Reply
Thread Tools View Mode
Old 12th Aug 2011, 16:03   #61
Deneteus
What's a Dremel?
Deneteus has yet to learn the way of the Dremel
Just a suggestion on the Dye
Don't use it. It's a pain in the arse to clean out of your loop and it can get stuck in the microchannels in certain blocks and muck up stuff. It looks neat but it has a price.
Deneteus is offline   Reply With Quote
Old 13th Aug 2011, 21:32   #62
l3p
www.^.nl
l3p's Avatar
l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.
Thanks guys!
Been polishing for 2 hours on the 3 holes to make it as straight as possible with nice round corners.
But finally they fit!
Tape can be removed.
Still need to paint the blank aluminum corners.
Need to be careful with the sawdust, so cleaned it first.
And further on with the plexi front for the Koolance controller.
Taping it first.
Drawing the round corners.
Started off with the dremel again, but the jigsaw won again
And again polishing.
Marking the plexi.
And again polishing it.
And it fits.
Next job like this im going to look for a lasercutting company near me
Further on tomorrow!
__________________
Preparing: Raz3r D3sk
Running : L3p Parvum
Finished : Cross - L3p AlCu - L3p L4n - L3p D3sk
Sites: www.l3p.nl - www.redharbinger.com
l3p is offline   Reply With Quote
Old 13th Aug 2011, 21:35   #63
Nutman
Never stuck with stock@Hotmods.net
Nutman's Avatar
Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.
Neat!
__________________
Best regards, Nutman
Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks
Nutman is offline   Reply With Quote
Old 13th Aug 2011, 22:00   #64
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Nicely done, wow it must have been a bit intense cutting this case but you done it well, phew .
Waynio is offline   Reply With Quote
Old 14th Aug 2011, 11:56   #65
l3p
www.^.nl
l3p's Avatar
Thanks Nutman and Waynio!
It really was intense, will also be my last 5mm thick case to make holes in
__________________
Old 16th Aug 2011, 22:55   #66
l3p
www.^.nl
l3p's Avatar
Small update from Picasso :P
Carefully removed the tiny sharp edge with an old knife.
This way I get a sloping edge of +/- 0.3 mm.
Selected the right "black" out of 4 colours to get the best matching colour.
It became Revell mat black #6
The edges of the Bitspower mesh with Revell shiny black #7
Actually not my kind of job, too shaky
But i did it!
Tomorrow the fanguards back in.
And waste some time on this
__________________
Old 17th Aug 2011, 02:20   #67
PureSilver
E-tailer Tailor
PureSilver's Avatar
PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.
Oh, man, it's been so long since I've seen someone lap a CPU on here. Looking forward to this!
__________________
Intel Core i7 920 @ 3Ghz, Noctua NH-U12P SE, Asus P6T Deluxe V1, Corsair 12GB (6x2GB) 1600Mhz C8 @ XMP,
EVGA GTX-680, Corsair AX750, 2x Samsung SpinPoint F3 1TB, Lian-Li V1020R with 3x Noctua NF-P12 & 3x NF-P14FLX
2.4Ghz 13" unibody MacBook, 4GB RAM & 128GB Samsung SSD
PureSilver is offline   Reply With Quote
Old 17th Aug 2011, 07:14   #68
Nutman
Nutman's Avatar
Hey, that's a great paint job - the dried surface looks very even and clean. Well done.
__________________
Old 17th Aug 2011, 07:23   #69
p0Pe
gief cake?
p0Pe's Avatar
p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!
As said, thats wicked work man! If i did not knew better i would say that was factory made
__________________
p0Pe is offline   Reply With Quote
Old 17th Aug 2011, 08:30   #70
Waynio
Waynio's Avatar
Ahh nicely painted edges & good to see you looked for the right black, excellent work .
Old 17th Aug 2011, 09:23   #71
l3p
www.^.nl
l3p's Avatar
Ok i'll make some extra pictures of it
Thanks a lot guys!
I'm really not into painting but i'm glad I succeeded
__________________
Old 18th Aug 2011, 14:51   #72
l3p
www.^.nl
l3p's Avatar
Lovely weather yesterday, so went out to lap my Cpu
This time I'm going to lap it faster then normal.
How to with extensive explanation can be found here:
http://www.l3p.nl/other-builds-mods/cpu-lapping/
Cpu still WITH warranty here
All you need..
Finding a way to protect the backside of the Cpu since Intel doesn’t
give a nice protection cap any more on boxed s1155 Cpu’s.
So we use marking / painters tape.
I’m using some rubber tape too.
This way you have a better grip and don’t get sore fingers.
Starting with P400.
Only a few “wipes” and … gone warranty.
The sanding with P400 is the most important and longest step.
Some people tape the sandpaper to the mirror, but if you hold it tight with your other hand you don’t have to.
Just go from left to right on the paper.
Don’t press on the cpu, just use the weight of your hand.
