Reply
Thread Tools View Mode
Old 12th Jul 2011, 22:45   #1
ColdzeroTeam
Expert Modder
ColdzeroTeam's Avatar
ColdzeroTeam has yet to learn the way of the Dremel
Project: Tj07 Black & White
Hi guys,
I'm starting a new case for myself. i had it gathering dust so i thought... "why not mod this puppy?"
it started out with something simple, and after a lot of thought i was able to come up with some ideas to make this mod a little better, and this is mostly all you guys fault because you raise the bar so high, that after that a simpler mod simply wont do...
but enough talk, and lets begin...
Sponsored by:
Hardware:
Rampage 3 Black Edition
Intel 990x
12GB (3x4GB) G.Skill 2000mhz CL8
3x Nvidia Gtx 470
SilverStone Strider Plus 1000w
Corsair F120 SSD
Cooling:
2x Thermochill TA120.4
2x Laing 10w
1x Koolance RP402x2
12x Noiseblocker XL2
Aquaero for fan Controll
All psu cables will be custom made and will feature the "no heat-shrink" sleeving touch
this case was originally meant for the Snow White Project, but problems with the powder coating (excessive paint) made me scrap the case, and paint a new one. Until i decided that i could use this case for me, since it was free anyway
at first i thought of using a 480 and 360 Thermochill TA radiators as well as a Laing E10 pump...
but then i thought... "uhm... maybe a little overkill, no??"
then i dropped that idea and decided to use two 480 rads at the bottom, which meant moving the psu to the 5.25" bay compartment. (don't mind the 800D at the back )
Since everything is going to be watercooled I won't be needing the top mesh
The new (narrower) vertical bars i was planing on using to allow for a 120mm on the back
Lian-li Aluminium Wheels. IMHO they look like they were made for this case. they go so well with the cases round corners on the front
Needed to add a plexi spacer for clearance
5.25" that were cut for the hot-swap system that won't be used any more...
And the parade of parts going to waste continues... this time is the midplate
And the backplate
To do list:
- Midplate
- 5.25" bays
- Mb tray
- Side panels (the ones painted don't fit the case, therefore -> trashed)
- Front pannel
basically all the interior is going to be made from scratch...
__________________
Finished Projects -> Casemod: Little Big 840 ATCS || Casemod: Corsair 700D R.O.G. 'R US MOTM Nominee || Casemod: Snow White || Casemod: TJ07 Classified ||
Work in Progress -> Casemod: TJ07 Black & White ||
ColdzeroTeam is offline   Reply With Quote
Old 14th Jul 2011, 21:03   #2
ColdzeroTeam
Expert Modder
Cpu waterblock chosen was Aquacomputer Kryos XT
I decided create a new cover...
And after a few tries... success!!!
will do something similar on the vga blocks. Aquacomputer AquagraFX nickel for the GTX470.
__________________
Old 15th Jul 2011, 22:52   #3
ColdzeroTeam
Expert Modder
while i try to finish the cpu waterblock, why don't i show you what i've done with the vga waterblocks
And the weapons of choice were... Aquacomputer AquagraFX GTX470 Nickel.
One of the reasons i prefer these blocks over other solutions, they include standoff's
Using the single slot pci plate makes the cards look so much better and slimer
And it's custom backplate time used a different scheme than usual.
The more i looked at the waterblock, the less i liked the top cover (too much of the same colour) so i decided to take care of that as well...
Almost...
Almost there...
Finished look
Nice Acetal + Nickel Look, don't you think
__________________
Old 15th Jul 2011, 22:54   #4
KidMod-Southpaw
Making You Feel Old Since 2010
KidMod-Southpaw's Avatar
KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.
Very nice colours- great start!
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2)
"The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181
KidMod-Southpaw is offline   Reply With Quote
Old 16th Jul 2011, 07:58   #5
djzic
Bokehlicious!
djzic's Avatar
djzic has yet to learn the way of the Dremeldjzic has yet to learn the way of the Dremeldjzic has yet to learn the way of the Dremel
Awesome! All that stands out now is those capacitators - polish em!
__________________
Check out my build: the Shuttle.
Q8300. 8gb XMS2. ATI 4650.
Thermalright AXP-140. Samsung SpinPoint 1TB.
1U 300w PSU. Shuttle Case. MDPC-X Sleeving.
djzic is offline   Reply With Quote
Old 16th Jul 2011, 13:31   #6
ColdzeroTeam
Expert Modder
i'll think about it
__________________
Old 19th Jul 2011, 20:31   #7
ColdzeroTeam
Expert Modder
I got a few more ideas for the case by looking/getting inspiration from my G.skill Trident heatspreaders as well as the TJ11.
The idea here is to widden the case a bit (call it a wide body kit, if you like )
To do that i thought of interleaving white and black plexi screwed to the chassi of the case on the side "ribs" that were used to fix the side panels, layer over layer until i got the with i wanted
Started the process of cutting the plexi, marking, drilling and finally threading all around the case...
