Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 13th Aug 2011, 10:31   #1
Lizard
@ Scan R&D
Lizard's Avatar
Lizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run Crysis
Synology DiskStation DS211+ Review
With a large fan, 512MB of DDR3 memory and a 1.6GHz CPU, is the DS211+ a speed daemon?
http://www.bit-tech.net/hardware/sto...ds211-review/1
Lizard is offline   Reply With Quote
Old 13th Aug 2011, 11:49   #2
wuyanxu
still wants Homeworld 3
wuyanxu's Avatar
wuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyan
wow, that's simply amazing speed.
and here is a public demo of their amazing NAS interface.
http://www.synology.com/us/products/demo/index.php
same as any electronic product, i always believe an easy to use one is miles better than a harder to use product that requires a lot of your time.
__________________
i7 2700k \ 16GB \ GTX 970 \ D2x \ Z68x-UD5 \ m4 128GB +2TB \ S12G-550 \ FT02-RW \ G15+G5+G51 \ U2711
X100 \ X-E2 \ 10-24 \ 55-200 \ 18/2 \ 60/2.4 \ Yn560 \ X1.1a \ Hadley Pro -- Photostreamr
wuyanxu is offline   Reply With Quote
Old 13th Aug 2011, 12:00   #3
faugusztin
I *am* the guy with two left hands
faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.
@wuyanxu: Other side of the coin is the situation like what happened to my coworker - he bought himself a QNAP NAS for 4 drives, because he could install ipkg packages. He was happy, until he found out that there is no PHP 5.3 package in ipkg, compiling it for yourself is hard as hell,...
NAS is good, if all you need is already supported by the firmware. But if you want more, you are maybe looking at wrong device for the job.
faugusztin is online now   Reply With Quote
Old 13th Aug 2011, 12:17   #4
BrightCandle
Multimodder
BrightCandle has yet to learn the way of the Dremel
I can't be the only person not impressed with the speed of these devices, they must be CPU limited as the drives and network are capable of much more.
A low end 2 core Sandy bridge CPU running at minimum speed running with an array of 4 Disks in Raid 5 will max out a gigabit connection, transferring files at 115-130 MB/s in both directions. Small file transfers around 60MB/s.
These NAS products aren't even that much cheaper than getting an MITX board with 2GB of RAM and a low end CPU with an appropriate case. They are simple to setup and use but so is FreeNas.
BrightCandle is offline   Reply With Quote
Old 13th Aug 2011, 14:34   #5
MSHunter
Mod Master
MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.
They should only sell NAS boxes with a minium of 4 drive bays and raid 5 support, otherwise why bother?
__________________
Caved and bought a Gigabyte P35x V3 gaming laptop.
ex-PC: Silverstone TJ08B-E, 2500K, Corsair H80, 256 GB Samsung 830,GENE-Z , Corsair V. LP 16GB, Gigabyte 1.5GB GTX 580 Super Overclock. U2711
PC Audio: AKG 271 mk II + Samson Go mic. + Asus Xonar D2X
Amp: DENON PMA510AE, Speakers: TANNOY MERCURY F1
MSHunter is offline   Reply With Quote
Old 13th Aug 2011, 14:36   #6
tonyd223
king of nothing
tonyd223 has yet to learn the way of the Dremel
HP Proliant Microserver is only 120 so why would I buy this? Freenas is free... So I just can't see how you justify this product in this type of magazine...
tonyd223 is offline   Reply With Quote
Old 13th Aug 2011, 14:59   #7
faugusztin
Man, what are you drinking ? 115-130MB/s ? On a gigabit ethernet ? Through Samba ? You can call yourself lucky if you get 70-80MB/s with jumbo frames. Small files at 60MB/s through gigabit ethernet ?
Old 13th Aug 2011, 15:31   #8
Floyd
Wire Twister
Floyd's Avatar
Floyd has yet to learn the way of the Dremel
I have the DS211j and its never let me down!
With 2 1TB drives setup to mirror I dont have to worry about my data getting lost or deleted ever again.
Floyd is offline   Reply With Quote
Old 13th Aug 2011, 15:57   #9
thehippoz
Banned
thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!
yeah thing with nas.. you just build a linux box- can do anything and it's secure remote with a ras key + password
put as many drives as you want, ssh in, do whatever you need.. I never did get nas really- it's easy but limited
thehippoz is offline   Reply With Quote
Old 13th Aug 2011, 15:59   #10
faugusztin
For many the "limited" is good enough, and if you add a easy web based UI on top of it, they are sold .
