Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 12th Jul 2011, 13:16   #1
arcticstoat
Hypermodder
arcticstoat's Avatar
arcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysis
HDMI to Mini DisplayPort cables ruled illegal
HDMI Organisation says HDMI to DisplayPort cables are illegal, as they don't meet HDMI spec.
http://www.bit-tech.net/news/hardwar...bles-illegal/1
__________________
Ben Hardwidge
Custom PC Editor
arcticstoat is offline   Reply With Quote
Old 12th Jul 2011, 13:22   #2
jcb121
Modder
jcb121 has yet to learn the way of the Dremel
does this mean DVI-Hdmi cables are also illegal?
jcb121 is offline   Reply With Quote
Old 12th Jul 2011, 13:28   #3
wuyanxu
still wants Homeworld 3
wuyanxu's Avatar
wuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyan
totally stupid spec, the dongle does exactly the same thing as a cable, there are no signal change inside those dongles.
can't wait for the day when TV's have DisplayPort as standard.
just get them from ebay is the best way forward, there will always be such ebay items because it's clearly a superior product compared to dongle+wire. ignore this retard ruling.
__________________
i7 2700k \ 16GB \ GTX 970 \ D2x \ Z68x-UD5 \ m4 128GB +2TB \ S12G-550 \ FT02-RW \ G15+G5+G51 \ U2711
X100 \ X-E2 \ 10-24 \ 55-200 \ 18/2 \ 60/2.4 \ Yn560 \ X1.1a \ Hadley Pro -- Photostreamr
wuyanxu is offline   Reply With Quote
Old 12th Jul 2011, 13:29   #4
Unknownsock
Supermodder
Unknownsock has yet to learn the way of the Dremel
However, the HDMI Organisation says that conversion cables with a female HDMI socket on one end and a DisplayPort connector on the other (pictured) will be fine, as you still need to buy a full-spec and properly tested HDMI cable in order to use it.
Seems abit odd regardless if its male or female, it should be illegal either way? So basically as usual it all boils down to money.
Unknownsock is offline   Reply With Quote
Old 12th Jul 2011, 13:31   #5
Kiytan
Shiny
Kiytan's Avatar
Kiytan - it's over 9000!!!!!!!!1!1!1!!!Kiytan - it's over 9000!!!!!!!!1!1!1!!!Kiytan - it's over 9000!!!!!!!!1!1!1!!!Kiytan - it's over 9000!!!!!!!!1!1!1!!!Kiytan - it's over 9000!!!!!!!!1!1!1!!!Kiytan - it's over 9000!!!!!!!!1!1!1!!!Kiytan - it's over 9000!!!!!!!!1!1!1!!!Kiytan - it's over 9000!!!!!!!!1!1!1!!!Kiytan - it's over 9000!!!!!!!!1!1!1!!!Kiytan - it's over 9000!!!!!!!!1!1!1!!!Kiytan - it's over 9000!!!!!!!!1!1!1!!!
that is.....stupid beyond belief.
Kiytan is offline   Reply With Quote
Old 12th Jul 2011, 13:35   #6
faugusztin
I *am* the guy with two left hands
faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.
No, the cables are not "illegal". Only they cannot sell them as HDMI cables. The manufacturers will relabel them to something like 'XY to High Definition Interface". Case solved.
faugusztin is offline   Reply With Quote
Old 12th Jul 2011, 13:40   #7
Instagib
Ultramodder
Instagib's Avatar
Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.
Someone at the HDMI Organisation has nothing better to do than nit-pick.
__________________
Silverstone FT04B | Maximus V Extreme | i7 - 3770K @4.6 | 16Gb Corsair Vengeance LP DDR3 1600Mhz | H80i | ASUS GTX 780Ti DCII |Seasonic 660XP2
Silverstone TJ07|Rampage 3 Extreme | X5650 @ 4.2 | 12Gb Corsair DDR3 1600mhz | EVGA GTX680 | Akasa 1000W Powermax | 480 rad; all under water
Instagib is offline   Reply With Quote
Old 12th Jul 2011, 13:44   #8
Salty Wagyu
moo
Salty Wagyu's Avatar
Salty Wagyu - it's over 9000!!!!!!!!1!1!1!!!Salty Wagyu - it's over 9000!!!!!!!!1!1!1!!!Salty Wagyu - it's over 9000!!!!!!!!1!1!1!!!Salty Wagyu - it's over 9000!!!!!!!!1!1!1!!!Salty Wagyu - it's over 9000!!!!!!!!1!1!1!!!Salty Wagyu - it's over 9000!!!!!!!!1!1!1!!!Salty Wagyu - it's over 9000!!!!!!!!1!1!1!!!Salty Wagyu - it's over 9000!!!!!!!!1!1!1!!!Salty Wagyu - it's over 9000!!!!!!!!1!1!1!!!Salty Wagyu - it's over 9000!!!!!!!!1!1!1!!!Salty Wagyu - it's over 9000!!!!!!!!1!1!1!!!