First Layer is complete
Don't mind the screws. Those are temporary
__________________
Old 19th Jul 2011, 22:30   #8
dream1
Multimodder
dream1's Avatar
dream1 has yet to learn the way of the Dremel
Ooh You got very big pump where did you get it ??? Nice build keep it going
dream1 is offline   Reply With Quote
Old 19th Jul 2011, 22:38   #9
ColdzeroTeam
Expert Modder
i got it from laing.de directly
__________________
Old 19th Jul 2011, 23:12   #10
Shazbom
Multimodder
Shazbom's Avatar
Shazbom has yet to learn the way of the Dremel
yo ColdzeroTeam keep it up.. can't wait to see where you going to put the psu... =)
+i've never seen such a big pump. how much stronger is that comparing to the d5 pump?
__________________
Current Work Log: Shazbom Waterworld 2 (15-07-20011)
http://forums.bit-tech.net/showthread.php?t=213165
Past Work Log:Shazbom Waterworld (23-01-2009)
http://forums.bit-tech.net/showthread.php?t=163363
Shazbom is offline   Reply With Quote
Old 20th Jul 2011, 05:27   #11
Stem83
Addicted to modding.
Stem83's Avatar
Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.
You have alot of really nice stuff floating about this mod. this is going somewhere very good!!
Stem83 is offline   Reply With Quote
Old 20th Jul 2011, 09:39   #12
ColdzeroTeam
Expert Modder
Tks
This pump can do 4500L/H and 4.5meters of pressure. It also has a knob to controll it from 1-7. and Consumes 62w. 230v
it's generally used for circulating water in house heating systems
tks
__________________
Old 20th Jul 2011, 10:16   #13
paz45
Supermodder
paz45's Avatar
paz45 is a hoopy frood who really knows where their towel is.paz45 is a hoopy frood who really knows where their towel is.paz45 is a hoopy frood who really knows where their towel is.paz45 is a hoopy frood who really knows where their towel is.paz45 is a hoopy frood who really knows where their towel is.paz45 is a hoopy frood who really knows where their towel is.paz45 is a hoopy frood who really knows where their towel is.paz45 is a hoopy frood who really knows where their towel is.paz45 is a hoopy frood who really knows where their towel is.paz45 is a hoopy frood who really knows where their towel is.paz45 is a hoopy frood who really knows where their towel is.
Nice will be watching
always enjoy your mods
paz45 is offline   Reply With Quote
Old 20th Jul 2011, 10:34   #14
thetrashcanman
Angel headed hipsters
thetrashcanman's Avatar
thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.
dude this is awesome, nice job! *subscribed* All these project mods I'm seeing with TJ07's seriously making me want one of these instead of a Xigmatek Elysium, DAMMIT!
__________________
i7 3930k/watercooled on 360 rad/Asus Rampage IV Extreme/16Gb Corsair Dominator GT 2133Mhz/Gtx 480/2 x Corsair Force GT 240Gb RAID0 /Silverstone TJ11/Enermax Platimax 1500W
thetrashcanman is offline   Reply With Quote
Old 20th Jul 2011, 11:22   #15
AnG3L
Ultimate Modder
AnG3L's Avatar
AnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run Crysis
Epic awesomeness on the way!!!!!
AnG3L is offline   Reply With Quote
Old 20th Jul 2011, 12:42   #16
ColdzeroTeam
Expert Modder
Tks
this case is still my all time favourite
hope so my friend
__________________
Old 20th Jul 2011, 14:54   #17
KiiYzOo
Multimodder
KiiYzOo has yet to learn the way of the Dremel
love the paint job makes it look like it's made out of white delrin
KiiYzOo is offline   Reply With Quote
Old 20th Jul 2011, 16:23   #18
stefan442
Supermodder
stefan442's Avatar
stefan442 has yet to learn the way of the Dremelstefan442 has yet to learn the way of the Dremelstefan442 has yet to learn the way of the Dremel
nice white build so many good mods going on atm!
__________________
Q6600 @ 3.0ghz | gigabyte g31m-es2l | 4gb crucial ballistix | 2GB XFX 6870 | antec 300 |Antec TruePower 550w | arctic cooling rev2 pro | 1tb wd caviar black
Antec 300 mini mod
stefan442 is offline   Reply With Quote
Old 22nd Jul 2011, 00:44   #19
ColdzeroTeam
Expert Modder
Here come the rest of the pieces...
First layer in place
Another white layer and things begin to take shape...
Second layer, and you can begin to notice the desired effect.
First side done
Only thing missing is the side panel in black plexi.
__________________
Old 22nd Jul 2011, 17:57   #20
Razarach
Multimodder
Razarach's Avatar
Razarach has yet to learn the way of the DremelRazarach has yet to learn the way of the DremelRazarach has yet to learn the way of the Dremel
wow. This looks beautiful
Razarach is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
