom. This year we’re using our booth as an opportunity to show the fans at Comic-Con how awesome a great case-mod can be and how PC geekery and sci-fi enthusiasm can meet in a beautiful way. So we’ve hired the best guys in the business to design and build an awesome Star Trek-themed PC, and we’ll be giving one away at Comic-Con and the other one will go to David Gerrold in exchange for some writing he’s doing for us in relation to Comic-Con. - Nathan Edwards, Senior Associate Editor
Conceptual Designer: Mike Okuda is graphic designer who has worked on Star Trek series since the 1980s and is responsible for much of its visual style, including the LCARS interface as seen on Next Generation.
Matt Jefferie's original design of the Tricorder served as Mike's inspiration for styling cues on the "Tricorder Chic" computer case design. We could have scratch built a PC that looked just like the Tricorder, but David wanted an actual computer case instead with specific utilitarian features like hot swap bays and a compartment for his Tribbles.
3D design of "Tricorder Chic" by Dave LaLopa
Top panel and storage compartment
Top panel will be milled from 2" thick 6061 aluminum
This Lancool K-58, manufactured by Lian Li will sacrifice it's chassis to this project.
Lancool K-58 chassis will be painted Matte Black Enamel.
Using Rounded side hand file to smooth the cut edges.
Using Red Scotch-Brite pad to scuff the surface in preparation for Primer base coat.
Lancool K58 chassis painted Matte Black Enamel (1 for david, 1 for comic-con)
Machined aluminum computer case feet, http://www.mnpctech.com/ITX_MATX_Com...Case_Feet.html
Machined aluminum computer case feet with grooved edges.
Black anodized thumbscrews, http://www.mnpctech.com/thumbscrew.html
Black PSU and fan wires cable sleeve kit
Cable Management Grommets, http://www.mnpctech.com/PC_Cable_Rub..._Grommets.html
The aluminum feet are machined on CNC Lathe, http://www.mnpctech.com/ITX_MATX_Com...Case_Feet.html
The bare aluminum is nice contrast to the Matte Black.
#10 x 5/8" Black Oxide Fan Screws, http://www.mnpctech.com/thumbscrew.html
Screws will be used in conjunction with fan silencing rubber grommets, http://www.mnpctech.com/FanGrommet.html
#10 x 5/8" Black Oxide Fan Screw inserted in rubber grommet
We are installing Yate Loon Blue LED 140mm cooling fan
http://www.mnpctech.3dpixelnet.com/p...ase_mod9z5.jpg
Lian Li Tool-Less PCI Card Holder, 7 x PCI Holder. Works with many Lian Li cases or other modified cases. Specifications: Tool-Less PCI Card Holder, 7 x PCI Holder. Designed for Most of Lian Li Cases. Dimension (W)70mm x (H)145mm x (D)30mm
Add your own Caption!!!
6/7/11
Worked on the side panel pre-assembly today> The inner wall of the steel panel needs to be painted Black.
Updated 6/22/11, http://forums.bit-tech.net/showthrea...=210616&page=5
The first of 2 lower half of the front bezel is finished. Next step is making the upper half and the compartment door covers.
I'll be sleeving the Sentry this Silverstone FP34S Premium 3.5inch Bay Card Reader & Front I/O combo module with our Black PSU and fan wires cable sleeve kit for everything. (8 mil PolyEthylene Terepthalate (PET) monofilament yarns)
Finished the front Hot Swap bay compartment doors last night. These will be hinged with 1/8" rod. The 1/8" Opaque Red acrylic plates will attach to the back side of the door. Still need to make door handles.
still need to make upper half of bezel, top panel, front grill, emblem and david's name plate.
Surething, doing those this afternoon. I did finish the side panel inlays last night
the Mill has a Belly ache....
Here is the entire front bezel assembly. The Silverstone FP34S Premium 3.5inch Bay Card Reader & Front I/O combo module mounts at 45 degree angle in the top panel. It's held in place with m3 set screws, inserted into countersunk holes on each side of the top panel. David chose this model mainly for it's card reader and headphone jack. It's from performance-pcs here It will be mounted in the new top panel.
Upper portion of the front bezel attaches to the top panel with "key" style fasteners for 8/32 machine screws..
David's signature name plate..
hey guys! 1st one arrived safely to Maximum PC Magazine's offices today... will ship 2nd with tribbles on Monday.. Here are final photos of 1st one before packing it.
__________________
My GPU support brackets We Ship International Orders!
mnpctech is offline   Reply With Quote
Old 2nd Jun 2011, 16:37   #2
zeBriukas
What's a Dremel?
zeBriukas's Avatar
zeBriukas has yet to learn the way of the Dremel
This will be badass
zeBriukas is offline   Reply With Quote
Old 2nd Jun 2011, 18:05   #3
bulldogjeff
The modding head is firmly back on.
bulldogjeff's Avatar
bulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyan
This is going to be interesting, especially with the time scale on it.
bulldogjeff is offline   Reply With Quote
Old 2nd Jun 2011, 18:45   #4
mnpctech
bit-tech sponsor
mnpctech's Avatar
Thanks for tuning in guys!
the chassis was piece of cake, the shell, well, thats where things get interesting...heh
__________________
Old 2nd Jun 2011, 19:07   #5
jrs77
theorycrafting
jrs77's Avatar
jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.
