Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 16th Jun 2011, 22:50   #1
nemo
Foregone Destruction
nemo's Avatar
nemo has yet to learn the way of the Dremelnemo has yet to learn the way of the Dremelnemo has yet to learn the way of the Dremelnemo has yet to learn the way of the Dremel
This computer is not running genuine windows
Has anyone else been getting pop-ups saying 'This Computer is not running genuine windows' on Windows 7 recently ?
Is it real or fake ?
I spent my money a few months ago on a shiny legit version of Windows 7 Ultimate, so I don't really believe this message.
I'm patched up to SP 1 too.
I've got Avast running, and that has not flagged anything as suspicious.
This contradicts the text in the system control panel which says 'Windows is activated'
Any ideas ?
__________________
CPU : Intel Core i7 930 / Mobo: Asus P6TSE / RAM : 6gb Corsair Dominator DDR3 8-8-8-24 / Sapphire Vapor-X HD5870 1gb / CpuCool: Titan Fenrir Xmas / PSU: Antec True Power New TP-650 / 1Tb F3 / Mouse : Logitech G7 Wireless / Case : Fractal Design Define R2 Silver Arrow / OS : Windws 7 Ultimate / Firefox
nemo is offline   Reply With Quote
Old 16th Jun 2011, 23:40   #2
IvanIvanovich
будет глотать вашу душу.
IvanIvanovich's Avatar
IvanIvanovich is a Super Spamming SaiyanIvanIvanovich is a Super Spamming SaiyanIvanIvanovich is a Super Spamming SaiyanIvanIvanovich is a Super Spamming SaiyanIvanIvanovich is a Super Spamming SaiyanIvanIvanovich is a Super Spamming SaiyanIvanIvanovich is a Super Spamming SaiyanIvanIvanovich is a Super Spamming SaiyanIvanIvanovich is a Super Spamming SaiyanIvanIvanovich is a Super Spamming SaiyanIvanIvanovich is a Super Spamming Saiyan
Open an elevated cmd prompt and run SFC /SCANNOW and see if it corrects it. If not run MGADiag and see what it has to say. if the report dosen't make any sense to you, copy paste it in this thread.
Sometimes the genuine check makes a false positive too.
__________________
intel xeon e5-2630l @2.7 | gigabyte g1.assassin.v2 | 16gb mushkin blackline 2133 | evga gtx970 ssc | kingston hyperx predator 240gb | seagate 600 240gb | seasonic ss460fl2 | nzxt s340 | gh60 keyboard | logitech g700 | achieva shimian qh270
IvanIvanovich is offline   Reply With Quote
Old 17th Jun 2011, 01:40   #3
thehippoz
Banned
thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!
if your legit you might want to phone up the activation center too.. get a key that works
remember there was a kb update a while back around march.. it pretty much brands anyone who runs ultimate a fake (because only pirates run it over premium seems)
lemme see- KB971033
once it's installed nowdays, you can't uninstall it.. if your still having trouble you might try and update everything but that one.. then hide the update so it doesn't come up again
thehippoz is offline   Reply With Quote
Old 17th Jun 2011, 07:12   #4
sparkyboy22
Web Tinkerer
sparkyboy22's Avatar
sparkyboy22 is the Cheesecake. Relix smiles down upon them.sparkyboy22 is the Cheesecake. Relix smiles down upon them.sparkyboy22 is the Cheesecake. Relix smiles down upon them.sparkyboy22 is the Cheesecake. Relix smiles down upon them.sparkyboy22 is the Cheesecake. Relix smiles down upon them.sparkyboy22 is the Cheesecake. Relix smiles down upon them.sparkyboy22 is the Cheesecake. Relix smiles down upon them.sparkyboy22 is the Cheesecake. Relix smiles down upon them.sparkyboy22 is the Cheesecake. Relix smiles down upon them.sparkyboy22 is the Cheesecake. Relix smiles down upon them.sparkyboy22 is the Cheesecake. Relix smiles down upon them.
If it has only come up the once then WindowsKey + Pause/Break.
Click the activate or change product key or whatever it says at the bottom.
Use your current serial number. If its genuine it will go through fine. If not phone the number that is given and tell them where you bought it.
