Reply
Thread Tools View Mode
Old 22nd Dec 2011, 20:18   #121
kier
kier's Avatar
kier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for president
Thank you all very much, love your comments
Originally Posted by TotalGaos View Post
Looking very good, Kier. Have you thought about using those leds to show activity? Like letting the light intensity or flash speed depend on the load of the component (cpu, gpu, hdd, etc). Or maybe the temperature. That way you could give those leds a purpose.
Either way, love the look of the case!
I tought of it yes. But I think this will be to much disturbance
Update !!!
When seeing the total package I was not very pleased with the blue/ purple acrylic at the side from the psu cover
It doesn't fits the case with the blue leds on. The acrylic outside looks fine, but inside it just isn't right I think.
So made some changes to the psu side panel. The idea for this was coming after I,ve did some brainstorming for some branding.
I was placing some casebadges from ZOTAC And then it hits me !!!
Why not do a special thanking to my sponsors because without them this build was not possible with these high-end products.
I'm going to make a new sidecover with the engraving of all logo's from the sponsors
Just a little tut how I did it:
For this I'm gonna use my good old dremle with flex shaft
And I'm using for the lines and shading diamond wheel points
Print and cut the logo's from ZOTAC, MSI, MNPCTECH, BITSPOWER, IT-Service.be and Coolermaster
Using the ZOTAC logo and past it behind the acrylic
For me it works better with a dark background and a light aside the acrylic
Engrave the outlines with the diamont point at low speed
Removed the logo when finished all the lines from the name
and then using the diamond wheel
to do the shading
After lots of coffee and some hours... the result
Ok I could have let a machine do it, but it's more fun doing it yourself
After that I've drilled some 3mm holes for the blue leds
Placed the leds
And there you have it.... your custom psu sideplate with sponsors
Thanks for watching and thank you all members for your votes at the Motm contest
__________________
kier is offline   Reply With Quote
Old 22nd Dec 2011, 20:21   #122
xSoMBrAx
Supermodder
xSoMBrAx has yet to learn the way of the DremelxSoMBrAx has yet to learn the way of the Dremel
Very nice detail Kier
Did you use 6mm acrylic?
The end results looks nice, and the leds give the perfect touch
__________________
Latest Project: « «[ Little Angel ]» » (FINISHED!)
Sponsors: *** Aquatuning | Atlas Informática | NZXT ***
*** ProSilentPC | Seasonic | IzarMicro | E22 ***
Follow me on Facebook!
xSoMBrAx is offline   Reply With Quote
Old 22nd Dec 2011, 20:27   #123
kier
kier's Avatar
Thanks, I've used 5mm acrylic
__________________
Old 22nd Dec 2011, 20:51   #124
alain-s
Supermodder
alain-s is definitely a rep cheat.alain-s is definitely a rep cheat.alain-s is definitely a rep cheat.alain-s is definitely a rep cheat.alain-s is definitely a rep cheat.alain-s is definitely a rep cheat.alain-s is definitely a rep cheat.alain-s is definitely a rep cheat.alain-s is definitely a rep cheat.alain-s is definitely a rep cheat.alain-s is definitely a rep cheat.
Very nice Richard
The Sponsors will appreciate that a lot ^^
alain-s is offline   Reply With Quote
Old 23rd Dec 2011, 04:05   #125
@nton
Modder
@nton's Avatar
@nton has yet to learn the way of the Dremel@nton has yet to learn the way of the Dremel
Like this a lot! this is going to be an awesome machine!! -respect
@nton is offline   Reply With Quote
Old 28th Dec 2011, 23:17   #126
mnpctech
bit-tech sponsor
mnpctech's Avatar
mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.
I can't wait to see this one finished. ...Always killer work by kier!
__________________
My GPU support brackets We Ship International Orders!
mnpctech is offline   Reply With Quote
Old 1st Feb 2012, 20:59   #127
kier
kier's Avatar
Last Update !!! final pictures
I forgot the SLI bridge to put on lol
Special thanks to all sponsors:
Coolermaster
Mnpctech
Bitspower
IT-Service
MSI
ZOTAC
Ed Geels
__________________
Old 1st Feb 2012, 21:04   #128
Angel OD
Pump Killer
Angel OD's Avatar
Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!
Beautiful!
But then again, that's what I have come to expect from you Kier!
__________________
It's NOT a mac... http://forums.bit-tech.net/showthread.php?t=139635 - Motm nominee
WII - UNLimited Edition http://forums.bit-tech.net/showthread.php?t=179763 - Moty nominee
Liquid Cooled CarPC - Sponsored by Mushkin Enhanced & Centrafuse
http://forums.bit-tech.net/showthread.php?t=207889 - Motm nominee
The Theory of Everything http://forums.bit-tech.net/showthread.php?t=219504 - Motm WINNER!
