Reply
Thread Tools View Mode
Old 13th Jun 2011, 14:47   #1
Paslis
Supermodder
Paslis's Avatar
Paslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run Crysis
Project Flipmode - 1 jan 2012 - Flipmode finisht -
Hi Everyone,
Allow me to introduce myself.My name is Pascal and i am from the netherlands and i am a metalworker/welder for 22 years now.I am infected with the mod virus and after building 2 desks http://gathering.tweakers.net/forum/...ssages/1439066 its time for something else.This time its gonna be a tower and again build from scratch.
The name of this project is Flipmode.
The drawnings.
The idea is to place the mobo under 45 degrees and putting the pump and reservoir behind the front.I also gonna use 2 koenigsegg doors in this project.
Sponsors :
Hardware :
Proc : i5 750
Mobo : Asus P7P55D
Mem : 8gb corsair dominator 1600c8
Vid : ATI Radeon 4870x2
Sound : Onboard
Hdd 1 : OCZ vertex 2 60gb
Hdd 2 : WD raptor 150gb
Hdd 3 : WD raptor 150gb
Psu : Cooler Master Silent Pro Gold 800W
Cooling :
Pump : Laing DDC-1Plus MCP355 + Bitspower top
Rad : EK Coolstream XTC 420
Res : Custom
Vga : Bitspower black freezer
Cpu : EK Supreme HF
Mem : Bitspower galaxy freezer
The hardware I'm still collecting.The material I will use will be a combination of steel and aluminum or stainless steel.The color of all I have in my head but as the build progresses can still change.The goal is to make everything as clean as possible to show.
Now it's time to start the project.
The Frame.
Cutting the frame.
The cutting work is completed so now its time to putt it together.
Below I have 4 right-angled corners welded.
The sides.
The sides are ready now so I will compile the entire frame.
The frame is finished so now its time to make the plates for the levelers.
The frame is finished.
The frame is finished, so now its time to make the custom hinges for the Koenigsegg doors.
The drawings of custom hinges.
I hope you can understand my dutchy english.Untill the next update.
Paslis is offline   Reply With Quote
Old 14th Jun 2011, 07:52   #2
Mystikal0412
Safety First, Think Twice!
Mystikal0412's Avatar
Mystikal0412 has yet to learn the way of the Dremel
English is good enough! It's the modding what counts! Was also following you on Tweakers! Keep up the good work!
__________________
WINNER MOTM-May-11 EXO-S
Casemod in Process: EXO-S
Mystikal0412 is offline   Reply With Quote
Old 14th Jun 2011, 17:30   #3
Paslis
Supermodder
Paslis's Avatar
Update 1 - 14 jun 2011
Today I started working with the plating.I chose for aluminium to make the case not to heavy.
First i cut the aluminium to the size i need.
The corners cut out.
Draw the holes.
Dril and sink the holes.I grapped a m4 bolt and adjusted the dept.
I also made the cover that i will place behind the frontpanel.
Now its time to compile everthing.
This was it for today.
Old 14th Jun 2011, 17:40   #4
Paslis
Supermodder
Paslis's Avatar
Was following your work also on tweakers.Keep up the good work to.
Old 14th Jun 2011, 19:55   #5
kelmannen
Supermodder
kelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremel
love it love it love it =D
this makes my swedish koeninsegg heart bleed tears of ioy =D
kelmannen is offline   Reply With Quote
Old 14th Jun 2011, 21:22   #6
Cleveland216
Carbon Fiber King
Cleveland216 has yet to learn the way of the DremelCleveland216 has yet to learn the way of the DremelCleveland216 has yet to learn the way of the DremelCleveland216 has yet to learn the way of the DremelCleveland216 has yet to learn the way of the DremelCleveland216 has yet to learn the way of the Dremel
Nice work bench. I am jealous. I always wondered how they made those hinges. I will be watching!
Cleveland216 is offline   Reply With Quote
Old 15th Jun 2011, 00:02   #7
BLUEHORSESTUDIOS
I haven't lost a finger yet!
BLUEHORSESTUDIOS's Avatar
BLUEHORSESTUDIOS has yet to learn the way of the DremelBLUEHORSESTUDIOS has yet to learn the way of the DremelBLUEHORSESTUDIOS has yet to learn the way of the DremelBLUEHORSESTUDIOS has yet to learn the way of the Dremel
Welcome to bit-tech, this is a great community of artist, modders,sculpters and PC builders and we welcome another great builder to the class.
I like your plans for your project and your shop is amazing.. I can't wait to see this develop.