__________________
i5 2500k @ 4.5 GHz | Corsair H100 | Asus P8P67 Pro | 16GB Corsair Vengeance | EVGA GTX680 | Corsair Force 3 240GB SSD
Corsair HX650 | Xigmatek Utgard | 27" LG Something or other
Logitech Z906 5.1 Speakers | Logitech K750 Solar Keyboard | Logitech Performance MX Mouse
sparkyboy22 is offline   Reply With Quote
Old 17th Jun 2011, 19:51   #5
OCJunkie
OC your Dremel too
OCJunkie's Avatar
OCJunkie has yet to learn the way of the DremelOCJunkie has yet to learn the way of the DremelOCJunkie has yet to learn the way of the DremelOCJunkie has yet to learn the way of the Dremel
Even some "shiny legit versions" can be pir8 if bought from shady outfits. Just try to reactivate, if it fails call M$ and explain the situation, they'll most likely fix you a new key.
__________________
Gaming: CM 690 II A / XFX Pro850 XXX / GB 990FXA-UD3 / X4 955BE @3.8GHz - Hyper 212+ / 8GB Corsair Vengeance 1600 / XFX HD 6950 2GB - Twin Turbo Pro / OCZ Agility 3 60GB / WD Black 640GB & Green 1TB / 3x Acer 23in @5760x1080 Eyefinity
Media: Ultra Aluminus / Corsair TX750 / GB MA790X-UD4 / X2 7750BE @3GHz - Freezer64 Pro / 4GB OCZ Reaper HPC 1066 / HD 4670 1GB / WD Blue 320GB + Green 1TB & 1.5TB / Samsung 40in HDTV / Samsung HW-C560S / Harmony 300
OCJunkie is offline   Reply With Quote
Old 22nd Jun 2011, 10:36   #6
paulp
Minimodder
paulp has yet to learn the way of the Dremel
Pirate windows
Have you heard of this happening? It's mighty big of microsoft to give out a key that way!
paulp is offline   Reply With Quote
Old 22nd Jun 2011, 11:54   #7
RichCreedy
Hey What Who
RichCreedy's Avatar
RichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming Saiyan
if you have to talk to a microsoft rep on the activation line, and they suspect the license, they will ask a few questions about the license sticker, ie what is written on the license, who installed it, how many times has it been installed etc,etc.
then if they are happy with the response, they will issue a new activation code, not a license key per se.
RichCreedy is offline   Reply With Quote
Old 22nd Jun 2011, 18:53   #8
OCJunkie
OC your Dremel too
OCJunkie's Avatar
Originally Posted by RichCreedy View Post
...then if they are happy with the response, they will issue a new activation code, not a license key per se.
That's what I meant. But yes generally they are surprisingly helpful if you're polite and give them no reason to think they're being played.
__________________
Old 22nd Jun 2011, 20:14   #9
nemo
nemo's Avatar
Thanks all for those suggestions.
thehippoz - you were spot on about KB971033 being the problem. Your advice to uninstall the KB971033 update, re-boot, check-for-new-updates, and then set the KB971033 to be a 'hidden' update did the job. We also found a good web-page about this update here
Just to provide a bit of background:
a) My copy of Windows 7 64bit Ultimate is 100% genuine. I purchased it about 9 months ago from Scan, one of the biggest and most reputable on-line dealers in the UK. I've also SP 1 installed (I normally install all the updates)
b) I did activate my Windows when I bought it. This is confirmed by 'my computer -> properties' where it says 'Windows is Activated'
c) Lysol -> I ran sfc /scannow and it said :
Verification 100% complete.
Windows Resource Protection found corrupt files but was unable to fix some of them.
Details are included in the CBS.log windir\Logs\CBS\CBS.log
The resulting log file is big (6mb). It seemed to be reasonably ok although it did flag up some problems (see end of post). However this did not stop the annoying pop-up from appearing (although I did learn that to get a 'cmd' console window with administrator privileges from the start menu program box, you type cmd then press CTRL+SHFT+RET )
d) I then downloaded and ran mgadiag. This reported the validation status as 'Genuine'.
e) I then went to the microsoft genuine validation web-page (using IE rather than Firefox/Chrome) and pressed the 'validate now' button. It reported 'Your windows is not genuine' (contradicting mgadiag). To resolve this problem it suggested that I buy a new copy of Windows 7, even though the holographic-ified dvd was sitting in my dvd reader. Not good.
e) One other weird thing. My mate built himself a new machine to almost the same spec as mine at the same time, purchasing both our copies of Windows 7 at the same time from Scan.
Our usage is pretty similar (playing games on Steam, Internet). However he has not got this problem. This is strange.
