Reply
Thread Tools View Mode
Old 5th Jun 2011, 21:38   #1
ikem
Modder
ikem is almost as Godly as yodasarmpitikem is almost as Godly as yodasarmpitikem is almost as Godly as yodasarmpitikem is almost as Godly as yodasarmpitikem is almost as Godly as yodasarmpitikem is almost as Godly as yodasarmpitikem is almost as Godly as yodasarmpitikem is almost as Godly as yodasarmpitikem is almost as Godly as yodasarmpitikem is almost as Godly as yodasarmpitikem is almost as Godly as yodasarmpit
Citrus
I have been modding this for a while, but i guess i could post my build here too.
Im have been modding my main rigs Lian Li A05NB for some time now, and it is time for a change. I used to cut corners for budget purposes, but this time, im pulling out the stops. Im going to make this pc my pride and joy.
This will be mainly a video log with some pictures, i dont really like to stop and take pics during modding, so im just going to record everything
This will be a three color, color scheme. White/Orange/Silver
I know that the color of the motherboard will be a problem but once bulldozer comes out, there may be something that will wit the colors. or i can just get a GB OC.
Starting hardware:
AMD Phenom II x6 1090t
Gigabyte GA890XA-UD3
GSkill Ripjaws DDR3 1600 4x2gb
HIS HD 6870 1gb
OCZ Vertex 2 60gb
Corsair HX650W
Cooling:
Noctua D-14
2x Xigmatek XLF-F1453
3x Xigmatek XLF-F1253
2x Xigmatek XLF-F1254 (89 cfm version)
1x ADDO 120mm 90cfm
NZXT Sentry 2 Fan Controller
got done stripping.. took a good 5 hours to get it done well. i wish lian li would have made this piece 3 seperate pieces instead of 1...
Tear Down begins!
here is what im doing to all my Xigmatek XLF fans. also the 140mm didnt have a hole for the led to shine though... i drilled a new hole and they are a little brighter
ikem is offline   Reply With Quote
Old 5th Jun 2011, 21:38   #2
ikem
Modder
to all A05n owners, we all know the cable management is a pain in this case...
well im working on a little cover that goes from the bottom 5/25 bay to the floor. im planning on adding cable management fasteners to this plate, in hopes that the wires are not as bunched up as before. it will be painted white to mask the wires, and make for a clean look.
after looking at this picture... i forgot to cut a place for the power/reset buttons to go through
I will be adding some sort of lower fastening to the mask
Old 5th Jun 2011, 21:39   #3
ikem
Modder
Finished the cable mask, added the bottom piece of angle aluminum. Drilled and tapped for screws to hold everything together
Just enough room so the psu can slip in
Prepped the plate for paint, i also bent about .25 inch so the cables wouldnt cut on the edge of the metal.
As it sits tonight, im resleeving the fans because the old sleeving wasnt the greatest, also with white heat shrink.
Old 5th Jun 2011, 21:39   #4
ikem
Modder
well i got the chassis from powder coat today. it was $20 to do it, if he was to do the full case it would be like $40. Very reasonable prices, and it is only a 15 min drive to the shop!
i gave him a sample of the lian li side panels, and they came out with some pin hole like spots, and i had already decided to paint them myself... i could have lived with the spots i think... to save alot of money... anyway...
mobo tray. Chevy Orange!
working with this white makes me really careful... it is sooooo un blemished... i was so careful with the rivets...
Installed the cable mask, looks great and i think it will work well.
MNPCtech 140mm fan grills. They do rotate but i like the 45 degree position.
Before assembly.
Also MNPCtech case feet, painted chevy orange.
im waiting on ftwpc to release thier sleeving and priceing before i purchase sleeving, im needing the tightest weave...
thanks for looking, ikem
Old 5th Jun 2011, 21:40   #5
ikem
Modder
got some things today.
once i get some sleeving i will be using those.
also i got the vandal hooked up. looks nice
finished the white coat on my gpu, and changed the tim in the process.
also painted the pci brackets, i need to find the rest of the lian li ones...
Old 5th Jun 2011, 21:40   #6
ikem
Modder
so i was taking my temp probe around the case and i was very worried about the back of the mobo around the cpu socket and vrms. there isnt even room for a 12mm fan and i refuse to mount an external fan. So i had an idea, since my case has a very high positive pressure vent system, i should just make a blow hole. I have a few MNPCtech grills that i have cut the center out of. Then I used the original Lian li 120mm fan grill for an insert. Using very short screws, because i dont want it to short, i think the air traveling over the back of the mobo will help alot. And it doesnt look that bad.
