Go Back   bit-tech.net Forums > Modding > Modding
View Poll Results: Vote for as many as you like
danitgeek 3 3.95%
GuilleAcoustic 31 40.79%
jrs77 7 9.21%
Gearheaddan 16 21.05%
k0rben 14 18.42%
eeced 35 46.05%
KayinBlack 9 11.84%
Dark~3nergy 10 13.16%
asura 8 10.53%
HardstylerDK 5 6.58%
13eightyfour 14 18.42%
Cheapskate 11 14.47%
Editor22 8 10.53%
Multiple Choice Poll. Voters: 76. You may not vote on this poll
Reply
Thread Tools View Mode
Old 3rd Jul 2011, 07:42   #1
confusis
Kiwi-modder
confusis's Avatar
confusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysis
MNPCTech Design Contest Volume 6 - VOTING
Hey guys, let's go!
For this round of the MNPCTech Design contest, we based the designs on the Cooler Master HAF932!
This was a one month long contest, with a community vote at the end to decide the top 3 placings. The contest was not restricted to any software, as long as the final entry is NOT rendered! (ensures a level playing field in regards to eye candy, etc)
Thanks heaps once again to our sponsors, MNPCTech, and a newcomer this round, Aurora Creative Studios NZ, and thanks to Jez for continuing to host the Sketchup Component Collection. Also thanks to Craigr1982 for supplying the model on which we will mod!
Prizes:
1st Place "Anodized Billet Pron by Mnpctech" Prize Package
+ US$30 MNPCTech voucher supplied by Aurora Creative Studios NZ
1x set of Black Anodized Billet "Diamond Knurl" PC Feet. Product Details
1x Black Anodized Billet 120mm Fan Grill with Honeycomb insert. Product Details
1x set of 4 Black Anodized Aluminum Thumbscrews 6/32 thread. Product Details
20x Black Pop Rivets for PC Chassis. Product Details
2nd Place "PC Modding Tools!" Prize Package
+ US$20 MNPCTech voucher supplied by Aurora Creative Studios NZ
1x Aluminum PC Mod Ruler & Reference Tool. Product Details
ATX Power Supply Pin Removal Tools. Product Details
1x ATX Pin Removal Tool (PSU & PCI-e)
1x ATX Molex Removal Tool (Male & Female) ATX Power Supply Pin Removal Tools. Product Details
3rd Place "Custom DIY window" Prize Package
+ US$10 MNPCTech voucher supplied by Aurora Creative Studios NZ
1x 12" x 12" cast acrylic PC window sheet. Product Details
1x 6 ft Mnpctech u-channel window molding. Product Details
1x roll of Scotch Tape #4010 super strength mounting tape, Product Details
[/CENTER]
Here are the entries we recieved this round:
danitgeek
"The Haf Urban
2 Psu Mounts
9x 120mm fan options
Atx/M-Atx/Itx
Mountaing options for 2 reservoirs
2x 2.5inch hard drive hot-swap bays
2x 3.5inch hard drive hot-swap bays
3x 3.5inch hard drive bays"
Click here for more images of danitgeek's design!
GuilleAcoustic
"HAF a tonne of copper, HAF air cooled, HAF water cooled ... but not HAF cool. 100% cool
- Fit a quad-opteron 12-cores and its quad-opteron 12-cores expansion board (96 cores crazyness)
- 6x hot-swap HDD bay
- 6x HDD activity LED (1 per drive)
- Motorized HDD door
- 2x 220mm intake fans
- 3x 120mm exhaust fans (2x top fans, 1x back fan)
- full copper top acting like a passive rad
- massive surrounding passive rad (3m² of dissipating surface)
- Quick disconnect connector to connect the rad to the case (easy maintenance)"
Click here to see more images of GuilleAcoustic's design!
jrs77
"Hafnium"
Click here to see more images of jrs77's design!
Gearheaddan
"HAF ROD
I designed it after the front end of an old school hot rod and tried to keep it to something that would actually be able to be built in regards to cost and still somewhat resemble the original case.
There are 2x 200mm fans behind the front grill, the air cleaner intakes on top are for the cpu radiator, and the hot air from the rad exits through the exhaust pipes."