In summary, I don't like the fact that i've disabled the KB971033 update (I want my machine to be as legit and secure as possible), but I refuse to accept being interrupted every couple of hours 'to buy a legal copy of windows'. My only options now seem to be :
  • Phone Microsoft (but after seeing their on-line web pages/validation process, I am not sure that they can help me out)
  • Revert to a previous restore point in the hope that whatever caused this message to start appearing a few weeks ago will be rolled-back. But I'll lose changes made since the backup date
  • Live with a disabled KB971033
Anyway, thanks everyone for your help & suggestions. Rep Cheesecake all round
CBS.log Extract
2011-06-18 14:30:25, Info CBS Session: 30158267_3783756571 initialized by client WindowsUpdateAgent.
2011-06-18 14:30:25, Info CBS Failed to internally open package. [HRESULT = 0x800f0805 - CBS_E_INVALID_PACKAGE]
2011-06-19 10:51:17, Info CSI 00000076 [SR] Beginning Verify and Repair transaction
2011-06-19 10:51:22, Info CSI 00000077 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\en-US" in component Microsoft-Windows-Foundation-Default-Security.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e39}, Type neutral, TypeName neutral, PublicKey neutral
2011-06-19 10:53:10, Info CSI 00000132 Repair results created: (lots of these)
2011-06-19 15:53:17, Info CSI 00000326 [SR] Cannot repair member file [l:38{19}]"sppuinotify.dll.mui" of Microsoft-Windows-Security-SPP-UX.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e39}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2011-06-19 15:53:17, Info CSI 00000327 [SR] This component was referenced by [l:266{133}]"Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~6.1.7601.17514.Windows Foundation Language Pack"
2011-06-19 15:53:17, Info CSI 00000328 Hashes for file member \??\C:\Windows\System32\en-US\sppuinotify.dll.mui do not match actual file [l:38{19}]"sppuinotify.dll.mui" :
2011-06-19 15:53:17, Info CSI 00000331 [SR] Verify and Repair Transaction completed. All files and registry keys listed in this transaction have been successfully repaired -> LOL ('have been successfully repaired' even though it says above 'cannot repair'. Bad skillz microsoft)
__________________
Old 18th Oct 2012, 17:21   #10
mlennox
What's a Dremel?
mlennox has yet to learn the way of the Dremel
started getting that message yesterday after 3 years
Any ideas ?
mlennox is offline   Reply With Quote
Old 18th Oct 2012, 17:24   #11
mlennox
What's a Dremel?
I tired SFC ?SCANNOW but the response is that I need to be an administrator. I checked and I am an administrator.
Old 18th Oct 2012, 17:27   #12
mlennox
What's a Dremel?
Here is output from the url above:
Diagnostic Report (1.9.0027.0):
Windows Validation Data-->
Validation Code: 0x8004FE21
Cached Online Validation Code: 0x0
Windows Product Key: *****-*****-742TJ-79G79-XRVFB
Windows Product Key Hash: jeqd3GGw31LbpnWUpSKT0Ym0pdg=
Windows Product ID: 00371-154-3873905-85841
Windows Product ID Type: 5
Windows License Type: Retail
Windows OS version: 6.1.7601.2.00010100.1.0.048
Is Admin: Yes
TestCab: 0x0
LegitcheckControl ActiveX: N/A, hr = 0x80070002
Signed By: N/A, hr = 0x80070002
Product Name: Windows 7 Professional
Architecture: 0x00000009
Build lab: 7601.win7sp1_gdr.120503-2030
TTS Error:
Validation Diagnostic:
Resolution Status: N/A
Vista WgaER Data-->
ThreatID(s): N/A, hr = 0x80070002
Version: N/A, hr = 0x80070002
Windows XP Notifications Data-->
Cached Result: N/A, hr = 0x80070002
File Exists: No
WgaTray.exe Signed By: N/A, hr = 0x80070002
WgaLogon.dll Signed By: N/A, hr = 0x80070002
OGA Notifications Data-->
OGAExec.exe Signed By: N/A, hr = 0x80070002
OGAAddin.dll Signed By: N/A, hr = 0x80070002
OGA Data-->
Office Status: 100 Genuine
Microsoft Office Visio Professional 2007 - 100 Genuine