Every 2 minutes turn the cpu 90° clockwise.
2 Minutes with P400.
Nothing to see yet.
7 Minutes with P400.
You can see clearly this Cpu isn’t flat.
Another 3 Minutes with P400.
Total 10 Minutes.
Another 10 Minutes with P400.
Total 20 Minutes.
And another 10 Minutes with P400.
Total 30 Minutes.
You can see the IHS is completely flat copper now.
Now the real polishing comes.
10 Minutes with P600.
Total 40 Minutes.
Skipping P800.
Straightly to P1000.
10 Minutes with P1000.
Total 50 Minutes.
You can see it’s already starting to mirror.
Further on with P1500.
10 Minutes with P1500.
Total 1 hour.
P2000.
10 Minutes with P2000
Total 1 hours and 10 Minutes
Now we need to change our strategy.
First of all clean the mirror and the cpu.
This is because the old copper particles can ruin your polish job by rubbing them into the IHS.
Now you don’t go from left to right with the cpu.
Just move in a circle for 2 minutes and then turn the cpu 90° clockwise again.
10 Minutes with P2500.
Total 1 hours and 20 Minutes.
You can see the copper dust already starts to oxidise.
5 Minutes with P2500.
Total 1 hours and 25 Minutes.
Almost done. :P
Another 5 Minutes with P2500
Total One and a half hour!
Pictures are clickable for full resolution.
Back to the case tomorrow
__________________
Old 18th Aug 2011, 15:01   #73
KoSoVaR^
Professional Sleever & Modder
KoSoVaR^'s Avatar
KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.
good work as i asid back i FB
KoSoVaR^ is offline   Reply With Quote
Old 18th Aug 2011, 15:04   #74
Waynio
Waynio's Avatar
Done this before got 10c less overall combined with lapping a thermalright ultra extreme which had a notoriously bad un flat base but once lapped 1 of the best air coolers ever, nice finishing shots .
Old 18th Aug 2011, 15:08   #75
rayson
turningthatintosomethingb ettercmod
rayson has yet to learn the way of the Dremel
do you have video on how you did it
the lapping too scared to do it without seeing someone trustable do it
tried it once used wet paper it sucked got blac dust on it
rayson is offline   Reply With Quote
Old 18th Aug 2011, 15:47   #76
miahallen
Team IRONMODS - World Champions!
miahallen's Avatar
miahallen has yet to learn the way of the Dremelmiahallen has yet to learn the way of the Dremel
Nice lap job
miahallen is offline   Reply With Quote
Old 18th Aug 2011, 21:04   #77
l3p
www.^.nl
l3p's Avatar
Well thanks again
Thanks Waynio!
I lapped my Thermalright Extreme too, together with my first lapped Cpu
I won 4-6 degrees with it.
No i'm sorry, don't have any video's, but you can find a lot on the net.
Watch a video and use my guide and you'll succeed :P
Originally Posted by miahallen View Post
Nice lap job
Thanks m8!
__________________
Old 19th Aug 2011, 08:26   #78
Kylevdm
The Mod Zoo Podcast Host
Kylevdm's Avatar
Kylevdm is a hoopy frood who really knows where their towel is.Kylevdm is a hoopy frood who really knows where their towel is.Kylevdm is a hoopy frood who really knows where their towel is.Kylevdm is a hoopy frood who really knows where their towel is.Kylevdm is a hoopy frood who really knows where their towel is.Kylevdm is a hoopy frood who really knows where their towel is.Kylevdm is a hoopy frood who really knows where their towel is.Kylevdm is a hoopy frood who really knows where their towel is.Kylevdm is a hoopy frood who really knows where their towel is.Kylevdm is a hoopy frood who really knows where their towel is.Kylevdm is a hoopy frood who really knows where their towel is.
Good work dude Loving the lapped CPU photos!
__________________
Kyle van der Merwe host at www.TheModZoo.com Podcasts!
Project: Codename C :: LANBOY APOCALYPSE (built with MNPCTECH!) :: Project: Deadline :: Project: MNU
Projects supported by EK Waterblocks, MNPCTECH, Fractal Design, NZXT, ENERMAX, and TM3 Connections
Core i7 920 D0 :: Asus P6T Deluxe v2 :: 6GB Crucial BalistiX :: Asus GTX 570 :: ENERMAX Platimax 850W :: OCZ Agility 3 120GB :: 4x Samsung SpinPoint F3 1TB
Kylevdm is offline   Reply With Quote
Old 19th Aug 2011, 09:55   #79
p0Pe
gief cake?
p0Pe's Avatar
The last few pics are pure pr0n!
How about leaving the cpu without cooler on, so that we can continue to see that beautiful finish
__________________
Old 19th Aug 2011, 10:09   #80
Nutman
Nutman's Avatar
Yeah! Quick - someone! OI! Do a transparent cooling block!
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