Angel OD is offline   Reply With Quote
Old 1st Feb 2012, 21:29   #129
Nutman
Never stuck with stock
Nutman's Avatar
Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.
It's a wonderful build - already looking forward to the next one (no pressure, though)
__________________
Best regards, Nutman
Projects: Nutman - Hampen - F.O.B. T.C. - BabyShark - The Scratchbench
Nutman is offline   Reply With Quote
Old 1st Feb 2012, 22:27   #130
Pranja
Blackwolf
Pranja's Avatar
Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.
Beautiful.
Pranja is offline   Reply With Quote
Old 2nd Feb 2012, 11:16   #131
Korvus
May contain traces of sanity.
Korvus's Avatar
Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!
So tidy and clean Great seeing this finished
Korvus is offline   Reply With Quote
Old 2nd Feb 2012, 14:13   #132
mnpctech
bit-tech sponsor
mnpctech's Avatar
patience + skill = kier
My favorite 600T build.
__________________
Old 8th Apr 2012, 17:51   #133
LeandroJVarini
Mod is my life!
LeandroJVarini's Avatar
LeandroJVarini has yet to learn the way of the Dremel
very beautiful work, detailed to the extreme!
__________________
SORRY FOR MY BAD ENGLISH!
LeandroJVarini is offline   Reply With Quote
Old 20th May 2012, 01:15   #134
mnpctech
bit-tech sponsor
mnpctech's Avatar
Been getting a lot of folks mentioning this project over past couple of weeks. It's still the cleanest 600T build I've seen.
__________________
Old 20th May 2012, 09:17   #135
kier
kier's Avatar
Thanks bro
Couldn't have done it without your products Bill 3M carbon and clear sidepanel
Must admid, There was a lot interest in this one and it was sold very fast
__________________
Old 31st Jul 2012, 14:24   #136
mnpctech
bit-tech sponsor
mnpctech's Avatar
Originally Posted by kier View Post
Sorry you guys for the pics above but photobucket is doing strange things, while I have a pro account???
Update !!!
Just a little tut regarding the tube sleeving. Maybe useful for some of you
Take a piece of precut tube
And some MDPC tube sleeve
Some wide heatshrink and tyraps
The tools
The heat shrink I marked 2cm long
I kept the sleeve 5mm on both sides of the tubes 5mm shorter (for the tyrap)
Heated the 2cm long heatshrink carefully with heatgun. Sleeve doesn't like heat, so keep distence with the heatgun
And shrinked
Tyrap around
That's it.............have a nice weekend!!!
This little tutorial is Worth sharing again, lots of people have been asking about the tubing
__________________
Old 31st Jul 2012, 15:14   #137
Waynio
Relaxing
Waynio's Avatar
Waynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming Saiyan
Extreme perfection yet again, kinda make it look easy Kier.
I should tune in to your logs more often for inspiration on neat & tidy, you totally have it mastered & the modding, it's subtle to really match the case your working, subtle but awesome & just looks like it was meant to be that way from the factory as a limited edition which it is after you've done with it.
Very nice manual engraving too mate.
stars & rep
__________________
Corsair AX860i - GA-Z97MX-Gaming 5 - i5-4690k - Noctua NH-D14 - 8GB DDR3 - GTX 980 Ti - Win 10
40" 4k Samsung TV - Corsair K70 - Corsair M65
Waynio is offline   Reply With Quote
Old 31st Jul 2012, 15:22   #138
kier
kier's Avatar
Thanks Bill and Waynio, your comments keeps me going
__________________
Old 31st Jul 2012, 15:43   #139
Attila
still thinking....
Attila's Avatar
Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.
Very nice guide Kier. Have some rep.
__________________
stillthinking
Attila is offline   Reply With Quote
Old 1st Aug 2012, 18:07   #140
Scrappy
Mod in progress!
Scrappy's Avatar
Scrappy can run CrysisScrappy can run CrysisScrappy can run CrysisScrappy can run CrysisScrappy can run CrysisScrappy can run CrysisScrappy can run CrysisScrappy can run CrysisScrappy can run CrysisScrappy can run CrysisScrappy can run Crysis
So far all of your mods i have seen are extremely nice! very well done on a once again very clean and tidy build.. i love that stealth look but then it all lights up blue and makes you think wow! it captures stealth and colour in one! Great build!
Scrappy is offline   Reply With Quote
Reply
Tags
600t case mod, water cool 600t
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