Sure
StarTrek themed case is allways welcome
__________________
...and allways remember, that the world is an orange!
Cooltek/Jonsbo U1 | Silverstone SX500-LG | Noctua NF-R8 Redux 1200
Gigabyte H97N-WiFi | intel i7-5775C | Noctua NH-D9L | Crucial Ballistix 16GB DDR3L1600 | Crucial MX200 250GB | 2.5" WD AV 1TB
jrs77 is offline   Reply With Quote
Old 2nd Jun 2011, 21:02   #6
mnpctech
bit-tech sponsor
mnpctech's Avatar
Awesome!!! ROFL!
Ok, I couldn't help myself and found another...
__________________
Old 2nd Jun 2011, 21:26   #7
jrs77
theorycrafting
jrs77's Avatar
I could do such things all day long
__________________
Old 2nd Jun 2011, 21:44   #8
bulldogjeff
IT'S MODDING JIM BUT NOT AS WE KNOW IT.
Old 2nd Jun 2011, 22:03   #9
Nanosec
absit iniuria verbis
Nanosec's Avatar
Nanosec has yet to learn the way of the DremelNanosec has yet to learn the way of the DremelNanosec has yet to learn the way of the DremelNanosec has yet to learn the way of the Dremel
Damnit Jim, I'm a Doctor not a PC Enthusiast !!
This is looking epic, would be nice if they also hired you to do a scratch build of a tricorder like what was mentioned in the article.
Sub'd
Nanosec is offline   Reply With Quote
Old 3rd Jun 2011, 01:27   #10
mnpctech
bit-tech sponsor
mnpctech's Avatar
Nice one Jeff!
Would have loved to Nano!
__________________
Old 3rd Jun 2011, 03:31   #11
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
"No, Jim. I don't want to know how many speeds it has."
Good! You got everything sorted out finally. It should be fun to see you mill some REAL billet this time.
Edit: For the 2nd pic: "I hate him because my wife had a checkered-colored baby!"
...I'm going to hell.
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 3rd Jun 2011, 03:45   #12
Warsmith
Enginseer
Warsmith has yet to learn the way of the Dremel
Was the kid's name Chess-ter?
Warsmith is offline   Reply With Quote
Old 3rd Jun 2011, 11:41   #13
mnpctech
bit-tech sponsor
mnpctech's Avatar
LOL! nice ones guys
I'm picking up following material list today.... 6061 aluminum
1.938 thick x 18.1875 x 8.25 (2 pieces)
1.5 thick x 8.25 x 5.906 (2 pieces)
1.4375 thick x 14.969 x 8.25 (2 pieces)
.4375 thick x 21.25 x 21.125 (4 pieces)
.25 thick 1.625 x .3125 (2 pieces)
.125 thick x 8.875 x 7 (2 pieces)
.125 thick x 20.5 x 20.375 (4 pieces)
.125 thick x 8.578 x 7.5 (2 pieces)
.125 thick x 1.82 x 1.11 (2 pieces)
.125 thick x 8.1875 x 3.219 (2 pieces)
__________________
Old 3rd Jun 2011, 14:11   #14
AnG3L
Ultimate Modder
AnG3L's Avatar
AnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run Crysis
LoL loved the last one!! Cant wait to see what you up to Bill! For sure it will rock!
AnG3L is offline   Reply With Quote
Old 3rd Jun 2011, 17:21   #15
MadFusionMedia
What's a Dremel?
MadFusionMedia's Avatar
MadFusionMedia has yet to learn the way of the Dremel
Looking good!
MadFusionMedia is offline   Reply With Quote
Old 3rd Jun 2011, 18:31   #16
mnpctech
bit-tech sponsor
mnpctech's Avatar
We will be swapping the hardware from NZXT's 5.25 bay Sentry Fan Controller into the top cover, available from performance-pcs, here
E.E.L Ambiense is having fun with making captions too!
__________________
Old 3rd Jun 2011, 19:04   #17
kier
kier's Avatar
kier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for president
12 days??? 24/7 mod challenge
Love the Lian Li card holders
__________________
kier is offline   Reply With Quote
Old 3rd Jun 2011, 23:35   #18
mnpctech
bit-tech sponsor
mnpctech's Avatar
haha, it just might turn into all nighters the last few days
__________________
Old 3rd Jun 2011, 23:40   #19
Warsmith
Enginseer
Monster "B.F.C." I.V.'s on stand-by!
Old 4th Jun 2011, 00:11   #20
23RO_UK
Hasta Mañana
23RO_UK's Avatar
23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan
You'll be finished long before my Phantom build Bill
I'm so looking forward to this one
23RO_UK is offline   Reply With Quote
Reply
Tags
star trek captions, star trek case mod, tricorder case
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