Hopefully these screws will be short enough.
Old 5th Jun 2011, 21:41   #7
ikem
Modder
more things came from frozen cpu today, the rest of my connectors, 4 fan molex connector, 12 inch led strip white, and a 12 inch fan extension.
i was deciding on where to put the light, but it looked best up in the top case rail, and it is totally hidden, and still lights everything well.
Let there be light.
mmm that gpu looks nice
Old 5th Jun 2011, 21:41   #8
ikem
Modder
mmm some late night cable management. Moved some things around and changed the 3.5 hdd's mounting back to the cut up Lian Li hdd cage.
I painted the Sentry 2 a while ago but wasnt happy with it. I redid it and this time it looks nicer. All but the little paint smudges on the lcd when i painted it the first time. Im going to remove them later. EDIT: also i have the temp sensor of Fan 1 (the one that is showing) taped to the inside of the front bezel, so i can get a nice estimate of the ambient temp.
Look mom! No Cables!
well a few... once i get the sleeving done tomorrow, everything will be hidden, almost. After looking at this photo, i think the fan cable could go behind that other 140mm fan. so could the power button cable. (once it is sleeved.) I think i found a great place for that unused 5.25 drive bay cover, didnt i?
sleeving arrives tomorrow. but i don't know if i will get everything done... gotta work alot tomorrow too. I will definitely take some pics of it though.
Thanks for looking, Ikem
Old 5th Jun 2011, 21:41   #9
ikem
Modder
Thanks Lutro for the availability of the MDPCx sleeving!
Here we are, i didnt measure it so i hope lutro sent me the right amount... hehe
orange connectors, 100 ft White Small MDPCx, 50 ft Orange Small MDPCx, and 75 precut White heatshrink. And a digital Heatgun
For my first time sleeving... EVER.. i like how it came out. I can see a little of the black under the white but it is acceptable.
After a long time.... i finished the 24 pin and 8 pin on the non modular part. Had to cut the hole a little larger for the extra size.
After getting everything together... It looks like a mess back here. I know i mixed it with black sleeving BUT the black sleeving is always located in the shadows, aka behind the fan contoller/ etc.
Also the metal plate i added is SO helpful because i dont know where i would have put all these wires.
Hmm hsf.... dont mind the orange scribbles... i was trying something and failed miserablly... Im going to remove it later.
The orange connectors really show on the GPU, alot better than having black ones.
All lit up. Notice the metal plate that hides the cables. It works so well!
And the side panel on.
also the 120mm blow hole that is positioned on the cpu backplate, i finally got all the side panels on and there is a considerable amount of air coming out of it. I'm happy with this airflow and im not going to add a fan.
Im going to be adding a few fan grills, such as on the psu and rear intake. But thanks for looking, Ikem
Old 5th Jun 2011, 22:58   #10
(FIH) The Don
Multimodder
(FIH) The Don's Avatar
(FIH) The Don has yet to learn the way of the Dremel
i love the color scheme man
pulled off very nicel
(FIH) The Don is offline   Reply With Quote
Old 5th Jun 2011, 23:03   #11
bulldogjeff
The modding head is firmly back on.
bulldogjeff's Avatar
bulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyan
Really, really nice clean and tidy build. Like it a lot...top modding dude.
bulldogjeff is offline   Reply With Quote
Old 6th Jun 2011, 07:38   #12
sparkyboy22
Web Tinkerer
sparkyboy22's Avatar
sparkyboy22 is the Cheesecake. Relix smiles down upon them.sparkyboy22 is the Cheesecake. Relix smiles down upon them.sparkyboy22 is the Cheesecake. Relix smiles down upon them.sparkyboy22 is the Cheesecake. Relix smiles down upon them.sparkyboy22 is the Cheesecake. Relix smiles down upon them.sparkyboy22 is the Cheesecake. Relix smiles down upon them.sparkyboy22 is the Cheesecake. Relix smiles down upon them.sparkyboy22 is the Cheesecake. Relix smiles down upon them.sparkyboy22 is the Cheesecake. Relix smiles down upon them.sparkyboy22 is the Cheesecake. Relix smiles down upon them.sparkyboy22 is the Cheesecake. Relix smiles down upon them.
