World´s First bei Cartago: the new Alphacool Radiators- now cut up!
Discussion in 'Watercooling' started by cartago2202, 4 Jul 2011.
  1. cartago2202
    cartago2202 What's a Dremel?
    19 Apr 2011
    Hi ho
    Here are some first pictures of the new Alphacool Radiators is the first in the world Cartago2202
    They are the alpha NexXxoS UT60 Full Copper 480mm
    and
    Alpha NexXxoS Full XT45 480mm Copper
    As the name suggests, are the radiators, unless of course the side plates, made of copper.
    There are all parts of copper
    which begins with the pre-& end chambers,
    The transition between the chambers of the channels
    the channels and the Finns are also made ​​of copper
    Everything else in an upcoming pre-test of the two pre-production.
    So here are the values​​:
    [SIZE ="4"]
    The test system in detail:
    [/SIZE]
    Motherboard: Asus Maximus II Formula
    Processor: Intel Core i7 860 with four 1.37 GHz @ V
    Graphics card: ATI Radeon HD6950
    Memory: 8GB Corair Vengeance CL9
    PSU: be quite! Dark Power Pro 850W P9
    HDD: 500GB Samsung F3
    Water cooling in detail: [/ B]
    CPU cooling EK Supreme HF full nickel
    GPU cooling Swiftech Komodo HD6970
    Pump: Laing Plus
    Conditions: Alphacool Cape Corp Coolplex Pro 25
    Connections: 16/10 Alphacool Screw Cooper
    DFM: AC DFM HighFlow
    Control: Aquaero5 XT
    Temperature sensors: 2xPhobya female / male screw-on ¼ and Conditions
    Hose: 16/10 Masterkleer
    5 quick couplings Koolance VLN3
    as you can see, the cooler than other 480s in the Roundup, the WLP is different from and indeed the new Phobya.
    The building is open.
    Now the values ​​in comparison to the Cool Gate Full Copper 480
    Not bad I would say. One has but to put this to emphasize that it is pre-series models. Therefore, there is no point to this conclusion.
  2. cartago2202
    19 Apr 2011
    Here are some detail photos, how to unscrew the radiator does have a "screwing protection" for them.
  3. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
  4. cartago2202
    19 Apr 2011
    I have here some very interesting pictures for you:
    Flex come out and you are needed hihihi
    So as you might easily recognize the two chamber actually made ​​of copper, thus the question should be answered clearly.
  5. GuilleAcoustic
    26 Nov 2010
    :dremel:DrCartago:dremel:
  6. cartago2202
    19 Apr 2011
    So here now the promised low even in comparison to other manufacturers.
    Price as of 12/07/2011
    Prices in Germany of Aquatuning.de
  7. cartago2202
    19 Apr 2011
    So here we have the exact dimensions
    LxW
    120mm 160x125
    240mm 280x125
    360mm 400 x 125
    480mm 518-521x125
    respectively 30, 45, 60mm deep
  8. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    How heavy are these? Thats a funky connector setup :)
  9. cartago2202
    19 Apr 2011
    and the wait finally has its end, here are the finished radiator in 120 and 360 respectively in 45mm and 60mm thick
    120er
    and 360er
