Reply
Thread Tools View Mode
Old 15th Aug 2011, 12:42   #1
PoLo
PoLoMoD
PoLo has yet to learn the way of the Dremel
ATCS 840 by PoLoMoD -> The end ... 05/12
Sponsors : Big thanks for their support !!
for money
For a "Platimax 850w", 4 Apollish T.B. UCTA12N-R and 4 Apollish T.B. UCTA14N-R
For a reduction of about 70% of a big order >> here<<
Sorry for the translation because I'm french .
Here I am with a project on a CoolerMaster ATCS 840, still no precise ideas in the design of the case but it will contain a final configuration full watercooled .
This first page will be updated regularly with links to not having to read all pages (if worklog achieved several pages of course) .
The project must meet several conditions :
- Integrate in-house 3 radiators (a PHOBYA G-Changer 420 and 2 MAGICOOL Slim 240) .
- The configuration must be full Watercooled (CPU, GPU, MOSFET, RAM) .
- The case should remain as simple as possible .
La Config :
- EVGA P55-FTW
- INTEL i5 750
- CORSAIR Dominator 2x2Go PC12800
- MSI R5870 1Go
- XFX 5870 1Go (bios MSI)
- THERMALTAKE Toughpower 700W
- SSD CRUCIAL M4 64Go
- WESTERN DIGITAL Caviar black 640Go
- WESTERN DIGITAL Caviar green 640Go (x2)
Le Watercooling :
- PHOBYA G-Changer 420
- Laing DDC-1T
- Réservoir Alpacool
- EK-FC5870 CF Nickel-Acetal + Backplate Nickel
- Masterkleer 11/16 Dark Red
- Embouts EK, feser, phobya
- Enermax Apollish 12 & 14
- MagiCool SLIM DUAL 240
- Laing DDC-1T
- EK Suprem HF full Nickel
- EK RAM Dominator
- ANFI-TEC EVGA P55 FTW full cover
- ANFI-TEC 028 EVGA P55 + ANFI-TEC 029 EVGA P55
PoLo is offline   Reply With Quote
Old 15th Aug 2011, 12:42   #2
PoLo
PoLoMoD
Reserved ...
Old 15th Aug 2011, 12:48   #3
PoLo
PoLoMoD
Receipt of the PC case : (Cooler Master ATCS840 black)
Removing the case :
Some pictures of the actual hardware :
EK DCP 4.0 and combo DCP 4.0 140mm :
4x2Go G.Skill RipJaws and Arctic Cooling RC :
MSI R5870 and EK FC-5870 Nikel :
EVGA P55-FTW, ANFI-TEC P55-FTW Nikel and ALPHACOOL nexXxos X2 HF Nikel :
Group photos :
Old 15th Aug 2011, 18:12   #4
jrs77
theorycrafting
jrs77's Avatar
jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.
Ah nice. The ATCS 840 is still one of the best ATX-cases around.
Will you do any mods to the case itself or leave it stock and only do the hardware?
__________________
...and allways remember, that the world is an orange!
Cooltek/Jonsbo U1 | Silverstone SX500-LG | Noctua NF-R8 Redux 1200
Gigabyte H97N-WiFi | intel i7-5775C | Noctua NH-D9L | Crucial Ballistix 16GB DDR3L1600 | Crucial MX200 250GB | 2.5" WD AV 1TB
jrs77 is offline   Reply With Quote
Old 15th Aug 2011, 18:34   #5
PoLo
PoLoMoD
Yes, the ATCS840 is a very good case.
I will not only integrate the hardware, I'll create some changes.
Old 15th Aug 2011, 18:37   #6
Mosquito
Hypermodder
Mosquito's Avatar
Mosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for president
I'm anxious to see you get the triple 140 and the pair of dual 120 rads in there... looking good
Mosquito is offline   Reply With Quote
Old 15th Aug 2011, 19:44   #7
PoLo
PoLoMoD
I painted the cart on the motherboard :
Installed water blocks EK Supreme, Anfi-Tec EVGA 028 & 029 :
Modification of the water block ANFI-TEC P55 EVGA 200 lightcover (it is incompatible with the motherboard EVGA P55 conventional) :
I painted the water blocks Anfi-Tec EVGA 028, 029 & 200 lightcover :
fixing creation of the PHOBYA G-Changer 420 :
Old 15th Aug 2011, 20:11   #8
Stark.Jr
Multimodder
Stark.Jr's Avatar
Stark.Jr has yet to learn the way of the Dremel
Nice big start i will follow!