Click here to see more images of Gearheaddan's design!
k0rben
"Mantis
Packed with a 2x480 rads,3xGTX295 and 2 custom mounted reservoirs"
Click here to see more images of k0rben's design!
eeced
"Air makes it so easier to breath than water, so I'm going for aircooling (that made no sence whatsoever). A case for two friends to drag (carrying probably not possible) to a lan party, a two in one computer."
Click here to see more images of eeced's design!
KayinBlack
"Self-contained waterfall cooling, and the top res is a fishtank, complete with filter."
Click here to see more images of KayinBlack's design!
Dark~3nergy
Click here to see more images of Dark~3nergy's design!
asura
Click here to see more images of asura's design!
HardstylerDK
Click here to see more images of HardstylerDK's design!
13eightyfour
Click here to see more images of 13eightyfour's design!
Cheapskate
Click here to see more images of Cheapskate's design!
Editor22
Click here to see more images of Editor22's design!
Good luck. Vote for as many entries as you like!
confusis is offline   Reply With Quote
Old 3rd Jul 2011, 07:57   #2
j0rd
FLOSS folder
j0rd's Avatar
j0rd has yet to learn the way of the Dremel
what if there is a tie for first / second / third place?
__________________
Word Press blog
Losias stats tracker (under development) is here
‾pɹ0ɾ
j0rd is offline   Reply With Quote
Old 3rd Jul 2011, 08:09   #3
confusis
Kiwi-modder
confusis's Avatar
The sponsors will discuss the options at that point.
Idea for round 7
Best of the best - invitational only!
Get together the top 3 placegetters of the previous contests and throw them in the ring together, 1 month to design a free for all case around a certain motherboard.
It would be randomly selected from the SCC collection, unless a manufacturer (ASUS, Gigabyte, etx HINTHINT) get involved
Old 3rd Jul 2011, 08:11   #4
j0rd
FLOSS folder
j0rd's Avatar
sounds like a plan
__________________
Word Press blog
‾pɹ0ɾ
Old 3rd Jul 2011, 08:23   #5
confusis
Kiwi-modder
confusis's Avatar
Previous winners:
Contest #5
Bartaggio
Burnout21
Langer
#4
Dark~3nergy
Lenne0815
Confusis
#3
Editor22
Cheapskate
Confusis
#2
Scooby
jrs77
Dark~3nergy
#1
Dark~3nergy
=Cheapskate
=bentleya
confusis
Which leaves, before this vote ends:
Bartaggio
Burnout21
Langer
Dark~3nergy
Lenne0815
Confusis
Editor22
Cheapskate
Scooby
jrs77
bentleya
As contestants in invite only..
Old 3rd Jul 2011, 19:06   #6
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
I don't think I'm eligible for this, although it doesn't look like it matters.
I have to say I don't like your idea for the next contest. Limiting the contestants also limits the potential output. For example, Scooby popped in for contest two and really blew us away.
I think sending invites to former designers so they know the contest exists is good. I'd also like another open format contest. The ideas get really freaky.
Upping thetime limit would bring in some of the busier builders too. It might get dull for the readers, but the end results should be worth it.
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 3rd Jul 2011, 20:54   #7
Editor22
E22 | Hex-Gear
Editor22's Avatar
Editor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming Saiyan
Aww I really wish I could have found more time to get this finished been paying close attention to the thread though and I have to say Guille's design really does push all my buttons in the right places ;D
I don't really have an opinion on the idea for #7 I would feel privileged to be offered a spot but at the same time I can see the downsides as cheap's mentioned. Also if you only limit it to the 7 - 10 finalists then your having to count on everyone being free for that month to get their designs in which could end up with only a few final entries
Adding on Cheaps extended time limit idea, why not run a "knock out" competition with small prizes for each stage and then a grand prize for the over all winner over say a 3 month period. Something like;
Month 1 / Round 1
  • Initial design / roughing
  • Voting
  • Top 10 go through to round 2
  • Small prizes for the top 2
Month 2 / Round 2
  • Semi complete
  • Voting
  • Top 5 go through to round 3
  • Small prizes for the top 3
Month 3 / Final
  • Final Designs / Renders
  • Voting
  • Winners announced
  • 1st place = Grand prize 2nd & 3rd = smaller prizes
Just an idea
__________________
Stores: E22 | HEX GEAR
Social: Youtube | Facebook
Projects: Evolution | K2 MK1 | 21
Editor22 is offline   Reply With Quote
Old 3rd Jul 2011, 21:47   #8
GuilleAcoustic
Ook ? Ook !