BLUEHORSESTUDIOS is offline   Reply With Quote
Old 15th Jun 2011, 03:50   #8
Shael
Multimodder
Shael's Avatar
Shael has yet to learn the way of the Dremel
Ahh another scratch build involving steel and welding will be definately following this and i cant wait to see how those hinges come together - subbed
Shael is offline   Reply With Quote
Old 15th Jun 2011, 07:11   #9
Blooddrunken
In Flames we Trust
Blooddrunken's Avatar
Blooddrunken has yet to learn the way of the Dremel
Nice work so far. I'm looking forward for more.
Blooddrunken is offline   Reply With Quote
Old 15th Jun 2011, 12:33   #10
Paslis
Supermodder
Paslis's Avatar
Thank you and my dutch heart bleeds tears of joy to when i see the koenigsegg.
Thank you and you will see them soon.
Thank you and it isnt my shop but its the shop of my boss but i have a key and i can use it whenever i want.
The hinges will be finisht soon.
Thank you.
Old 16th Jun 2011, 16:12   #11
Paslis
Supermodder
Paslis's Avatar
Update 2 -16 jun 2011-
Today i did some drawning and afcouse some modwork.
First i drilled some holes from 3,5mm then tapped with a tap m4.
Then I started working with the backside.
Drilling the holes for the backplate.
I had a backplate from another build so this one im gonna use.
A piece of 5mm plexi drilled some holes in it and tapped them.
Putting it together with m4 bolts but they are temporarily because i will replace them for black sunk bolts.
Not its time to fit the parts in the frame.
I was wondering how much the case weighs at this point so i putt it on a scale and it already weighs 12 kg.
Old 17th Jun 2011, 11:21   #12
Herculess
What's a Dremel?
Herculess has yet to learn the way of the Dremel
great welding job you made! keep modding and i will watching your work my friend!
Herculess is offline   Reply With Quote
Old 17th Jun 2011, 12:41   #13
miahallen
Team IRONMODS - World Champions!
miahallen's Avatar
miahallen has yet to learn the way of the Dremelmiahallen has yet to learn the way of the Dremel
I was thinking he must be a welder Very nice work
miahallen is offline   Reply With Quote
Old 17th Jun 2011, 21:12   #14
(FIH) The Don
Multimodder
(FIH) The Don's Avatar
(FIH) The Don has yet to learn the way of the Dremel
o love how you turned the MB just a bit
definately gonna be watching this one
(FIH) The Don is offline   Reply With Quote
Old 18th Jun 2011, 07:04   #15
Paslis
Supermodder
Paslis's Avatar
Thank you and i will keep on modding.
Your correct im a welder.
Turning the MB gives allot of extra space.
Old 19th Jun 2011, 06:03   #16
Paslis
Supermodder
Paslis's Avatar
Update 3 - 19 jun - 2011
Time for some modding.The hinge is ready so its time to putt it in place.
The hinge is made of stainless steel and the bearings are made of brass.The axle is also made of stainless steel.
Drilling the holes for the hinge.
Placing the hinge inside the cover.
Now its time to make the frame for the door.For this im gonna use aluminium 20x20x2mm.Everything is measured out so the sawing can begin.
The sawing is finisht so not its time to compile the door.
Some finishing.
Then i made a plate for the axle with 2 m4 holes in it and weld it on the frame.
Then i made the same plate out of stainless steel and screw it on the aluminium plate.
Then i measured everything out and welded the axle on the plate.
It fits perfect and works like a charm.
Old 20th Jun 2011, 16:11   #17
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
Excellent work, and welcome to Bit-tech.
Cheapskate is offline   Reply With Quote
Old 20th Jun 2011, 16:23   #18
k.3nny
Hypermodder
k.3nny's Avatar
k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.
Heey u here also!
Nice to see u here buddy, Keep on going !
k.3nny is offline   Reply With Quote
Old 20th Jun 2011, 16:24   #19
Karrek
Multimodder
Karrek's Avatar
Karrek has yet to learn the way of the Dremel
Very nice door. Never seen that done in a computer (or much else for that matter). Is there much flex or play in the hinge? great job!
Karrek is offline   Reply With Quote
Old 20th Jun 2011, 18:41   #20
bulldogjeff
The modding head is firmly back on.
bulldogjeff's Avatar
bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.
Thats some nice metal work skills you've got. looking good so far. I was wandering about the weight also, but you've answered that. It going to get a lot heavier by the time it's finished...lol
bulldogjeff is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
