Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 19th Aug 2011, 17:16   #1
Lizard
@ Scan R&D
Lizard's Avatar
Lizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run Crysis
Asus reveals Mars II dual-GeForce GTX 580 card
Asus has revealed its Mars II graphics card, based on two GTX 580s!
http://www.bit-tech.net/news/hardwar...orce-gtx-580/1
Lizard is offline   Reply With Quote
Old 19th Aug 2011, 17:18   #2
sp4nky
BF3: Aardfrith WoT: McGubbins
sp4nky's Avatar
sp4nky - may the hammer of Bindi be bestowed on yousp4nky - may the hammer of Bindi be bestowed on yousp4nky - may the hammer of Bindi be bestowed on yousp4nky - may the hammer of Bindi be bestowed on yousp4nky - may the hammer of Bindi be bestowed on yousp4nky - may the hammer of Bindi be bestowed on yousp4nky - may the hammer of Bindi be bestowed on yousp4nky - may the hammer of Bindi be bestowed on yousp4nky - may the hammer of Bindi be bestowed on yousp4nky - may the hammer of Bindi be bestowed on yousp4nky - may the hammer of Bindi be bestowed on you
I hope it's sturdily built because I don't fancy that hanging upside down from a PCI-E slot. Also, is it PCI-E 2 or 3?
__________________
World of Tanks
Player name: McGubbins
sp4nky is offline   Reply With Quote
Old 19th Aug 2011, 17:33   #3
Gigglebyte
:3
Gigglebyte's Avatar
Gigglebyte has yet to learn the way of the Dremel
The spec on scan.co.uk says that it is 2.0.
http://www.scan.co.uk/products/3gb-a...dl-dvi-dp-hdmi
Gigglebyte is offline   Reply With Quote
Old 19th Aug 2011, 17:35   #4
Killbz
I havent got a dremel
Killbz has yet to learn the way of the Dremel
Take it apart! take it apart!
Killbz is offline   Reply With Quote
Old 19th Aug 2011, 17:37   #5
mjm25
Supermodder
mjm25's Avatar
mjm25 has yet to learn the way of the Dremelmjm25 has yet to learn the way of the Dremelmjm25 has yet to learn the way of the Dremelmjm25 has yet to learn the way of the Dremelmjm25 has yet to learn the way of the Dremel
£1200 inc VAT! F*ck!
__________________
EP45-UD3R, QX6800, 8GB Ballistix 6400 4-4-4-12, Radeon 6990, All in an Arc!
mjm25 is offline   Reply With Quote
Old 19th Aug 2011, 17:37   #6
Killbz
They are already up for preorder on my local pc store.. for the princely sum of $1699
Old 19th Aug 2011, 17:37   #7
xMathiasD
<Title></Title>
xMathiasD's Avatar
xMathiasD is a hoopy frood who really knows where their towel is.xMathiasD is a hoopy frood who really knows where their towel is.xMathiasD is a hoopy frood who really knows where their towel is.xMathiasD is a hoopy frood who really knows where their towel is.xMathiasD is a hoopy frood who really knows where their towel is.xMathiasD is a hoopy frood who really knows where their towel is.xMathiasD is a hoopy frood who really knows where their towel is.xMathiasD is a hoopy frood who really knows where their towel is.xMathiasD is a hoopy frood who really knows where their towel is.xMathiasD is a hoopy frood who really knows where their towel is.xMathiasD is a hoopy frood who really knows where their towel is.
bindi! go get the hammer!
__________________
i rep - do you?
xMathiasD is offline   Reply With Quote
Old 19th Aug 2011, 17:41   #8
will_123
Small childs brain in a big body
will_123's Avatar
will_123 is the Cheesecake. Relix smiles down upon them.will_123 is the Cheesecake. Relix smiles down upon them.will_123 is the Cheesecake. Relix smiles down upon them.will_123 is the Cheesecake. Relix smiles down upon them.will_123 is the Cheesecake. Relix smiles down upon them.will_123 is the Cheesecake. Relix smiles down upon them.will_123 is the Cheesecake. Relix smiles down upon them.will_123 is the Cheesecake. Relix smiles down upon them.will_123 is the Cheesecake. Relix smiles down upon them.will_123 is the Cheesecake. Relix smiles down upon them.will_123 is the Cheesecake. Relix smiles down upon them.
£1000+ for the card...who pays that..?
__________________
Thinkpad T450s | Pure Pro MX Blue
will_123 is offline   Reply With Quote
Old 19th Aug 2011, 17:50   #9
mattbailey
Multimodder
mattbailey has yet to learn the way of the Dremel
Can it run Crysis?
mattbailey is offline   Reply With Quote
Old 19th Aug 2011, 17:55   #10
rollo
I Mod, Therefore I Own
rollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyan
no dout it can lol
rollo is offline   Reply With Quote
Old 19th Aug 2011, 17:55   #11
Madness_3d
Bit-Tech/Asus OC Winner
Madness_3d's Avatar
Madness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for president
Don't see why It'd need special drivers given it's just a 590 with higher clocks. Unless Asus have changed the Name the card presents to the drivers, which would mean surely you could just mod the .ini files to add MARS II in.
