Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 3rd Jun 2011, 12:40   #1
MaD_ColiN
What's a Dremel?
MaD_ColiN's Avatar
MaD_ColiN has yet to learn the way of the Dremel
Upgrading from a CRT Monitor
Hi folks,
Really after some advice as to what I should be looking at as far as upgrades to a CRT. I have a really old Ilyama 19" and its just very bulky, and I would like to transition to a LCD. I mainly use my PC for playing games and browsing the internet. I've looked over the topics here and generally the Dell U2410 seems to be one that everyone is raving about.
Is it worth considering it, or as its being phased out, albeit for inferior models, is it worth buying one before it disappears, or getting another brand?
Probabaly could sink £600 if it was worth having.
Need some help really.
MaD_ColiN is offline   Reply With Quote
Old 3rd Jun 2011, 14:18   #2
noizdaemon666
I've been away far too long
noizdaemon666's Avatar
noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.
Inb4 Goodbytes
Yeah, definitely worth getting the U2410 before they're phased out. Especially since you're coming from a CRT.
As Goodbytes will no doubt say when he sees this thread, the newer models probably aren't going to be any where near as good. And there won't be any 16:10 ratios (1920x1200 for the U2410). For playing games and things the added bit of resolution, for some people, can make a lot of difference.
__________________
AMD A4 5300 @ 4GHz | | 4GB 1600 Patriot | 128GB SSD | 500GB Samsung HD501LJ | 320GB Hitachi 2.5" | CX430 PSU
noizdaemon666 is offline   Reply With Quote
Old 3rd Jun 2011, 14:27   #3
GoodBytes
How many wifi's does it have?
GoodBytes's Avatar
GoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpit
The U2410 is a fantastic monitor. I got 2.. and not for a dual screen setup.. for my 2 computers (second for my computer at my father place.. which my father uses as well, when I am away).
I would definitely get it, before 16:10 disappears, and that it goes backward using LED technology, as manufacture wants to use the same panel for the TV's and computer monitors. I highly doubt that the new generation of monitor would be better. At BEST (for some reason) it might be the same, but 16:9 (because LG doesn't produce or will stop producing 16:10 panels).
The monitor looks sleek and professional, so I again doubt it that you would be disappointed when the newer comes out. So far I have been disappointing in Dell new laptops and desktop refresh. They cut on quality everywhere, even on the super high end business series. No more OS disk, no more nice slim and compact PSU.. now it's this HUGE brick, that looks like those 230W laptop PSU but only 90W, with no cable wrapping, like those 200$ laptop, cheap keyboard, bad layout, and well all looks the same... they all look like a 1998 Dell Inspiron. So yea, I my expectations are quiet low for the next monitor.
And even if they come with RGB back light and uniform back light somehow... It's useless for you, as you are not a professional that need pin point color accuracy edge to edge.
__________________
Nv GPU Pro - Automate your graphic card overclock base on what you run, reduce power and noise. Designed for Laptops and Desktops. Filled with features.
Core i7 930 2.8GHz | G.Skill Pi 6GB 1600MHz 7-5-7-24 1.5V | Gigabyte GA-X58A-UD5 | GeForce GTX 260 | W.D Caviar Black 1TB | Corsair AX750 | Noctua NH-U12P | Xonar Essence STX | Win8 Pro 64-bit | Dell U2410 - 1920x1200 | OCZ Vertex 4 250GB
GoodBytes is offline   Reply With Quote
Old 3rd Jun 2011, 15:05   #4
MaD_ColiN
What's a Dremel?
MaD_ColiN's Avatar
Awesome, thats exactly the sort of recommendation I was looking for really. Plus if I was actually looking to do higher end graphical work or design, not having a specifically tailored monitor would be a bad idea anyway - Gaming doesnt warrent the extra expence.
Old 3rd Jun 2011, 21:33   #5
Pookeyhead
It's big, and it's clever.
Pookeyhead's Avatar
Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.
You can't go wrong with the 2410. Get one while you can still get a 16:10 screen.
__________________
MAIN RIG |Intel i7 3960X @ 4.7GHz ¦¦ Asus Rampage IV Extreme ¦¦ 16Gb Mushkin DDR3 2133 ¦¦ 512GB Samsung 830 SSD ¦¦ 4TB of HDD Storage ¦¦ 4GB EVGA GTX670 Superclocked SLI ¦¦ Corsair 650D ¦¦ Eizo ColorEdge CG303W & Dell 2007FP ¦¦ Logitech Z623
EARTH| Celeron E3200 ¦¦ Gigabyte G31M-ES2L ¦¦ LSI SAS8704EM2 ¦¦ 3TB RAID5 ¦¦ Headless - VNC administered
MOON | Thecus N3200pro 3TB RAID5
Pookeyhead is offline   Reply With Quote
Old 3rd Jun 2011, 21:42   #6
azrael-
I'm special...
azrael-'s Avatar
azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!
