Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 2nd Aug 2011, 06:49   #1
arcticstoat
Who is the Milkman?
arcticstoat's Avatar
arcticstoat has yet to learn the way of the Dremelarcticstoat has yet to learn the way of the Dremelarcticstoat has yet to learn the way of the Dremelarcticstoat has yet to learn the way of the Dremelarcticstoat has yet to learn the way of the Dremelarcticstoat has yet to learn the way of the Dremelarcticstoat has yet to learn the way of the Dremelarcticstoat has yet to learn the way of the Dremel
Everise Variable Speed Rotary Tool Review
Can this £23 rotary tool match the legendary Dremel without breaking the bank?
http://www.bit-tech.net/hardware/201...-tool-review/1
__________________
Ben Hardwidge
Custom PC Editor
www.russell-crow.com
arcticstoat is offline   Reply With Quote
Old 2nd Aug 2011, 07:13   #2
V3ctor
Tech addict...
V3ctor's Avatar
V3ctor has yet to learn the way of the Dremel
LOL... Talk about timing, I was searching for a Dremel or something to do some small mods to my CM690... U guys read my mind... lol
__________________
Intel Core i3 3220 / AC Freezer 7 / ASUS P8B75-M LX / 2x4Gb DDR3 Gskill Sniper 1866Mhz / ATi HD5870 1Gb GDDR5 / Samsung T260 (HD) / Samsung 470 128Gb / Creative X-Fi Titanium / Corsair CX600 / CM 690
Intel Core i7 2670QM 2.2~3.1Ghz / 10Gb DDR3 1333Mhz / nVidia GT550M 2Gb / Intel 330 180Gb
Intel Core i7 4770K@4.5Ghz / Noctua NH-U12P SE2 / ASUS Sabertooth Z87 / 2x4Gb Gskill Trident X 2400Mhz / AMD HD7970 3Gb / Samsung T260 / 2x Corsair Force GT 240Gb raid0/ Corsair HX-850W/ Silverstone FT02R-Wi
V3ctor is offline   Reply With Quote
Old 2nd Aug 2011, 07:42   #3
Jipa
Avoiding the "I guess.." since 2004
Jipa's Avatar
Jipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run Crysis
It's exactly the same tool sold with a number of brands. It gets the job done, but is noisier and not as refined as the real thing. Also the bits that come with these cheapo tools are largely rubbish, so if you're on a tight budget, get one of these tools, but use higher quality Dremel cutting disks etc.
My 2cents.
(for the record I own the 4000, 300, Trio and also a generic rotary tool identical to this one...)
__________________
Half a dozen operational setups and truckloads of spare parts.
AllTheMods - MetkuMods - LedCalc - Flickr - BF:BC2
Jipa is offline   Reply With Quote
Old 2nd Aug 2011, 07:51   #4
mpr
Multimodder
mpr has yet to learn the way of the Dremel
I love my Dremel kit... It looks like these bits can be used with a Dremel which could save on cost? Not that the Dremel stuff is that expensive.
mpr is offline   Reply With Quote
Old 2nd Aug 2011, 08:09   #5
Xir
I Mod, Therefore I Own
Xir's Avatar
Xir is almost as Godly as yodasarmpitXir is almost as Godly as yodasarmpitXir is almost as Godly as yodasarmpitXir is almost as Godly as yodasarmpitXir is almost as Godly as yodasarmpitXir is almost as Godly as yodasarmpitXir is almost as Godly as yodasarmpitXir is almost as Godly as yodasarmpitXir is almost as Godly as yodasarmpitXir is almost as Godly as yodasarmpitXir is almost as Godly as yodasarmpit
Have you tried unscrewing the black plastic protector thingy between the tool and the collet?
On my dremel-clone it revealed the typicel thread for the flexible shaft.