OGA Version: N/A, 0x80070002
Office Diagnostics: B4D0AA8B-604-645_025D1FF3-364-80041010_025D1FF3-229-80041010_025D1FF3-230-1_025D1FF3-517-80040154_025D1FF3-237-80040154_025D1FF3-238-2_025D1FF3-244-80070002_025D1FF3-258-3
Browser Data-->
Proxy settings: N/A
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Win32)
Default Browser: N/A, hr=0x80070002
Download signed ActiveX controls: Prompt
Download unsigned ActiveX controls: Disabled
Run ActiveX controls and plug-ins: Allowed
Initialize and script ActiveX controls not marked as safe: Disabled
Allow scripting of Internet Explorer Webbrowser control: Disabled
Active scripting: Allowed
Script ActiveX controls marked as safe for scripting: Allowed
File Scan Data-->
File Mismatch: C:\Windows\system32\wat\watadminsvc.exe[7.1.7600.16395], Hr = 0x80092003
File Mismatch: C:\Windows\system32\wat\watux.exe[7.1.7600.16395], Hr = 0x80092003
File Mismatch: C:\Windows\system32\sppobjs.dll[6.1.7601.17514], Hr = 0x80092003
File Mismatch: C:\Windows\system32\sppc.dll[6.1.7601.17514], Hr = 0x800b0100
File Mismatch: C:\Windows\system32\sppcext.dll[6.1.7600.16385], Hr = 0x800b0100
File Mismatch: C:\Windows\system32\sppwinob.dll[6.1.7601.17514], Hr = 0x80092003
File Mismatch: C:\Windows\system32\slc.dll[6.1.7600.16385], Hr = 0x800b0100
File Mismatch: C:\Windows\system32\slcext.dll[6.1.7600.16385], Hr = 0x800b0100
File Mismatch: C:\Windows\system32\sppuinotify.dll[6.1.7600.16385], Hr = 0x80092003
File Mismatch: C:\Windows\system32\slui.exe[6.1.7601.17514], Hr = 0x80092003
File Mismatch: C:\Windows\system32\sppcomapi.dll[6.1.7601.17514], Hr = 0x800b0100
File Mismatch: C:\Windows\system32\sppcommdlg.dll[6.1.7600.16385], Hr = 0x800b0100
File Mismatch: C:\Windows\system32\sppsvc.exe[6.1.7601.17514], Hr = 0x80092003
File Mismatch: C:\Windows\system32\drivers\spsys.sys[6.1.7127.0], Hr = 0x80092003
File Mismatch: C:\Windows\system32\drivers\spldr.sys[6.1.7127.0], Hr = 0x80092003
File Mismatch: C:\Windows\system32\systemcpl.dll[6.1.7601.17514], Hr = 0x800b0100
File Mismatch: C:\Windows\system32\user32.dll[6.1.7601.17514], Hr = 0x800b0100
Other data-->
Office Details: <GenuineResults><MachineData><UGUID>{A456BC6F-F536-4E18-BDD6-E9351D7C0C35}</UGUID><Version>1.9.0027.0</Version><OS>6.1.7601.2.00010100.1.0.048</OS><Architecture>x64</Architecture><PKey>*****-*****-*****-*****-XRVFB</PKey><PID>00371-154-3873905-85841</PID><PIDType>5</PIDType><SID>S-1-5-21-1781262384-756789545-919954020</SID><SYSTEM><Manufacturer>Gateway </Manufacturer><Model>NV59 </Model></SYSTEM><BIOS><Manufacturer>Phoenix Technologies LTD</Manufacturer><Version>V1.09 </Version><SMBIOSVersion major="2" minor="6"/><Date>20091126000000.000000+000</Date></BIOS><HWID>7C553607018400FC</HWID><UserLCID>0409</UserLCID><SystemLCID>0409</SystemLCID><TimeZone>Pacific Standard Time(GMT-08:00)</TimeZone><iJoin>0</iJoin><SBID><stat>3</stat><msppid></msppid><name></name><model></model></SBID><OEM><OEMID>ACRSYS</OEMID><OEMTableID>ACRPRDCT</OEMTableID></OEM><GANotification/></MachineData><Software><Office><Result>100</Result><Products><Product GUID="{90120000-0051-0000-0000-0000000FF1CE}"><LegitResult>100</LegitResult><Name>Microsoft Office Visio Professional 2007</Name><Ver>12</Ver><Val>261DF31330E7D86</Val><Hash>/Zl65I/UD0zxZ4WF63qmVCFXWY0=</Hash><Pid>89405-707-0089083-63064</Pid><PidType>14</PidType></Product></Products><Applications><App Id="53" Version="12" Result="100"/></Applications></Office></Software></GenuineResults>
Spsys.log Content: 0x80070002
Licensing Data-->
Software licensing service version: 6.1.7601.17514
Name: Windows(R) 7, Professional edition
Description: Windows Operating System - Windows(R) 7, RETAIL channel
Activation ID: e838d943-63ed-4a0b-9fb1-47152908acc9
Application ID: 55c92734-d682-4d71-983e-d6ec3f16059f
Extended PID: 00371-00170-154-387390-01-1033-7600.0000-1822011