Originally Posted by MaD_ColiN View Post
Hi folks,
If you want to game then stay the hell away from LCD! At least if you play anything fast-paced like FPSs. I've recently "upgraded" from a CRT to one of the better TFT (LCD) monitors out there and now I can hit f**k all.
As far as I can tell it's input lag-related. All TFT monitors have input lag issues, which apparently are worsened by enabling vsync. The problem is, with vsync disabled images are even more unwatchable on a TFT than on a CRT.
I'm seriously considering going back to my CRT, even though I'd miss the text clarity and increased desktop space.
CAVEAT: I'm just typing this after once again having spent time playing CS:CZ without basically being able to hit *anything* at all.
__________________
It's not the end of the world ...but you can see it from here.
Xeon E3-1245 v2 3.4 GHz | ASUS P8C WS | 16GB Kingston ECC DDR3 | Samsung 830 256GB | eVGA GTX670 2GB | SB Audigy | Seasonic X-560 | Corsair Obsidian 550D | Dell 2209WA
azrael- is offline   Reply With Quote
Old 3rd Jun 2011, 21:47   #7
DragunovHUN
Go ahead, spell my name wrong.
DragunovHUN's Avatar
DragunovHUN can run CrysisDragunovHUN can run CrysisDragunovHUN can run CrysisDragunovHUN can run CrysisDragunovHUN can run CrysisDragunovHUN can run CrysisDragunovHUN can run CrysisDragunovHUN can run CrysisDragunovHUN can run CrysisDragunovHUN can run CrysisDragunovHUN can run Crysis
Are you for real?
__________________
Gigabyte EX58-UD5 | Intel i7 920 @stock | 6x2gb 1600Mhz Corsair Dominator | 560Ti Hawk | Tagan 480W EasyCon | Lian Li PC-A77FB | Samsung Syncmaster 2443 | Logitech Illuminated | Logitech G500
gog.com - Classic videogames, Windows 7 compatible, no DRM, bundled extras, outstanding service. Check it out, get hooked, spread the word!
DragunovHUN is offline   Reply With Quote
Old 3rd Jun 2011, 21:47   #8
azrael-
I'm special...
azrael-'s Avatar
Originally Posted by DragunovHUN View Post
Are you for real?
I certainly am.
I decided to finally ditch my CRT because I don't game as much as I used to. And the lure of a better screen for work was too strong. The problem is, now I can't game at all.
__________________
Old 3rd Jun 2011, 21:58   #9
Pookeyhead
Pookeyhead's Avatar
I certainly am.
Get a decent screen then, as I can game just fine. Hang on, your sig says 2209. You should have no problems gaming on that whatsoever.
__________________
Old 3rd Jun 2011, 22:12   #10
smc8788
potato
smc8788's Avatar
smc8788 - may the hammer of Bindi be bestowed on yousmc8788 - may the hammer of Bindi be bestowed on yousmc8788 - may the hammer of Bindi be bestowed on yousmc8788 - may the hammer of Bindi be bestowed on yousmc8788 - may the hammer of Bindi be bestowed on yousmc8788 - may the hammer of Bindi be bestowed on yousmc8788 - may the hammer of Bindi be bestowed on yousmc8788 - may the hammer of Bindi be bestowed on yousmc8788 - may the hammer of Bindi be bestowed on yousmc8788 - may the hammer of Bindi be bestowed on yousmc8788 - may the hammer of Bindi be bestowed on you
If you care that much about fast-paced FPSes you should be buying a 120Hz monitor anyway, the only real replacement for a CRT in those circumstances. There is no real reason for still owning a CRT in this day and age.
Saying you can't game at all on a 60Hz LCD screen is just ludicrous, and one of the main types of games I play is fast-paced FPSes. Sure, it takes some getting used to after owning a 120Hz monitor, but I can live it it and it hardly makes the games unplayable.
