Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 12th Jul 2011, 12:49   #1
arcticstoat
Hypermodder
arcticstoat's Avatar
arcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysis
GlobalFoundries prepares Tri-Gate competitor
GlobalFoundries discusses its roadmap, including a move to 3D transistors and gate-last production.
http://www.bit-tech.net/news/hardwar...e-competitor/1
__________________
Ben Hardwidge
Custom PC Editor
arcticstoat is offline   Reply With Quote
Old 12th Jul 2011, 13:05   #2
r3loaded
Ultramodder
r3loaded's Avatar
r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.
" How small can we make silicon transistors before they become unmanageable?"
Well, that's an easy one to answer - the lower bound is going to be the size of silicon atoms themselves
__________________
Main: Silverstone FT03 | Asus P8P67-M Pro | i5 2500K @ 4.6Ghz | CM 212+ | 16GB Corsair Vengeance 1600Mhz | XFX Radeon 7970 DD | 500GB Samsung 840 Evo | Samsung XL2270HD | KBT Race | Logitech G402
Mac: 13 inch MacBook Pro 2014 | 16GB RAM | Filco Minila Air | Magic Trackpad
Server: Asus M3N78-AM | Athlon II X3 400e | 4GB Corsair XMS2 | 4x 2TB Samsung F4EG (RAID-5) | LSI MegaRAID 8708EM2 | Corsair CX400 | Arch Linux
r3loaded is offline   Reply With Quote
Old 12th Jul 2011, 13:16   #3
Jezcentral
Multimodder
Jezcentral has yet to learn the way of the Dremel
So, are we on course for Moore's Law to break down in 2017?
Jezcentral is offline   Reply With Quote
Old 12th Jul 2011, 14:17   #4
Xir
I Mod, Therefore I Own
Xir's Avatar
Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.
wouldn't happen to have mentioned something like "Triple-Spacer" or "Finfet" now would he?
__________________
SN25P
A64 3700+ (San Diego)
2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T
X1800XT 512mb Sapphire
200GB Samsung SP2004C 24" Asus VW246H 1920x1080
Xir is offline   Reply With Quote
Old 12th Jul 2011, 14:21   #5
WildThing
Hypermodder
WildThing's Avatar
WildThing is the Cheesecake. Relix smiles down upon them.WildThing is the Cheesecake. Relix smiles down upon them.WildThing is the Cheesecake. Relix smiles down upon them.WildThing is the Cheesecake. Relix smiles down upon them.WildThing is the Cheesecake. Relix smiles down upon them.WildThing is the Cheesecake. Relix smiles down upon them.WildThing is the Cheesecake. Relix smiles down upon them.WildThing is the Cheesecake. Relix smiles down upon them.WildThing is the Cheesecake. Relix smiles down upon them.WildThing is the Cheesecake. Relix smiles down upon them.WildThing is the Cheesecake. Relix smiles down upon them.
Nice to see Intel's competition doing something, and thanks Paul for the gate-first vs gate-last explanation, been wanting to read up on that for a while now. Cheers.
__________________
Asus P8P67 PRO Intel i5 2500K @ 4.4GHz Titan Fenrir XFX 6950 @ 6970 2x4GB Corsair DDR3 1600MHz 2x Crucial C300 128GB (OS + Games) Samsung Spinpoint F3 1TB Auzentech XFI-Prelude + Creative T7700 7.1 Enermax Liberty 500W Corsair 650D case HP 24" LP2475W Win7 x64
WildThing is offline   Reply With Quote
Old 12th Jul 2011, 15:16   #6
azazel1024
Supermodder
azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.
Last I heard the issues are around 8-10nm and that is about where any current and most theoretical manufacturing techniques are unable to produce a viable transister. So we have at least another 4-6 years before we are at neeing a major "break through" to keep advancing transister size.
The gist I got from the article is basically that "Hi, we are 1-2 years behind Intel, but don't worry, that works for us!"
Most of the time I hear things about using "backwards" technology because you haven't innovated or there is a defect, companies always spin it as a "design feature" or "it gives us X benifit". So 10-20% space savings compared to gate last at 28nm, I doubt that, or if true it is because of your manufacturing technique and the way you are laying out the chips. That or it may be true, but yields are significantly lower for you to change or too much time redesigning the process. Or it may also be true, but transistor performance is lower.
Since Intel and TSMC are doing gate last I don't think they decided to do that for no reason.
__________________
Core 2 Duo E7500, MSI P43-C51, 2x2GB G.Skill Eco DDR3 1600 Cas 7, OCZ Vertex 60GB, Vertex 30GB, Samsung F3 500GB, Samsung F4 2TB, Powercolor Go Green ATI 5570
azazel1024 is offline   Reply With Quote
Old 12th Jul 2011, 16:10   #7
Bindibadgi
Am I out of touch?
Bindibadgi's Avatar
Bindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming Saiyan
Thanks for the write-up Paul!
__________________
The bitterness of poor quality remains long after the sweetness of low price is forgotten.
Bindibadgi is offline   Reply With Quote
Old 12th Jul 2011, 17:48   #8
John_T
Supermodder
John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.
I love reading all this kind of stuff, even though I'll admit to only understanding about half of it!
I am amazed by the constant shrinking process, even more so when I look back at some of the older PC's I've had over the years. The original Pentium was, I believe, based on an 800nm technology - so to now have 28nm, to be preparing 20nm - and to be talking about 14nm transistors being well underway, I do think it's all pretty amazing.
Just roll out a tape measure to 800mm, then roll it back down to 20mm & 14mm for a visual comparison of scale. It's astonishing what they have been able to achieve in such a short space of time really...
John_T is offline   Reply With Quote
Old 13th Jul 2011, 03:55   #9
ssj12
Hypermodder
ssj12 has yet to learn the way of the Dremel
Why is it I suspect they saw Intel's tech announcement and said "oh crap, get to the drawing board ASAP!?"
ssj12 is offline   Reply With Quote
Old 13th Jul 2011, 07:06   #10
Bindibadgi
Am I out of touch?
Bindibadgi's Avatar
FinFETs (branded 3D transistors) were originally developed by IBM actually iirc - who GloFo is in a co-operative development relationship.
It was on Ee times I think.
http://en.wikipedia.org/wiki/Multigate_device
__________________
Old 13th Jul 2011, 12:33   #11
Xir
Xir's Avatar
Yup. The AMD-IBM alliance (direct follower of the AMD-Motorola alliance)
__________________
SN25P
Old 13th Jul 2011, 12:37   #12
stonedsurd
Is a cackling Yuletide Belgian
stonedsurd's Avatar
stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.
That's more along the lines of what I'd like to see around here. Great article and well done Bit!
PS: Paul, do have an aunt named Holly?
__________________
stonedsurd is online now   Reply With Quote
Old 13th Jul 2011, 22:49   #13
ssj12
Hypermodder
That sounds like a horrid alliance. Thank god I have my Droid X2.
Old 15th Jul 2011, 10:04   #14
Xir
Xir's Avatar
The AMD-Motorola Alliance gave you copper-interconnects which led to the break of the 1Ghz barrier.
(while Intel still said...naah Aluminum will do just fine)
__________________
SN25P
Old 19th Jul 2011, 01:14   #15
saneblane
What's a Dremel?
saneblane has yet to learn the way of the Dremel
intel may be ahead in lithography but IBM is always ahead in R&D, that company just knows how to conduct themselves. and what they develop is the research they do benefit so many companies and people. amd then their is AMD, the company with the most pioneering chip designs, with the bulldozer arch, we don't even know how to count the cores. this is what happens when competitions is tough, people innovate
saneblane is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
