#121 |
Professional Sleever & Modder
I have made some work on the 3D Scetch now...I think i have made a very good job, i stardey for he first time yesterday and this goes like a charm! I have made awsome progsess until today an i hope i will get better on it, this will be very needed for my second project...
The case ![]() ![]() I found some components ![]() ![]() The radiators: ![]() The reservoir: ![]() ![]() Finished reservoir: ![]() ![]()
#122 |
Multimodder
nice
#123 |
Making You Feel Old Since 2010
Agreed, can't wait for the rest!
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2) "The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181 |
#124 |
#125 |
Finished the rads with a last touch and i made a front radiatorholder, where the exaust also will be, it will be awsome when i have this in front of me when i work with the case!, nothing can go wrong !
![]() ![]() The radholder at the front, will be some major changes on it , there will be a fan on the other side of it to save some space! and the fans will be added to the 240rad![]()
#126 |
Now i has finally made some more things!: Pump + Reservoir with a fitting is fixed, some fans and small changes are there for made aswel
, it begins to look like i high end system now!To@Sack! Sure the fit ! with a little marginal too !![]() ![]() The overall picture: (will be fun with the final rendering!) ![]() ![]()
#127 |
Ooh, it seemed like you had a lot of space to work with but when everything goes in it's severely cut down. Will you be watercooling your GPU? Becuse it looks like a 480 and heaven forbid how hot that might get looking at the renders!
__________________
#129 | |
![]() hmm i wounder too brow ;o), i do it to actually, i hope it works :/ |
#130 |
Now it is getting tight in the scetch, but as I say ... tight is just cozy!
Water Block and Psu where fitted , I should just cut a hole for SFX also![]() It seems seems that the scetch is almots done... there is just some stuff left ![]()
#131 |
I have now made an extender/raiser to the PSU, I thought to mount PSU as I showed above, the raiser will raise the PSU from the case's bottom and then I can mount the power cord on the bottom where I can access the switch on a light way
, I will use myself out of 25mm M3 screws , it will be so fine!![]() ![]() ![]() Has also changed the banner ... finally !
#132 |
Now i have cut a hole on the bottom! Soon it will be assembling and grouping of the models
! It will be fun o see the finished render !
#133 |
Now I have finally finished the bottom part, which I have grouped together with the base plate, the Raiser and the PSU ... it is not so much to do...or is it?? let me know if I forgot something!
#134 |
Then it was finally finished...im joking...the top panel is done, the cutout on it is perfect
, I can't whait until i start modding the case ! ![]()
#135 |
Multimodder
nice
#136 |
Interesting, and very good looking!
__________________
#137 |
#138 |
Never stuck with stock@Hotmods.net
Thorough planning - I hope it pays off in the end!
__________________
Best regards, Nutman Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks |
#139 |
#140 |
Minimodder
Awesome bro...subbed
| Tags |
| bitspower, chokolate, djungelapa, lamptron, temptation |
| Thread Tools | |
| View Mode | |
