Reply
Thread Tools View Mode
Old 14th Jul 2011, 19:47   #1
GuilleAcoustic
Ook ? Ook !
GuilleAcoustic's Avatar
GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.
Retrocade - retro arcade stick
Hi mates,
here's a project log I had in mind since a long time. And I'm finally taking the time to build it. This will be done in two steps.
- First and more important : prototyping
- Second : Final build
The prototyping mainly lies in finding the perfect angle for the top panel to allow long long long play time. I'll build an adjustable top panel and then will have ..... oh my god that's horrible ..... I will have to play !!
Here are the selected test titles :
- Metal Slug X (the best one IMHO)
- King of fighter 98' (again the best one)
- Last blade 2
- Wind jammers (nom nom nom, simple but addictive)
- some unselected shoot them up (Nam 1945, Mars matrix, etc..)
The final design will looks like that :
Materials will be a full waxed concrete housing and a lackered wooden top panel. Stick and buttons will all be Sanwa branded, all connected to a Arcade controller (like I-PAC for example)
http://www.ultimarc.com/ipac1.html
Since the housing will be made of concrete (to weighten the whole damn thing), I need to build a prototype to determine the best angle for the top panel, before making a mold for the concrete.
For the prototype use, I'll be using spare parts from my dead X-Arcade stick (the controller is dead, resulting in keyboard buffer overflows). I'm not a big fan of this stick, and that's the reson why I'm building one from scratch (prefer ball shaped stick to pear shaped stick)
Here is the organ donator (sorry, pics been taken from my cellphone)
The faultry controller :
Next step, the prototype housing ... coming in a few days
Stay tuned
GuilleAcoustic is offline   Reply With Quote
Old 15th Jul 2011, 21:14   #2
GuilleAcoustic
Ook ? Ook !
Hi there,
a little update following my link sharing attitude.
The following link http://www.slagcoin.com/joystick/introduction.html can be considered as the DIY arcade stick bible. It explains everything you need to build your very own stick (from the component brand comparison to the panel or box layout). Everything is compared and explained step by step, please click on all icons from the top banner.
Stay tuned
Old 16th Jul 2011, 20:45   #3
GuilleAcoustic
Ook ? Ook !
Hi mates,
daily update (I hope it'll be daily). By advance, sorry for the cellphone pictures. I'm in holyday and not home, so slow update and no sketchup (Athlon 64 3500+ @ 2.2GHz, 1 GB Corsair DDR400 cas 1.5, 10 years old geForce 4 TI 4200 64mo).
Finished dimanteling the X-arcade sitck. Buttons and sticks where glued to the top panel. A real pain in the arsh to remove them. Two hours of battling and a few scars later, I'm done with the stripping.
What do we have there :
- 2 Happ's sticks (not that good, but enough for testing)
- 17 black + 2 white + 2 player select Happ's push buttons (again good enough for testing
- 1 keyboard emulator PCB (laggy one but I only want to test layout and panel angle)
I've printed the final 2 layouts. The first one has 8 buttons and the second one has 7 buttons. I do not really need 8 buttons (only 6 for Street fighter like games and 4 for SNK games), but the layout is really different. So 2 prototypes will be build to find out the less stressing one, to allow long play sessions.
Here is a quick fitting test to check that buttons and sticks fit on the selected layout :
And a comparison with my old dead companion :
Tomorrow work :
- Build a variable angle box
- Build the 2 prototype top panels (7 and 8 buttons)
Stay tuned
Old 16th Jul 2011, 21:22   #4
Dark~3nergy
what was dat sandvich ?
Dark~3nergy's Avatar
Dark~3nergy has yet to learn the way of the DremelDark~3nergy has yet to learn the way of the DremelDark~3nergy has yet to learn the way of the DremelDark~3nergy has yet to learn the way of the Dremel
will be watching this one, i'm a huge fan of arcades myself, et très précisément la série des metal slug !!
__________________
My deviantart page : link Battlefield 3: Mindrusted My computer : Link
Dark~3nergy is offline   Reply With Quote
Old 17th Jul 2011, 14:30   #5
GuilleAcoustic
Ook ? Ook !
Très précisément en effet ... and an arcade stick suite all those marvellous games so much more than keyboard or gamepad (even if I'm used to spawn KOF combo with a keyboard ).
Edit :
Been drilling holes this evening ... and one broken mesh, one broken hole saw and one scar later ...
