Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 9th Jun 2011, 09:50   #1
arcticstoat
Hypermodder
arcticstoat's Avatar
arcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysis
Corsair announces Force 3 SSD recall
Corsair has announced that it's recalling a specific model of its latest SandForce-based SSD range.
http://www.bit-tech.net/news/hardwar...3-ssd-recall/1
__________________
Ben Hardwidge
Custom PC Editor
arcticstoat is offline   Reply With Quote
Old 9th Jun 2011, 10:27   #2
3lusive
Ultramodder
3lusive's Avatar
3lusive is a hoopy frood who really knows where their towel is.3lusive is a hoopy frood who really knows where their towel is.3lusive is a hoopy frood who really knows where their towel is.3lusive is a hoopy frood who really knows where their towel is.3lusive is a hoopy frood who really knows where their towel is.3lusive is a hoopy frood who really knows where their towel is.3lusive is a hoopy frood who really knows where their towel is.3lusive is a hoopy frood who really knows where their towel is.3lusive is a hoopy frood who really knows where their towel is.3lusive is a hoopy frood who really knows where their towel is.3lusive is a hoopy frood who really knows where their towel is.
Corsair asks for a full recall. OCZ says it affects 1% of their users. Something doesnt add up, especially when you see how many people are getting random BSODs etc on the OCZ support forums
__________________
Antec 300 | Asus P8H67-M Pro R3 | i5 2500K | 16GB XMS3 RAM | GT 430 Zone | 60GB F60 SSD | 1TB F3 + 500GB HDD | CX430W PSU | Logitech G500 + C510 | Win7 Ultimate x64
QNIX QX2710 PLS Evolution ll 27" 2560x1440 x2
3lusive is offline   Reply With Quote
Old 9th Jun 2011, 10:50   #3
Xtrafresh
It never hurts to help
Xtrafresh's Avatar
Xtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run Crysis
The problems always look worse on a forum. If all the happy users would post, you wouldn't even be able to FIND the unhappy ones.
It does look rather serious though...
__________________
Think of how stupid the average person is, and realize half of them are stupider than that.
- George Carlin
Xtrafresh is offline   Reply With Quote
Old 9th Jun 2011, 10:58   #4
Baz
I work for Corsair
Baz's Avatar
Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.
Spoke to Corsair and OCZ. Corsair confirm the issue isn't in the drive controller, and that they have "full confidence" in the SandForce drive controller."
Doing some digging, more info soon hopefully.
Baz is offline   Reply With Quote
Old 9th Jun 2011, 12:45   #5
Christopher N. Lew
Folding in memory of my father
Christopher N. Lew's Avatar
Christopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for president
If the fault only affects 120GB drives, why have you illustrated the story with an image of the 240GB model?
Christopher N. Lew is offline   Reply With Quote
Old 9th Jun 2011, 16:18   #6
Farfalho
Supermodder
Farfalho's Avatar
Farfalho has yet to learn the way of the Dremel
Christopher has a point. Although explicit in the article, the image doesn't add up to it.
I believe the problem is in the hardware used by Corsair. If it was a controller problem, maybe the two companies would issue a return and Corsair wouldn't have said what Baz told us hence the discrepancy between Corsair and OCZ's statements.
There's always something that can go south
Farfalho is offline   Reply With Quote
Old 24th Oct 2011, 15:24   #7
fallentech
What's a Dremel?
fallentech has yet to learn the way of the Dremel
SSD failures
I purchased 7 of these for testing and 4 have failed in less than 3 months...
fallentech is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