GuilleAcoustic's Avatar
GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.
Month 1 / Round 1
  • Voting
Month 2 / Round 2
  • Semi complete
  • Voting
Month 3 / Final
  • Voting
  • Winners announced
Just an idea
@Editor22 : thanks mate
Kind of reminds me of the Phobya contest (with the per stage prize added). Very nice idea. The phobya contest was a very nice experience, I learned a lot and it was nice sharing with everyone on this community. I'm new to case modding and it was a perfect first time, very teaching.
Thanks to MNPCTesh, Confusis, Aurora Creative Studios NZ, and everyone involved. Good luck to all contestants.
@Confusis : How long will the vote last ?
GuilleAcoustic is offline   Reply With Quote
Old 3rd Jul 2011, 21:56   #9
asura
jack of all trades
asura's Avatar
asura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyan
I like the idea of a limited competition, and basing it on previous winners will make it (hopefully) of a higher quality. However you may get some people grumping about being unable to compete, perhaps it would be best to have a divided competition with different classes (like Le Mans) and suitably staggered prizes; e.g. previous top3, previous top 10, open.
I hadn't expected to see my entry here it being unfinished (hardly started) and entirely undeserving of any votes at it's current level of development.
asura is online now   Reply With Quote
Old 3rd Jul 2011, 22:20   #10
confusis
Kiwi-modder
confusis's Avatar
Open and Invitational, good idea.. may be harder to get enough prizes though.. I'll have to see what I can do.
Vote will be for 21 days from yesterday.. Thought with it being summer up there folks may not be on as often
Old 4th Jul 2011, 13:55   #11
GuilleAcoustic
Ook ? Ook !
It's very quiet here
@confusis : the #7 is going to be a scratch build only around a mobo or will it be scratch / case mod ?
Old 4th Jul 2011, 16:40   #12
Editor22
E22 | Hex-Gear
Editor22's Avatar
Pssssst.... scratch build......
:P
__________________
Old 4th Jul 2011, 16:57   #13
GuilleAcoustic
Ook ? Ook !
I eared you : p ... And I'm sacrifying a 3DFx for a scratch build contest
Old 4th Jul 2011, 17:02   #14
Editor22
E22 | Hex-Gear
Editor22's Avatar
the gods will be happy with your sacrifice I can at least dream of it being a scratch build contest
__________________
Old 4th Jul 2011, 17:13   #15
Cheapskate
Cheapskate's Avatar
+1 on a scratch build. If I come up with something cool, I can probably convince someone to build it.
__________________
Old 4th Jul 2011, 17:16   #16
GuilleAcoustic
Ook ? Ook !
You can scratch build your dream. Take a 3dfx, add a mobo and then a little touch of copper. You can even SLI your dream with a bikini contest :
possible resulting dream : gals in copper bikini fighting in cooling fuild for a brand new motherbord
Old 5th Jul 2011, 15:05   #17
GuilleAcoustic
Ook ? Ook !
UP ... and just a suggestion, but a front page would increase the person voting
Old 5th Jul 2011, 15:24   #18
Cheapskate
Cheapskate's Avatar
I just had an image of Bender's head exploding while reading that.
__________________
Old 5th Jul 2011, 17:03   #19
Nanosec
absit iniuria verbis
Nanosec's Avatar
Nanosec has yet to learn the way of the DremelNanosec has yet to learn the way of the DremelNanosec has yet to learn the way of the DremelNanosec has yet to learn the way of the Dremel
Well it wouldn't be the first time you managed to get someone to build one of your creatively cool designs.....
http://www.mnpctech.com/nvidia_ion_cube_pc_casemod.html
Nanosec is offline   Reply With Quote
Old 6th Jul 2011, 08:12   #20
GuilleAcoustic
Ook ? Ook !
I think I should stop checking the votes .... it's stressing me up
Reply
Tags
contest, design, mnpctech, voting, win!
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