Why do the HDMI Organisation do nothing about 100 Monster cables?
__________________
Main System & HTPC Specs
Salty Wagyu is offline   Reply With Quote
Old 12th Jul 2011, 13:52   #9
smc8788
...at least I have chicken
smc8788's Avatar
smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.
You might be waiting a while, HDMI has pretty much established itself as the de facto standard for TVs and AV equipment now so most companies will see no good reason to add an additional connector 'just' because it's technically superior. I think HDMI will only be replaced when 2k resolution 3D screens hit the market, as I'm pretty sure that would exceed the bandwidth of the current spec. Even then, they will probably just launch a new 'high performance' cable capable of that before it becomes commonplace anyway.
__________________
My Rig: [FD Define Mini] - [Asus P8Z77-M Pro] - [i5 2500k @ 4.4GHz/1.34V] - [Corsair H60] - [8GB Corsair Vengeance LP] - [Asus GTX TITAN] - [512GB Vertex 4, 1TB F3, 2TB F4 x 2] - [Corsair HX650]
Other stuff I own: [BenQ XL2411T/Dell 2407WFP] - [CM Novatouch TKL] - [Zowie FK1] - [Fostex TH900] - [Woo Audio WA7 Fireflies] - [Sony Bravia KDL65W855] - [Onkyo TX-NR515] - [B&W 685]
[Steam] - [Battlelog]
smc8788 is offline   Reply With Quote
Old 12th Jul 2011, 13:54   #10
Bungletron
Ultramodder
Bungletron's Avatar
Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.
What a bunch of guff, I read the blind HDMI cable comparison posted on the other HDMI news that came about last week, no one could really tell the difference, so how does the termination make any difference? The other thing that was mentioned was the HDMI standard (1 lost bit per billion or something) is only tested on the first batch of cables a company produces, after that they are licensed to churn out whatever mediocrity they choose, does not seem like it is any guarantee of quality at all, more just a protection of their license fee. Even the dongle pictured has a bit of cable in it, are you sure that does not count as illegal?
This. Its how I have my xbox 360 connected to a monitor, does this mean stormtroopers will be battering down my door anytime soon?
Bungletron is offline   Reply With Quote
Old 12th Jul 2011, 14:00   #11
faugusztin
No. It is about manufacturing and selling them, not about the buyers.
Old 12th Jul 2011, 14:04   #12
John_T
Supermodder
John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.
...does not seem like it is any guarantee of quality at all, more just a protection of their license fee.
Nail + hammer = loud thumping sound.
The more difficult they make DisplayPort to use, the more ubiquitous HDMI becomes.
John_T is offline   Reply With Quote
Old 12th Jul 2011, 14:15   #13
Xir
I Mod, Therefore I Own
Xir's Avatar
Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.
Other way round really, they see a chance to kick DP (and mini DP), as next to noone is using it anyway.
The percentage of displays that have HDMI is larger than the persentage of displays using DP or both.
(DP displays also have HDMI in, but HDMI displays rarely have DP in.)
__________________
SN25P
A64 3700+ (San Diego)
2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T
X1800XT 512mb Sapphire
200GB Samsung SP2004C 24" Asus VW246H 1920x1080
Xir is offline   Reply With Quote
Old 12th Jul 2011, 14:20   #14
Pete J
RIP Teelzebub
Pete J's Avatar
Pete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming Saiyan
Heh. I smell bribery. Maybe I'm just being pessimistic
As much as we love to hate the Monster cables, the truth is that over a certain length (several meters IIRC) the monster cables can maintain data stability far better than a run of the mill cable. Still, I don't know why you'd have a need for such a long cable!
__________________
Latest system review here / I also have a laptop: Gigabyte P35X v6
HTC Vive review coming soon!
