#1 |
MegaRUSH
[Worklog] Dragon v2.0 Almost done... new grafics card
![]() This project is sponsored by: ![]() ![]() ![]() ![]() ![]() ![]() Hardware: Cpu: Intel i5 3570K @ 4,7Ghz Mobo: Asrock Z77 Extreme 6 Rams: Kingston Genesis 2000 16Gb SSD: Kingston HyperX 3K 120Gb VGA: Asus DirectCU II GTX 580 Sound Card: Asus Xonar Phobues coming Case: Corsair Obsidian 800D PSU: Antec TPQ 1200W OC edi. Waterccoling: CPU block: EK Supreme HF Acetal VGA block: Rad CPU loop: Thermochill PA 120.3 Fans:Gentle Typhon 1850 Rad VGA loop: EK-CoolStream RAD XT (240) Fans: Phobya 1500 Nano-G 1500rpm Pump #1: Jingway DP-1200 Pump #2: Jingway DP-1200 RES Cpu loop: FrozenQ RES VGA loop: EK-Multioption RES X2 - 100 Basic Connectors: Bitspower Carbon Black & Deep red
__________________
Intel i5 3570K @ 5Ghz | Asrock Z77 Extreme 6| Kingston HyperX Beast 2133 16Gb | Asus GTX580 DirectCU II | Kingston HyperX 3K 120Gb | Corsair AX860i | XSPC H2 @ Full WC| Projects: Purple Li | Dragon Beast | Fractal uP Gaming | Pande Benchtable Last edited by aRkangeL; 27th Jul 2012 at 14:31. |
#2 |
MegaRUSH
The mobo will be other but i take some photos with this only to show some ideas!
![]() ![]() ![]() ![]() ![]() ![]() [/size]
__________________
Intel i5 3570K @ 5Ghz | Asrock Z77 Extreme 6| Kingston HyperX Beast 2133 16Gb | Asus GTX580 DirectCU II | Kingston HyperX 3K 120Gb | Corsair AX860i | XSPC H2 @ Full WC| Projects: Purple Li | Dragon Beast | Fractal uP Gaming | Pande Benchtable |
#3 |
MegaRUSH
Today i have received some stuff from my friend Stefan from Djungelapa.se
http://www.djungelapa.se/ ![]() Thanks Stefan for your big help! ![]() ![]() ![]()
__________________
#4 |
Multimodder
nice one m8
![]() I like how your writing too
#5 |
MegaRUSH
Thanks,
Oh my english is very bad!
__________________
#6 |
Multimodder
could just use google translate?
#7 |
Minimodder
Are the feet you are going to put onto the bottom of the case metal or plastic? and how did you make all those holes for the each of the 24 pin cable to go through, it looks awesome.
#8 | |
MegaRUSH
LOL google translate sucks, but when Im sleepy I suck more!
The holes for the24 pins i made it with some mesh and a drill! Now some photos of new arrivals, some of them to use in other project! ![]() ![]()
__________________
#9 |
MegaRUSH
A great thanks to Mr.P from Coldzero for your help to this project
Soon as possible some photos!!! ![]() http://www.coldzero.pt/coldzero/
__________________
Intel i5 3570K @ 5Ghz | Asrock Z77 Extreme 6| Kingston HyperX Beast 2133 16Gb | Asus GTX580 DirectCU II | Kingston HyperX 3K 120Gb | Corsair AX860i | XSPC H2 @ Full WC| Projects: Purple Li | Dragon Beast | Fractal uP Gaming | Pande Benchtable Last edited by aRkangeL; 30th Jul 2011 at 19:04. |
#10 |
MegaRUSH
__________________
#11 |
Hypermodder
This is a nice looking mod but I can't help but think the main power cable would look better behind the tube/reservoir instead of in front of it. Sorry. Just my 2 cents.
__________________
ASUS P8P67 Pro - i5 2500k + 8GB Ripjaw X 1333MHZ DDR3 MSI GTX 560 TI Twin Frozr II + Crucial C300 64GB Samsung F3 Spinpoint 1/2 TB + Fractal Design Define R3 [black pearl] |
#12 | |
MegaRUSH
Lets see what i can do!
__________________
#13 |
MegaRUSH
__________________
#14 |
MegaRUSH
__________________
#15 |
Multimodder
4 Pumps? two pumps per loop?
Very nice work so far, but need moar! Last edited by rak500; 25th Aug 2011 at 10:47. Reason: didn't read op |
#16 |
MegaRUSH
Maybe, im thinking what can I do you it!
__________________
#17 |
MegaRUSH
![]() Some specs: DIVISION 2 BACKGROUND Patriot Part #: PXD38G1866ELK (2 x 4GB) Description: Viper Xtreme Series, Division 2 Edition DDR3 8GB 1866MHz Kit Warranty: Lifetime Patriot’s Viper Xtreme Series, Division 2 Edition memory kits are designed for Intel’s® 2nd Generation Core™ processors. Engineered for PC Gamers and enthusiasts, the Viper Xtreme Division 2’s utilize a custom designed heatshield solution with an outer shield built around a copper core to provide enhanced cooling. Each module is tested and validated on the Intel® 6 Series platform to achieve maximum performance. These modules are engineered to reach PC3-15000 (1866MHz) at 9-11-9-27 timings and are available 4GB kits (2 x 2GB) and 8GB kits (2 x 4GB). Each module is 100% hand-tested and is backed by a full-lifetime warranty and industry leading customer service. Highlights of Division 2: - Tested and validated on P67 boards - XMP enabled Highlights of the new shields: - Copper insert across the DRAM chips & slim profi le extruded anodized aluminum outer piece - Slightly lower profi le than previous versions of the Viper heatshields - Modules are targeted and designed for performance enthusiasts and overclockers Aqui ficam algumas fotos! ![]() ![]() ![]() ![]() And the fluid that I will use!
__________________
#18 |
MegaRUSH
__________________
#19 |
Minimodder
Can we get more pics of the power supply area, especially of that panel you've made to cover it up.
__________________
i7 2600k@ 4.5GHz / Noctua NH-C12P / Maximus IV Extreme / Corsair 8GB Vengeance / Corsair Force GT 120GB x2 in RAID 0 / 4TB JBOD / MSI GTX580 Twin Frozr II SLI / Samsung SA950 27" LED 3D LCD / Z5500s / Steelseries Xai + 7G |
#20 | |
MegaRUSH
Today arrived a great PSU!! ![]() A great Thanks to OCZ... Some Specs! 850 Watts of Continuous Rock-Solid Power (940W Peak) +12VDC @ 71A Single Rail Design Ultra-Quiet 135mm Double Ball-Bearing, Thermally-Controlled Fan Ultra-High Efficiency (over 90%) 80 Plus® Gold Certified Dual GPU-Ready 5 year warranty backed by OCZ's exclusive PowerSwap Warranty replacement program. 850W Connectors 1 x 24-pin Main connector 1 x 8-pin EPS12V 1 x 4/8-pin CPU 3 x SATA Modular 4 x 6/8-pin PCI-Express 9 x SATA 3 x Peripheral 1 x Floppy The Photos! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Great PSU people.
__________________
| Thread Tools | |
| View Mode | |