/me looks at my i5-2500K+8GB+10 hard drive "NAS"
Old 13th Aug 2011, 16:32   #11
wuyanxu
wuyanxu's Avatar
it's like iphone vs android.
i prefer iphone. limited, everything works with minimal tweaking.
there's always people out there like me, want something that works out of the box. and this Synology model is certainly one of the best.
__________________
Old 13th Aug 2011, 16:49   #12
dyzophoria
Supermodder
dyzophoria has yet to learn the way of the Dremel
I don't know what is with all the people with their uber own built NAS devices, you are enthusiasts, you know what you are doing, aside from the usual overkill hardware just for a NAS device, If you know what you want how to get it, then I doubt you will even peak at consumer devices like these, this product is clearly for people who just wan't a small basic out of the box NAS device. why not 4-5 drives? they don't need it, why 2? the most common thing they will ever need, redundancy. that will take little to no thinkering just to get it working, keep in mind most of who will be using this might not even be saturating their gigabit connection all the time. or they might be even using wireless connections at most.
__________________
[FONT=Lucida Console]picture this..[/FONT] // [FONT=Tahoma][FONT=Fixedsys]picture that..[/FONT][/FONT]
dyzophoria is offline   Reply With Quote
Old 13th Aug 2011, 17:01   #13
faugusztin
@dyzophoria: this specific device maybe. But don't degrade NAS just to some home user category. I'm not sure you could put this device in that category for example :
http://www.synology.com/products/pro...611xs&lang=enu
And it is still a NAS.
For example my "NAS" is also a development webserver, database i run virtualization on it, XBMC, DVB-C TV capture, SqueezeBox, it is also a download station...
Old 13th Aug 2011, 18:06   #14
mrbens
Supermodder
mrbens's Avatar
mrbens has yet to learn the way of the Dremel
If you are going to spend this much on a storage solution then you'd be better off chucking a load of hard drives in an old PC and using unRAID. It uses one drive for redundency so it can rebuild any of the other drives if they die and you can add up to 20 data drives and they all look and act as one LARGE network drive on my main PC!
You can get a new case with 9 external drive bays for around 43 and then use 3 of these bay converters to house 12 drives all for total 82.50.
It also uses an easy web based UI like these NAS boxes but also can use multiple addons made by the community to add extra features.
Loving my unRAID server.
__________________
My SilverStone TJ07B PC: Haswell i5 4670K | MSI Z87-G45 Gaming mobo | 8GB Corsair Vengeance Pro Red 8GB DDR3 1600Mhz | MSI GTX 760 Twin Frozr 2GB | Seasonic X-Series 750W PSU | Crucial M4 128GB SSD | Crucial M225 128GB SSD | OCZ Solid 3 120GB SSD
Sound: Epiphany Acoustics' E-DAC & O2 Heahphone Amp | Little Dot MK III Tube Headphone Amp | Beyerdynamic DT880 Premium 600ohm Headphones (music) | Onkyo HT-S3305B AV Receiver + 5.1 speakers (movies)
mrbens is offline   Reply With Quote
Old 13th Aug 2011, 23:58   #15
megamale
Multimodder
megamale's Avatar
megamale is a Super Spamming Saiyanmegamale is a Super Spamming Saiyanmegamale is a Super Spamming Saiyanmegamale is a Super Spamming Saiyanmegamale is a Super Spamming Saiyanmegamale is a Super Spamming Saiyanmegamale is a Super Spamming Saiyanmegamale is a Super Spamming Saiyanmegamale is a Super Spamming Saiyanmegamale is a Super Spamming Saiyanmegamale is a Super Spamming Saiyan
Great product but it's twice the price of the DS211J... If you are a consumer and you want something that just works then the DS211J is great. But this one is getting too close to the price of a full blown pc, and it doesn't even include the disks. The performance is certainly improved but do the "consumer" cares? AFAIK the underlyong OS and the features are identical
__________________
Asus Maximus V Formula - 3770k@4.7 - 2x trifire XFX R9 290 - Corsair AX1200i - All under water in a Phanteks Enthoo Primo
HTPC: Z97i Plus - 4790K - XFX R9 290 in an Ncase M1
megamale is offline   Reply With Quote
Old 14th Aug 2011, 22:42   #16
TheButler
Minimodder
TheButler's Avatar
TheButler should be considered for presidentTheButler should be considered for presidentTheButler should be considered for presidentTheButler should be considered for presidentTheButler should be considered for presidentTheButler should be considered for presidentTheButler should be considered for presidentTheButler should be considered for presidentTheButler should be considered for presidentTheButler should be considered for presidentTheButler should be considered for president
I think some of you are missing the point of a NAS. They are a specialised ready-to-go product with very little setup needed and offers web server, iTunes, DLNA, etc. Yes I could have built a PC for cheaper, but it would have pulled at least 50W (My NAS pulls only 18 - 20W with drives), had all the usual bugs\setup problems that Windows or Linux would have had and would not be able to be put away on a shelf and be largely forgotten about.