__________________
SN25P
A64 3700+ (San Diego)
2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T
X1800XT 512mb Sapphire
200GB Samsung SP2004C 24" Asus something 1920x1080
Xir is offline   Reply With Quote
Old 2nd Aug 2011, 08:15   #6
[WP@]WOLVERINE
Supermodder
[WP@]WOLVERINE's Avatar
[WP@]WOLVERINE has yet to learn the way of the Dremel[WP@]WOLVERINE has yet to learn the way of the Dremel
Personally i would never use any of the cheapo knockoffs ive tried a couple and they are just not up to par. When it comes to tools its always better to pay a bit more and get tools that last for years. My 400D is an awesome piece of kit that i couldnt live without. So if you ask me id say -Dont be cheap get the real deal
__________________
Intel i7 980X EE | 6gb HyperX 2ghz DDR3 | Asus P6T Deluxe OC Palm ed | Asus 7950 DCII | Corsair HX1000 | SB X-Fi Fatality | 5.1tb storage+2xX25M 80gb SSD | Lian Li pc201 | 3xBenQ G2420HDB@Eyefinity | Ms Natural 4000 | Corsair M60 | Logitech Z-5450.
[WP@]WOLVERINE is offline   Reply With Quote
Old 2nd Aug 2011, 08:17   #7
andersson.j
Minimodder
andersson.j has yet to learn the way of the Dremel
I've had a few of those cheaper ones. They usually don't last long and are very weak.
Also dremel is way overrated! Check out the Proxxon IB/E instead.
andersson.j is offline   Reply With Quote
Old 2nd Aug 2011, 08:20   #8
Digi
The not-so-funny Cockney
Digi's Avatar
Digi can't run CrysisDigi can't run CrysisDigi can't run CrysisDigi can't run CrysisDigi can't run CrysisDigi can't run CrysisDigi can't run CrysisDigi can't run CrysisDigi can't run CrysisDigi can't run CrysisDigi can't run Crysis
I never got the hype of these tools. What can they do that you can't do with hammer and chisel or hacksaw and butter knife? Tsk.
(yes I just haven't used one..)
__________________
i5 3570k with a H100 on top / Asus Sabertooth Z77 / EVGA GTX 670 2gb SC / 8gb Corsair Veng 1866 / 128gb Crucial M4 / Seasonic 80+ 750w / Fractal R3 / 1TB Samsung F3 x2
A member of a mystical group of master-gamers. Find them hiding at www.tunedgaming.co.uk
Digi is offline   Reply With Quote
Old 2nd Aug 2011, 08:40   #9
sotu1
Ex-Modder
sotu1's Avatar
sotu1 is almost as Godly as yodasarmpitsotu1 is almost as Godly as yodasarmpitsotu1 is almost as Godly as yodasarmpitsotu1 is almost as Godly as yodasarmpitsotu1 is almost as Godly as yodasarmpitsotu1 is almost as Godly as yodasarmpitsotu1 is almost as Godly as yodasarmpitsotu1 is almost as Godly as yodasarmpitsotu1 is almost as Godly as yodasarmpitsotu1 is almost as Godly as yodasarmpitsotu1 is almost as Godly as yodasarmpit
Jeez you know you're on a geeks site when it starts reviewing rotary tools....Still I'm interested and thanks!
__________________
wc206 on Steam and bawnslippy1 on Origin.
sotu1 is offline   Reply With Quote
Old 2nd Aug 2011, 08:59   #10
DarkFear
Supermodder
DarkFear's Avatar
DarkFear has yet to learn the way of the Dremel
I have a sudden urge to try and spray my kinda-similar ugly, gray dremel knockoff lime green now....
DarkFear is offline   Reply With Quote
Old 2nd Aug 2011, 09:15   #11
Combatus
Custom PC/bit-tech modding sections
Combatus's Avatar
Combatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for president
Yep, we mentioned this in the review - sadly this thread wasn't compatible with the Dremel Flexible shaft we have.