The test panel is almost done ... just have to make the hole for the stick ... but the hole saw is dead. I'd better buy better quality ones to my wife's dad , damn hard to make a good job with bad tools .
Been playing with the buttons, pressing them over and over and I have to say that this layout is very pleasant and not stressing at all. I'll keep the same length under them as it is nice to have it to rest the hand palm.
I'll order the Sanwa stick and the Sanwa buttons next week. They are a little bit smaller than those I use for the test, but are the SOTA in arcade gaming.
Stay tuned
Old 26th Jul 2011, 22:46   #6
GuilleAcoustic
Ook ? Ook !
Hi mates,
just bought a new hole saw and found some times to work on this project. Drilled some holes and I have to say that it is better with nice tools.
After a few hours spent playing Street fighter III : 3rd impact, I have to say that it would be more comfortable with the stick a few centimeters more to the left.
I'm also wondering if it is worth a concrete housing. With only the buttons, stick and half the housing (using low thickness wood), the system weights quite a lot.
With thicker real wood and a latex feet, I'm sure it won't move an inch.
stay tuned
Old 21st Oct 2011, 00:10   #7
dmcgrath
Master of Pancakes
dmcgrath's Avatar
dmcgrath has yet to learn the way of the Dremeldmcgrath has yet to learn the way of the Dremeldmcgrath has yet to learn the way of the Dremeldmcgrath has yet to learn the way of the Dremeldmcgrath has yet to learn the way of the Dremeldmcgrath has yet to learn the way of the Dremel
Concrete is probably overkill. If you need weight It just recommend some lead plugs glued inside the unused areas. Heavy wood and decent feet will help a lot, yeah!.
dmcgrath is offline   Reply With Quote
Old 21st Oct 2011, 03:04   #8
Gaming_freak_10
Ultramodder
Gaming_freak_10's Avatar
Gaming_freak_10 is definitely a rep cheat.Gaming_freak_10 is definitely a rep cheat.Gaming_freak_10 is definitely a rep cheat.Gaming_freak_10 is definitely a rep cheat.Gaming_freak_10 is definitely a rep cheat.Gaming_freak_10 is definitely a rep cheat.Gaming_freak_10 is definitely a rep cheat.Gaming_freak_10 is definitely a rep cheat.Gaming_freak_10 is definitely a rep cheat.Gaming_freak_10 is definitely a rep cheat.Gaming_freak_10 is definitely a rep cheat.
That's awesome!!
So what are you going to do with the extra buttons? use them as spares in case if one of those buttons basically die?
__________________
Steam: Gaming_Freak_10. PSN: enickel2009 Twitch/Twitter: DeafGamer2015
Black Fox: Processor: AMD FX-6300. Motherboard: GA-78LMT-USB3 (rev. 5.0). 16GB DDR3 RAM. 64GB SSD. 640GB and 320GB HDDs. XFX 5770 HD Graphic card. Case: Thermaltake Core V21. PSU: EVGA NEX750B 750Watt PSU
In memory of Kidmod-Southpaw (1997 - 2014) and Teelzebub (1955 - 2016)
Gaming_freak_10 is offline   Reply With Quote
Old 21st Oct 2011, 09:59   #9
GuilleAcoustic
Ook ? Ook !
Thanks a lot. Long time I didn't opened this thread. Concrete was my first idea, before I start building the first prototype. Now, with just the stick and the buttons plus the top panel .... it's already damn heavy ! I'll go with heavy wood and a thick alu bottom panel + rubber feet.
Originally Posted by Gaming_freak_10 View Post
That's awesome!!
Thank mate . All this hardware is only a temporary one. I'll order full Sanwa (stick + button) high end arcade parts and try to find some time to finish this as the prototype is done and validated (was hard to spend all those hours playing at fighting games ).
I'll build 2 other sticks for my nephews with my prototyping parts.
Old 22nd Oct 2011, 20:10   #10
Gaming_freak_10
Ultramodder
Do ya mind sending me the old buttons and stuff? that way it wont be wasted lol
__________________
Old 24th Oct 2011, 13:04   #11
GuilleAcoustic
Ook ? Ook !
Sorry, but they will be used to build 2 arcade stick for my nephews.
I've ordered the Sanwa buttons and stick and made a first attempt for the cover artwork :
Buttons and stick are Dark Hai (grey) color :
What do you think of it ?
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