& @Bit-Tech guys, Please don't review this like it's a part of nvidia's lineup. It's SLI inside which you hate so I know you'll slate it for that, but this is the 911 GT3 to the GTX 590's 911. It's meant to have stripped out seats and stripped out features, or in this case, draw more power, produce more heat, run noisily, and require some enthusiast knowledge to get the most from. That's the point of it
Originally Posted by mattbailey View Post
Can it run Crysis?
I'm sure at sensible resolutions it'll oblitterate it much as SLI 580's does, You can bring every card to it's knees eventually if you keep upping the res, it'll either start to run out of resources or RAM
__________________
XFXScorpio911INTEL i7 3770k @ 4.5Ghz SLI GTX 480 1536MB ASUS MAXIMUS V FORMULA16GB CORSAIR DDR3 1600 9-9-9-24 1TCORSAIR HYDRO H50CORSAIR Force 3 120GB WINDOWS 7 HP 64bitMusings On The Technical WorldSteam
Madness_3d is offline   Reply With Quote
Old 19th Aug 2011, 17:59   #12
Skiddywinks
Hypermodder
Skiddywinks has yet to learn the way of the DremelSkiddywinks has yet to learn the way of the Dremel
I think it's in reference to the fact the last Mars sucked balls most of the time, simply because you can't just throw together two cards and expect it to work.
Skiddywinks is offline   Reply With Quote
Old 19th Aug 2011, 18:00   #13
TwiZtah
What's a Dremel?
TwiZtah has yet to learn the way of the Dremel
This ain't no news, the Swedish site Sweclockers.com has already reviewed these, in SLI!
TwiZtah is offline   Reply With Quote
Old 19th Aug 2011, 18:18   #14
GiantKiwi
Banned
GiantKiwi is definitely a rep cheat.GiantKiwi is definitely a rep cheat.GiantKiwi is definitely a rep cheat.GiantKiwi is definitely a rep cheat.GiantKiwi is definitely a rep cheat.GiantKiwi is definitely a rep cheat.GiantKiwi is definitely a rep cheat.GiantKiwi is definitely a rep cheat.GiantKiwi is definitely a rep cheat.GiantKiwi is definitely a rep cheat.GiantKiwi is definitely a rep cheat.
Any normal user who takes one of these over say a 580 sli setup, deserves a hard slap.
GiantKiwi is offline   Reply With Quote
Old 19th Aug 2011, 18:20   #15
M7ck
Ⓜod Ⓜaster
M7ck's Avatar
M7ck is a hoopy frood who really knows where their towel is.M7ck is a hoopy frood who really knows where their towel is.M7ck is a hoopy frood who really knows where their towel is.M7ck is a hoopy frood who really knows where their towel is.M7ck is a hoopy frood who really knows where their towel is.M7ck is a hoopy frood who really knows where their towel is.M7ck is a hoopy frood who really knows where their towel is.M7ck is a hoopy frood who really knows where their towel is.M7ck is a hoopy frood who really knows where their towel is.M7ck is a hoopy frood who really knows where their towel is.M7ck is a hoopy frood who really knows where their towel is.
Why?
__________________
M7ck is offline   Reply With Quote
Old 19th Aug 2011, 18:23   #16
Mraedis
Multimodder
Mraedis has yet to learn the way of the Dremel
Originally Posted by M7ck View Post
Why?
Driver issues, it's bound to happen, and it's bound to be abandoned after a while whereas older reference cards usually receive minor updates still.
__________________
Mraedis is offline   Reply With Quote
Old 19th Aug 2011, 18:37   #17
Paulg1971
Multimodder
Paulg1971's Avatar
Paulg1971 has yet to learn the way of the Dremel
trouble is i can't read swedish so its news to me
Paulg1971 is offline   Reply With Quote
Old 19th Aug 2011, 19:00   #18
TwiZtah
What's a Dremel?
Yeah, my point was, why are they so late with these news when a SWEDISH site already reviewed them?
Old 19th Aug 2011, 19:13   #19
M7ck
Ⓜod Ⓜaster
M7ck's Avatar
As they are a limited edition cards I guess it is up to Asus as to whom they send review cards.
__________________
Old 19th Aug 2011, 19:16   #20
Ayrto
Supermodder
Ayrto should be considered for presidentAyrto should be considered for presidentAyrto should be considered for presidentAyrto should be considered for presidentAyrto should be considered for presidentAyrto should be considered for presidentAyrto should be considered for presidentAyrto should be considered for presidentAyrto should be considered for presidentAyrto should be considered for presidentAyrto should be considered for president
So why would someone buy this over (say) Sli'ed 580s- 3GB version ones, that can be watercooled and have guaranteed driver support, unlike this non reference outing?
Ayrto is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
