#161 |
Supermodder
You need not explain anymore!
![]() Its looking great Kier, as for the cover of the red parts, have you just covered them with film and cut it to fit ? a little yellow film might be cool ...
__________________
#162 |
What's a Dremel?
hi man tsih mod is awesome!
is great the slim line dvd-r, but i have not understand how you can eject the discs without any button?!?!?... :? |
#163 |
a.k.a KazeModz
Awesome and Im glad your doing a manifold setup with the GPUs so each block gets the same temp fluid passing through it.
Just gorgeous.
__________________
Current Rig: Project STEALTH
• DimasTech Test Bench • Black ICE Triple 120 Rad • Dual Bay Res/Pump • DD Fill Port & Res • D-Tek FuZion 2 CPU Block • ASUS M3A79-T Deluxe Mobo • AMD Phenom II 3ghz @ 4ghz • 8gb DDR2-1100 Memory • (2) AMD 6870 XFire • (2) WD Black 640gb Raid 0 • (2) 1.5TB SEAGATE • Blu-Ray/HD DVD Drive • ASUS XONAR DX2 • 30" DOUBLESIGHT LCD • (2) 23" ASUS LCD • ZALMAN 8 FAN CONTROLLER • (4) NOCTUA P12 • (2) NOCTUA P14 • 1000W ZALMAN PSU • WINDOWS 7 PRO 64 • |
#164 |
Pump Killer
Sorry for the noob question, but I just can't grasp how that manifold setup works?!
Could anyone explain to me how the water flows through those GPU blocks? ![]() Edit: Spent 10 minutes looking at it, and the second I post this, my mind get's it! ![]() But it DOES require a pretty high flow from the pump to fill all 3, doesn't it?
__________________
It's NOT a mac... http://forums.bit-tech.net/showthread.php?t=139635 - Motm nomineeWII - UNLimited Edition http://forums.bit-tech.net/showthread.php?t=179763 - Moty nominee Liquid Cooled CarPC - Sponsored by Mushkin Enhanced & Centrafuse http://forums.bit-tech.net/showthread.php?t=207889 - Motm nominee The Theory of Everything http://forums.bit-tech.net/showthread.php?t=219504 - Motm WINNER!
#165 |
Modding and coffee
Just a little small update about the cables and the hdd's
Finally I got my hdd's in, 4TB is enough for this build ![]() There's also a OCZ vertex 2 ssd 120 GB coming in for the OS So installed all the hdd's and routing the sata and power cables A small piece of the power is visible, but this is gonna be sleeved ![]() ![]() All the power cables are between the hdd bracket and the drive bay ![]() So almost no cables visible ![]() ![]() All the sata's are going to be sleeved and placed like this ![]() ![]() ![]() The power led, usb and other cables are placed behind the slide-out bracket (dont how it's called) ![]() This is it for the weekend. Greetings my modding friends |
#166 | |
Modding and coffee
the good thing is that all gpu's gets the same temps like HourBeforeDawn said If the passing flow is to much I can always close two fittings from the second gpu |
#167 | |
Pump Killer
![]() I'm just wondering if the last card in the serie get's most flow through it? Then the second card would get medium flow, and the first card would get the least flow. I'm guessing that liquid will take the shortest route it can... Not sure.. But the build looks frikkin awesome!
__________________
#168 | |
Never stuck with stock@Hotmods.net
But I've also wondered about it - I guess the water pressure splits equally into every opening, providing the openings are all the same size?
__________________
Best regards, Nutman Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks |
#169 | |
Modding and coffee
![]() I have an external wiring from the original eject ![]() ![]() The power button on top of the case is going to be my eject, the one in front is my powerbutton |
#170 |
Modding and coffee
![]() ![]() ![]() Update: First loop filled Finally all the acryl pipes are connected. Had some difficult issues with a few fittings but it came out fine Like the connection on the full cover block ![]() ![]() ![]() But..........everything is connected now ![]() ![]() ![]() ![]() Made some changes to the GPU loop, instead of the BP rotery snake I've used some more crystal link tubes ![]() ![]() Time for the liquid. ![]() ![]() ![]() ![]() And one loop filled. ![]() ![]() ![]() The plan was to do the second loop also............but made a mistake Need to order some more Feser because I dont have enough for the second loop So to be continued |
#171 |
Project: Elegant-Li
The plumbing looks great, really neat and tidy. The coolant reminds me of puss lol.
__________________
Project: Elegant-Li *NEW* Project: Alpha FINISHED Project: LEXA Revival FINISHED Project: LEXA FINISHED MOTM Nominee October 08 |
#172 |
Orange or White? Lets mod!
That liquid looks like a banana juice
![]() You got a explendid system over there m8
#173 |
Supermodder
I love the coolant color, it works well with the black overlaying the acrylic.
#174 |
Supermodder
high class on this one!
#175 |
Multimodder
really enjoying seeing this build coming on - its definitely inspiring me to do my own scratch build.
__________________
System Specs: Asus P8P67 Pro | 2500K @ 4.5Ghz | PNY 570GTX | 16GB XMS 1600Mhz | Be Quiet! Dark Rock Pro | Vertex 3 120 GB | 2TB Samsung HDD | Antec Truepower 650 | Fractal Design XL |
#176 |
Building Proxima
Very very niiice.
__________________
Proxima - The log of Dreams
CAGE - MOTM September 2010 Winner ------------------------------------------------------ LOSIAS.net Losias.net Facebook :: Losias.net Twitter |
#177 |
Really like this and yellow fluid is sooo cool to look at - however, it looks like it could use just a TAD more red dye to match the acrylic 100%, or is it just the camera playing tricks on me?
__________________
#178 |
a.k.a KazeModz
ya the plumbing is fantastic
__________________
#179 |
Reformed Grumpy Sod..kinda
A feast for the eyes!
__________________
-Banana in disc drive error- To win the battle, is to be prepared to die - Miyamoto Musashi |
#180 |
Bringing the dremolition
So, so profoundly awesome!
__________________
"We are the music makers and we are the dreamers of dreams" |
| Tags |
| carbon fiber, silverstone tj11 case mod, water cool tj11, yellow |
| Thread Tools | |
| View Mode | |