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES! | Mod of the Month March 2013 is here! Vote now!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is online now   Reply With Quote
Old 2nd Aug 2011, 09:15   #12
andrew8200m
Not quite with it...
andrew8200m's Avatar
andrew8200m is the Cheesecake. Relix smiles down upon them.andrew8200m is the Cheesecake. Relix smiles down upon them.andrew8200m is the Cheesecake. Relix smiles down upon them.andrew8200m is the Cheesecake. Relix smiles down upon them.andrew8200m is the Cheesecake. Relix smiles down upon them.andrew8200m is the Cheesecake. Relix smiles down upon them.andrew8200m is the Cheesecake. Relix smiles down upon them.andrew8200m is the Cheesecake. Relix smiles down upon them.andrew8200m is the Cheesecake. Relix smiles down upon them.andrew8200m is the Cheesecake. Relix smiles down upon them.andrew8200m is the Cheesecake. Relix smiles down upon them.
Sweet! Looks like buying custompc is not needed anymore given that pretty much all reviews in the mag end up on bit-tech the minute the mag gets superceeded with the following months.
Its a good review though so ill try not to derail too much.
__________________
Haswell i7 4770K @ 4.8GHz - Haswell matx G1.Sniper M5 - Corsair 2800MHz Dominator Platinum - EVGA GTX670 4096MB SC (step uo to GTX780) - Plextor M5 Pro 512GB - Logitech G9x - Corsair K60 - Dell 3007WFPHC
M-Audio DX8A Deluxe Stereo Monitors - SBX10 Sub
andrew8200m is offline   Reply With Quote
Old 2nd Aug 2011, 09:15   #13
Combatus
Combatus's Avatar
We'll take that as a compliment!
__________________
Old 2nd Aug 2011, 10:02   #14
confusis
Kiwi-modder
confusis's Avatar
confusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysis
Bought a similar one (as a previous person mentioned, they make this model for multitudes of brands)
6 months of sporadic use: dry solder joints caused unit to fail.. resoldered myself.
6 more months - motor burnt out.
Word of warning
confusis is offline   Reply With Quote
Old 2nd Aug 2011, 10:22   #15
Jipa
Jipa's Avatar
Word of warning
Then again, atleast mine came with a 3 year warranty, so what's the big deal?
__________________
Old 2nd Aug 2011, 10:27   #16
Risky
Mod Master
Risky's Avatar
Risky - may the hammer of Bindi be bestowed on youRisky - may the hammer of Bindi be bestowed on youRisky - may the hammer of Bindi be bestowed on youRisky - may the hammer of Bindi be bestowed on youRisky - may the hammer of Bindi be bestowed on youRisky - may the hammer of Bindi be bestowed on youRisky - may the hammer of Bindi be bestowed on youRisky - may the hammer of Bindi be bestowed on youRisky - may the hammer of Bindi be bestowed on youRisky - may the hammer of Bindi be bestowed on youRisky - may the hammer of Bindi be bestowed on you
Miight pick one up for occasional use as my dremel is at the other end of the country.
__________________
As a rule watercooling can be simple, affordable and effective... I guess I just like to break the rules.
Risky is online now   Reply With Quote
Old 2nd Aug 2011, 10:51   #17
mpr
Multimodder
They're amazing for case modding... and it doesn't hurt that you can justify the purchase to the missus (or mister) as a valuable tool for the entire house... Show the wife you can polish jewlery and cupboard trim... WIN!
Old 2nd Aug 2011, 10:52   #18
[WP@]WOLVERINE
Supermodder
Try doing this with a hammer, chisel and hacksaw......
http://img543.imageshack.us/img543/5599/800s19.jpg
__________________
Old 2nd Aug 2011, 11:17   #19
zr_ox
Whooolapoook
zr_ox's Avatar
zr_ox has yet to learn the way of the Dremel
Can we see pictures of the tests?
The review seems more like an evaluation of the device based on the accessories and feel vs it's ability to actually perform? Do you not also need a reference product to be able to assign a value?
__________________
0ptimizm
:PC under review
zr_ox is offline   Reply With Quote
Old 2nd Aug 2011, 11:24   #20
V3ctor
Tech addict...
V3ctor's Avatar
Originally Posted by [WP@
WOLVERINE]
And its beautiful... Great work
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
