Reply
Thread Tools View Mode
Old 19th Aug 2011, 11:11   #81
l3p
www.^.nl
l3p's Avatar
l3p is the Cheesecake. Relix smiles down upon them.l3p is the Cheesecake. Relix smiles down upon them.l3p is the Cheesecake. Relix smiles down upon them.l3p is the Cheesecake. Relix smiles down upon them.l3p is the Cheesecake. Relix smiles down upon them.l3p is the Cheesecake. Relix smiles down upon them.l3p is the Cheesecake. Relix smiles down upon them.l3p is the Cheesecake. Relix smiles down upon them.l3p is the Cheesecake. Relix smiles down upon them.l3p is the Cheesecake. Relix smiles down upon them.l3p is the Cheesecake. Relix smiles down upon them.
Thanks!
Lol, maybe we should create a diamond WC block sicne that has some kind of thermal conductivity
__________________
Finished Projects: : www.l3p.nl
Follow me daily: www.fb.com/l3p.nl
l3p is offline   Reply With Quote
Old 19th Aug 2011, 11:28   #82
p0Pe
gief cake?
p0Pe's Avatar
p0Pe is definitely a rep cheat.p0Pe is definitely a rep cheat.p0Pe is definitely a rep cheat.p0Pe is definitely a rep cheat.p0Pe is definitely a rep cheat.p0Pe is definitely a rep cheat.p0Pe is definitely a rep cheat.p0Pe is definitely a rep cheat.p0Pe is definitely a rep cheat.p0Pe is definitely a rep cheat.p0Pe is definitely a rep cheat.
Hmm... Lets brainstorm here, what is the thermal conductivity of diamond compared to copper
And how do we find a tap that can tap the G1/4 holes:P
p0Pe is offline   Reply With Quote
Old 20th Aug 2011, 22:22   #83
l3p
www.^.nl
l3p's Avatar
Ordered something last week i could really use today
First some holes for the buttons of the pump/fan controller.
Tape so it won't move.
And some holes with 3.5mm.
Wow, it fits
Sanded the frame so i can paint it.
Oops almost forgot i also had to paint the edge where the plexi goes.
Glued the plexi.
Bitspower fanguards back in after the paintjob.
And some glue.
Rub it in with a wet finger.
Believe me this glue doesn't let go
Next problem, what to do with this..
Ah we'll see
Hmm... needs more cutting.
Losing the sharp edges and create some nice roundings.
Paint it black.
Also glued the frame for the pump/fan controller.
Second part of the ex-5.25" slot.
Let's stick the Dremel in there too.
(Not easy to hold a Dremel in one hand and a cam in the other )
And more polishing.
Making it rough so i can paint it.
And some fitting.
Painted.
Lots of work for something you hardly see back, but im satisfied for today.
Time for BBQ! :P
__________________
Old 20th Aug 2011, 22:56   #84
Nutman
Never stuck with stock
Nutman's Avatar
Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.
Nice - but won't you see the glue trough those grills?
__________________
Best regards, Nutman
Projects: Nutman - Hampen - F.O.B. T.C. - BabyShark - The Scratchbench
Nutman is offline   Reply With Quote
Old 21st Aug 2011, 00:18   #85
Drysofar
Modder
Drysofar has yet to learn the way of the Dremel
Would be good, Diamond is 2 to 6 times a better conductor of heat than copper, bitch to mill though.. Maybe you could grow it
__________________
If you're not living on the edge you're taking up too much space..
Drysofar is offline   Reply With Quote
Old 21st Aug 2011, 00:38   #86
l3p
www.^.nl
l3p's Avatar
Thanks and nope, you can't see it, i'll make some detailed photo's soon for you
__________________
Old 21st Aug 2011, 02:23   #87
Nutman
Nutman's Avatar
Yup. You can.
__________________
Old 23rd Aug 2011, 18:59   #88
KoSoVaR^
Professional Sleever & Modder
KoSoVaR^'s Avatar
KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.
good work in progses dude!, i cant whait to put my hands into my build !, the case has finally arrived and om my birthday too !
KoSoVaR^ is offline   Reply With Quote
Old 23rd Aug 2011, 19:07   #89
rayson
Damn sure it was legal
rayson has yet to learn the way of the Dremel
beautiful
rayson is offline   Reply With Quote
Old 23rd Aug 2011, 22:41   #90
l3p
www.^.nl
l3p's Avatar
Thanks guys!
Kosovar, let me know when you've got it
__________________
Old 24th Aug 2011, 00:41   #91
KoSoVaR^
KoSoVaR^'s Avatar
Originally Posted by l3p View Post
Thanks guys!
I have got it today on my bithday amd a pacage from bitspower aswell . what a epic day !!!!
Old 24th Aug 2011, 05:27   #92
l3p
www.^.nl
l3p's Avatar
Congratulations m8!
__________________
Old 24th Aug 2011, 05:46   #93
KoSoVaR^
KoSoVaR^'s Avatar
Congratulations m8!
hehe thanks dude !, i will make an update later, will pst when on fb
Old 24th Aug 2011, 07:53   #94
Fuganater
Supermodder
Fuganater's Avatar
Fuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run Crysis
Good work so far l3p. Can't wait for the next update!
Fuganater is offline   Reply With Quote
Old 27th Aug 2011, 23:58   #95
l3p
www.^.nl
l3p's Avatar
Assembled the case again this week
Quite some work cause of the lcd screen
After that tested if the Velcro would work out.
Works great, i think it can hold me too :P
Pulling it off again wasn't that easy
Placed the other stuff again too.
Don't want too much lights on the outside, i like it this way.
Maybe some red glow from the bottom...
Maybe the top casewindow will be blood red plexi too.
Here an airflowtest with the new fanholes.
__________________
Old 28th Aug 2011, 02:33   #96
Attila
still thinking....
Attila's Avatar
Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.
Well, I never would have thought of velcro to hold the radiator. Great idea. And nice work all round.
__________________
stillthinking
Attila is offline   Reply With Quote
Old 28th Aug 2011, 09:45   #97
l3p
www.^.nl
l3p's Avatar
Thanks Attila
I will probably start a scratch build again after seeing your latest work
__________________
Old 28th Aug 2011, 13:48   #98
KoSoVaR^
KoSoVaR^'s Avatar
why velcro on such a serious build mate :O, i dont think it will hold with all the water in place :/
Old 28th Aug 2011, 13:56   #99
l3p
www.^.nl
l3p's Avatar
Venhar, don't worry, the velcro doesn't have to hold the rads weight, just to hold it on it's place.
The rad itself wil be standing on a few layers of rubber tape.
__________________
Old 28th Aug 2011, 14:10   #100
KoSoVaR^
KoSoVaR^'s Avatar
ahaa i see ! great thought and great idea!
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