Pete J is offline   Reply With Quote
Old 12th Jul 2011, 14:24   #15
l3v1ck
really joined on Dec 24th 2004.
l3v1ck's Avatar
l3v1ck has yet to learn the way of the Dremell3v1ck has yet to learn the way of the Dremell3v1ck has yet to learn the way of the Dremell3v1ck has yet to learn the way of the Dremell3v1ck has yet to learn the way of the Dremell3v1ck has yet to learn the way of the Dremel
To the Sunday markets.......
__________________
Originally Posted by Sifter3000
We swung the banhammer in his little stupid spamming face
The old Dennis Forums (CPC, PC Pro, Mac User etc) - Meeting Place lives on. You're welcome to visit it HERE
l3v1ck is offline   Reply With Quote
Old 12th Jul 2011, 14:30   #16
GoodBytes
How many wifi's does it have?
GoodBytes's Avatar
GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.
Because HDMI is a serious money maker for them. Royalty fees are really high for what it is. Sure it's probably (guessing here) 0.75-1$ range... but do the math. Plus you have it on your 2 devices (example: Blu-ray/game console and TV) and the cables.
__________________
Core i7 930 2.8GHz | G.Skill Pi 6GB 1600MHz 7-5-7-24 1.5V | Gigabyte GA-X58A-UD5 | GeForce GTX 260 | W.D Caviar Black 1TB | Corsair AX750 | Noctua NH-U12P | Xonar Essence STX | Win8 Pro 64-bit | Dell U2410 - 1920x1200 | OCZ Vertex 4 250GB
GoodBytes is offline   Reply With Quote
Old 12th Jul 2011, 14:31   #17
3lusive
Ultramodder
3lusive's Avatar
3lusive is a hoopy frood who really knows where their towel is.3lusive is a hoopy frood who really knows where their towel is.3lusive is a hoopy frood who really knows where their towel is.3lusive is a hoopy frood who really knows where their towel is.3lusive is a hoopy frood who really knows where their towel is.3lusive is a hoopy frood who really knows where their towel is.3lusive is a hoopy frood who really knows where their towel is.3lusive is a hoopy frood who really knows where their towel is.3lusive is a hoopy frood who really knows where their towel is.3lusive is a hoopy frood who really knows where their towel is.3lusive is a hoopy frood who really knows where their towel is.
Yeah but they sell 1m cables for +50 too, like this one
__________________
Antec 300 | Asus P8H67-M Pro R3 | i5 2500K | 16GB XMS3 RAM | GT 430 Zone | 60GB F60 SSD | 1TB F3 + 500GB HDD | CX430W PSU | Logitech G500 + C510 | Win7 Ultimate x64
QNIX QX2710 PLS Evolution ll 27" 2560x1440 x2
3lusive is offline   Reply With Quote
Old 12th Jul 2011, 14:39   #18
GoodBytes
GoodBytes's Avatar
Stopping Monster Cable, will look bad for the HDMI group... and people will be afraid and drop HDMI for Display Port. They don't want this.
PLUS, Monster Cable provide a high markup to retail stores, and well them.
Everyone (except the consumer) is really happy. The consumer has a choice to buy them or not... consumer choose to buy them like hot cakes.
__________________
Old 12th Jul 2011, 14:39   #19
johnnyboy700
I *am* a Dremel
johnnyboy700's Avatar
johnnyboy700 is definitely a rep cheat.johnnyboy700 is definitely a rep cheat.johnnyboy700 is definitely a rep cheat.johnnyboy700 is definitely a rep cheat.johnnyboy700 is definitely a rep cheat.johnnyboy700 is definitely a rep cheat.johnnyboy700 is definitely a rep cheat.johnnyboy700 is definitely a rep cheat.johnnyboy700 is definitely a rep cheat.johnnyboy700 is definitely a rep cheat.johnnyboy700 is definitely a rep cheat.
Yeah but there's one on Amazon for about 9500:-
http://www.amazon.co.uk/2-5m-HDMI-Ca...f=pd_rhf_p_t_2
Darn, they've taken the price off!
johnnyboy700 is offline   Reply With Quote
Old 12th Jul 2011, 14:55   #20
raxonb
Multimodder
raxonb's Avatar
raxonb has yet to learn the way of the Dremel
This needs to be reported to the News Of The World...oh wait!
Seriously though the HDMI people are just being stupid. Hopefully ethernet will become the standard.
__________________
If you recognise my avatar your childhood was awesome!
To Be This Good Takes AGES...
To Be This Good Takes SEGA
raxonb is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