__________________
My Rig: [FD Define Mini] - [Asus P8Z77-M Pro] - [i5 2500k @ 4.4GHz/1.34V] - [Corsair H60] - [8GB Corsair Vengeance LP] - [Asus GTX TITAN] - [512GB Vertex 4, 1TB F3, 2TB F4 x 2] - [Corsair HX650]
Other stuff I own: [BenQ XL2411T] - [HHKB Pro2 Type-S] - [Zowie EC1] - [Sennheiser HD800] - [Audez'e LCD2 rev. 2] - [Woo Audio WA7 Fireflies] - [Philips 46PFL9705H] - [Onkyo TX-NR515] - [B&W 685]
[Steam] - [Battlelog]
smc8788 is offline   Reply With Quote
Old 3rd Jun 2011, 22:21   #11
azrael-
I'm special...
azrael-'s Avatar
Well, that's the problem. I consider the 2209WA to be one of the better TFT monitors out there. In most tests it even bests the U2410 for gaming, but trust me on this: I can't game on it at all. At least not my favourite games (most of all CS:CZ, which I've played since 2001, well CS anyway). I can shoot at an enemy at point blank range and not even get a single registered hit. Didn't have that issue with my CRT. Of course, everyone has good days and bad days, but since the switch I've only had bad days.
As I wrote I believe it's a problem with input lag. Anandtech did some research into this 2 years ago. I believe they're on to something. A 120 Hz monitor might alleviate the situation, but I'll be damned if I ever touch a TN-based monitor, which is currently the only way to get a 120 Hz panel.
As for the original poster, what I'm trying to get across is: Make sure you're aware of all potential pitfalls when switching from CRT to TFT. Just because everyone says it works great doesn't mean it really is so. Don't get me wrong, I absolutely love the image clarity and the large desktop (not too fond of the IPS "sheen" and poor black levels, though), but for (FPS) gaming the monitor has turned out to be a dud. At least for me. Just coming from CRT and now having used the 2209WA for a couple of weeks should entitle me to an informed opinion.
Perhaps more console-oriented games fare better on TFTs? After all, they are usually made with flatscreens in mind.
As it stands I'm extremely frustrated...
__________________
Old 3rd Jun 2011, 22:26   #12
GoodBytes
GoodBytes's Avatar
I think it's just you that is not good with the game, and you blame your hardware. And now you spreading false exaggerations. Even crazy hard core championship winners uses LCD screen during their competition.
After that story.. you probably go and blame your mouse and keyboard, and then on some computer performance, and I don't know what.
Oh what, THERE YOU ARE (NFSW)
Ok now you are excused.
__________________
Old 3rd Jun 2011, 22:30   #13
azrael-
I'm special...
azrael-'s Avatar
But of course. For 10 years I have no problems, but the moment I switch from CRT to TFT I'm suddenly bad at the game.
Crazy hard core championship winners won't use TFTs unless they can't help it. FWIW, I don't consider myself hardcore in any way whatsoever.
__________________
Old 3rd Jun 2011, 22:48   #14
GoodBytes
GoodBytes's Avatar
mmhmm, that is like Bill Gates saying "I don't consider myself rich in any way watchsoever". It has the same validity.
__________________
Old 3rd Jun 2011, 23:03   #15
azrael-
I'm special...
azrael-'s Avatar
I've really no idea what point you are trying to make.
__________________
Old 3rd Jun 2011, 23:35   #16
GoodBytes
GoodBytes's Avatar
It means I don't believe you. You are a crazy hardcore gamer like no tomorrow, with reflexes faster than a humming bird wing movement speed as your life is around that game, but you are very modest
Your like the poker player that comes on a table and beat the whole table constituted of experts, and go "I only rarely play poker, I just started a few months ago".
Anyway, you are becoming defensive, clearly showing that it's you on the above video
(I am just fooling with you..)
__________________
Old 4th Jun 2011, 08:18   #17
azrael-
I'm special...
azrael-'s Avatar
Shame on you for messing with a beleaguered old man...
__________________
Old 4th Jun 2011, 15:39   #18
thehippoz
Banned
thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!
lol I believe you az.. I still have a few crt's but don't fps game anymore- but it's the only way to fps game.. pros use crt's too (maybe they switched don't keep up with it anymore)
in cs (used to play that a lot back in the day before source) or quake.. get 2 guys who know how to play.. you put one on a crt and one on a lcd.. crt will win everytime.. also the native resolution has a lot to do with it.. crt you can run the lowest resolution full screen with no input lag- so the crosshair and people your aiming at are bigger
at lans the tourney gamers used to always do this.. jack up the brightness, lowest resolution possible, cvar tweaks out the yingyang
thehippoz is offline   Reply With Quote
Reply
Tags
24" monitor, lcd, u2410
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