Could you do the top of your heat sink orange?
__________________
i5 2500k @ 4.5 GHz | Corsair H100 | Asus P8P67 Pro | 16GB Corsair Vengeance | EVGA GTX680 | Corsair Force 3 240GB SSD
Corsair HX650 | Xigmatek Utgard | 27" LG Something or other
Logitech Z906 5.1 Speakers | Logitech K750 Solar Keyboard | Logitech Performance MX Mouse
sparkyboy22 is offline   Reply With Quote
Old 6th Jun 2011, 09:06   #13
Jipa
Avoiding the "I guess.." since 2004
Jipa's Avatar
Jipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run Crysis
Really fresh color scheme and kudos for even painting the GFX-card.
I just don't understand how you've thought the cooling? I mean you have three fans pushing in air and just one exhaust at the front Suppose it works, it just looks weird
__________________
Half a dozen operational setups and truckloads of spare parts.
AllTheMods - MetkuMods - LedCalc - Flickr - BF:BC2
Jipa is offline   Reply With Quote
Old 6th Jun 2011, 11:04   #14
bushi
Multimodder
bushi has yet to learn the way of the Dremel
That colour scheme is the best!
Very similar to what I'm thinking. I'm not big on case mods but I love this one.
bushi is offline   Reply With Quote
Old 6th Jun 2011, 12:17   #15
MilOk
Multimodder
MilOk's Avatar
MilOk has yet to learn the way of the Dremel
so nice man great job !!!
MilOk is offline   Reply With Quote
Old 6th Jun 2011, 15:15   #16
ikem
Modder
done alot of heat tests and this is the best one.
here is what it looked like with a regular front to back airflow
and the
temp tests with my config, and a normal fan layout.
My Layout
Regular Layout
i have changed it a bit since then and i should test again. (different fans and such)
Old 6th Jun 2011, 18:16   #17
Stem83
Addicted to modding.
Stem83's Avatar
Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.
Well there is 2 pulling out as you have the PSU as well...
Thats a nice build, turned out so well.
Stem83 is offline   Reply With Quote
Old 6th Jun 2011, 18:59   #18
jrs77
theorycrafting
jrs77's Avatar
jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.
Nice colour-scheme indeed. Very fresh
For your temps... you traded +4 on the CPU for -9 on the GPU, which is a very good tradeoff imho, allthough your chipset is aswell running a little hotter with your flipped setup.
All in all very good built
__________________
...and allways remember, that the world is an orange!
Cooltek/Jonsbo U1 | Silverstone SX500-LG | Noctua NF-R8 Redux 1200
Gigabyte H97N-WiFi | intel i7-5775C | Noctua NH-D9L | Crucial Ballistix 16GB DDR3L1600 | Crucial MX200 250GB | 2.5" WD AV 1TB
jrs77 is offline   Reply With Quote
Old 6th Jun 2011, 20:17   #19
flame696
Terminating People Since 1980....
flame696's Avatar
flame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyan
i love it i did a orange build but i love the white its such a cool colour well done!
__________________
flame696 is offline   Reply With Quote
Old 7th Jun 2011, 19:40   #20
OCJunkie
OC your Dremel too
OCJunkie's Avatar
OCJunkie has yet to learn the way of the DremelOCJunkie has yet to learn the way of the DremelOCJunkie has yet to learn the way of the DremelOCJunkie has yet to learn the way of the Dremel
Wicked colours bro, super squeeky clean wiring too!
__________________
Gaming: CM 690 II A / XFX Pro850 XXX / GB 990FXA-UD3 / X4 955BE @3.8GHz - Hyper 212+ / 8GB Corsair Vengeance 1600 / XFX HD 6950 2GB - Twin Turbo Pro / OCZ Agility 3 60GB / WD Black 640GB & Green 1TB / 3x Acer 23in @5760x1080 Eyefinity
Media: Ultra Aluminus / Corsair TX750 / GB MA790X-UD4 / X2 7750BE @3GHz - Freezer64 Pro / 4GB OCZ Reaper HPC 1066 / HD 4670 1GB / WD Blue 320GB + Green 1TB & 1.5TB / Samsung 40in HDTV / Samsung HW-C560S / Harmony 300
OCJunkie is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