Installation ID: 00017289799402641570367173102287829117333605731311 1282
Processor Certificate URL: http://go.microsoft.com/fwlink/?LinkID=88338
Machine Certificate URL: http://go.microsoft.com/fwlink/?LinkID=88339
Use License URL: http://go.microsoft.com/fwlink/?LinkID=88341
Product Key Certificate URL: http://go.microsoft.com/fwlink/?LinkID=88340
Partial Product Key: XRVFB
License Status: Licensed
Remaining Windows rearm count: 2
Trusted time: 10/18/2012 9:25:10 AM
Windows Activation Technologies-->
HrOffline: 0x8004FE21
HrOnline: N/A
HealthStatus: 0x000000000001EFF0
Event Time Stamp: 10:16:2012 09:01
ActiveX: Registered, Version: 7.1.7600.16395
Admin Service: Registered, Version: 7.1.7600.16395
HealthStatus Bitmask Output:
Tampered File: %systemroot%\system32\sppobjs.dll
Tampered File: %systemroot%\system32\sppc.dll|sppc.dll.mui
Tampered File: %systemroot%\system32\sppcext.dll|sppcext.dll.mui
Tampered File: %systemroot%\system32\sppwinob.dll
Tampered File: %systemroot%\system32\slc.dll|slc.dll.mui
Tampered File: %systemroot%\system32\slcext.dll|slcext.dll.mui
Tampered File: %systemroot%\system32\sppuinotify.dll|sppuinotify. dll.mui
Tampered File: %systemroot%\system32\slui.exe|slui.exe.mui|COM Registration
Tampered File: %systemroot%\system32\sppcomapi.dll|sppcomapi.dll. mui
Tampered File: %systemroot%\system32\sppcommdlg.dll|sppcommdlg.dl l.mui
Tampered File: %systemroot%\system32\sppsvc.exe|sppsvc.exe.mui
Tampered File: %systemroot%\system32\drivers\spsys.sys
HWID Data-->
HWID Hash Current: LgAAAAEAAQABAAEAAAACAAAAAgABAAEA6GGOQ6LA3hEEu5i87L/B47jj7MtcXQ==
OEM Activation 1.0 Data-->
N/A
OEM Activation 2.0 Data-->
BIOS valid for OA 2.0: yes
Windows marker version: 0x20001
OEMID and OEMTableID Consistent: yes
BIOS Information:
ACPI Table Name OEMID Value OEMTableID Value
APIC PTLTD APIC
FACP INTEL CALPELLA
HPET INTEL CALPELLA
BOOT PTLTD $SBFTBL$
MCFG INTEL CALPELLA
SLIC ACRSYS ACRPRDCT
SSDT PmRef CpuPm
Old 18th Oct 2012, 18:10   #13
deathtaker27
Probook Addict
deathtaker27's Avatar
deathtaker27 is a Super Spamming Saiyandeathtaker27 is a Super Spamming Saiyandeathtaker27 is a Super Spamming Saiyandeathtaker27 is a Super Spamming Saiyandeathtaker27 is a Super Spamming Saiyandeathtaker27 is a Super Spamming Saiyandeathtaker27 is a Super Spamming Saiyandeathtaker27 is a Super Spamming Saiyandeathtaker27 is a Super Spamming Saiyandeathtaker27 is a Super Spamming Saiyandeathtaker27 is a Super Spamming Saiyan
Right click it and select run as administrator if your on vista or above
deathtaker27 is offline   Reply With Quote
Old 1st Nov 2012, 16:19   #14
short1uk
Multimodder
short1uk's Avatar
short1uk can run Crysisshort1uk can run Crysisshort1uk can run Crysisshort1uk can run Crysisshort1uk can run Crysisshort1uk can run Crysisshort1uk can run Crysisshort1uk can run Crysis
Is the software protection service started?
__________________
Intel i5 750 Lynnfield 2.67Ghz, Gigabyte P55M-UD4, Corsair 4GB XMS3, NVIDIA GeForce GT 430 1GB, 2 x 1TB Samsung HD, 650w Antec PSU, Cool Master Elite 330 case
[www.bodtree.co.uk
short1uk is offline   Reply With Quote
Old 1st Nov 2012, 17:51   #15
javaman
May irritate Eyes
javaman's Avatar
javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.
I had this with HP. They carried out a bios update from their auto downloader software which changed the Identity of the the bios. HP's response was "its my fault since I hadn't created a backup" despite the fact it was their own pre installed bloatware that I hadn't got round to removing. Even within warrenty they refused to fix it unless I paid postage for it to be sent and returned with 100 for time spent looking at it and repair disk. After talking to Ebuyer they where kind enough to give me credit and was able to get a new PC.
javaman is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