I do not have the time to learn/configure Linux code (yes I do know the NAS is based on Linux) and find windows too unreliable. I have tried the latest Windows Home Server and no matter what Microsoft say, it is based on Server 2008 R2 and needs a decent dual-core processor and 4GB+ RAM. It is also clumsy to use. This rig pulled 80W - not good enough.
I have purchased a DS211 at £220, which looks like the DS211J but has double the RAM. This has the same 80MB/s read speed as the DS211+ and am very impressed.
TheButler is offline   Reply With Quote
Old 15th Aug 2011, 05:46   #17
|V| 4 L k i 3 R
Supermodder
|V| 4 L k i 3 R has yet to learn the way of the Dremel
I have an Infrant ReadyNAS and the reason I bought it instead of doing a pc build with unRaid or other software setup is the size. I end up having to move a lot and not always for long periods of time so I know I can pick it up, drop it into a handbag sized pelican case and walk off. If I had this in a PC form factor, I would need a keyboard and monitor available wherever I was going or bring it with me.
__________________
Gaming - MSI P67A-GD53 (B3) |i5-2500k 3.3Ghz | Thermaltake Frio| 3x2Gb OCZ 1600 | 2 x Gigabyte GTX580 3Gb | Crucial M4 64Gb | 2 x Barracuda 1Tb | LG Bluray Drive | NZXT Phantom | Antec HCP-750 | Win7 Home Pre | Logitech G500 Mouse/G15 Keyboard/G27 Wheel| Onkyo HT-RC160 w/ Z-5500 satelite speakers | 2 x Dell U2711 | Gateway XHD3000 |
Portable - 17" MacBook Pro | LaCie 500Gb Firewire 800
Other - Linksys E2000 | ReadyNAS RNV2-S2 | 4 x 2Tb Seagate Barracuda | iPhone 3Gs 32Gb | iPad 3g 32Gb
|V| 4 L k i 3 R is offline   Reply With Quote
Old 15th Aug 2011, 20:35   #18
P. K.
What's a Dremel?
P. K. has yet to learn the way of the Dremel
I bought the DS411slim a few days ago with 4 disks (SAMSUNG Spinpoint M8 HN-M101MBB 1TB) in a RAID 5.
I ran ATTO Disk Benchmark against a simple samba share and got up to 57MB/s write and 90MB/s read (transfer size: 512KB, Total length: 2GB). That's with normal frames, I didn't managed to get the jumbo frames working even though the configuration seemed quite simple for PC and DS.
Not bad for 2.5" disks and even faster than my desktop's old sata 2 disk. At least for reading.
@Antony Leather: You said that you took noise and hard drive temperature into consideration. I miss those in your article. I would really like to hear about your DSM's CPU temp after load.
My DS ended up with 74C CPU and ~40C for the HDs (except the one next to the CPU with 45C). I'm happy with the disks, but the CPU seems to be a bit hot.
Noise: The spin sound of the 2.5" disks is louder than the fan. So overall really quiet.
P. K. is offline   Reply With Quote
Old 16th Aug 2011, 10:47   #19
Combatus
Bit-tech Modding + hardware reviews
Moderator
Combatus's Avatar
Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.
Will fire it up when I can and post the results!
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 16th Aug 2011, 10:58   #20
sandys
Mod Master
sandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpit
You wouldn't need all that, My home built NAS is an Atom based ITX machine in a tiny case from the itx-store, its not seen a keyboard and mouse or a monitor since I installed it over a year ago, very cheap to build has low power consumption and you can remote access it from the web browser.
It works just the same as it runs headless, just pick it up move it somewhere and switch it on, job done.
Its no faster than this NAS above though really but was cheaper even when including a few terabytes of disc.
sandys is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