//S.Jr
__________________
Sorry for my bad english
Project [Mac G5]: ReBoot
Stark.Jr is offline   Reply With Quote
Old 15th Aug 2011, 20:14   #9
meandmymouth
I Mod, Therefore I Own
meandmymouth's Avatar
meandmymouth is a Super Spamming Saiyanmeandmymouth is a Super Spamming Saiyanmeandmymouth is a Super Spamming Saiyanmeandmymouth is a Super Spamming Saiyanmeandmymouth is a Super Spamming Saiyanmeandmymouth is a Super Spamming Saiyanmeandmymouth is a Super Spamming Saiyanmeandmymouth is a Super Spamming Saiyanmeandmymouth is a Super Spamming Saiyanmeandmymouth is a Super Spamming Saiyanmeandmymouth is a Super Spamming Saiyan
Looking good
__________________
Main - i7 3770K, Maximus V Gene, 32GB Crucial, 480 Sandisk Ultra II, 7TB HDD's, Fractal Arc Mini, CM 850W
meandmymouth is offline   Reply With Quote
Old 15th Aug 2011, 23:52   #10
Warsmith
Enginseer
Warsmith has yet to learn the way of the Dremel
Subbed!
Warsmith is offline   Reply With Quote
Old 16th Aug 2011, 00:00   #11
PoLo
PoLoMoD
Fixing the PHOBYA G-Changer 420 at the top :
Sleeving the 24 pins :
Remove the HDD cage and the cage change bay 5,25" :
Creation of fixing radiators (2 x 240) :
Cutting a window on the door
__________________
Sorry for my english ==> google translation
Old 16th Aug 2011, 00:06   #12
mars-bar-man
Side bewb.
mars-bar-man's Avatar
mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.
I like this, I like this a lot!
__________________
Bewbs.
mars-bar-man is offline   Reply With Quote
Old 16th Aug 2011, 10:07   #13
MilOk
Multimodder
MilOk's Avatar
MilOk has yet to learn the way of the Dremel
nice work =)
MilOk is offline   Reply With Quote
Old 17th Aug 2011, 07:45   #14
mav2000
In Training
mav2000 has yet to learn the way of the Dremel
Wow nice work...am working on an ATCS myself..
mav2000 is offline   Reply With Quote
Old 17th Aug 2011, 15:28   #15
Marcos_Viegas
Supermodder
Marcos_Viegas's Avatar
Marcos_Viegas has yet to learn the way of the Dremel
I love the cut of the window, is 800D style, realy awesome!
Congratulations! +rep
Marcos_Viegas is offline   Reply With Quote
Old 17th Aug 2011, 22:40   #16
PoLo
PoLoMoD
Originally Posted by MilOk View Post
nice work =)
Thanks
I saw your ATCS840 ... Good project!
Yes, I copied the window on the 800D.
I ordered some parts today:
- Pump Laing DDC-1T
- Plexi Bay Reservoir XSPC Dual Laing DDC pumps for 2
- Fittings compression 15.9 / 11.1
- Fittings EK @ 90 °
- The Feser Company wall passes
- Tubing Masterkleer 15.9 / 11.1 Dark Red
- Sleeve color MDPC-X-X
- Screw M3x6mm Black MDPC-X
- M3 Brainwasher MDPC-X
__________________
Old 17th Aug 2011, 23:16   #17
Marcos_Viegas
Supermodder
i used that style im my case too...
Old 18th Aug 2011, 10:44   #18
PoLo
PoLoMoD
Today I started the cladding in red, the change of screws, changing the red pipe, replacement of barbed ends by caps and reorganization of the tubing:
The HD5870 before :
The HD5870 after :
The 24pins wrapped :
Changing the motherboard screw :
I return to work ...
__________________
Old 18th Aug 2011, 17:15   #19
PoLo
PoLoMoD
Cladding on the motherboard almost finished
__________________
Old 18th Aug 2011, 19:36   #20
KiiYzOo
Multimodder
KiiYzOo has yet to learn the way of the Dremel
amazing
KiiYzOo is offline   Reply With Quote
Reply
Tags
atcs 480, watercooling
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
